+Larry Posted January 23, 2015 Share Posted January 23, 2015 I have a couple of DCM files that appear to be non-standard. They both fail decompression when I try to convert them back to disks or ATR's. They are both around 60 - 70 KB. Any thoughts about what might be amiss or a possible line of attack? Were the earlier versions of Disk Communicator compatible with 3.2 (which is the "standard" DCM, I believe. What is on the DCM's is not so important -- now it is about the challenge of solving this puzzle! -Larry Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted January 23, 2015 Share Posted January 23, 2015 (edited) Some of the Megazine DCMs have some difficulty converting to atr. Have you tried the conversion Option of AtariWin800 Plus 4.1 also an older DCM2ATR programs only work with Window XP 32bit and earlier .... Also try mounting the DCM as drive one with ALTIRRA [EMU] and saving as ATR. Edited January 23, 2015 by rdea6 1 Quote Link to comment Share on other sites More sharing options...
evilmoo Posted January 23, 2015 Share Posted January 23, 2015 If you post links to them, I'll try to figure out what's going on with them. Quote Link to comment Share on other sites More sharing options...
+Larry Posted January 23, 2015 Author Share Posted January 23, 2015 Thanks, but Altirra works. It mounts them without complaining, and as Roy suggested, I could SAVE the disks as ATR images. The DCM images are now gone! I should have remembered about emulators being (generally) less picky about images. Thanks, Roy! -Larry Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted January 24, 2015 Share Posted January 24, 2015 Good to know! Quote Link to comment Share on other sites More sharing options...
