Byte Knight Posted March 4, 2020 Author Share Posted March 4, 2020 3 hours ago, ghsqb said: BK are you still offering this service? Any changes to the original post (is it still a Pie B, etc)? I'm still doing the upgrades - requests continue to trickle in as these Flashbacks approach the end of their lifespans... The only difference from the original post is that I use Pi 3's now and also use a custom controller board. Quote Link to comment Share on other sites More sharing options...
ColecoJoe Posted March 4, 2020 Share Posted March 4, 2020 5 minutes ago, Byte Knight said: I'm still doing the upgrades - requests continue to trickle in as these Flashbacks approach the end of their lifespans... The only difference from the original post is that I use Pi 3's now and also use a custom controller board. Are there any performance enhancements or are you using 3’s because they are readily available? Quote Link to comment Share on other sites More sharing options...
Byte Knight Posted March 4, 2020 Author Share Posted March 4, 2020 3 minutes ago, ColecoJoe said: Are there any performance enhancements or are you using 3’s because they are readily available? Boot time is much quicker, but that's about it. 1 Quote Link to comment Share on other sites More sharing options...
Inzi Posted March 9, 2020 Share Posted March 9, 2020 Do you still sell complete builds? I could get a flashback off eBay or something and send... but would be interested in getting one directly as you’d know know if everything works. Quote Link to comment Share on other sites More sharing options...
+fdr4prez Posted March 9, 2020 Share Posted March 9, 2020 (edited) 34 minutes ago, Inzi said: Do you still sell complete builds? I could get a flashback off eBay or something and send... but would be interested in getting one directly as you’d know know if everything works. If you get one from eBay, the only thing that needs to work are the two controllers. But hard to test the controllers if the console itself is not working. The case is gutted, so no need to confirm if the console itself is working or not. Even the power supply is replaced. The controllers are fairly robust, so if they look to be in decent shape then odds are that they are ok Edited March 9, 2020 by fdr4prez Quote Link to comment Share on other sites More sharing options...
donjn Posted July 18, 2020 Share Posted July 18, 2020 Do you do upgrades that include a composite output and audio as well? I would love to run this on my Commodore monitor. Trouble is your menu system is all widescreen. Quote Link to comment Share on other sites More sharing options...
+fdr4prez Posted July 18, 2020 Share Posted July 18, 2020 The Pi3B units have a 3.5mm port that is used for composite and audio output: Quote Link to comment Share on other sites More sharing options...
+intvsteve Posted July 18, 2020 Share Posted July 18, 2020 40 minutes ago, fdr4prez said: The Pi3B units have a 3.5mm port that is used for composite and audio output: It works great, too! In fact, you an order an old Zune cable - they work perfectly. 1 Quote Link to comment Share on other sites More sharing options...
Knievel Posted August 5, 2020 Share Posted August 5, 2020 Hi I posted in you thread about the boards but not sure if you'll see it there and I was unable to send you a message. Anyway I would like to purchase a pre-modded Intellivision Flashback if possible. Interested in the kit including the board otherwise. Thanks Brad Quote Link to comment Share on other sites More sharing options...
Byte Knight Posted August 5, 2020 Author Share Posted August 5, 2020 40 minutes ago, Knievel said: Hi I posted in you thread about the boards but not sure if you'll see it there and I was unable to send you a message. Anyway I would like to purchase a pre-modded Intellivision Flashback if possible. Interested in the kit including the board otherwise. Thanks Brad PM sent. Quote Link to comment Share on other sites More sharing options...
donjn Posted August 5, 2020 Share Posted August 5, 2020 Was hoping someone could answer my previous question and I have one more. 1. If I purchase this, and want to use it on my Commodore monitor through composite, wont the edges be cut off as the nice interface is built for widescreen? 2. Can I easily remove and add roms? Thanks! Quote Link to comment Share on other sites More sharing options...
+fdr4prez Posted August 5, 2020 Share Posted August 5, 2020 47 minutes ago, donjn said: Was hoping someone could answer my previous question and I have one more. 1. If I purchase this, and want to use it on my Commodore monitor through composite, wont the edges be cut off as the nice interface is built for widescreen? 2. Can I easily remove and add roms? Thanks! Your question about composite was answered: And confirmed: About the possibility of the edges getting cut off, there is a RetroPie Forum that you can ask in there, but you can open the proper configuration file on the Pi itself and you can set the desired resolution for the system, and there are overscan settings that you can adjust for the Pi to get the output correct for your monitor/tv. For adding ROMs, you can do it using a USB stick or over wifi (or wired network connection) using Samba shares or WinSCP to remote into the Pi and you can add the roms into the needed folder. Some of this is detailed in the manual provided by ByteKnight. for deleting roms you would need to do this over a network connection using Samba shares or WinSCP to remote into the Pi and you can delete the desired roms. Quote Link to comment Share on other sites More sharing options...
donjn Posted August 5, 2020 Share Posted August 5, 2020 I didn't ask again IF I could use composite, I know it was answered earlier. if you read what I wrote, i asked about edges being cut off. Thanks for your reply! Quote Link to comment Share on other sites More sharing options...
donjn Posted August 5, 2020 Share Posted August 5, 2020 Yeah, If I am gonna spend $150 I want this to be setup for me beforehand and tested. Meaning output to composite working and not stretched. Quote Link to comment Share on other sites More sharing options...
ColecoJoe Posted August 5, 2020 Share Posted August 5, 2020 48 minutes ago, donjn said: Yeah, If I am gonna spend $150 I want this to be setup for me beforehand and tested. Meaning output to composite working and not stretched. You can set the aspect ratio to 4:3 in the config. The menu will still look a little wonky on the Commodore monitor but I got it to a usable state a while back when I was using it through that monitor you will just need to tweak it a bit until you're happy with it. The games always fit perfectly on the screen though. 1 Quote Link to comment Share on other sites More sharing options...
+fdr4prez Posted August 5, 2020 Share Posted August 5, 2020 1 hour ago, donjn said: Yeah, If I am gonna spend $150 I want this to be setup for me beforehand and tested. Meaning output to composite working and not stretched. You can contact Byte Knight and see if he is willing to do that for you, but you'd have to send him your monitor. I carry my Pi with me often when I travel and I've connected it to many HDMI tvs, and some tvs have a black border (on top and bottom only), and some tvs have all 4 edges slightly cut off, and some TVs are displayed just fine. Why this happens? I don't know. So even for HDMI tvs, there isn't a consistency for how things are displayed. Some tvs in the hotels are 720p and some are 1080p, etc, and tons of other reasons. This is the function of the overscan setting in the Pi's configuration file, so after you set the resolution for the Pi you can then further finetune the edges as needed for your particular display. I do not do this for my Pi because there is no telling what TV model I will be connecting it to, so I live with a little RetroPie inconsistency. Once you have the RetroPie setup and looking good on your monitor, then you can adjust the setting for the Intellivision emulator, too, as shown in the manual provided by ByteKnight: The emulator can be set to just about whatever resolution you want, so you can really dial it in for your particular monitor. 1 Quote Link to comment Share on other sites More sharing options...
donjn Posted August 5, 2020 Share Posted August 5, 2020 Thanks for your help. At this point I don't think its worth the $150 though. The point of it is to play them via HDMI. The JZINTV emulator is working great for me, along with my Vision-Daptor and real Intellivision controllers. I also have all of the overlays. And with the Intellivison clunky controllers if there is input lag, I sure as heck don't notice it in the JZINTV. This is why I was thinking of doing this, the reaction times on a CRT are unbeatable. But even with a RetroPie on a CRT vs the JZINTV on my computer I doubt I would notice that much of a difference. Plus technically I would be spending $150 for basically a handful of games that are already on the Intellivision Flashback. I mainly use the emulator for games that aren't on there like Tron games, etc. Quote Link to comment Share on other sites More sharing options...
mr_me Posted August 5, 2020 Share Posted August 5, 2020 7 hours ago, donjn said: Was hoping someone could answer my previous question and I have one more. 1. If I purchase this, and want to use it on my Commodore monitor through composite, wont the edges be cut off as the nice interface is built for widescreen? 2. Can I easily remove and add roms? Thanks! A crt does cut off a small amount on all sides including top and bottom due to overscan but yeah if a widescreen image is cut down to fit, you could have a significant amount of the sides lost. Or the wide picture could be squeezed into the narrow aspect ratio without cutting off the sides. Either way, Retropie has a couple of themes for CRT and 4:3 aspect ratios that should address it. For a hundred and fifty dollars you're also getting a raspberry pi and a usb adapter for two intellivision controllers. 1 Quote Link to comment Share on other sites More sharing options...
Byte Knight Posted August 6, 2020 Author Share Posted August 6, 2020 23 hours ago, donjn said: Was hoping someone could answer my previous question and I have one more. 1. If I purchase this, and want to use it on my Commodore monitor through composite, wont the edges be cut off as the nice interface is built for widescreen? 2. Can I easily remove and add roms The games themselves will look fine in 4:3, but the game selection screen will not look very good as it is designed for widescreen. Adding roms is easy via a USB thumb drive or wifi. Quote Link to comment Share on other sites More sharing options...
Old Timey Retro Gamer Posted August 30, 2020 Share Posted August 30, 2020 You just recently upgraded mine. I can't thank you enough! It has given me a chance to play Intellivision games that I know I will never find!!! I loved the Flashback before, but it is even better after the upgrade! Thanks again Byte Knight! 1 Quote Link to comment Share on other sites More sharing options...
stdjxf15 Posted September 16, 2020 Share Posted September 16, 2020 I’m late on this Byte Knight but want one as well. PM sent. Quote Link to comment Share on other sites More sharing options...
rj_esq Posted February 9, 2021 Share Posted February 9, 2021 I have an Intellivision Flashback in which the power light goes on, but no longer displays on the TV. Can this set be upgraded? If so, I would like to get the upgrade service. Is Byte Knight still doing these? Quote Link to comment Share on other sites More sharing options...
+fdr4prez Posted February 9, 2021 Share Posted February 9, 2021 4 hours ago, rj_esq said: I have an Intellivision Flashback in which the power light goes on, but no longer displays on the TV. Can this set be upgraded? If so, I would like to get the upgrade service. Is Byte Knight still doing these? Yes, it can be upgraded. The upgrading process will remove the internal guts of your old Flashback unit. @Byte Knight will need to response about his availability to do more upgrades Quote Link to comment Share on other sites More sharing options...
Byte Knight Posted February 10, 2021 Author Share Posted February 10, 2021 10 hours ago, rj_esq said: I have an Intellivision Flashback in which the power light goes on, but no longer displays on the TV. Can this set be upgraded? If so, I would like to get the upgrade service. Is Byte Knight still doing these? Still doing them - PM sent. 2 Quote Link to comment Share on other sites More sharing options...
keith@keithconnell.ca Posted February 19, 2021 Share Posted February 19, 2021 I am interested in a complete system for Intellivision simply sent to me as a plug and play. Do you offer this type of service? Quote Link to comment Share on other sites More sharing options...
