tebe Posted February 19 Author Share Posted February 19 fixed, https://github.com/tebe6502/Mad-Pascal Quote Link to comment Share on other sites More sharing options...
roeoender Posted February 20 Share Posted February 20 Great, thanks for quick fix! This unearthed another thing that seems to be semicolon handling bug, that took me long to replicate and identify the cause. In attached code crucial part is in wpn.pas - legal no semicolon after CRT_Readkey prevents working of "targetHpPtr^ := 0;" (but only when assignment is to 0). if (targetHpPtr^ > g_baseIdx) then begin targetHpPtr^ := targetHpPtr^ - g_baseIdx; CRT_Write(' RESULT:'~); CRT_Write(targetHpPtr^); CRT_NewLine; CRT_Readkey // no semicilon here is legal but causes generation of incorrect code! only affects assignment of 0, other values would work correctly // adding semicolon generates correct code end else begin targetHpPtr^ := 0; // doesn't assign! CRT_Write(' EXPECTED 0:'~); CRT_Write(targetHpPtr^); CRT_NewLine; end; Change can be seen in generated assembly code (in 2 places) Bad code: ; optimize FAIL ('B_CRT.CRT_READKEY', WPN), line = 21 jsr B_CRT.CRT_READKEY inx mva B_CRT.CRT_READKEY.RESULT :STACKORIGIN,x dex jmp l_0257 l_0239 ; optimize OK (WPN), line = 24 mwy TARGETHPPTR :bp2 ldy #$00 sta (:bp2),y Wrong output: INI HP:5 DMG:1 RESULT:4 INI HP:4 DMG:1 RESULT:3 INI HP:3 DMG:1 RESULT:2 INI HP:2 DMG:1 RESULT:1 INI HP:1 DMG:1 EXPECTED 0:1 INI HP:1 DMG:1 EXPECTED 0:1 After adding semicolon I got correct result: INI HP:5 DMG:1 RESULT:4 INI HP:4 DMG:1 RESULT:3 INI HP:3 DMG:1 RESULT:2 INI HP:2 DMG:1 RESULT:1 INI HP:1 DMG:1 EXPECTED 0:0 INI HP:0 DMG:1 EXPECTED 0:0 And correct asm: ; optimize FAIL ('B_CRT.CRT_READKEY', WPN), line = 21 jsr B_CRT.CRT_READKEY jmp l_0257 l_0239 ; optimize OK (WPN), line = 24 mwy TARGETHPPTR :bp2 ldy #$00 tya sta (:bp2),y pascal_semicolon.zip Quote Link to comment Share on other sites More sharing options...
tebe Posted February 20 Author Share Posted February 20 3 hours ago, roeoender said: This unearthed another thing that seems to be semicolon handling bug, that took me long to replicate and identify the cause. fixed Quote Link to comment Share on other sites More sharing options...
roeoender Posted February 21 Share Posted February 21 8 hours ago, tebe said: fixed Thank you! Now works correctly also in my main project. Now on my main project I stumbled on a "gotcha" that could be prevented with a warning, in attached program file dd.pas defines: const COLOR_GREEN = 2; const GREY = 1; Which run.pas tries to simply print: writeln('COLOR_GREEN ', COLOR_GREEN); writeln('GREY ', GREY); And the result is quite unexpected: COLOR_GREEN 196 GREY 8 The base reason is that system.pas and ctr.pas define such generic-named constants and they take precedence (MP documentation warns about order of uses so it is somewhat OK). This is easy to identify in such simple program, but in my main project MP didn't give me any warning and amazingly program worked differently on an earlied MP version - few weeks before - it seems that in mad pascal updates since around 2024-02-01 something changed in resolving priority of such redefinitions, this change may be perfectly OK and justified, but it would be a lot better if redefinition to a constant would be logged as a warning. Also would be better if constants with simple names had some name prefix to prevent such clashes - seems that Bocianu's blibs to some extent follow such convention examples: 'PMG_gractl_missiles' in b_pmg.pas, 'CRT_screenWidth' in b_crt.pas I understand that there may be no easy/backwards compatible solution to this. pascal_redef.zip Quote Link to comment Share on other sites More sharing options...
tebe Posted February 21 Author Share Posted February 21 (edited) 25 minutes ago, roeoender said: Now on my main project I stumbled on a "gotcha" that could be prevented with a warning, USES has recently been improved so that it works as in FPC uses def_1, def_2; def_2 is primary uses def_2, def_1; def_1 is primary https://wiki.freepascal.org/Uses Quote However, two or more units listed in the uses clause might declare the same identifier. Then, only the identifier declared by the unit later in the list can be referred to using the short notation. Identifiers declared by earlier units in the uses clause can only be accessed via fully-qualified identifiers. uses dd,crt; begin writeln('COLOR_GREEN ', dd.COLOR_GREEN); writeln('GREY ', dd.GREY); readkey; end. Edited February 21 by tebe 1 Quote Link to comment Share on other sites More sharing options...
roeoender Posted February 21 Share Posted February 21 50 minutes ago, tebe said: USES has recently been improved so that it works as in FPC uses def_1, def_2; def_2 is primary uses def_2, def_1; def_1 is primary https://wiki.freepascal.org/Uses uses dd,crt; begin writeln('COLOR_GREEN ', dd.COLOR_GREEN); writeln('GREY ', dd.GREY); readkey; end. Thank you for explaination. Prefixing with unit name is a good solution. Hope this info will be helpful to others. Your MP and MADS are great tools! 1 Quote Link to comment Share on other sites More sharing options...
neuling Posted February 22 Share Posted February 22 Hi good afternoon. I play with the madpascal and the plus4 (Yape) What does the memory control/memory structure look like? I would like to start the program at $8000 so that I can use the storage underneath myself. how can I do that please? Thanks. Quote Link to comment Share on other sites More sharing options...
tebe Posted February 22 Author Share Posted February 22 6 hours ago, neuling said: I would like to start the program at $8000 so that I can use the storage underneath myself. mp.exe file.pas -t c4p -code:8000 mads file.a65 -xi:<MadsPath>\base Quote Link to comment Share on other sites More sharing options...
neuling Posted February 22 Share Posted February 22 mp.exe hello.pas -t c4p -code:8000 Hello thanks for the information. But I can't find the start address in hello.a65: 8000? Thanks. ---------------------------------- ; ------------------------------------------------------------ ; Mad Pascal Compiler version 1.7.1 [2024/02/19] for 6502 ; ------------------------------------------------------------ STACKWIDTH = 16 TRUE = 1 FALSE = 0 ; ------------------------------------------------------------ org $02 zpage .if .def(@AllocMem)||.def(MAIN.SYSTEM.GETMEM)||.def(MAIN.SYSTEM.FREEMEM) psptr .ds 2 ; PROGRAMSTACK Pointer .fi bp .ds 2 bp2 .ds 2 eax .ds 4 ;8 bytes (aex + edx) -> divREAL edx .ds 4 ecx .ds 4 TMP ztmp ztmp8 .ds 1 ztmp9 .ds 1 ztmp10 .ds 1 ztmp11 .ds 1 STACKORIGIN .ds STACKWIDTH*4 zpend ; ------------------------------------------------------------ ax = eax al = eax ah = eax+1 cx = ecx cl = ecx ch = ecx+1 dx = edx dl = edx dh = edx+1 org eax FP1MAN0 .ds 1 FP1MAN1 .ds 1 FP1MAN2 .ds 1 FP1MAN3 .ds 1 org ztmp8 FP1SGN .ds 1 FP1EXP .ds 1 org edx FP2MAN0 .ds 1 FP2MAN1 .ds 1 FP2MAN2 .ds 1 FP2MAN3 .ds 1 org ztmp10 FP2SGN .ds 1 FP2EXP .ds 1 org ecx FPMAN0 .ds 1 FPMAN1 .ds 1 FPMAN2 .ds 1 FPMAN3 .ds 1 org bp2 FPSGN .ds 1 FPEXP .ds 1 ; ------------------------------------------------------------ opt h-f+ org $1001 org [a($1001)],$1001 basic_start(START) org $100E CODEORIGIN STATICDATA ; ------------------------------------------------------------ RTLIB icl 'rtl6502_c4p.asm' .print 'ZPAGE: ',zpage,'..',zpend-1 .print 'RTBUF: ',@buf,'..',@buf+255 .print 'RTLIB: ',RTLIB,'..',*-1 ; ------------------------------------------------------------ START tsx stx MAIN.@halt+1 VLEN = VARDATASIZE-VARINITSIZE VADR = DATAORIGIN+VARINITSIZE ift (VLEN > 0) && (VLEN <= 256) ldx #256-VLEN lda #$00 sta:rne VADR+VLEN-256,x+ eli VLEN>256 m@init eif .ifdef psptr mwa #PROGRAMSTACK psptr .fi lda #$0e jsr $ffd2 ; shifted charset ldx #$00 stx bp ; BP = 0 dex ; X = 255 UNITINITIALIZATION .local MAIN ; PROCEDURE jmp l_0012 ; ------------------------------------------------------------ .local SYSTEM ; UNIT ; ------------------------------------------------------------ M_PI_2 = $0648 D_PI_2 = $0192 D_PI_180 = $04 FMOPENREAD = $04 FMOPENWRITE = $08 FMOPENAPPEND = $09 FMOPENREADWRITE = $0C SCREENWIDTH = DATAORIGIN+$0000 SCREENHEIGHT = DATAORIGIN+$0002 DATESEPARATOR = DATAORIGIN+$0004 FILEMODE = DATAORIGIN+$0005 GRAPHMODE = DATAORIGIN+$0006 IORESULT = DATAORIGIN+$0007 EOLN = DATAORIGIN+$0008 RNDSEED = DATAORIGIN+$0009 .endl ; UNIT SYSTEM ; ------------------------------------------------------------ .local CRT ; UNIT ; ------------------------------------------------------------ BW40 = $00 CO40 = $01 BW80 = $02 CO80 = $03 MONO = $07 C40 = $01 C80 = $03 BLACK = $00 WHITE = $01 RED = $02 CYAN = $03 PURPLE = $04 GREEN = $05 BLUE = $06 YELLOW = $07 ORANGE = $08 BROWN = $09 YELLOW_GREEN = $0A PINK = $0B BLUE_GREEN = $0C LIGHT_BLUE = $0D DARK_BLUE = $0E LIGHT_GREEN = $0F BLINK = $80 .endl ; UNIT CRT l_0012 ; optimize FAIL ('@print', hello.pas), line = 5 @printSTRING #CODEORIGIN+$0000 @printEOL @exit @halt ldx #$00 txs rts ; ------------------------------------------------------------ ; ------------------------------------------------------------ .local @DEFINES C4P .endl .local @RESOURCE .endl .endl ; MAIN ; ------------------------------------------------------------ ; ------------------------------------------------------------ .macro UNITINITIALIZATION .ifdef MAIN.SYSTEM.@UnitInit jsr MAIN.SYSTEM.@UnitInit .fi .ifdef MAIN.CRT.@UnitInit jsr MAIN.CRT.@UnitInit .fi .endm ; ------------------------------------------------------------ ift .SIZEOF(MAIN.SYSTEM) > 0 .print 'SYSTEM: ',MAIN.SYSTEM,'..',MAIN.SYSTEM+.SIZEOF(MAIN.SYSTEM)-1 eif ift .SIZEOF(MAIN.CRT) > 0 .print 'CRT: ',MAIN.CRT,'..',MAIN.CRT+.SIZEOF(MAIN.CRT)-1 eif .nowarn .print 'CODE: ',CODEORIGIN,'..',MAIN.@RESOURCE-1 ; ------------------------------------------------------------ ?adr = * ift (?adr < ?old_adr) && (?old_adr - ?adr < $120) ?adr = ?old_adr eif org ?adr ?old_adr = * DATAORIGIN .by $28 $00 $18 $00 $2D $0C VARINITSIZE = *-DATAORIGIN VARDATASIZE = 11 PROGRAMSTACK = DATAORIGIN+VARDATASIZE .print 'DATA: ',DATAORIGIN,'..',PROGRAMSTACK ; ------------------------------------------------------------ .macro STATICDATA .by $0D $48 $65 $6C $6C $6F $20 $57 $6F $72 $6C $64 $20 $21 .endm end ------------------------------------------------------- Quote Link to comment Share on other sites More sharing options...
zbyti Posted February 22 Share Posted February 22 (edited) @neuling first of all I admire your MP tests but if I were you I choose RAW target for Commodore machines for $8000 Edited February 22 by zbyti Quote Link to comment Share on other sites More sharing options...
zbyti Posted February 22 Share Posted February 22 @neuling and I'm really think you are @funkheld 1 Quote Link to comment Share on other sites More sharing options...
Gury Posted February 23 Share Posted February 23 It came to my mind also 😃 I suggest to neuling to open new topic for questions about Mad Pascal on its own. 1 Quote Link to comment Share on other sites More sharing options...
neuling Posted February 29 Share Posted February 29 I lost the password at Funkheld when I was 75 years old. greeting Quote Link to comment Share on other sites More sharing options...
Gury Posted February 29 Share Posted February 29 Great to see you switched to Mad Pascal👍 Quote Link to comment Share on other sites More sharing options...
neuling Posted February 29 Share Posted February 29 (edited) Hi, Thank You. At 75 years old, I can no longer remember things that are more than 2 weeks old, that's why I ask so many questions. I have another problem with starting a program life.pas for the X16 under Windows 11. This is my request in the madpascal folder: mp.exe -t x16 c:\madpascal\samples\x16\CRT\life.pas but there is a message saying that it was entered incorrectly. Thanks. greeting Edited February 29 by neuling Quote Link to comment Share on other sites More sharing options...
tebe Posted February 29 Author Share Posted February 29 2 hours ago, neuling said: with starting a program life.pas for the X16 MadRafi tries to add target x16, currently such a target does not exist. target: a8, c64, c4p, neo, raw Quote Link to comment Share on other sites More sharing options...
neuling Posted February 29 Share Posted February 29 this is in the madpascal. https://github.com/MADRAFi/Mad-Pascal/tree/x16 greeting Quote Link to comment Share on other sites More sharing options...
MADRAFi Posted February 29 Share Posted February 29 (edited) this is my fork. It is unfinished and probably never will be. in order to use new target you need to compile mp.pas to mp.exe. Those in the repo are old ones and are not recompiled. fpc -MDelphi -vh -O3 mp.pas Edited February 29 by MADRAFi Quote Link to comment Share on other sites More sharing options...
neuling Posted February 29 Share Posted February 29 Hello, thanks for the help. will recompile it. Your work for the x16 is wonderful. please continue. Thanks. greeting Quote Link to comment Share on other sites More sharing options...
amarok Posted March 4 Share Posted March 4 @tebe, I am not sure, but I think I've just found a problem with memory alignment for variables with fixed address (set by absolute) which are types of records containing arrays. Please see the following source code: program Test; const SIZE = 3; type TStructure = record array_of_bytes: array[0..SIZE - 1] of Byte; array_of_words: array[0..SIZE - 1] of Word; byte_field: Byte; end; var auto: TStructure; fixed: TStructure absolute $4000; begin end. There are two variables of the same type - auto, which address is automatically set by compiler and fixed with address set by hand. When I look on lst file I can see that alignemnt for members of auto variable is proper but for fixed not. Please see the following excerpt from lst file. 262 = 205F adr.AUTO = DATAORIGIN+$000B ; [10] RECORD 263 2032 .var AUTO = adr.AUTO .word 264 = 205F adr.AUTO.ARRAY_OF_BYTES = [DATAORIGIN+$000B] .array [3] 265 2032 .var AUTO.ARRAY_OF_BYTES = adr.AUTO.ARRAY_OF_BYTES .word 266 = 2062 adr.AUTO.ARRAY_OF_WORDS = [DATAORIGIN+$000E] .array [3] .word 267 2032 .var AUTO.ARRAY_OF_WORDS = adr.AUTO.ARRAY_OF_WORDS .word 268 = 2068 AUTO.BYTE_FIELD = DATAORIGIN+$0014 269 = 4000 adr.FIXED = $4000 270 2032 .var FIXED = adr.FIXED .word 271 = 4000 adr.FIXED.ARRAY_OF_BYTES = $4000 272 2032 .var FIXED.ARRAY_OF_BYTES = adr.FIXED.ARRAY_OF_BYTES .word 273 = 4002 adr.FIXED.ARRAY_OF_WORDS = $4002 274 2032 .var FIXED.ARRAY_OF_WORDS = adr.FIXED.ARRAY_OF_WORDS .word 275 = 4004 FIXED.BYTE_FIELD = $4004 You can see that the local offsets of members are proper in case of auto variable: - array_of_bytes: 0=$205F-$205F - array_of_words: 3=$2062-$205F - byte_field: 9=$2068-$205F But local offsets of members are invalid for fixed variable: - array_of_bytes: 0=$4000-$4000 - array_of_words: 2=$4002-$4000 - byte_field: 4=$4004-$4000 I am using the latest version of MadPascal and MadAssembler taken from github. Have you ever found the problem? I really need to use records with fixed addresses for cartridge version of Time Wizard. Could you please fix it? Thank you in advance for your help. Quote Link to comment Share on other sites More sharing options...
tebe Posted March 4 Author Share Posted March 4 17 hours ago, amarok said: I am not sure, but I think I've just found a problem with memory alignment for variables with fixed address fixed 1 1 Quote Link to comment Share on other sites More sharing options...
amarok Posted March 4 Share Posted March 4 Many thanks, @tebe. You are really fast. I've checked the latest version and it works perfectly. 1 Quote Link to comment Share on other sites More sharing options...
tebe Posted April 4 Author Share Posted April 4 unit PP (Power Packer decompressor) example https://github.com/tebe6502/Mad-Pascal/tree/master/samples/a8/compression/pp PowerPacker (gcc main.c) https://github.com/lab313ru/powerpacker_src 3 Quote Link to comment Share on other sites More sharing options...
Alfred Posted April 5 Share Posted April 5 Just trying to build the sieve.pas example. MP compiles it fine, but mads has issues: What file has the missing definitions ? Quote Link to comment Share on other sites More sharing options...
tebe Posted April 5 Author Share Posted April 5 1 hour ago, Alfred said: but mads has issues: mads.exe filename.a65 -x -i:<MadPascalPath>\base switch -x is important 1 Quote Link to comment Share on other sites More sharing options...
