+Larry Posted December 9, 2015 Share Posted December 9, 2015 (Anyone...) What are the part numbers (CO) of the PAL 7-bit and 8-bit Antics? 7-bit: CO12296x (?) 8-bit CO21698 (?) Pretty sure that the latter number is valid for most XL and all XE. -Larry Quote Link to comment Share on other sites More sharing options...
GoodByteXL Posted December 9, 2015 Share Posted December 9, 2015 (Anyone...) What are the part numbers (CO) of the PAL 7-bit and 8-bit Antics? 7-bit: CO12296x (?) 8-bit CO21698 (?) Pretty sure that the latter number is valid for most XL and all XE. -Larry PAL (I guess also for SECAM) 7 bit: C014887 8 bit: C021698 NTSC 7 bit: C012296 8 bit: C021697 Quote Link to comment Share on other sites More sharing options...
bugbiter Posted December 9, 2015 Author Share Posted December 9, 2015 Mine here is a CO14887-03 Quote Link to comment Share on other sites More sharing options...
ClausB Posted December 10, 2015 Share Posted December 10, 2015 Bugbiter, you must add a wire between C and ANTIC, and also change jumper JP3 to -. Quote Link to comment Share on other sites More sharing options...
bugbiter Posted December 12, 2015 Author Share Posted December 12, 2015 (edited) My Lightsaber animation, developed for 130XE uses only 4 additional 16K banks. So I did a quick test using all 16 banks showing in Gr.8 mode and it's working... Seems I really don't need line C. Too bad, I was already looking forward to doing some more soldering.. :-) In what way do you expect malfunctions without line c? Edited December 12, 2015 by bugbiter Quote Link to comment Share on other sites More sharing options...
ClausB Posted December 13, 2015 Share Posted December 13, 2015 One would expect random memory corruption in some programs that use custom display lists, causing freezing up or perhaps saving bad data to disk. We have an expression in the US: "Just do it!" Auf Deutsch heist das vielleicht, "Einfach so machen!" 1 Quote Link to comment Share on other sites More sharing options...
GoodByteXL Posted December 13, 2015 Share Posted December 13, 2015 It's mandatory to use the c line with your ANTIC C014887. I built in some Rambos around 1990 and can confirm that issue. BTW, that's a 0 (zero) in C0 after the C, not an O. 1 Quote Link to comment Share on other sites More sharing options...
bugbiter Posted December 13, 2015 Author Share Posted December 13, 2015 OK, I got your drift.. :-) I'll post some pics when finished! I also did a nice job bulging out the shield to make room for the Rambo board, if I might say so .. Quote Link to comment Share on other sites More sharing options...
ClausB Posted January 26, 2016 Share Posted January 26, 2016 Have you done the fix yet? Quote Link to comment Share on other sites More sharing options...
Guest Posted January 26, 2016 Share Posted January 26, 2016 (edited) @brenski- 32-in-1 OS with the Rambo makes a very nice machine, doesn't it. Do you use a PBI hard drive and if so does it have any stability problems (from the 32-in-1 and/or Rambo)? I've got a couple similar setup XL's, and on at least one I had to do the Bob Puff "Stable XL" fixes. -Larry update to previous post i've now managed to "pickup" 3x different 32-in-1 boards from ebay.fr - all of them very cheap é15-é20 each all 3 work properly - first time using original (flashjazzcat) wiring/soldering - straight out of the box all i did was slot the board into the socket mobo and plug in the connector so it looks as if Steve managed to send me two faulty boards/and/or GALs Edited January 26, 2016 by Guest Quote Link to comment Share on other sites More sharing options...
bugbiter Posted January 27, 2016 Author Share Posted January 27, 2016 Have you done the fix yet? Sorry, not yet... more important things on my mind just now... Quote Link to comment Share on other sites More sharing options...
bugbiter Posted August 16, 2016 Author Share Posted August 16, 2016 I still haven't fixed the missing line (all working well still) But here are some pictures of my shielding bulge job. A steel chisel, a hammer and aluminium tape... :-) 2 Quote Link to comment Share on other sites More sharing options...
