HOME AUTOMATION Posted March 13, 2020 Share Posted March 13, 2020 I bought mine from arcadeshopper. I have been quite pleased with it! There are a few different compilations around, all work well... official... FinalGROM99.zip 2 Quote Link to comment Share on other sites More sharing options...
AtariNostalgia Posted March 13, 2020 Share Posted March 13, 2020 Thanks! Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted March 13, 2020 Share Posted March 13, 2020 1 hour ago, AtariNostalgia said: Hi all. I'd like to buy a Grom cartridge but I'm very confused as to which is the final version and where to buy a pre assembled on from. Can I download games (for example) and have them run from it directly instead of inserting my solid states one by one? did you read the FAQ? if not.. I'll summorize.. you can get the finalgrom99 at arcadeshopper.com.. the flashrom99 was discontinued when the finalgrom99 was released. Quote Link to comment Share on other sites More sharing options...
AtariNostalgia Posted March 13, 2020 Share Posted March 13, 2020 3 minutes ago, arcadeshopper said: did you read the FAQ? if not.. I'll summorize.. you can get the finalgrom99 at arcadeshopper.com.. the flashrom99 was discontinued when the finalgrom99 was released. I hadn't read it because I saw a youtube video about the uber99 and 1 before it. By the time I got here I realized that there were a plethora of different versions, but I should have read the FAQ. 2 Quote Link to comment Share on other sites More sharing options...
ngtwolf Posted August 10, 2020 Share Posted August 10, 2020 Question for anyone who has anyone made one of these themselves? I had a pcb from a few years time back that I had started to build out but got sidetracked on other projects (plus I already own a flashrom99 anyway). I thought I would revisit building this board, and I had all the parts except the Cypress SRAM (CY62158ELL-45ZSXI) which is apparently hard to find and seems outrageously expensive for what it is. Anyone know if theres an alternative sram that would work? Quote Link to comment Share on other sites More sharing options...
+helocast Posted August 10, 2020 Share Posted August 10, 2020 (edited) A little slower, 55ns vs 45ns and wider voltage supply range. Other than that it is also in the 44-pin TSOP II package. $6.92 AS6C8008-55ZIN https://www.mouser.com/datasheet/2/12/AS6C8008-1288432.pdf I haven't checked compatibility any closer than that. Doug Edited August 12, 2020 by helocast Found possible variant Quote Link to comment Share on other sites More sharing options...
ralphb Posted August 12, 2020 Author Share Posted August 12, 2020 (edited) Basically any SRAM IC from this page should work: https://www.digikey.com/products/en/integrated-circuits-ics/memory/774?k=sram&k=&pkeyword=sram&sv=0&pv276=127091&pv276=130284&pv276=202821&pv276=171276&sf=1&FV=-8|774%2C69|409393%2C142|227886%2C961|407300%2C1291|220518%2C1291|220519%2C1989|0%2C2043|383917&quantity=&ColumnSort=0&page=1&pageSize=25 Note that some parts are listed multiple times in different minimum quantities, and some are not in stock. EDIT: To be safe, download the datasheet before you buy and check that the pins match the original (attached). cy62158ev30ll.pdf Edited August 12, 2020 by ralphb 2 Quote Link to comment Share on other sites More sharing options...
GDMike Posted August 12, 2020 Share Posted August 12, 2020 Thx ralph Quote Link to comment Share on other sites More sharing options...
globeron Posted August 12, 2020 Share Posted August 12, 2020 On 8/17/2019 at 8:50 PM, kl99 said: Nice that you keep improving the FinalGrom. Really! I am wondering if you want to return to try getting the FinalGrom working for the 99/4Q, v2.2, 99/8? and the TI-99/4 ? (the TI-99/4 keyboard only accepts Uppercase, but once in the menu cannot select any option, was just trying it out for fun to see if Bounce 'N Pounce game would work). Quote Link to comment Share on other sites More sharing options...
ralphb Posted August 12, 2020 Author Share Posted August 12, 2020 1 hour ago, globeron said: and the TI-99/4 ? (the TI-99/4 keyboard only accepts Uppercase, but once in the menu cannot select any option, was just trying it out for fun to see if Bounce 'N Pounce game would work). IIRC the TI 99/4 uses an entirely different menu system, as shown by early carts like Video Chess. That cart basically draws its own menu (similar to what we see on the 4A), so the entry analyzer of the FG99 gets confused. (I patched the image for the FinalGROM99.zip.) On the other hand, I assume that later cartridges (Parsec) also work on the 4? Anyway, it's hard to work on something I don't own, so if you want to make a donation, I'll see what I can do! ? Quote Link to comment Share on other sites More sharing options...
jrhodes Posted August 12, 2020 Share Posted August 12, 2020 A version of finalgrom99 for QI units would be neat. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted August 12, 2020 Share Posted August 12, 2020 23 minutes ago, jrhodes said: A version of finalgrom99 for QI units would be neat. +1. I understand Ralph was trying to figure out the issue, but I have not kept up with whether that has been sussed out or not. 2 Quote Link to comment Share on other sites More sharing options...
jrhodes Posted August 12, 2020 Share Posted August 12, 2020 (edited) 1 hour ago, OLD CS1 said: +1. I understand Ralph was trying to figure out the issue, but I have not kept up with whether that has been sussed out or not. I understand the v2.2 qi TI's can still boot sidecar games like miner 2049er, so make a sidecar version of the finalgrom99, with a passthrough for memory Tipi etc to connect to. Edited August 12, 2020 by jrhodes Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted August 12, 2020 Share Posted August 12, 2020 I understand the v2.2 qi TI's can still boot sidecar games like miner 2049er, so make a sidecar version of the finalgrom99, with a passthrough for memory Tipi etc to connect to. He's in the middle of this project. It does a lot more tooSent from my LM-V600 using Tapatalk Quote Link to comment Share on other sites More sharing options...
jrhodes Posted August 12, 2020 Share Posted August 12, 2020 14 minutes ago, arcadeshopper said: He's in the middle of this project. It does a lot more too Sent from my LM-V600 using Tapatalk What project? I guess the more i think about what i posted, the more it sounds like the SDD99 project... 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted August 12, 2020 Share Posted August 12, 2020 7 hours ago, jrhodes said: I understand the v2.2 qi TI's can still boot sidecar games like miner 2049er, so make a sidecar version of the finalgrom99, with a passthrough for memory Tipi etc to connect to. The cartridge port address space does not appear at the expansion port. Ah, I see... a FG for side-port carts, not a FG to bypass QI problems at the cart port. Quote Link to comment Share on other sites More sharing options...
Casey Posted August 12, 2020 Share Posted August 12, 2020 4 hours ago, ralphb said: On the other hand, I assume that later cartridges (Parsec) also work on the 4? Anyway, it's hard to work on something I don't own, so if you want to make a donation, I'll see what I can do! ? Back when I had a 99/4 and a sizable cart collection, the only carts I had that wouldn’t show up on the 99/4’s menu were the ROM only Atarisoft carts. Parsec would show up but didn’t work because of the bitmap mode it requires that the 99/4 doesn’t have. Selecting Parsec from the menu simply cleared the screen and then returned to the color bar screen. 4 Quote Link to comment Share on other sites More sharing options...
ralphb Posted August 13, 2020 Author Share Posted August 13, 2020 16 hours ago, jrhodes said: I understand the v2.2 qi TI's can still boot sidecar games like miner 2049er, so make a sidecar version of the finalgrom99, with a passthrough for memory Tipi etc to connect to. QI and v2.2 are actually two different things: You can have QI with version 1.x and v2.2 without QI. The FinalGROM works with v2.2, as its menu is GROM. But the QI architecture did change something that prevents the FG99 from functioning. A quick look with a logic analyzer didn't reveal any differences, though. I must admit that this project is rather low priority, although I do have a QI machine. When I have more free time (i.e., next year), I can pick up the analysis of this case again. 2 Quote Link to comment Share on other sites More sharing options...
ralphb Posted August 13, 2020 Author Share Posted August 13, 2020 16 hours ago, jrhodes said: I understand the v2.2 qi TI's can still boot sidecar games like miner 2049er, so make a sidecar version of the finalgrom99, with a passthrough for memory Tipi etc to connect to. Yes, see I haven't tried the sidecar on a QI console yet, though. I should really do this! 1 1 Quote Link to comment Share on other sites More sharing options...
ralphb Posted August 13, 2020 Author Share Posted August 13, 2020 15 hours ago, Casey said: Back when I had a 99/4 and a sizable cart collection, the only carts I had that wouldn’t show up on the 99/4’s menu were the ROM only Atarisoft carts. Parsec would show up but didn’t work because of the bitmap mode it requires that the 99/4 doesn’t have. Selecting Parsec from the menu simply cleared the screen and then returned to the color bar screen. OK, then Parsec was actually a bad example. I meant regular GROM and/or ROM carts made for the 4A. We now know they work on 4s as well, which kind of invalidates my theory (but Video Chess is weird). Guess I have to buy one after all. 2 Quote Link to comment Share on other sites More sharing options...
+helocast Posted August 14, 2020 Share Posted August 14, 2020 13 hours ago, ralphb said: QI and v2.2 are actually two different things: You can have QI with version 1.x and v2.2 without QI. The FinalGROM works with v2.2, as its menu is GROM. But the QI architecture did change something that prevents the FG99 from functioning. I must admit that this project is rather low priority, although I do have a QI machine. When I have more free time (i.e., next year), I can pick up the analysis of this case again. Considering I only run/own V1 QI, I'm still wondering what to do with my FG purchased early in 2018? Can we get credit/trade-in against a future SDD99 sale if that will finally support the QI? Doug Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted August 14, 2020 Share Posted August 14, 2020 2 hours ago, helocast said: Considering I only run/own V1 QI, I'm still wondering what to do with my FG purchased early in 2018? Can we get credit/trade-in against a future SDD99 sale if that will finally support the QI? Doug I have been considering getting a second one. You wanna make a deal? 1 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted August 14, 2020 Share Posted August 14, 2020 3 hours ago, helocast said: Considering I only run/own V1 QI, I'm still wondering what to do with my FG purchased early in 2018? Can we get credit/trade-in against a future SDD99 sale if that will finally support the QI? Doug Have you tried loading the SD card with multiple files or only a single file? The FinalGROM 99 handles these tasks somewhat differently. 1 Quote Link to comment Share on other sites More sharing options...
ralphb Posted August 14, 2020 Author Share Posted August 14, 2020 (edited) 10 hours ago, helocast said: Considering I only run/own V1 QI, I'm still wondering what to do with my FG purchased early in 2018? Can we get credit/trade-in against a future SDD99 sale if that will finally support the QI? Yes, we can do that, or sell your FG99 to OLD CS1. Or if you want, you can return it to me now for a refund. Edited August 14, 2020 by ralphb 2 Quote Link to comment Share on other sites More sharing options...
ralphb Posted August 14, 2020 Author Share Posted August 14, 2020 6 hours ago, HOME AUTOMATION said: Have you tried loading the SD card with multiple files or only a single file? The FinalGROM 99 handles these tasks somewhat differently. No, that's not it. QI consoles just do not work for the FinalGROM. Nobody knows why. 1 1 Quote Link to comment Share on other sites More sharing options...
