Lavalamp Posted March 25, 2018 Share Posted March 25, 2018 Finally got the 1088XEL assembled but it turns out my 5V Adapter from Digikey was DOA, I'll source one locally, does the 1088XEL require 2A? I cant seem locate a match. I tried a 5v 1A I have, but I get no power on LED, just flickering LED son the USB/SIO board. :/ Thanks in advance. Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted March 25, 2018 Share Posted March 25, 2018 Finally got the 1088XEL assembled but it turns out my 5V Adapter from Digikey was DOA, I'll source one locally, does the 1088XEL require 2A? I cant seem locate a match. I tried a 5v 1A I have, but I get no power on LED, just flickering LED son the USB/SIO board. :/ Thanks in advance. Be very careful, 5v DC power supplies other than the one specified have shown to get some odd results. Quote Link to comment Share on other sites More sharing options...
Lavalamp Posted March 25, 2018 Share Posted March 25, 2018 Be very careful, 5v DC power supplies other than the one specified have shown to get some odd results. I understand a 2A USB Power Adapter will work? Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted March 25, 2018 Share Posted March 25, 2018 I understand a 2A USB Power Adapter will work? It probably will. I am just saying that even power supplies that are of the same specifications as the one in the BOM have shown to be a little odd in its results. quite a few were tried. Quote Link to comment Share on other sites More sharing options...
+mytek Posted March 25, 2018 Share Posted March 25, 2018 I understand a 2A USB Power Adapter will work? No most USB adapters are really more of a charger, than meant to act as a standalone PSU, meaning that they depend upon the battery to smooth things out. What MacRorie is referring to was associated with the early beta version of the 1088XEL where there were problems with some standalone PSUs, but that got remedied by improving the DC filtering on board, so most any 2 Amp or greater supply with a center positive and the correct size plug should work fine now. Quote Link to comment Share on other sites More sharing options...
Lavalamp Posted March 26, 2018 Share Posted March 26, 2018 (edited) No most USB adapters are really more of a charger, than meant to act as a standalone PSU, meaning that they depend upon the battery to smooth things out. What MacRorie is referring to was associated with the early beta version of the 1088XEL where there were problems with some standalone PSUs, but that got remedied by improving the DC filtering on board, so most any 2 Amp or greater supply with a center positive and the correct size plug should work fine now. Thanks I have identified a local power adapter https://www.jaycar.co.nz/27w-3-12vdc-switchmode-plugpack-with-usb-outlet/p/MP3316 Edited March 26, 2018 by Lavalamp Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted March 26, 2018 Share Posted March 26, 2018 Okay, I have a perplexing problem with the sound output: I have key click sounds coming out on both channels, so the buffer amps are working. I don't have the sound from Pokey appearing on the same outputs. I do have sound from Pokey on each pin #1 of RN3 and RN4. All 3 resistors in RN3 and RN4 read 100k... Any thoughts? Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted March 27, 2018 Share Posted March 27, 2018 Okay, I have a perplexing problem with the sound output: I have key click sounds coming out on both channels, so the buffer amps are working. I don't have the sound from Pokey appearing on the same outputs. I do have sound from Pokey on each pin #1 of RN3 and RN4. All 3 resistors in RN3 and RN4 read 100k... Any thoughts? Something to do with the Stereo settings in the BIOS? Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted March 27, 2018 Share Posted March 27, 2018 I have Stereo Pokey Disabled and Pokey-2 IRQ Disabled so that only Sound from the Left Pokeyis used. Quote Link to comment Share on other sites More sharing options...
+mytek Posted March 27, 2018 Share Posted March 27, 2018 Okay, I have a perplexing problem with the sound output: I have key click sounds coming out on both channels, so the buffer amps are working. I don't have the sound from Pokey appearing on the same outputs. I do have sound from Pokey on each pin #1 of RN3 and RN4. All 3 resistors in RN3 and RN4 read 100k... Any thoughts? So with key clicks being heard, as you said that confirms that the buffer amps are indeed working. And if you have Pokey sound on pin #1 of the resistor networks, but nothing coming out of the buffer amps, then it's beginning to sound like you have the wrong type of networks (bussed instead of isolated). Not much else could be wrong unless a pin or two of the resistor networks isn't soldered, or bridged to ground. Bottom line is that we know the design as is works, and has been proven so by many people now. So it's got to be either wrong part or a soldering issue. Just out of curiosity, if you put this into stereo mode and play a stereo Pokey tune, do you hear anything? If not then it's really leaning towards the wrong type of resistor networks being used. 1088XEL Schematic (look at page 4) Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted March 27, 2018 Share Posted March 27, 2018 Both RN3 and RN4 have the ( 3 ) 100k resistors as shown on the schematic and have been ohmed out to verify. Also checked for shorts. Quote Link to comment Share on other sites More sharing options...
+mytek Posted March 27, 2018 Share Posted March 27, 2018 Both RN3 and RN4 have the ( 3 ) 100k resistors as shown on the schematic and have been ohmed out to verify. Also checked for shorts. Hmm... well that certainly makes for a mystery. Not much else springs to mind, but obviously something isn't correct in your build that is at the root of the problem. I just don't know what that would be at this point. I wish I could be of more help, but remote troubleshooting is difficult at best. Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted March 27, 2018 Share Posted March 27, 2018 Yep, it's perplexing Could you tell me what voltages you have on Pins 1, 2, 3 and 6 on either RN3 or RN4 ? Quote Link to comment Share on other sites More sharing options...
+mytek Posted March 27, 2018 Share Posted March 27, 2018 Yep, it's perplexing Could you tell me what voltages you have on Pins 1, 2, 3 and 6 on either RN3 or RN4 ? I dob't have access to a 1088XEL at the moment, but I'll check that tomorrow and post the information (assuming no one else beats me to it). Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 27, 2018 Share Posted March 27, 2018 Yep, it's perplexing Could you tell me what voltages you have on Pins 1, 2, 3 and 6 on either RN3 or RN4 ? c. 0.67V on pins 1, 2, and 3, and 3.3V on pin 6 (both networks). 2 Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted March 27, 2018 Share Posted March 27, 2018 c. 0.67V on pins 1, 2, and 3, and 3.3V on pin 6 (both networks). Thanks Jon Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted March 29, 2018 Share Posted March 29, 2018 Made some progress with my sound problem, First I had a bad Right Pokey and the Second problem appears that Q4 has a bad B-E junction where 0.6 volts is always seen on Q4's Base and Pin #2 on U9 (Pulled U9 to verify ). So in Mono Mode, that 0.6 volts passes through to Pin #15, thus disabling Q3 and no Sound from the Right channel. Tomorrow I swap out Q4 and with a bit-o-luck, it will work as it should 1 Quote Link to comment Share on other sites More sharing options...
Lavalamp Posted March 30, 2018 Share Posted March 30, 2018 It turned out my DIGIKEY 5v/2amp was working fine, but I get no 5v LED, what would I check next? Quote Link to comment Share on other sites More sharing options...
+mytek Posted March 30, 2018 Share Posted March 30, 2018 It turned out my DIGIKEY 5v/2amp was working fine, but I get no 5v LED, what would I check next? The LED might be backwards. If you check the power bus with a volt meter do you see 5 VDC when you press the power switch? This can be checked on one of the 14 pin HCT series chips (pin 7 = GND, pin 14 = 5 VDC). You also need to have the 555 timer installed to be able to switch on the power. Also check out this link: http://atariage.com/forums/topic/272817-1088xel-atari-itx-motherboard-diy-builders-thread/page-11?do=findComment&comment=3938060 2 Quote Link to comment Share on other sites More sharing options...
Lavalamp Posted April 2, 2018 Share Posted April 2, 2018 The LED might be backwards. If you check the power bus with a volt meter do you see 5 VDC when you press the power switch? This can be checked on one of the 14 pin HCT series chips (pin 7 = GND, pin 14 = 5 VDC). You also need to have the 555 timer installed to be able to switch on the power. Also check out this link: http://atariage.com/forums/topic/272817-1088xel-atari-itx-motherboard-diy-builders-thread/page-11?do=findComment&comment=3938060 Hang on, so the square pads for LEDs are negative,but elsewhere on the board its positive? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 2, 2018 Share Posted April 2, 2018 Square pads often signify pin 1. This does not necessarily imply polarity. 1 Quote Link to comment Share on other sites More sharing options...
+mytek Posted April 2, 2018 Share Posted April 2, 2018 Hang on, so the square pads for LEDs are negative,but elsewhere on the board its positive? It is unfortunate that the square pad which is being used to represent positive for the electrolytic capacitors , turns out to be the negative lead instead for the LEDs. But the square pad usage is correct, since it denotes the cathode connection of the LED, and is also the same usage for the 1N914 diodes on the board as well. However most people would usually not know the difference and instead follow the board's silk screen which does correctly and quite clearly show the proper orientation of the LED. Always best to go by the silkscreen representation when assembling PCBs. So if you look around the net, you'll see that square pad usage is most often used for the cathode on diodes and LEDs, + on a capacitor, and to designate pin one on a connector, header, or a SIP resistor network. I have followed this convention. Sorry if that caused any confusion. Reference Edit: BTW any place else that an LED connection is depicted to a header, the pin 1 marking of the header takes precedence, and in no way confers polarity. 2 Quote Link to comment Share on other sites More sharing options...
Lavalamp Posted April 2, 2018 Share Posted April 2, 2018 It is unfortunate that the square pad which is being used to represent positive for the electrolytic capacitors , turns out to be the negative lead instead for the LEDs. But the square pad usage is correct, since it denotes the cathode connection of the LED, and is also the same usage for the 1N914 diodes on the board as well. However most people would usually not know the difference and instead follow the board's silk screen which does correctly and quite clearly show the proper orientation of the LED. Always best to go by the silkscreen representation when assembling PCBs. So if you look around the net, you'll see that square pad usage is always for the cathode on diodes and LEDs, + on a capacitor, and to designate pin one on a connector, header, or a SIP resistor network. I have followed this convention. Sorry if that caused any confusion. Reference Edit: BTW any place else that an LED connection is depicted to a header, the pin 1 marking of the header takes precedence, and in no way confers polarity. Thanks for that! Every day is a school day! 2 Quote Link to comment Share on other sites More sharing options...
+mytek Posted April 3, 2018 Share Posted April 3, 2018 Thanks for that! Every day is a school day! I made a small correction in my last post from 'always' to "...most often used for...", since I'm sure there will be some people doing it differently. Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted April 3, 2018 Share Posted April 3, 2018 Not to berate Lavalamp, but as a note/warning/reminder to folks who later begin a build, it’s probably worth telling everyone who starts to at least scan through the (many!) pages of the entire thread - at this point, 4+ months since people began building, there’s a good shot someone has already had the same assembly issue or made a mistake they might avoid. E.g., I installed my power LED’s backwards waaaaay back in January (and many pages earlier!) and all this was covered there. I hate for Michael to feel like he has to repeat these lessons every time one of us has made a mistake. 1 Quote Link to comment Share on other sites More sharing options...
