_The Doctor__ Posted December 9, 2018 Share Posted December 9, 2018 the ones I mentioned go super low and you use them on the two chips not his board though, you can use the pins and a low profile socket to get the two chips low and the add on board low as well all together... Quote Link to comment Share on other sites More sharing options...
Faicuai Posted December 9, 2018 Share Posted December 9, 2018 (edited) I didnt like how the pixels Sophi outputs are square. On NTSC the pixels are not square so the images from the DVI output of Sophia dont match what the analog output looks like. Absolutely correct! NTSC true aspect ratio is 11:12 at the scan lines´s "dot". That´s why you draw a mathematically perfect circle in NTSC Gr.8, it will show as a vertically-oriented oval. It needs compensation for the final output´s aspect ratio. I have been holding off Sophia, precisely for this, as the solution lies on my digital processors... I just don´t want to throw my DVDO VP50pro at it, just to fix the input-to-screen aspect ratio... I need to do it with my iScan HD/+ which are the ones I use for the Ataris, but the available DVI input is a pass-through one, and I am not sure if built-in aspect ratio correction will work... 1:1 is WRONG for NTSC. End of the story. Edited December 9, 2018 by Faicuai Quote Link to comment Share on other sites More sharing options...
jowi Posted December 9, 2018 Share Posted December 9, 2018 the ones I mentioned go super low and you use them on the two chips not his board though, you can use the pins and a low profile socket to get the two chips low and the add on board low as well all together... The sophia board on a 600xl is just 1 or 2mm too wide and too tall to clear u24 and u8, so you can’t go lower even if you change to lower sockets... and even if the board was a bit smaller, going lower would make sophia touch the components underneath the sophia board. I think my solution is the best you can get on a 600. Just remove the sockets for u24/u8. Maybe there are revisions of the 600xl board where the chips are arranged differently so sophia might fit as is. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted December 11, 2018 Share Posted December 11, 2018 I was talking specific to used the lowest profile pins on u24 and u8 so long as it work for you is all that matters Quote Link to comment Share on other sites More sharing options...
jowi Posted December 11, 2018 Share Posted December 11, 2018 (edited) I was talking specific to used the lowest profile pins on u24 and u8 Ah ok Still, if you look at my pictures you can see that even with u8 soldered to the board, sophia just clears it... adding a socket, even a extreme low profile one, will be too high in this case. Edited December 11, 2018 by jowi Quote Link to comment Share on other sites More sharing options...
+mytek Posted December 11, 2018 Share Posted December 11, 2018 Same problem on 1088XEL, although at least in that case there is ample headroom to add another socket under Sophia, which Simius is kind enough to provide . Quote Link to comment Share on other sites More sharing options...
+adamchevy Posted December 11, 2018 Share Posted December 11, 2018 (edited) I have a new 19” 5:4 NEC display running at 1280x1024. My 800 is modded with the 5:4 resolution Sophia Rev C. I verified that it is running at 1280x1024. Here are a few pictures with different games. I still get bars on the top and bottom. Edited December 11, 2018 by adamchevy 2 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted December 12, 2018 Share Posted December 12, 2018 where is the border around basic and memo pad?? something is amiss Quote Link to comment Share on other sites More sharing options...
Simius Posted December 12, 2018 Author Share Posted December 12, 2018 When the Sophia DVI board generate 1280x1024 screen (which correspond to the 320x256 Atari image), you will always have a top and bottom bars, because ANTIC can display only 240 scan lines. The remaining 4*(256-240)=64 lines are drawing during a vertical blanking time. This is where the black bars come from. 1 Quote Link to comment Share on other sites More sharing options...
jowi Posted December 12, 2018 Share Posted December 12, 2018 (edited) That is why i wanted 1280x960 960/4 = 240 and 1280x960 is a 4:3 aspect ratio. Edited December 12, 2018 by jowi Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted December 12, 2018 Share Posted December 12, 2018 His picture show no border on the left and right of the memo pad or basic screens, the borders are used in a number of situations, and of course flashing, status and the like... 1 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted December 12, 2018 Share Posted December 12, 2018 His picture show no border on the left and right of the memo pad or basic screens, the borders are used in a number of situations, and of course flashing, status and the like... Right - there's always a visible left/right border even when in 48 byte per line mode. Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted December 12, 2018 Share Posted December 12, 2018 I wonder if the monitor is auto zooming the input, that monitor by default has an auto h.size adjust Quote Link to comment Share on other sites More sharing options...
jowi Posted December 14, 2018 Share Posted December 14, 2018 Is it possible some of the colors are wrong with the board? I always thought pacman was yellow, but he looks orange? Quote Link to comment Share on other sites More sharing options...
Simius Posted December 15, 2018 Author Share Posted December 15, 2018 I don't think so. Pacman is yellow in the NTSC system. In the PAL system Pacman is salmon. Quote Link to comment Share on other sites More sharing options...
Faicuai Posted December 15, 2018 Share Posted December 15, 2018 (edited) I have a new 19” 5:4 NEC display running at 1280x1024. My 800 is modded with the 5:4 resolution Sophia Rev C. I verified that it is running at 1280x1024. Here are a few pictures with different games. I still get bars on the top and bottom. Frogger II- The Deep! extends WELL BEYOND the standard left-and-right field margins... where are they??? I can't see them there (although I clearly see them here...) PS: Very nice NEC you have there... EXCELLENT choice, indeed! Edited December 15, 2018 by Faicuai Quote Link to comment Share on other sites More sharing options...
jowi Posted December 16, 2018 Share Posted December 16, 2018 Pacman is yellow in the NTSC system. In the PAL system Pacman is salmon. Never knew that, but i guess that is what i’m seeing. Quote Link to comment Share on other sites More sharing options...
jowi Posted December 16, 2018 Share Posted December 16, 2018 I'm still struggling to get the Sophia signal displayed on a monitor. The best attempt is an old HP L2465 monitor, advised by Simius. I got a 2nd hand one cheap, but it has over 90.000 hours (!) runtime on it, probably ran with 100% contrast and 100% brightness... yikes... so i'm looking for a modern alternative. Must be 24" or higher, 16:9. What are people using as Sophia monitor that accepts the signal? Can we make a list of monitors that can still be bought, that support Sophia out of the box? Quote Link to comment Share on other sites More sharing options...
+adamchevy Posted December 16, 2018 Share Posted December 16, 2018 The Dell 30” U3011t has been tested with the 16:9 and 5:4 Sophia. It works well with both. Quote Link to comment Share on other sites More sharing options...
jowi Posted December 16, 2018 Share Posted December 16, 2018 Looks like the Dell U3011t is out of production as well... but good to know that works! Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted December 16, 2018 Share Posted December 16, 2018 The Dell 30” U3011t has been tested with the 16:9 and 5:4 Sophia. It works well with both. For PAL and NTSC? Quote Link to comment Share on other sites More sharing options...
jowi Posted December 16, 2018 Share Posted December 16, 2018 I have a new 19” 5:4 NEC display running at 1280x1024. My 800 is modded with the 5:4 resolution Sophia Rev C. I verified that it is running at 1280x1024. This is interesting; these Multisync series are still available, and they've also got a 24" and a 27" version: https://www.necdisplay.com/documents/ColorBrochures/EA193Mi.223.243WM.273WMi_SpecBrochure.pdf Not cheap, but if they work... might be worth it. Quote Link to comment Share on other sites More sharing options...
Simius Posted December 16, 2018 Author Share Posted December 16, 2018 it has over 90.000 hours (!) runtime on it Total hours or backlight hours? Quote Link to comment Share on other sites More sharing options...
jowi Posted December 16, 2018 Share Posted December 16, 2018 I think it was total, not sure, i found the service menu at some point and that has reset the counters. But it was a lot, and you can tell the image has degraded. Quote Link to comment Share on other sites More sharing options...
Simius Posted December 16, 2018 Author Share Posted December 16, 2018 I think the total hours included standby state. Actual working hours is the backlight hours. Quote Link to comment Share on other sites More sharing options...
