GDMike Posted November 22, 2020 Share Posted November 22, 2020 (edited) Interesting, there's 3.75v coming in,(sram removed). There is 4.29 on the 32K sram in the flashrom99. I'll disconnect that led on my Supercart Edited November 22, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 22, 2020 Share Posted November 22, 2020 5 minutes ago, GDMike said: Interesting, there's 3.75v coming in,(sram removed). There is 4.29 on the 32K sram in the flashrom99. I'll disconnect that led on my Supercart Disconnecting the LED had no influence on the voltage on the SRAM for my Supercart. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 22, 2020 Share Posted November 22, 2020 I just wanted to make sure I didn't make a mistake and replaced the normal 8K RAM in my board with the 8K Clock RAM M48T18 and it works. I didn't install the battery clip on my board. Don't know if that makes a difference. I did try two others that I had in the drawer. Both of them caused the menu screen to have other junk on the screen. One was so bad that I couldn't get to menu item 2. The other one let me start Camel Forth that runs in the cartridge. After I started Camel Forth and removed the junk from the 8K ram chip it worked fine. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 22, 2020 Share Posted November 22, 2020 I tried the one that didn't work again and it let me do menu 2 and the menu 5. So all three work now. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 22, 2020 Share Posted November 22, 2020 I found 4.29v here on R5. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 22, 2020 Share Posted November 22, 2020 And to be 100% clear the version of Camel Forth that I ran was over Rs232 and it loaded into the super cart from floppy disk. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 22, 2020 Share Posted November 22, 2020 I'll go back and touch up some solder points.. Otherwise.. maybe run that 4.29 over to the chip.. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 22, 2020 Share Posted November 22, 2020 Looks like the internal batteries are dead on my units. Not surprising they are 25 years old 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 22, 2020 Share Posted November 22, 2020 (edited) Well a jumper 4.29 volts to it and it tested good without the chip, and it still tested with no data received with the chip. Edited November 22, 2020 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 22, 2020 Share Posted November 22, 2020 I'll try the 8k sram stock and see if it works. Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 22, 2020 Share Posted November 22, 2020 Yup.. the old 8K still works fine Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 22, 2020 Share Posted November 22, 2020 Keeps my supernotes Express data VID_20201121_205041671.mp4 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 22, 2020 Share Posted November 22, 2020 (edited) Well all I can think of is it's a bad MK48T08.. it came from a place in Los Angeles off of eBay because I didn't want to buy anything from China but it probably came in from China and went to LA anyway. Edited November 22, 2020 by GDMike 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 22, 2020 Share Posted November 22, 2020 Here is a version of Camel99 forth V2.62 that runs in Supercart. CAML62SC.zip 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 22, 2020 Share Posted November 22, 2020 I used the last set of disks that you gave me the other day and I loaded it from DSK2 and went to disc one looking for the rest of it to load. Then I tried loading it from dsk4 and it went back to disc one again just like I suspected. So I moved my tippy drive to disk 1 and I threw everything into one folder and it loaded I think four files and then it stopped loading here.. Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 22, 2020 Share Posted November 22, 2020 Oh and by the way I I couldn't copy any of the display fixed files at all from the zip file. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 22, 2020 Share Posted November 22, 2020 1 minute ago, GDMike said: I used the last set of disks that you gave me the other day and I loaded it from DSK2 and went to disc one looking for the rest of it to load. Then I tried loading it from dsk4 and it went back to disc one again just like I suspected. So I moved my tippy drive to disk 1 and I threw everything into one folder and it loaded I think four files and then it stopped loading here.. I have never tested with TIPI. That needs to be stated honestly up front. Yes it assumes everything for booting and support libraries are on DSK1. In this case from the screen it can't find DSK1.LOADSAVE. Is the file LOADSAVE on DSK1. ? Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 22, 2020 Share Posted November 22, 2020 Does it use a supercart for storage space for the user or is it storage space for camel ? FORTH? Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 22, 2020 Share Posted November 22, 2020 3 minutes ago, GDMike said: Oh and by the way I I couldn't copy any of the display fixed files at all from the zip file. That one I have no idea about. I don't remember making any display fixed files. Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 22, 2020 Share Posted November 22, 2020 Yes I believe was on my disc 1 if it's a disk fixed file it didn't get copied to the floppy because I couldn't copy any did fixed files. I'll go look at the floppy again. One sec Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 22, 2020 Share Posted November 22, 2020 1 minute ago, GDMike said: Does it use a supercart for storage space for the user or is it storage space for camel ? FORTH? When you select option 5 Camel Forth load into the super cart. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 22, 2020 Share Posted November 22, 2020 (edited) 5 minutes ago, TheBF said: When you select option 5 Camel Forth load into the super cart. Btw loadsave is on disk 1 Edited November 22, 2020 by GDMike 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 22, 2020 Share Posted November 22, 2020 Just now, GDMike said: Btw loadsave is on disk 1 Which is a TIPI drive? Quote Link to comment Share on other sites More sharing options...
GDMike Posted November 22, 2020 Share Posted November 22, 2020 1 minute ago, TheBF said: Which is a TIPI drive? No I'm just using the regular floppy Drive we decided to tipi wasn't going to work I think. And now my phone's dying... How do I use the super cart version? Does it replace everything you sent me the other day? Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 22, 2020 Share Posted November 22, 2020 14 minutes ago, GDMike said: I used the last set of disks that you gave me the other day and I loaded it from DSK2 and went to disc one looking for the rest of it to load. Then I tried loading it from dsk4 and it went back to disc one again just like I suspected. So I moved my tippy drive to disk 1 and I threw everything into one folder and it loaded I think four files and then it stopped loading here.. From this point now that the error has occurred try typing INLCUDE DSK1.LOADSAVE 1 Quote Link to comment Share on other sites More sharing options...
