+DrVenkman Posted September 22, 2018 Share Posted September 22, 2018 (edited) I am new to Atari computers and bought the SDrive-max. Are there good instructions on use someplace I can download and print? I inverted the display playing around with it, now I can't get it to access functions correctly. Its really pretty straightforward. If you power it up while touching the screen, youll be prompted to re-calibrate the screen. Then you should be able to tap disk slots properly and select files for each one, access the CFG menu for the screen configuration or to save the disk/file configurations, etc. Edited September 22, 2018 by DrVenkman Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4118357 Share on other sites More sharing options...
_The Doctor__ Posted September 22, 2018 Share Posted September 22, 2018 (edited) You plugged the screen in upside down? You may need to repair or replace either piece... can't help but think power went places it should not go? at the very least reflash the device twice... Edited September 22, 2018 by _The Doctor__ Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4118360 Share on other sites More sharing options...
Level42 Posted September 22, 2018 Share Posted September 22, 2018 Farb/Kbr....I would like to do a request.... Mac users will see their lists like shown on the first picture. I think this is because OSX produces extra files with about the same name for system reasons. It makes the screen kinda messy and half of the listed files are useless for the Sdrive Max. Would it be possible to adjust the Sdrive Max firmware to hide these file types ? Further....I noticed sometimes the screen gets a bit messed up...not sure when or how but sometimes I see the drivelist like on the second picture. I have a feeling this is probably a library bug ? Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4118674 Share on other sites More sharing options...
+DrVenkman Posted September 22, 2018 Share Posted September 22, 2018 Farb/Kbr....I would like to do a request.... Mac users will see their lists like shown on the first picture. I think this is because OSX produces extra files with about the same name for system reasons. It makes the screen kinda messy and half of the listed files are useless for the Sdrive Max. Would it be possible to adjust the Sdrive Max firmware to hide these file types ? Further....I noticed sometimes the screen gets a bit messed up...not sure when or how but sometimes I see the drivelist like on the second picture. I have a feeling this is probably a library bug ? Just run dotclean on the SD card before you eject it. https://lifehacker.com/377011/delete-mac-system-files-with-dotclean 3 Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4118705 Share on other sites More sharing options...
_The Doctor__ Posted September 22, 2018 Share Posted September 22, 2018 Just run dotclean on the SD card before you eject it. https://lifehacker.com/377011/delete-mac-system-files-with-dotclean You dah man Venkman! Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4118711 Share on other sites More sharing options...
+DrVenkman Posted September 22, 2018 Share Posted September 22, 2018 You dah man Venkman! I used Macs daily for 13-1/2 years. You run into stuff like this pretty often if you exchange files in FAT volumes. Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4118716 Share on other sites More sharing options...
Level42 Posted September 23, 2018 Share Posted September 23, 2018 Nice and would work of course but that means running that app every time you add 1 a single file.... Im lazy and would much prefer a solution on the Sdrive Max side. It cant be too hard to put a filter in that looks at the underscore as the first character of the file and following that ignore displaying it... in fact ...I can have a look at the source code and see if I can add it myself Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119018 Share on other sites More sharing options...
+DrVenkman Posted September 23, 2018 Share Posted September 23, 2018 Nice and would work of course but that means running that app every time you add 1 a single file.... Im lazy and would much prefer a solution on the Sdrive Max side. It cant be too hard to put a filter in that looks at the underscore as the first character of the file and following that ignore displaying it... in fact ...I can have a look at the source code and see if I can add it myself Sure, but remember two things: 1) OS X will add dotfiles for EVERY file, in EVERY directory; that's going to be a lot of files if you have many thousands of .ATR, ATX, XEX and .CAS files on your card. And 2) the ATmega chip is pretty low-powered and reading directories, sorting and now potentially excluding dotfiles will just add overhead to what is already fairly slow (listing and scrolling through files). 2 Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119068 Share on other sites More sharing options...
_The Doctor__ Posted September 23, 2018 Share Posted September 23, 2018 best to use what's left in the sdrive for other things, dealing with duplicates of every file that shouldn't be there in the first place just can't be one of them, It's wasteful on all fronts. 1 Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119173 Share on other sites More sharing options...
lemiel Posted September 23, 2018 Share Posted September 23, 2018 My screen is somewhat broken? - horizontal line on it like on photo. and it does not show anything after succesfull v0.9 flashing: sudo avrdude -carduino -pm328p -P /dev/ttyUSB0 -U flash:w:"/home/lemiel/AVR/sdrive-max/atmega328-ili9341/eeprom_writer.hex" sudo avrdude -carduino -pm328p -P /dev/ttyUSB0 -U flash:w:"/home/lemiel/AVR/sdrive-max/atmega328-ili9341/SDrive.hex" It should show something right after programming? Bought this one: https://pl.aliexpress.com/item/2-8-inch-TFT-color-LCD-touch-screen-module-for-Arduino-UNO-MEGA2560-R3-Development-board/32831754174.html I also tried three others versions. Also no response on screen. Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119307 Share on other sites More sharing options...
_The Doctor__ Posted September 23, 2018 Share Posted September 23, 2018 That screen looks cracked.. if it is well... not much chance for it to work or look correctly 1 Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119321 Share on other sites More sharing options...
AtariGeezer Posted September 23, 2018 Share Posted September 23, 2018 Is this offer for anyone willing to send you an SIO cable. I have just about given up on getting the UNO + Screen combo that works together.. Which UNO and Screens did you buy? Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119323 Share on other sites More sharing options...
Level42 Posted September 23, 2018 Share Posted September 23, 2018 best to use what's left in the sdrive for other things, dealing with duplicates of every file that shouldn't be there in the first place just can't be one of them, It's wasteful on all fronts. A simple if then statement should be enough.....and what other things do you mean ? It serves me well as it is and for me the whole cassette emulation could be ripped out as I fail to see the pint of emulating cassettes. But other people probably love it......what I’m trying to say, to each his own.....and the more people tell me not to do something ....the more I get triggered.... Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119328 Share on other sites More sharing options...
Level42 Posted September 23, 2018 Share Posted September 23, 2018 That screen looks cracked.. if it is well... not much chance for it to work or look correctly How can you see that when the proctecitive film is still on ??? First remove the protective film....no way to know how it looks under it with it still on...also....4 bad displays ? No way. Only ordered 2 and both are fine. It must be a step in the process you do incorrectly. Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119331 Share on other sites More sharing options...
_The Doctor__ Posted September 23, 2018 Share Posted September 23, 2018 (edited) My eyesight is bad but it's not so bad I can't see the screen looks like it is cracked..... adjust your monitor angle or something. I have 3 screens I can't use... but others work.. it's that high standards quality control out of china... what can you do... Dr Venkman gave the prescription. It works, and doesn't cause any issues. It corrects an Apple issue that's affected numerous things over time. some people do it automatically so.... there you have it. It's not an sdrive max issue, but hey a filter to be set up for any chars to be avoided is a novelty that people might like. or the other way around to only show stuff with certain chars in them sounds like fun the programmer should say reading writing and reading and something about the the success of the flash... and that gets done in two flash sessions, one before and one after usb disconnect re connect.... if you don't see something to that affect it's gone wrong Edited September 23, 2018 by _The Doctor__ 1 Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119355 Share on other sites More sharing options...
Level42 Posted September 23, 2018 Share Posted September 23, 2018 (edited) Never mind... Edited September 23, 2018 by Level42 Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119379 Share on other sites More sharing options...
lemiel Posted September 23, 2018 Share Posted September 23, 2018 Tried flashing with and without putting USB plug between both Hex files. With this protective film crack is better seen. Do you know how to check which chip this screen is using? Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119388 Share on other sites More sharing options...
toddtmw Posted September 23, 2018 Share Posted September 23, 2018 A simple if then statement should be enough.....and what other things do you mean ? It serves me well as it is and for me the whole cassette emulation could be ripped out as I fail to see the pint of emulating cassettes. But other people probably love it......what Im trying to say, to each his own.....and the more people tell me not to do something ....the more I get triggered.... I mean, the reality is, files that start with a . are supposed to be hidden on many file systems. It seems like a pretty simple change to check for that and dont display them. But, maybe it would mess up the programs ability to index to the correct file. I havent looked at the code. Todd 1 Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119396 Share on other sites More sharing options...
_The Doctor__ Posted September 23, 2018 Share Posted September 23, 2018 (edited) those are usually ili9341's... some of them if you carefully warm the double sided sticky tape will say on the other side of the screen... and sometimes they silk screen directly on the pcb... you would have to look around to be sure... one or two boards turned to be hx8347g though Edited September 23, 2018 by _The Doctor__ Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119397 Share on other sites More sharing options...
toddtmw Posted September 23, 2018 Share Posted September 23, 2018 Well, according to this thread you can set the mac not to create the files. https://forums.macrumors.com/threads/solved-prevent-hidden-files-creation-on-usb-drives.2022099/ defaults write com.apple.desktopservices DSDontWriteUSBStores -bool true sudo mdutil -i off -d /Volumes Havent tried it. Use at your own risk. Todd 1 Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119400 Share on other sites More sharing options...
+DrVenkman Posted September 23, 2018 Share Posted September 23, 2018 If running dotclean from the terminal before ejecting the card is too much trouble for some people, we're all wasting our breath to suggest alternatives. Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119407 Share on other sites More sharing options...
toddtmw Posted September 23, 2018 Share Posted September 23, 2018 If running dotclean from the terminal before ejecting the card is too much trouble for some people, we're all wasting our breath to suggest alternatives. I still say a simple IF statement in the sdrive code is worth a shot. It is by far the best solution. One IF statement is better than answering this question over and over again. 1 Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119409 Share on other sites More sharing options...
_The Doctor__ Posted September 23, 2018 Share Posted September 23, 2018 I like it the way it is unless it's made select-able this things already fighting not to be too slow. 1 Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119432 Share on other sites More sharing options...
Level42 Posted September 23, 2018 Share Posted September 23, 2018 (edited) If running dotclean from the terminal before ejecting the card is too much trouble for some people, we're all wasting our breath to suggest alternatives. Yeah man....sorry for thinking of an INTELLIGENT solution instead of having to type in a stupid manual command every single time I add ONE freaking file to my Sdrive-Max SD card..... I didnt buy a Mac to type in stupid terminal commands. And mr, Dokter always knows whats best for everyone without actually ever providing a single solution... What makes you thinki that one single if statement would slow things down so much huh ? Have you actually ever DONE any Arduino programming ? And you dont HAVE to install the version for Mac users...should it ever arrive. The end is that your comments were pointless and only aiming to discourage KBR to have a look at it because YOU dont want it. Have ZERO problems with the speed of Sdrive Max....its fast enough and one freaking line of code is not going to bring performance to its knees. Hey....making it selectable will add even more code..... Edited September 23, 2018 by Level42 Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119489 Share on other sites More sharing options...
Level42 Posted September 23, 2018 Share Posted September 23, 2018 (edited) I still say a simple IF statement in the sdrive code is worth a shot. It is by far the best solution. One IF statement is better than answering this question over and over again. Thanks for the support....I should have asked this in a PM to KBR instead. Why do people want to blow an idea out of the water just because its not what THEY want ? Edited September 23, 2018 by Level42 Quote Link to comment https://forums.atariage.com/topic/275629-sdrive-max-atx-support/page/15/#findComment-4119493 Share on other sites More sharing options...
