+mizapf Posted May 28, 2023 Share Posted May 28, 2023 I did not try that yet. Will report. Quote Link to comment Share on other sites More sharing options...
+9640News Posted May 29, 2023 Share Posted May 29, 2023 56 minutes ago, mizapf said: I did not try that yet. Will report. The loop I believe was a result of not activating emulation mode on the PI. I did get things booted once, but not sure what the issue(s) are why it will not reboot at the moment. Quote Link to comment Share on other sites More sharing options...
+mizapf Posted June 9, 2023 Share Posted June 9, 2023 On 5/28/2023 at 10:15 PM, 9640News said: I upgraded a PI 4 to use Bullseye with MAME and, using the new MDOS release. Something isn't playing well in the powerup routine and things are in a loop. Next step is to see about upgrading MAME. @mizapf Have you got MAME booting MDOS from the latest update to the TIPI? Yes, here: http://www.mizapf.eu/files/genevetipi_boot.webm (updated TIPI software to 3.17) 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 9, 2023 Share Posted June 9, 2023 this is what I get when i try it gregory@linuxmintgamingpc:~/Downloads/mame$ ./mame geneve -window -bios 2.00 -peb:slot5 speech -peb:slot6 tipi -conn rpi.tipipz2 -oslog [:maincpu] Variant = standard (with on-chip RAM), Overflow int = no check [:peb] AMA/B/C address prefix set to 00000 [:peb] Slot 2 = empty [:peb] Slot 3 = empty [:peb] Slot 4 = empty [:peb] Slot 5 = :peb:slot5:speech [:peb] Slot 6 = :peb:slot6:tipi [:peb] Slot 7 = empty [:peb] Slot 8 = empty Soft reset [:peb:slot6:tipi] Trying to connect to Raspberry Pi at tipipz2:9901/tipi [:] Video RAM set to 128 KiB [:maincpu] RESET; automatic wait state creation is disabled [:kbd:geneve_kb_101] Reset triggered [:peb:slot6:tipi] Connection established [:peb:slot6:tipi] TIPI server offers ASYNC communication [:] Keyboard reset (line not connected) [:kbd:geneve_kb_101] Reset triggered [:peb:slot6:tipi] Got error: End of file (2) [:peb:slot6:tipi] Trying to connect to Raspberry Pi at tipipz2:9901/tipi [:peb:slot6:tipi] Connection established [:peb:slot6:tipi] TIPI server offers ASYNC communication [:peb:slot6:tipi] Got error: End of file (2) 2023-06-07 15:09:44,222 TipiService : INFO websocket mode enabled 2023-06-07 15:09:44,232 TipiService : INFO TIPI Ready 2023-06-09 07:41:24,008 TipiService : INFO websocket mode enabled 2023-06-09 07:41:24,019 TipiService : INFO TIPI Ready Quote Link to comment Share on other sites More sharing options...
+hloberg Posted June 10, 2023 Share Posted June 10, 2023 not sure if this should be under MAME or TIPI? got 2 questions: 1.) I'm setting up a TIPI with TIPI and QEMU on an test PC. I got QEMU running fine. can get to it with web. I run JS99er.net with the recommended settings ws://localhost:9901/tipi full TIPI. when I run CALL TIPI it just hangs. ALSO tried with MAME. I installed the TIPI slot setup like @mizapf put in the notes. MAME starts fine. run CALL TIPI and it hangs too. I must be leaving out something? 2.) Is it possible to use a REAL RasPI TIPI with MAME? How would I hook it up if so? Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 10, 2023 Share Posted June 10, 2023 20 minutes ago, hloberg said: not sure if this should be under MAME or TIPI? got 2 questions: 1.) I'm setting up a TIPI with TIPI and QEMU on an test PC. I got QEMU running fine. can get to it with web. I run JS99er.net with the recommended settings ws://localhost:9901/tipi full TIPI. when I run CALL TIPI it just hangs. ALSO tried with MAME. I installed the TIPI slot setup like @mizapf put in the notes. MAME starts fine. run CALL TIPI and it hangs too. I must be leaving out something? 2.) Is it possible to use a REAL RasPI TIPI with MAME? How would I hook it up if so? https://github.com/jedimatt42/tipi/wiki/emulation-installation Has the answers and you should should check the TIPI log to see if you're getting connections on your QEMU TIPI If you're not getting connections then you might want to check to make sure you don't have a firewall or something else going on. Additionally, JS99er will not work unless it's HTTP it has to be HTTP not HTTPS. A lot of browsers are going to force you to be HTTPS at this point. This is because webhooks requires you to not cross between HTTPS and HTTP and so therefore you have to turn off HTTPS in your browser for that to work correctly Mame is in my opinion not working correctly and hasn't for a while. There is something wrong with the web hooks code in mame. It has always been hit or miss and lately it is 100% mess in the last few versions. I'm assuming it's something to do with timing or handshaking, but that's an assumption If you want to work through your problems with some help, we're going to be on the zoom call in a little while and will be all happy to help you during the call Quote Link to comment Share on other sites More sharing options...
+hloberg Posted June 10, 2023 Share Posted June 10, 2023 18 minutes ago, arcadeshopper said: https://github.com/jedimatt42/tipi/wiki/emulation-installation Has the answers and you should should check the TIPI log to see if you're getting connections on your QEMU TIPI If you're not getting connections then you might want to check to make sure you don't have a firewall or something else going on. Additionally, JS99er will not work unless it's HTTP it has to be HTTP not HTTPS. A lot of browsers are going to force you to be HTTPS at this point. This is because webhooks requires you to not cross between HTTPS and HTTP and so therefore you have to turn off HTTPS in your browser for that to work correctly Mame is in my opinion not working correctly and hasn't for a while. There is something wrong with the web hooks code in mame. It has always been hit or miss and lately it is 100% mess in the last few versions. I'm assuming it's something to do with timing or handshaking, but that's an assumption If you want to work through your problems with some help, we're going to be on the zoom call in a little while and will be all happy to help you during the call thanks, i'll look into that with the QEMU. Doing yard work on and off today so will get the next ZOOM meeting. plan to get back into the 99 more. Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 20, 2023 Author Share Posted June 20, 2023 There is a bug in TIPI 3.x SD card image the prevents the tipi_kernel_module from loading on Raspberry PI Zero W ( and probably plain Zero ) I've produced a fix, but don't have time at the moment to fix the SD card image and re-publish it. So, manual steps to get going if you are in that situation for the time being: - ssh to tipi@tipi.local or attach a keyboard and monitor and login as tipi user - cd to /home/tipi/tipi_kernel_module - run : git pull - run : sudo reboot now on boot it should then automatically recompile the kernel module and load. It was supposed to do this, but a bug snuck in, cause I tested that on a different brand of SBC originally. Hopefully I'll have time Friday or Saturday to update the SD card image, so this can be forgotten about. 2 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted June 23, 2023 Share Posted June 23, 2023 On 6/9/2023 at 9:39 PM, arcadeshopper said: this is what I get when i try it ... [:peb:slot6:tipi] Trying to connect to Raspberry Pi at tipipz2:9901/tipi [:peb:slot6:tipi] Connection established [:peb:slot6:tipi] TIPI server offers ASYNC communication [:peb:slot6:tipi] Got error: End of file (2) Does it work reliably now? In our last message exchange you seemed to be successful. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 23, 2023 Share Posted June 23, 2023 43 minutes ago, mizapf said: Does it work reliably now? In our last message exchange you seemed to be successful. So far so good in linux. I have no idea what changed but it seems to be good Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted June 24, 2023 Author Share Posted June 24, 2023 On 6/19/2023 at 6:58 PM, jedimatt42 said: There is a bug in TIPI 3.x SD card image the prevents the tipi_kernel_module from loading on Raspberry PI Zero W ( and probably plain Zero ) ... Hopefully I'll have time Friday or Saturday to update the SD card image, so this can be forgotten about. This is fixed now in a newly uploaded SD Card image. I also freshened up SD image with current 3.17 code. 2 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted July 9, 2023 Share Posted July 9, 2023 I don't know if this was a "one time" issue with my system or something that might need to be addressed. I updated from 3.14 to 3.17. I loaded PI.CONFIG into an editor, added a "NATIVE_TEXT_DIRS" entry, and attempted to write PI.CONFIG to the TIPI. My system locked up. I reset the Geneve and TIPI/RPi, then repeated the steps to edit PI.CONFIG. The system locked up again. I checked the TIPI log and it reported the following error: Updated from 3.14 to 3.17. Loaded PI.CONFIG into editor Save PI.CONFIG results in the following: 2023-07-08 19:52:13,129 Pab : INFO opcode: Open, fileType: Sequential, mode: Output, dataType: Display, recordType: Variable, recordLength: 0, recordNumber: 0 2023-07-08 19:52:13,140 Pab : INFO opcode: Write, fileType: Sequential, mode: Output, dataType: Display, recordType: Variable, recordLength: 80, recordNumber: 0 2023-07-08 19:52:13,153 Pab : INFO opcode: Write, fileType: Sequential, mode: Output, dataType: Display, recordType: Variable, recordLength: 80, recordNumber: 1 2023-07-08 19:52:13,167 Pab : INFO opcode: Write, fileType: Sequential, mode: Output, dataType: Display, recordType: Variable, recordLength: 80, recordNumber: 2 2023-07-08 19:52:13,181 Pab : INFO opcode: Write, fileType: Sequential, mode: Output, dataType: Display, recordType: Variable, recordLength: 80, recordNumber: 3 2023-07-08 19:52:13,194 Pab : INFO opcode: Write, fileType: Sequential, mode: Output, dataType: Display, recordType: Variable, recordLength: 80, recordNumber: 4 2023-07-08 19:52:13,207 Pab : INFO opcode: Write, fileType: Sequential, mode: Output, dataType: Display, recordType: Variable, recordLength: 80, recordNumber: 5 2023-07-08 19:52:13,222 Pab : INFO opcode: Write, fileType: Sequential, mode: Output, dataType: Display, recordType: Variable, recordLength: 80, recordNumber: 6 2023-07-08 19:52:13,234 Pab : INFO opcode: Write, fileType: Sequential, mode: Output, dataType: Display, recordType: Variable, recordLength: 80, recordNumber: 7 2023-07-08 19:52:13,245 Pab : INFO opcode: Write, fileType: Sequential, mode: Output, dataType: Display, recordType: Variable, recordLength: 80, recordNumber: 8 2023-07-08 19:52:13,256 Pab : INFO opcode: Write, fileType: Sequential, mode: Output, dataType: Display, recordType: Variable, recordLength: 80, recordNumber: 9 2023-07-08 19:52:13,267 Pab : INFO opcode: Write, fileType: Sequential, mode: Output, dataType: Display, recordType: Variable, recordLength: 80, recordNumber: 10 2023-07-08 19:52:13,279 Pab : INFO opcode: Write, fileType: Sequential, mode: Output, dataType: Display, recordType: Variable, recordLength: 80, recordNumber: 11 2023-07-08 19:52:13,290 Pab : INFO opcode: Write, fileType: Sequential, mode: Output, dataType: Display, recordType: Variable, recordLength: 80, recordNumber: 12 2023-07-08 19:52:13,295 TipiService : ERROR Unhandled exception in main Traceback (most recent call last): File "/home/tipi/tipi/services/./TipiService.py", line 90, in <module> if specialFiles.handle(pab, filename): File "/home/tipi/tipi/services/SpecialFiles.py", line 63, in handle handler.handle(pab, devname) File "/home/tipi/tipi/services/ConfigFile.py", line 32, in handle self.write(pab, devname) File "/home/tipi/tipi/services/ConfigFile.py", line 71, in write value = msg.split('=')[1].strip() IndexError: list index out of range 2023-07-08 19:52:14,075 TipiService : INFO physical mode enabled 2023-07-08 19:52:14,084 TipiService : INFO TIPI Ready Line 12 contained the deprecated line "TIPI_NAME=TIPI". I deleted the line and was able to successfully save PI.CONFIG with no errors. When I reloaded PI.CONFIG, the "TIPI_NAME=TIPI" entry had returned (or was never removed). The good news is that saving PI.CONFIG works and no error is reported. 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 9, 2023 Author Share Posted July 9, 2023 The error would indicate that there was a line that did not have an "=" in it. A blank line would cause this. PI.CONFIG is probably very intolerant. I can improve that a bit, such as ignoring any line that isn't of the form: key=value 2 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 10, 2023 Author Share Posted July 10, 2023 Update 3.18 - July 9th 2023 Bug fixes brought to my attention thanks to @InsaneMultitasker, and @dhe - Fix PI.CONFIG write operations to ignore lines that are not a map entry - Fix loading of /home/tipi/tipi.config to also ignore lines that are not a map entry, in case you manually edit it from linux. - Fix web-ui to show perceived file type based on NATIVE_TEXT_DIRS configuration. 5 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 14, 2023 Author Share Posted July 14, 2023 Update 3.19 - July 14th 2023 More bug finding love from @InsaneMultitasker, @dhe, and @9640News - Fix native flags so that when creating a file (OPEN OUTPUT or APPEND when file is not present) if a native_flag is set, then the PAB data type and record type and record length must be appropriate for the active native_flag. * Note: internally NATIVE_TEXT_DIRS sets the ?W native flag for operations, so this should fix the create of DF80 object files in the Geneve MDOS source builds where the source or build is happening from a directory specified in NATIVE_TEXT_DIRS. ** Note: This restricted ?X native flag to DISPLAY FIXED 128 files. 1 2 1 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted July 15, 2023 Share Posted July 15, 2023 1 hour ago, jedimatt42 said: - Fix native flags so that when creating a file (OPEN OUTPUT or APPEND when file is not present) if a native_flag is set, then the PAB data type and record type and record length must be appropriate for the active native_flag. * Note: internally NATIVE_TEXT_DIRS sets the ?W native flag for operations, so this should fix the create of DF80 object files in the Geneve MDOS source builds where the source or build is happening from a directory specified in NATIVE_TEXT_DIRS. I ran a simple test program that creates a new DF80, DV20, IF100, and IV90 file. All four files were created with a TIFILES headered file. I was also able to successfully assemble a native text file into a TIFILES headered DF80 file. Outstanding. 3 Quote Link to comment Share on other sites More sharing options...
+9640News Posted July 15, 2023 Share Posted July 15, 2023 2 hours ago, jedimatt42 said: Update 3.19 - July 14th 2023 More bug finding love from @InsaneMultitasker, @dhe, and @9640News - Fix native flags so that when creating a file (OPEN OUTPUT or APPEND when file is not present) if a native_flag is set, then the PAB data type and record type and record length must be appropriate for the active native_flag. * Note: internally NATIVE_TEXT_DIRS sets the ?W native flag for operations, so this should fix the create of DF80 object files in the Geneve MDOS source builds where the source or build is happening from a directory specified in NATIVE_TEXT_DIRS. ** Note: This restricted ?X native flag to DISPLAY FIXED 128 files. Thank you Matt. Much appreciated for all your continued support!!!! 1 Quote Link to comment Share on other sites More sharing options...
JasonACT Posted July 15, 2023 Share Posted July 15, 2023 Hi, I'm still working on my Pi Pico PEB board, which is using more and more TIPI source code - quite a lot actually, from the TI side. I was wondering if someone could try this on their TIPI in TI BASIC: 10 CALL CLEAR LIST "PI.PIO" And let me know if it produces a PDF file with the program listing? For some reason, probably me, mine does strange things and crashes the TI - and I'm kind of stuck. Thanks Quote Link to comment Share on other sites More sharing options...
JasonACT Posted July 15, 2023 Share Posted July 15, 2023 I finally fixed it... TI BASIC sends in an empty record, using the automatic CRLF of PIO/RS232 - and I wasn't checking for zero length. Sorry for the disturbance! 1 Quote Link to comment Share on other sites More sharing options...
nwah Posted July 17, 2023 Share Posted July 17, 2023 Hi all--decided to pull out my sidecar TIPI after a few months, but just hangs when I CALL TIPI. As I was hooking it up I did power it on with the connector plugged into the wrong end of the GPIO pins on the Pi, so I'm wondering if I fried something. The light on the TIPI does come on, but I tried the TipiDebug.py script and I'm not seeing the register values updated on the Pi side, although they do seem to stick on the TI. I have not tried updating the SD card on the Raspberry Pi yet, but everything was working great when I last used it so not sure else would've changed. Any other ideas for things to test, or should I just replace the Tipi? Thanks! Quote Link to comment Share on other sites More sharing options...
Duewester Posted July 18, 2023 Share Posted July 18, 2023 (edited) Well, there is a warning somewhere in the docs about hooking up to the Pi on the wrong pins and bad stuff for the TiPi "Warning: connecting the cables to the +5V pins, 2 & 4, of the Raspberry PI will result in destroying the CPLD on the TIPI board." I use a Pi Zero w2 with the minimum pins on it and plug it directly into the sidecar. I'm prone to getting things backwards and mixed up so I do what ever I can to reduce the opportunities for errors. At least you can ssh into the Pi so, it's probably functional. Edited July 18, 2023 by Duewester Quote Link to comment Share on other sites More sharing options...
nwah Posted July 18, 2023 Share Posted July 18, 2023 1 hour ago, Duewester said: Well, there is a warning somewhere in the docs [...] Yeah... unfortunately I didn't read this until I went to the docs to check the right way to install it when it wasn't working. Wondering if there's a way to definitively confirm that before I shell out for another one. I was looking at the Pi Zero W2 though since the Pi 3 I'm using is pretty clunky. Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted July 18, 2023 Author Share Posted July 18, 2023 Sadly, I've never seen a survival... the CPLD pin that get mis-connected, dump the full current the PI's 5V supply can provide before it cooks, in an instant. I've replaced the CPLD on half a dozen of these, and that has always resurrected them. I don't have any spare CPLDs anymore, so I'm not in a position to offer repair service. 1 4 Quote Link to comment Share on other sites More sharing options...
+dhe Posted July 18, 2023 Share Posted July 18, 2023 If something can be plugged in backwards, I've probably done it. When I have something that can plug in multiple ways, I take a silver sharpie and mark the top of the board and top of the connector. For future reference @jedimatt42, can you take a picture of the board and highlight the chip that gets fry-ed? 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted July 18, 2023 Share Posted July 18, 2023 13 minutes ago, dhe said: If something can be plugged in backwards, I've probably done it. When I have something that can plug in multiple ways, I take a silver sharpie and mark the top of the board and top of the connector. For future reference @jedimatt42, can you take a picture of the board and highlight the chip that gets fry-ed? It's the CPLD.. the only square SMD chip 2 Quote Link to comment Share on other sites More sharing options...
