IndusGT Posted November 16, 2022 Share Posted November 16, 2022 20 minutes ago, tmp said: i'm unable to get any reliable numbers from rwtest, according to docs latest sdx should support divisor as low as 1 but i'm having issues with it (read speeds dropping to hundreds of bytes per sec indicating there are tons of retries while writes being stable) with divisor 5 i had write/read 5050/5455 (via sio) emulated hdd speeds were around 50-60kB/s (i forgot to write them down) i need to figure out why low divisors are acting up in sdx Thanks for running them, guess there's a compromise with stability/speed with writes. I just bought a cart with all cables, looking forwards to trying it out. Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted November 16, 2022 Share Posted November 16, 2022 On 11/14/2022 at 5:06 PM, Mclaneinc said: Also had a weird thing, the AVG menu wasn't coming up, it just booted normally. Had a similar problem. Whenever I plugged in the AVG cart. the READY prompt appeared as if the cart wasn't there. Always had to press the cart button to make the menu appear, which seemed strange to me. Control+S solved that problem for me. (And next time something strange happens I will try Shift+? to see if I accidentally enabled something that I do not need.) Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted November 16, 2022 Share Posted November 16, 2022 2 hours ago, CharlieChaplin said: Had a similar problem. Whenever I plugged in the AVG cart. the READY prompt appeared as if the cart wasn't there. Always had to press the cart button to make the menu appear, which seemed strange to me. Control+S solved that problem for me. (And next time something strange happens I will try Shift+? to see if I accidentally enabled something that I do not need.) Me too, I seem to be all fingers and thumbs at the moment.. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted November 17, 2022 Share Posted November 17, 2022 Hi, one of my usual "I really should know this" questions. I'm close to getting a PBI cable, but I can't remember if all the PCB's with take the cable. I have the green PCB that didn't have the SIO connector socket already added. I have 2 identical connects, one for SIO and one for debricking / programming. There' s a place on the PCB for where a much longer (9 holes) place to be wired to? Is this the one that needs to be added. Or do I have a non-expandible PCB. I seem to remember a series of pictures showing the various production PCB's and where to put a connector, but I can find it, sure its in this thread but 86 pages is a slow process TIA Paul.. Quote Link to comment Share on other sites More sharing options...
tmp Posted November 17, 2022 Author Share Posted November 17, 2022 two issues with PBI cable and older carts 1. 5V there's no 5v on 800xl pbi by default so one pin on 9pin connector was changed from ground to 5v on the newer carts the fix would be either isolating that pin before soldering the 9 pin connector on the pcb and bringing 5v to it via wire or modifying 800xl to have 5v on pbi and pbi cable pcb to use 5v from pbi and not from the cart first option is shown here at the bottom, 5v wire is missing though https://avgcart.tmp.sk/ecimod/ 2. length currently made pbi cables are probably too short for being plugged into old position connector and loop inside the cart to exit (cable braid is also adding stiffness so it increases the radius of that loop) i'll take a photo later to show what i mean Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted November 17, 2022 Share Posted November 17, 2022 I may forgo all this as I have a Ultimate 1MB in there, I was just going to do it to use the fancy stuff on the cart, but I already have the ram and can have 4 OS's. Seems a load of hassle and extra cable cost to mod it... Thanks for the info tmp, you saved me time and a bit of cash.. Quote Link to comment Share on other sites More sharing options...
MrFSL Posted November 18, 2022 Share Posted November 18, 2022 7 hours ago, tmp said: two issues with PBI cable and older carts 1. 5V there's no 5v on 800xl pbi by default so one pin on 9pin connector was changed from ground to 5v on the newer carts the fix would be either isolating that pin before soldering the 9 pin connector on the pcb and bringing 5v to it via wire or modifying 800xl to have 5v on pbi and pbi cable pcb to use 5v from pbi and not from the cart first option is shown here at the bottom, 5v wire is missing though https://avgcart.tmp.sk/ecimod/ 2. length currently made pbi cables are probably too short for being plugged into old position connector and loop inside the cart to exit (cable braid is also adding stiffness so it increases the radius of that loop) i'll take a photo later to show what i mean Well, now I am confused.... If I have a newer cart and the PBI cable... is there any problem connecting it to any of these: 600xl (has 5V on the PBI) 800xl (has no 5V on the PBI) 800XL (modified to add 5V to PBI via jumper to pin 47) 800XL (modified to add 5V to PBI via jumper to pin 48) Quote Link to comment Share on other sites More sharing options...
tmp Posted November 18, 2022 Author Share Posted November 18, 2022 20 minutes ago, MrFSL said: Well, now I am confused.... If I have a newer cart and the PBI cable... is there any problem connecting it to any of these: 600xl (has 5V on the PBI) 800xl (has no 5V on the PBI) 800XL (modified to add 5V to PBI via jumper to pin 47) 800XL (modified to add 5V to PBI via jumper to pin 48) no Quote Link to comment Share on other sites More sharing options...
mnemo Posted November 18, 2022 Share Posted November 18, 2022 6 hours ago, MrFSL said: Well, now I am confused.... If I have a newer cart and the PBI cable... is there any problem connecting it to any of these: 600xl (has 5V on the PBI) 800xl (has no 5V on the PBI) 800XL (modified to add 5V to PBI via jumper to pin 47) 800XL (modified to add 5V to PBI via jumper to pin 48) But it looks a bit like Avg of Borg. 3 Quote Link to comment Share on other sites More sharing options...
MrFSL Posted November 18, 2022 Share Posted November 18, 2022 11 hours ago, mnemo said: But it looks a bit like Avg of Borg. HA! Yes, yes it does. We are AVG. We will add your technological distinctiveness to our own. 1 Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted November 19, 2022 Share Posted November 19, 2022 On 11/12/2022 at 6:50 PM, rcamp48 said: OK I will wait until I get the new Mylar from Best I just put in the new mylar and updated my AVG cart but I am still getting weird graphics from the AVF player, anyone know why? 1941309965_Untitled2.mp4 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 19, 2022 Share Posted November 19, 2022 On 11/16/2022 at 12:17 AM, tmp said: i'm unable to get any reliable numbers from rwtest, according to docs latest sdx should support divisor as low as 1 but i'm having issues with it (read speeds dropping to hundreds of bytes per sec indicating there are tons of retries while writes being stable) with divisor 5 i had write/read 5050/5455 (via sio) emulated hdd speeds were around 50-60kB/s (i forgot to write them down) i need to figure out why low divisors are acting up in sdx SDX only doing lower SIO divisors with different filter afair... like when you use pclink etc. Quote Link to comment Share on other sites More sharing options...
tmp Posted November 19, 2022 Author Share Posted November 19, 2022 19 hours ago, rcamp48 said: I just put in the new mylar and updated my AVG cart but I am still getting weird graphics from the AVF player, anyone know why? 1941309965_Untitled2.mp4 can you elaborate on that? no video plays properly or some videos don't play properly? did it work before on the same sd card? did you try another sd card? did you check whether the videos are contiguous? Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted November 20, 2022 Share Posted November 20, 2022 3 hours ago, tmp said: can you elaborate on that? no video plays properly or some videos don't play properly? did it work before on the same sd card? did you try another sd card? did you check whether the videos are contiguous? None of my videos play properly they used to, maybe I have bad files to create them and I tried 2 different sd cards Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted November 20, 2022 Share Posted November 20, 2022 On 11/17/2022 at 3:45 PM, Mclaneinc said: I may forgo all this as I have a Ultimate 1MB in there, I was just going to do it to use the fancy stuff on the cart, but I already have the ram and can have 4 OS's. Seems a load of hassle and extra cable cost to mod it... Thanks for the info tmp, you saved me time and a bit of cash.. Do you have any problems using the AVG cart with the U1MB cart? Is there special firmware for both? Russ Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted November 20, 2022 Share Posted November 20, 2022 Not having any issues between them Russ, no special firmware being used BUT I don't use the IDE side of things, I use it as a loader from the cart / storage, the whole streaming thing was nice to see but I don't use it. Quote Link to comment Share on other sites More sharing options...
mimo Posted November 24, 2022 Share Posted November 24, 2022 This has just appeared on youtube, been waiting a while for it. Only watched about a third of it so far, as it's rather long Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted November 24, 2022 Share Posted November 24, 2022 Wow, Kaz and tmp are so young, I now feel officially OLD.. 1 Quote Link to comment Share on other sites More sharing options...
MiCV2 Posted November 29, 2022 Share Posted November 29, 2022 (edited) @tmp I have a question. There is this new awesome 1MB demo "Rewind". My Atari XE&XL has this internal 512K memory expansion (picture). I also own AVGCART. With the Internal 512K Memory Expansion, could I use it together with the AVGCART Memory Expansion to get 1MB? Is it then possible to start this 1MB Rewind demo? 🤔 Best regards, MiC Edit: I haven't bought the ECI cable yet. If 1MB is possible, I'll buy two immediately 🙂 Rewind by New Generation & Zelax :: pouët.net (pouet.net) Edited November 29, 2022 by MiCV2 Quote Link to comment Share on other sites More sharing options...
tmp Posted November 29, 2022 Author Share Posted November 29, 2022 1 hour ago, MiCV2 said: With the Internal 512K Memory Expansion, could I use it together with the AVGCART Memory Expansion to get 1MB? no, it doesn't work that way Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted November 29, 2022 Share Posted November 29, 2022 @tmp Will there be new AVG carts or new AVG firmware someday that give(s) you 1MB of XRAM ?!? Quote Link to comment Share on other sites More sharing options...
tmp Posted November 29, 2022 Author Share Posted November 29, 2022 i don't know, i don't plan features, features happen 3 1 7 Quote Link to comment Share on other sites More sharing options...
MiCV2 Posted November 30, 2022 Share Posted November 30, 2022 Thanks tmp 👍 It's the first time I actually need 1MB of RAM. For everything else there are now cartridges (Space Harrier or AtariBlast!). It would also be enough for me if someone would split this demo into two parts. Quote Link to comment Share on other sites More sharing options...
leech Posted November 30, 2022 Share Posted November 30, 2022 21 hours ago, tmp said: i don't know, i don't plan features, features happen This sounds like so many other projects / products! Quote Link to comment Share on other sites More sharing options...
MiCV2 Posted December 1, 2022 Share Posted December 1, 2022 The demo will probably be split into two parts soon.. 🙂 3 Quote Link to comment Share on other sites More sharing options...
