BoatofCar Posted January 22, 2019 Share Posted January 22, 2019 I'm feeling frustrated with the lack of compatibility with my MyIDE II CF cart. Am I understanding correctly that a SIO2USB solution will be more accepting of file formats, the only downside is being tethered to a PC? Quote Link to comment Share on other sites More sharing options...
Albert Posted January 22, 2019 Author Share Posted January 22, 2019 I can't personally speak for the adapter mentioned above, but this is the one which I tested extensively with SIDE2 and the XEL-CF last year: eBay Auction -- Item Number: 192369777289 s-l1600.jpg Thanks for the link. ..Al Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted January 22, 2019 Share Posted January 22, 2019 What's the advantage to running in PAL? Are there are quite a few games that only support PAL? I'd then need a proper monitor that can display PAL, something I was looking to do anyway for other reasons. Definitely need a RAM upgrade of some sort, if I'm going to stick with the 800XL (my first computer was an 800XL, so I'm a bit keen on them--I upgraded that one to 256K back in the day). And absolutely will get S-Video output one way or another. ..Al Yeah theres a bunch of games released in the UK and Europe in the late 80's and up to now that only work in PAL, it's more common the newer the games get. Loads of PAL only demos too. The 800XL was my first computer too so I have a fondness for it, the keyboard is much better than the 130XE which is why I said an 800XL and memory upgrade over the 130XE. Quote Link to comment Share on other sites More sharing options...
Swami Posted January 22, 2019 Share Posted January 22, 2019 I'm feeling frustrated with the lack of compatibility with my MyIDE II CF cart. Am I understanding correctly that a SIO2USB solution will be more accepting of file formats, the only downside is being tethered to a PC? It cannot load rom or car files, which are fairly common, but these often also have an xex version. The Ultimate Cart only loads car and xex files but there are shareware rom-to-car utilities out there. I don't know about converting rom and car to xex files, but there is a discussion here: http://atariage.com/forums/topic/165142-car-to-atr-xex/ Quote Link to comment Share on other sites More sharing options...
Swami Posted January 22, 2019 Share Posted January 22, 2019 What's the advantage to running in PAL? Are there are quite a few games that only support PAL? I'd then need a proper monitor that can display PAL, something I was looking to do anyway for other reasons. Definitely need a RAM upgrade of some sort, if I'm going to stick with the 800XL (my first computer was an 800XL, so I'm a bit keen on them--I upgraded that one to 256K back in the day). And absolutely will get S-Video output one way or another. ..Al There are a lot of PAL games out there, but there is a trick if your 1702 or PVM has vertical hold. Switch the ANTIC chip from NTSC to PAL and adjust the vertical hold to lock picture and now the PAL only games work...the trade-off is that it is slightly faster than on a PAL console/monitor and the colors may be off slightly. As mentioned earlier, LEVEL42 is working on the AntiX which allows you to have both NTSC and PAL ANTIC and switch between. Otherwise you have one 800XL with an NTSC ANTIC and another with a PAL ANTIC or a PAL 800XL with a multi-region TV. 1 Quote Link to comment Share on other sites More sharing options...
Albert Posted January 22, 2019 Author Share Posted January 22, 2019 Yeah theres a bunch of games released in the UK and Europe in the late 80's and up to now that only work in PAL, it's more common the newer the games get. Loads of PAL only demos too. The 800XL was my first computer too so I have a fondness for it, the keyboard is much better than the 130XE which is why I said an 800XL and memory upgrade over the 130XE. Yeah, I also much prefer the 800XL keyboard versus the mushy 130XE keyboards. Quote Link to comment Share on other sites More sharing options...
Albert Posted January 22, 2019 Author Share Posted January 22, 2019 There are a lot of PAL games out there, but there is a trick if your 1702 or PVM has vertical hold. Switch the ANTIC chip from NTSC to PAL and adjust the vertical hold to lock picture and now the PAL only games work...the trade-off is that it is slightly faster than on a PAL console/monitor and the colors may be off slightly. As mentioned earlier, LEVEL42 is working on the AntiX which allows you to have both NTSC and PAL ANTIC and switch between. Otherwise you have one 800XL with an NTSC ANTIC and another with a PAL ANTIC or a PAL 800XL with a multi-region TV. A switchable ANTIC would be really nice, but I'd be okay having a PAL-only 800XL. Is it possible to convert an NTSC 800XL to PAL? Obviously I'd need a PAL ANTIC, but I'm sure there are other changes. Yes, I can adjust the vertical hold on the 1702s to play PAL games (I do this when using a 2600), but I'd prefer the colors and timing to be correct. ..Al Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 22, 2019 Share Posted January 22, 2019 You need PAL ANTIC, PAL GTIA, PAL master crystal, PAL colourburst crystal and associated circuitry. Quote Link to comment Share on other sites More sharing options...
Albert Posted January 22, 2019 Author Share Posted January 22, 2019 You need PAL ANTIC, PAL GTIA, PAL master crystal, PAL colourburst crystal and associated circuitry. Well, that sounds like it would be easier to just get a PAL 800XL. 3 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 22, 2019 Share Posted January 22, 2019 Possibly so. I have an NTSC machine coming here shortly for a PAL conversion, nevertheless. Fortunately I have several dead PAL donor boards with most of the required parts. I'll probably live-stream it. Quote Link to comment Share on other sites More sharing options...
Atari8guy Posted January 22, 2019 Share Posted January 22, 2019 My solution was one of each with a JVC Broadcast monitor I got for 20 bucks that has a fancy "PAL/NTSC" button. Best 20 bucks I've spent on my Atari hobby. 2 Quote Link to comment Share on other sites More sharing options...
Swami Posted January 22, 2019 Share Posted January 22, 2019 Well, that sounds like it would be easier to just get a PAL 800XL. Possibly so. I have an NTSC machine coming here shortly for a PAL conversion, nevertheless. Fortunately I have several dead PAL donor boards with most of the required parts. I'll probably live-stream it. It has made me wonder why; Unless it's that importing a good 800XL of opposite NTSC/PAL standard or such plus a power supply for your locale is more expensive than converting a local 800XL, or you already own five and don't mind sacrificing one. Still, seems like it would be hard to come out much ahead or behind either way and just importing an 800XL of the opposite standard to have one of each would be simpler. I found buying a UK PAL 800XL is about 50% more than a U.S. NTSC 800XL. Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted January 22, 2019 Share Posted January 22, 2019 The only gotcha with my suggested setup (PAL 800XL, Memory Upgrade, S-Video Upgrade, Ultimate Cart, optional Stereo upgrade) is the few games that are ATR only (the Ultimate will play CAR and XEX games, not ATR). You have a SiDE2 so you can load those from that, but it is an inconvenience, Alternate Reality is one of those ATR only games. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 22, 2019 Share Posted January 22, 2019 It has made me wonder why; Unless it's that importing a good 800XL of opposite NTSC/PAL standard or such plus a power supply for your locale is more expensive than converting a local 800XL, or you already own five and don't mind sacrificing one. Still, seems like it would be hard to come out much ahead or behind either way. It's not for me. I guess someone in the UK got saddled with an NTSC 800XL and would rather pay for a few parts and an hour's work than go looking for another Atari. Quote Link to comment Share on other sites More sharing options...
shoestring Posted January 22, 2019 Share Posted January 22, 2019 (edited) I'm using a Sony PVM9041QM which can handle both PAL / NTSC and has vhold adjustment on the back, so that's always an option too if you can get one. Here is a really good review of one. Edited January 22, 2019 by shoestring 1 Quote Link to comment Share on other sites More sharing options...
Albert Posted January 22, 2019 Author Share Posted January 22, 2019 I'm using a Sony PVM9041QM which can handle both PAL / NTSC and has vhold adjustment on the back, so that's always an option too if you can get one. Yes, I've wanted to get a Sony PVM that supports PAL/NTSC for a while.. Haven't yet put in the effort to watch for them on eBay, but I need to do so. ..Al Quote Link to comment Share on other sites More sharing options...
Swami Posted January 22, 2019 Share Posted January 22, 2019 I'm a big fan of S-Video, so I'd definitely like to have that as an option, both for the televisions and the Commodore 1702s. Composite is certainly better than RF, but S-Video is nicer still. An SIO2USB and/or SIO2SD would be nice.. I don't mind using a cart solution (which I expect is fastest), but being able to connect to the computer would be nice, rather than having to futz with an SD or CF card every time you want to load new software that's not already on the card. ..Al Just a stock 800XL at the moment. What are the advantages to upgrading? I assume with SIO2PC I would only be able to use it with Windows? That would be more of a pain for me, since I predominantly use Macs. I have some PCs, as well as VMs that run Windows, but that's outside my normal work flow. Thanks, ..Al The Toshiba Flashair 3 WiFi SD card is Mac compatible. There is apparently an app you download for your Mac. I'm guessing it would work with the SDrive Max, then. As far as SIO2PC for Mac, there was something as late as 2015 called SIO2Sx that was a Mac version of the SIO2PC software, but the registration site seems down, but you might be able to contact the guy who hosts the site. I can't comment on how good it is vs SIO2PC or SDrive-Max, for instance, if it can do ATX and XEX like the full registered AtariMax SIO2PC software (APE) can. http://www.atarimac.com/sio2osx.php http://atariage.com/forums/topic/237530-sio2pc-program-for-powerpc-macs/ 1 Quote Link to comment Share on other sites More sharing options...
Magic Knight Posted January 22, 2019 Share Posted January 22, 2019 That would be easy enough if I could get one of those boards. I'd probably install an S-Video jack, though...Al PM Sent! 1 Quote Link to comment Share on other sites More sharing options...
Swami Posted January 22, 2019 Share Posted January 22, 2019 Yes, I've wanted to get a Sony PVM that supports PAL/NTSC for a while.. Haven't yet put in the effort to watch for them on eBay, but I need to do so. ..Al I would probably have bought one, but it seems to be living on the edge to pay $500 for a 35 year old CRT that could go any day. Quote Link to comment Share on other sites More sharing options...
Albert Posted January 22, 2019 Author Share Posted January 22, 2019 I would probably have bought one, but it seems to be living on the edge to pay $500 for a 35 year old CRT that could go any day. Damn, is that what they're going for now? ..Al Quote Link to comment Share on other sites More sharing options...
Albert Posted January 22, 2019 Author Share Posted January 22, 2019 The Toshiba Flashair 3 WiFi SD card is Mac compatible. There is apparently an app you download for your Mac. I'm guessing it would work with the SDrive Max, then. As far as SIO2PC for Mac, there was something as late as 2015 called SIO2Sx that was a Mac version of the SIO2PC software, but the registration site seems down, but you might be able to contact the guy who hosts the site. I can't comment on how good it is vs SIO2PC or SDrive-Max, for instance, if it can do ATX and XEX like the full registered AtariMax SIO2PC software (APE) can. http://www.atarimac.com/sio2osx.php http://atariage.com/forums/topic/237530-sio2pc-program-for-powerpc-macs/ Thanks for this information, much appreciated. ..Al Quote Link to comment Share on other sites More sharing options...
Swami Posted January 22, 2019 Share Posted January 22, 2019 Damn, is that what they're going for now? ..Al For 19 inch and up. I've never cared for the small monitors. I'd say 90% of the ones on eBay with a Q near the end of the model number are 8 inches. Quote Link to comment Share on other sites More sharing options...
Nebulon Posted January 22, 2019 Share Posted January 22, 2019 The main set up that I use is: - an Atari 800XL - 1084 monitor / Magnavox 8CM515 - AtariMax cartridges - SEGA Genesis controller I'm really happy with the way this configuration works. Quote Link to comment Share on other sites More sharing options...
shoestring Posted January 22, 2019 Share Posted January 22, 2019 For 19 inch and up. I've never cared for the small monitors. I'd say 90% of the ones on eBay with a Q near the end of the model number are 8 inches. Yes the larger ones are too damn expensive. This one is 9” which still isn’t too bad. Quote Link to comment Share on other sites More sharing options...
Albert Posted January 22, 2019 Author Share Posted January 22, 2019 Yes the larger ones are too damn expensive. This one is 9” which still isn’t too bad. Yeah, I've always been eyeing the smaller ones, but a larger one would be nice as well. Mainly I've wanted one to test PAL games on a few different systems (2600, 7800, Jaguar), but I see that it would be useful to play PAL demos and games for the 8-bit that do not exist in NTSC form. So I'll have to have a look around. ..Al Quote Link to comment Share on other sites More sharing options...
