Penult RPG (Atari 2600)
Karl G
"Penult" is my RPG for the Atari 2600, heavily inspired by the early games in the Ultima series, especially Ultima III: Exodus. The premise and gameplay are explained in the attached manuals. The game requires one joystick. If you wish to save your game progress, then you will need an AtariVox or SaveKey for the second joystick port. If you are playing in Stella, the emulator should detect the AtariVox/SaveKey code, and emulate one of these devices automatically, saving your progress.
World map without spoilers:
Penult limited demo 8/19/2022:
penultdemo-NTSC-20.bin
penultdemo-PAL60-20.bin
Draft Penult Manuals:
The Queen's Missive (Penult Manual).pdf
Otherworldly Information (Penult Technical Manual).pdf
penult_48.thumb.png.9c594f3cc25143137f6c25fa0cd3eec1.png penult_49.thumb.png.d3de08a84bdffef916340adca2d848ca.png penult_52.thumb.png.23bb447eca0f14f15428eab6e77396bd.png penult_51.thumb.png.13d41b6bcacab1d3196f4d5f29ca2289.png penult_21.thumb.png.a5a11064c464fdcd53b46e3e08ce97d5.png
New demo 8/19/2022:
I uploaded a new public demo of the game. I've been reluctant to release a public demo of the game with my custom maps, as I did not want too much of the game spoiled prior to release. This demo contains a reduced world map with just the starting city of Arcadia, Queen Avaline's castle, and surrounding lands, as well as one dungeon. You can go up in level to level 6, and earn gold to upgrade equipment.
This version includes the ability to save your game if you have an AtariVox or SaveKey attached to your second controller port (or that option enabled in Stella). The game saves when you save at  your  home in Arcadia, and automatically when the following game events occur: character creation, going up a level, dying (sorry), buying equipment other than food, and learning a new spell (if you figure out how!).
This demo also has two display modes, selectable with the Color/B&W switch: Color includes an "accent color" in certain parts of the game, and B&W does not, but shows a more "solid" display. On CRT displays, I've found that the B&W display mode has much less visible flicker. On modern TVs, it can go either way as to which looks better.
Hopefully this limited demo will give people a good idea as to the look and feel of gameplay, as well as allowing them to determine how well it works on their own consoles.
The attached ROM is 128K (DFSC format), and may be played via Stella, or on hardware via a Harmony Encore or an Unocart/PlusCart with the latest firmware for each. It will not work with Javatari, or the Atari Flashback Portable. It probably will work on the Retron 77 with the latest community software update, but this is untested.
Feedback will be greatly appreciated!
  • Like 34
My next task is to find a cycle/memory efficient way to implement vision fields. Specifically, only tiles that should be visible to the hero are shown. Things like mountains, heavy forest, walls, etc. block vision. Here's a comparison of my current engine vs. Ultima 3 (DOS with EGA upgrade):
Edit: I deleted the DOS screenshot, since it keeps getting pulled in as a thumbnail image for this topic, making it seem like that's a screenshot of Penult.
Nice! You’ve certainly nailed the look of Ultima III (a personal favorite RPG of mine from back in the day). Excited to see this progress.
As for the character not being centered.. it would look better that way, but it’s not a game killer as is. I assume you aren’t planning a right side info/panel - which would shrink the play field and center the character?
Sent from my Keyboard Component using Jack's Conversational Intelli-talk cassette
One thing in particular I am wondering is if having the hero not be quite centered horizontally is going to bother people. It is 12 tiles wide, so there's no way to center him without reducing that to 11. I can certainly do that, but I wasn't sure if it would be better to have him centered, or have a bigger window.
If you switch to 11 while still drawing 12 you could then do smooth scrolling of the world. To accomplish that give the playfield priority and hide the extra pixels behind it.
Check this video at 37:00 to see BOOM! which does this in the left-right direction. You'd implement smooth scrolling up/down by adjusting how you enter your kernel.
Cool idea, but I don't think that would work for my kernel. I am using a blue asymmetric playfield to add a splash of color by making the water tiles (and boat background) blue. The tile-based movement is at least no worse than the older Ultimas in that regard, though. :)
Edit: Perhaps I could do the color change right before the last tile, but it seems unlikely that I could do both a color change and a playfield priority change in time and not too soon for one of those.
That's pretty darned awesome!
One question, though -- when I run it in Stella, holding the joystick in a direction doesn't make your character keep moving in that direction. You have to keep nudging the stick in the direction you want to go. Is that what you intended?
Wow, this plays so well. I LOVED the Ultima series and played them extensively on my C64 so you can imagine how happy I was to see this posted. I've been waiting for an Ultima-like tile based 2600 RPG for so long, especially after seeing the now-abandoned Homestar Runner WIP game.
Looking forward to showing this off on an upcoming ZeroPage Homebrew episode!
Well, yes, it is intentional for the moment at least. I will eventually have it auto-repeat if it is held in the same direction.
I don't mind the hero being not in the center, because I just think of this as an awesome concept! This is I guess BUS stuffing, really cool to see! :)
You will add some text under the map I guess? :)
Thanks. I'm not using bus stuffing or any other ARM assistance. It's a 96-pixel display (similar to RoboMechanik), but also adding in the playfield for a bit of color for the water tiles. There will be two lines of text: one for status information, and the other for messages.
I've updated the ROM in the first post. Still no gameplay, but it now supports dynamic field of vision. Specifically, the mountain and heavy forest tiles block vision, so things can be obscured on the map that are behind these tiles.
Screenshots don't really capture the effect well, but to see it in action, try circling around the patch of mountains to the west of the starting area and find the town within, or find the dungeon entrance to the northeast of the starting area.
If you find any bugs with the vision field support, please take a screenshot and post it! You will need to turn on phosphor in Stella (Alt-P or Command-P on a Mac) to get the whole screen.
Nope, not BUS. It's a variation of the technique used in BASIC Programming
with the addition of the playfield as an accent color, like seen in Homestar Runner RPG
Using BUS lets you colorize each tile, as seen in my RPG demo.
attachicon.gifHomestar Runner Demo #2 (2004-03-29).png attachicon.gifHomestar Runner Demo #2 (2004-03-29)_1.png
Thank you for the info!
Both p0 and p1 is used in basic programming and homestar runner for the tiles?
