+atari2600land Posted August 25, 2019 Share Posted August 25, 2019 I get this: 30 used 8-bit variables of 202 available 1 used 16-bit variables of 8000 available Compilation finished I highly doubt I have 8,000 available 16-bit numbers. Plus, if I try to print that number, it shows up as 65,535. Why? Quote Link to comment Share on other sites More sharing options...
intvnut Posted August 25, 2019 Share Posted August 25, 2019 If you compile with the --jlp or --cc3 flag, you'll get 8000 16-bit words. But, if you're not running with a recent version of jzIntv, and you compiled with --jlp, then you also need to run jzIntv with the --jlp flag. Recent versions of jzIntv should pick this up from the CFG file (if you assemble to BIN+CFG) or ROM metadata if you assemble to ROM format. For ROM metadata, though, you also need to use a version of AS1600 that comes with recent jzIntv. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted August 25, 2019 Author Share Posted August 25, 2019 OK, if I can have 8,000 16-bit numbers, why does my number show up as 65,535? Quote Link to comment Share on other sites More sharing options...
+Lathe26 Posted August 25, 2019 Share Posted August 25, 2019 12 minutes ago, atari2600land said: OK, if I can have 8,000 16-bit numbers, why does my number show up as 65,535? When you implement what JZ said, jzintv emulates 8K words of extra RAM being supporting in the emulated cartridge. Without these (or only some of them), the extra RAM is absent and your code tries to read where the RAM should have been but is missing, which results in reading 65535 (or 0xFFFF in hex) because this is what the real hardware would do. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted August 26, 2019 Share Posted August 26, 2019 Or maybe you are using an old version of IntyBASIC that had a bug where it doesn't initialized the JLP memory. If you aren't going to use JLP memory then just make sure you don't use the --cc3 flag or --jlp flag when running IntyBASIC. Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted August 26, 2019 Author Share Posted August 26, 2019 How odd. When I use a different version of jzINTV, the problem goes away. Which is really odd because they both say they're version 1.0. Quote Link to comment Share on other sites More sharing options...
mr_me Posted August 26, 2019 Share Posted August 26, 2019 (edited) Jzintv has been at version 1.0 beta for years and years and years. I don't know if there is a way to find the revision without a correct file date or some sort of file hash check. If not using external ram, shouldn't there be 72 locations of 16-bit RAM available. Edited August 26, 2019 by mr_me Quote Link to comment Share on other sites More sharing options...
intvnut Posted August 29, 2019 Share Posted August 29, 2019 Right now, it's best to look at the SVN Revision reported by jzIntv: $ jzintv jzIntv v1.0 SVN Revision 1878 <--- this part right here ... Technically, jzIntv is not yet at 1.0 final. It's asymptotically approaching that. I'd hoped to have the official 1.0 release by the end of last year, but never got there. My recommendation is to always run the latest jzIntv. That's what I do. Or, if anything: "If you see an issue, make sure you're running the latest jzIntv." Also: I strongly recommend folks learn how to use the PATH variable so you only need one copy of jzIntv installed. Just sayin'. ? I should push out a new release. I've been so swamped and burned out, I just haven't gotten around to doing so. There's some minor enhancements in there, some minor bug fixes, etc. Quote Link to comment Share on other sites More sharing options...
intvnut Posted August 29, 2019 Share Posted August 29, 2019 On 8/26/2019 at 4:03 AM, atari2600land said: How odd. When I use a different version of jzINTV, the problem goes away. Which is really odd because they both say they're version 1.0. Does the problem go away with that version of jzIntv if you use the --jlp flag when launching with jzIntv? If not, then that's a really old version of jzIntv and you should just delete it. I only keep one copy of jzIntv "installed" on my system. I set up the PATH variable to point to it. Once you set up your PATH variable to include jzintv/bin/, you can invoke jzintv, as1600, etc. from anywhere when working at the command line. Quote Link to comment Share on other sites More sharing options...
intvnut Posted August 29, 2019 Share Posted August 29, 2019 Side note: I'm "following" this thread, but I haven't seen any email notifications. Have any of you had issues with email notifications? Quote Link to comment Share on other sites More sharing options...
mr_me Posted August 29, 2019 Share Posted August 29, 2019 2 hours ago, intvnut said: Side note: I'm "following" this thread, but I haven't seen any email notifications. Have any of you had issues with email notifications? In the settings of the new system, the email notification toggle for "New content for things I follow" might be off by default. There's a similar setting for "Someone comments on something I follow". Not sure of the difference so I turned them all on. Quote Link to comment Share on other sites More sharing options...
