Quiver Posted January 28, 2020 Share Posted January 28, 2020 11 hours ago, Curt Vendel said: I was actually having this very discussion with Thom... having something akina to a Fujinet version of Google, but yes, like Gopher for finding and going to various servers. We'd have to establish a FujiDNS type server system and have a Foogle type search engine of sorts... It would DEFINITELTY be great to have email, chat/IM which should'n't be an issue, we all had those going back to the Compuserve and even into the AOL days, so those don't require any graphics and as for webpages and such, ATASCII could do the trick... This seems like a lot of reinventing the wheel. Gopher still exists, has an official RFC. If we need to denote a text file as being ATASCII we could do so by using the '{' character for an item type designation. This would appear as a spade character to the Atari. I'm just trying to figure out why a seperate DNS would be needed. Isn't the current one doing the job? 1 Quote Link to comment Share on other sites More sharing options...
+mytek Posted January 29, 2020 Share Posted January 29, 2020 Since people are talking about accessing the internet via FujiNet using Gopher, I did a little research since I hadn't a clue about what Gopher was. Wikipedia Gopher (protocol) When Gopher Ruled the Internet The Overbite Project (adding Gopher to present day browsers) I installed OverbiteWX in my Linux box for Firefox from the Add-Ons page, since it appeared to be the easiest and safest way for me to experience Gopher. And then I went to this URL... https://gopher.floodgap.com/gopher/gw Where I saw the following menu (only a portion of the page is being shown)... I then proceeded to click on some of the links, and navigate the subsequent pages which all had a similar look and feel. Yes I can see how this would definitely work for the limited graphics abilities of our A8 machines. Be even nicer if an ST mouse were supported for selecting and clicking on links from an Atari version of a Gopher browser. 3 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted January 29, 2020 Author Share Posted January 29, 2020 (edited) Somehow my reply to this got lost, rewriting: * I abhor NIH, and reinventing wheels, this is why I chose TNFS for file storage. * Yes, Gopher is a good idea to pursue. * DNS works, and works well, and we have the ability to leverage mDNS to both advertise and consume local network services. * I am working through the ability to deal with consuming and producing links to different things on the internet that may be potentially long or unweildy to type. If anyone wants to try working through a way to deal with this, it would be of tremendous benefit to everyone who uses #FujiNet. -Thom Edited January 29, 2020 by tschak909 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted January 30, 2020 Author Share Posted January 30, 2020 The N: device has had a major rewrite, and is starting to breathe again! This device will allow TCP and HTTP communication at the operating system level. The prototype is written in C, will be ported to assembler when feature complete. 7 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted January 30, 2020 Author Share Posted January 30, 2020 #Atari8bit #FujiNet here is an example of what can be returned via the STATUS command to the N: device, given different AUX1 values. This is ultimately in the esp32/tests/tcp test, and is documented, here: https://github.com/FujiNetWIFI/atariwifi/wiki/CIO-Commands-for-N-Device Of typical note, this means that devicespecs opened via the N: device will have the following format: Nx:<TCP|HTTP>:HOST:PORT for client connections, and: Nx:<TCP|HTTP>:PORT for listening connections, when OPEN's AUX1=1. Of particular note, the firmware keeps track seperately of client connections, of which up to 8 can be done, so, N1: to N8: and up to 8 possible server listening ports, also N1: to N8: This means that the meaning is overloaded, and therefore if you CLOSE one of the IOCBs, that only closes the client connection, potentially freeing the listening socket for further use. To close a listening socket, you must issue an UNLISTEN command, e.g. in BASIC: XIO 117,#1,0,0,"N:" This means, if you have a socket waiting, you can ACCEPT it on any client IOCB, e.g. OPEN #2,12,0,"N2:":REM PREPARE FOR ACCEPTED SOCKET XIO 97,#1,0,0,"N2:":REM ACCEPT SOCKET Do your socket I/O: PRINT #1;"HELLO FROM YOUR ATARI!" And close the socket. CLOSE #1 When you're done serving, you can unlisten, as I typed above. 6 Quote Link to comment Share on other sites More sharing options...
goldy/gmg aka lopez453 Posted January 31, 2020 Share Posted January 31, 2020 On 1/27/2020 at 11:22 PM, tschak909 said: meh, just make a way to send that link efficiently to the fujinet. something worth researching. -Thom what about 8 virtual files on the fujinet that would contain full url so I write the long url to "U:URL1" file and then can use the URL1 in all functions, D and N: devices... so usecase: put "http://www.verylong.com/address/foo/foo/bar/secret.bas" as content of file U:URL1 LOAD "N:URL1" URL1 can be optionally just part of url if we will be able to append to it, something like: LOAD "N:URL1/program.bas" so normally: "LOAD: N:http://pigwa.net/atari/8bit/demos/hedgehog.com" will be be just LOAD "N:URL1/hedgehog.com" ideally if we could use own shortcut url names like "LOAD N:pigwademos/hedgehog.com" 3 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted January 31, 2020 Author Share Posted January 31, 2020 5 hours ago, goldy/gmg aka lopez453 said: what about 8 virtual files on the fujinet that would contain full url so I write the long url to "U:URL1" file and then can use the URL1 in all functions, D and N: devices... so usecase: put "http://www.verylong.com/address/foo/foo/bar/secret.bas" as content of file U:URL1 LOAD "N:URL1" URL1 can be optionally just part of url if we will be able to append to it, something like: LOAD "N:URL1/program.bas" so normally: "LOAD: N:http://pigwa.net/atari/8bit/demos/hedgehog.com" will be be just LOAD "N:URL1/hedgehog.com" ideally if we could use own shortcut url names like "LOAD N:pigwademos/hedgehog.com" Yup, this was what I essentially implemented for Set BASE URL command, which is implemented in the UCD.COM command (see esp32/tests/http-fetch) But I am wondering if we can leverage integration with other devices in a cleaner way to augment this, such as what SIO2BT is doing with being able to click on a link on AtariAge and have it mount on the SIO2BT.. something similar. So many things to explore. p.s. if anyone wants to see how I implemented ucd.com: /** * ucd - Set the base URL for N: * * Author: Thomas Cherryhomes * <thom.cherryhomes@gmail.com> * * Licensed under GPL v3, see * LICENSE for details. */ #include <atari.h> #include <string.h> #include <stdlib.h> #include <peekpoke.h> #include "sio.h" #include "conio.h" #include "err.h" unsigned char url[80]; void set_base_url(void) { OS.dcb.ddevic=0x70; OS.dcb.dunit=1; OS.dcb.dcomnd=0xE3; // Set Base URL OS.dcb.dstats=0x80; OS.dcb.dbuf=&url; OS.dcb.dtimlo=0x0f; OS.dcb.dbyt=sizeof(url); OS.dcb.daux=0; siov(); if (OS.dcb.dstats!=1) { err_sio(); exit(OS.dcb.dstats); } } int main(int argc, char* argv[]) { unsigned char i; OS.lmargn=2; if (_is_cmdline_dos() && argc>1) strcpy(url,argv[1]); else { // DOS 2.0 print("\x9b"); print("ENTER BASE URL OR \xA0\xD2\xC5\xD4\xD5\xD2\xCE\xA0 TO CLEAR?\x9b"); get_line(url,sizeof(url)); // remove EOL for (i=0;i<sizeof(url);i++) if (url[i]==0x9b) url[i]=0x00; } set_base_url(); print("N: = "); print(url); print("\x9b"); return(0); } The print and get_line are simple calls to CIO. is_cmdline_dos is an excellent routine that CC65 provides to detect DOS types. Does anyone have questions as to how I am implementing these things? -Thom 1 Quote Link to comment Share on other sites More sharing options...
manterola Posted January 31, 2020 Share Posted January 31, 2020 (edited) I was thinking that maybe we just need an implementation of the TNFS server for android (and iphone?). That way we can keep downloading stuff from atariage.com and then access those in the moment using the tnfs client you already developed. Now, regarding the idea of webserver "address book", I think it is seems simple and great. Edited January 31, 2020 by manterola 2 Quote Link to comment Share on other sites More sharing options...
goldy/gmg aka lopez453 Posted January 31, 2020 Share Posted January 31, 2020 (edited) 2 hours ago, tschak909 said: being able to click on a link on AtariAge and have it mount on the SIO2BT.. something similar. If we have mDNS and simple webserver on fujinet, I could click hyperlink on Atariage from the PC browser that is in the same local network as fujinet, and the link like this should work: <a href="http://myfujinet.local/set_base_url?device=1&url=http://atariage.com/folder/disk1.atr">Load to my fujinet</a> Without any special software on the PC from unmodified browser. If you want to use more Fujinet devices, of course only the first one with default name will have this "comfort". Or be able to copy/paste the url via simple web interface. Edited January 31, 2020 by goldy/gmg aka lopez453 Quote Link to comment Share on other sites More sharing options...
TheMontezuma Posted January 31, 2020 Share Posted January 31, 2020 3 hours ago, manterola said: I was thinking that maybe we just need an implementation of the TNFS server for android (and iphone?). That way we can keep downloading stuff from atariage.com and then access those in the moment using the tnfs client you already developed. Now, regarding the idea of webserver "address book", I think it is seems simple and great. I had exactly the same idea TNFS server C source code is available, so maybe someone could port it to Android. Quote Link to comment Share on other sites More sharing options...
TheMontezuma Posted January 31, 2020 Share Posted January 31, 2020 5 hours ago, tschak909 said: But I am wondering if we can leverage integration with other devices in a cleaner way to augment this, such as what SIO2BT is doing with being able to click on a link on AtariAge and have it mount on the SIO2BT.. something similar. SIO2BT doesn't actually work this way. You can't directly mount links. First you have to download a file, then you can mount it Quote Link to comment Share on other sites More sharing options...
tschak909 Posted January 31, 2020 Author Share Posted January 31, 2020 #FujiNet #deepdive In this video, I talk a bit about how the Central I/O system on the #Atari 8-bit system works, and how I have implemented a prototype of the N: device handler, that interfaces #FujiNet to the CIO in C. Should you wish to follow along: https://github.com/FujiNetWIFI/atariwifi/tree/master/esp32/tests/tcp Please watch and comment, especially if I am wrong. -Thom 4 Quote Link to comment Share on other sites More sharing options...
manterola Posted January 31, 2020 Share Posted January 31, 2020 (edited) 41 minutes ago, TheMontezuma said: I had exactly the same idea TNFS server C source code is available, so maybe someone could port it to Android. The Bluetooth option is a very decent substitute to the tnfs server for android. However, the Bluetooth emulation never worked for me. Not using your short program for the esp32, nor using the latest firmware and pressing Boot. It it detected by sio2bt app in android, I can do the pairing and the connection. So everything looks great up to that point: it shows connected and I selected the images. But then nothing happens if I try to boot an image or read a directory (only Atari farts). Not sure what is wrong since your small program it is quite simple. Maybe there is an option I did not selected in the Arduino IDE... BTW the same phone with sio2bt app works perfectly with the original SIO2BT modules. Edited January 31, 2020 by manterola Quote Link to comment Share on other sites More sharing options...
TheMontezuma Posted February 1, 2020 Share Posted February 1, 2020 (edited) 8 hours ago, manterola said: However, the Bluetooth emulation never worked for me. Not using your short program for the esp32, nor using the latest firmware and pressing Boot. It it detected by sio2bt app in android, I can do the pairing and the connection. So everything looks great up to that point: it shows connected and I selected the images. But then nothing happens if I try to boot an image or read a directory (only Atari farts). Not sure what is wrong since your small program it is quite simple. Maybe there is an option I did not selected in the Arduino IDE... BTW the same phone with sio2bt app works perfectly with the original SIO2BT modules. You can download an app "Bluetooth Terminal" to see if you get any data from Atari. And yes, it could be related to Arduino, it's configuration or ESP32 support. Perhaps software update would help. Edited February 1, 2020 by TheMontezuma Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 1, 2020 Author Share Posted February 1, 2020 @everyone anyone who wants to test esp32/tests/tcp, please let me know. There is a tcp.atr disk on irata.online, which can be used with it, and you can see how to write TCP programs. The Tincans program uses TCP port 2000, so you need to forward it to your fujinet, if you want to test with someone over the internet. 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 2, 2020 Author Share Posted February 2, 2020 #FujiNet showing the TINCANS chat program written in BASIC. Uses a standard TCP socket, as can be seen from the PC connecting to the #atari8bit #Atari. 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 2, 2020 Author Share Posted February 2, 2020 The source code for TINCANS.BAS 0 DIM H$(80),D$(80),MSG$(254) 100 REM TINCANS - QUICK CHAT PROGRAM 110 ? CHR$(125) 120 PRINT " TINCANS CHAT PROGRAM " 130 PRINT 140 REM GET ADDRESSES 150 XIO 13,#1,1,0,"N:":REM GET EXT ADDRE SS 160 PRINT "EXT ADDRESS: ";PEEK(746);"."; PEEK(747);".";PEEK(748);".";PEEK(749) 161 XIO 13,#1,2,0,"N:":REM GET INT ADDRE SS 170 PRINT "INT ADDRESS: ";PEEK(746);"."; PEEK(747);".";PEEK(748);".";PEEK(749) 180 PRINT 200 REM GET HOSTNAME / LISTEN 210 PRINT "ENTER HOSTNAME OR RETURN FOR LISTEN" 220 PRINT "> "; 230 INPUT #16,H$ 240 IF H$="" THEN 300 250 REM CONNECT TO HOST 260 D$="N:TCP:":D$(7)=H$:D$(LEN(D$))=":2 000" 270 OPEN #1,12,0,D$ 280 GOTO 400 300 REM LISTEN FOR CONNECTION 310 OPEN #1,12,1,"N:TCP:2000":REM LISTEN FOR CONNECTIONS TO PORT 2000 320 PRINT :PRINT "WAITING FOR CONNECTION ..."; 330 STATUS #1,A 331 FOR X=1 TO 100:NEXT X:REM SLIGHT DEL AY 340 IF PEEK(747)=0 THEN 330 350 XIO 16,#1,12,0,"N:":REM ACCEPT CONNE CTION 360 PRINT :PRINT "CONNECTION SUCCESSFUL. ":PRINT 370 REM FALL THROUGH... 400 PRINT "CHAT ACTIVE. TYPE BYE TO END. ":PRINT 405 PRINT :PRINT " YOU: "; 410 POKE 764,255 420 IF PEEK(764)<>255 THEN 550 430 STATUS #1,A 440 IF PEEK(746)>0 THEN 500 450 FOR X=1 TO 50:NEXT X:REM SLIGHT DELA Y. 460 GOTO 420 500 REM RECEIVED A MESSAGE FROM THEM 510 INPUT #1,MSG$ 520 PRINT :PRINT "??? THEM: ";MSG$:PRIN T 521 IF MSG$="BYE " THEN 600 530 GOTO 405 550 REM TAPPED A KEY FOR INPUT 560 INPUT #16,MSG$ 570 PRINT #1;MSG$ 580 IF MSG$="BYE" THEN 600 590 GOTO 405 600 REM CLOSE EVERYTHING 610 XIO 17,#1,0,0,"N:":REM UNLISTEN 620 CLOSE #1 630 PRINT :PRINT "CONNECTION CLOSED." 650 END 2 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 2, 2020 Author Share Posted February 2, 2020 #FujiNet with the simplest possible terminal program for the N: device. Slow? Yes, but it works. #Atari #Atari8bit 4 Quote Link to comment Share on other sites More sharing options...
damosan Posted February 3, 2020 Share Posted February 3, 2020 Relocatable code on the 8bit. A question... I'm working on a code relocator. It's pretty straight forward in that it does the following: Moves code from a particular memory region to MEMLO. Remaps a function pointer table at MEMLO for three "public" functions. The relocator scans for documented 3-byte instructions modifying the target to point to the new memory region - BUT ONLY if the target was in the initial high memory range. Updates MEMLO to the first byte past the copied code. It appears to be working. When I do a FRE(0) with DOS loaded I show 32,274 bytes. After the autorun.sys executes I show 32,224 bytes with FRE(0) - the three public assembly routines are very small obviously. The C code starts at address 0x4000 (arbitrary) linking in an assembler file that exports beginning/end of code symbols so the C code knows how many bytes are to be copied. The Question: When looking through the (documented) 6502 instruction list it didn't seem like I'd have to do anything to deal with the zeropage instructions as well as the various single byte instructions. Am I missing something here? I probably should add some of the undocumented 3 byte instructions as well... 2 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 3, 2020 Author Share Posted February 3, 2020 Thanks so much, @damosan! meanwhile, I've managed to debug the N: TCP device well enough to be able to log onto Level 29 BBS This is a telnet program written in approximately 10 lines of BASIC. The irony is, that I will be able to add full TELNET processing, on the ESP side, without affecting the BASIC code, whatsoever. This is critically important, as it means that people will be able to easily write networked applications, even in BASIC. The terminal program is TERM.BAS on the tcp.atr disk in the esp32/tests/tcp/data if anyone wants to take a look. Special thanks to FozzTexx. -Thom 7 Quote Link to comment Share on other sites More sharing options...
StickJock Posted February 3, 2020 Share Posted February 3, 2020 7 hours ago, damosan said: Relocatable code on the 8bit. A question... I'm working on a code relocator. It's pretty straight forward in that it does the following: The relocator scans for documented 3-byte instructions modifying the target to point to the new memory region - BUT ONLY if the target was in the initial high memory range. Make sure that any indirect JMPs (opcode $6C) don't end up with the low byte of the address as $FF (JMP $xxFF). This will trigger a known 6502 bug. If you find that the relocated code does this, maybe increment your starting address (wasting a byte) and run your relocator again? Repeat until you get a good conversion. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted February 3, 2020 Share Posted February 3, 2020 9 hours ago, damosan said: I'm working on a code relocator. It's pretty straight forward in that it does the following: You might have a look at MKRELO which is part of the ABC Compiler. You compile your program twice, each time for a different target address. MKRELO then compares both files and creates a relocatable file. I never tried it myself, but from the description in the manual this sounds completely independent from ABC itself. Manual at MrFish's website: Chapter 5.2 Generating relocatable code 1 Quote Link to comment Share on other sites More sharing options...
damosan Posted February 3, 2020 Share Posted February 3, 2020 2 hours ago, StickJock said: Make sure that any indirect JMPs (opcode $6C) don't end up with the low byte of the address as $FF (JMP $xxFF). This will trigger a known 6502 bug. If you find that the relocated code does this, maybe increment your starting address (wasting a byte) and run your relocator again? Repeat until you get a good conversion. Interesting - is that a bug in all 6502s? Is it documented anywhere? What I'll do is scan for indirect JMPs first - if I find any that would match this condition I'll shift the copied code one byte and try again. Thanks. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 3, 2020 Author Share Posted February 3, 2020 Now that the TCP routines in esp32/tests/tcp are working stably, I was able to port the #Atari8bit version of #PLATOTERM to #FujiNet's N: device, and as you see, it works quite well even for the preliminary 256 byte buffer. 9 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 4, 2020 Author Share Posted February 4, 2020 #Atari8bit #FujiNet hardware demigod @mozzwald is hard at work assembling Ice Cream Sandwiches (the ESP32 variant of #FujiNet), I AM PSYCHED! 7 Quote Link to comment Share on other sites More sharing options...
