amiman99 Posted May 3, 2020 Share Posted May 3, 2020 (edited) IT'S NOT FOR SALE AS OF NOW, MAYBE IN THE FUTURE I'm going to post this here and some other Amiga forums before it goes on Ebay. It will be cheaper here for obvious reasons. For sale Amiga 4000 with 68040 25MHz CPU, with Video Toaster 4000 board, 2.1GB Hard Drive, 3.0 ROMs and ClassicWB OS installed. Comes with A4000 books (some are yellowed), floppy disks (tested working), and Video Toaster manual (cover is stained). The CPU card has new capacitors installed. The power supply has a "newer" internals, it was swapped from a PC power supply about 15 years ago, maybe more. Below are some flaws I could find: The power button on the power supply (internally) is shorter than it should be. Power supply rod easily pops off when the case is open. The clips on one of the SIMM socket are broken, and the memory module is held by a putty. Works fine. Needs a new SIMM socket. Battery was removed before it could do a significant damage. See pictures. Missing CPU standoffs, it means the CPU card is not screw in securely to the motherboard. There is some discoloration on the front face and the keyboard. The keyboard's space bar is loose a bit, do to broken piece under the space-bar. Works fine. The floppy drive is not A4000 original, it came from an external drive, so the color is different. Works very well. There is a broken screw behind the face plate. The caddy that holds the CDROM and floppy drive is held by one screw, should be 2. (the screw was broken when I try to remove it, it was pretty tight). Joystick port is bent a little. Case has scuff marks all around, not perfect. Amiga mouse has worn off Amiga Logo. The A4000 is stable, was able to do few hour renderings in Lightwave. Play some Doom, run Shapeshifter etc. I'm not sure how much to ask, but some prices on Ebay are crazy good. Some are more than $2k. Edited October 22, 2022 by amiman99 spelling 1 Quote Link to comment Share on other sites More sharing options...
dadstoy70 Posted October 7, 2022 Share Posted October 7, 2022 Is this A4000 still available? Quote Link to comment Share on other sites More sharing options...
amiman99 Posted October 22, 2022 Author Share Posted October 22, 2022 I forgot about it. I still have it, but it's not for sale anymore. Maybe in the future. Quote Link to comment Share on other sites More sharing options...
Crazy Climber Posted October 22, 2022 Share Posted October 22, 2022 2 hours ago, amiman99 said: I forgot about it. I still have it, but it's not for sale anymore. Maybe in the future. Woah, a 2+ year necrobump asking if you still have the item...and you actually STILL HAVE THE ITEM!! Gotta admit, didn't see that coming.... I guess it does pay to ask sometimes 😃 5 Quote Link to comment Share on other sites More sharing options...
soviet conscript Posted October 22, 2022 Share Posted October 22, 2022 Quote Link to comment Share on other sites More sharing options...
Cebus Capucinis Posted October 22, 2022 Share Posted October 22, 2022 So what you're saying is necrobump again in 2 years.... ✅ 1 1 Quote Link to comment Share on other sites More sharing options...
amiman99 Posted October 23, 2022 Author Share Posted October 23, 2022 Well, no one was interested and it got pushed back. and I did not bump it, so there you go. As of now, I don't need the money, and I don't need anything retro or interesting that would warrant sale of my A4000. See you in 2 years... 1 3 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 27, 2022 Share Posted October 27, 2022 On 10/21/2022 at 11:44 PM, Crazy Climber said: Gotta admit, didn't see that coming.... I guess it does pay to ask sometimes 😃 Ugh, this just encourages more! On 10/23/2022 at 4:20 PM, amiman99 said: See you in 2 years... Quote Link to comment Share on other sites More sharing options...
