Speech syn for beige TI-99/4a
hloberg
On 8/4/2020 at 7:06 PM, wierd_w said:
Well..  I am going to reference this thread and the dialog on color picking we just dropped in it, after about another week.
I get paid biweekly, and am not the most wealthy.  I should have some disposable income to drop on filament then.
An alternative would possibly be @Mehridian Sanders , who confided that he is intending to set up a filament recycler/extruder. (he intends to buy bulk PLA pellets, and fabricate filament.)
Ok the PLA I ordered arrived... I will be test printing tonight. probably take a while. Has anyone had any luck with the door? I myself am only basically a 3D Modeller. not advanced yet.
I am holding off on releasing my updated models until I am happy with them...
They do not currently implement the door, but implementing it would not be that difficult.
I think it could be done as a "Print in place", especially if the original type design were followed. Door actuation might be a little rough at first, but I think it could work.
I have the bottom part printed in the "Desert Tan" PLA.
It feels VERY solid and good in my hands.  It should be a VERY durable part.  I had the print speed a bit too high in the initial part of the print though, so it's a bit ugly at the beveled bottom.. Been sanding it, and it sands beautifully.  The 2mm thick walls give plenty of meat to sand into to get rid of all the layering artifacts. When I have both the top and the bottom printed, I will assemble them, then sand them assembled.  That way they match.
I am going to test to see if the new hole location is right.
Edit:
New hole location fits perfectly!
(but forgot to enlarge the bay the .5mm all around, so it is way too snug with the RF shield in there. It went in, but it is super tight. I dont know if I can get it back out again.)  I think just this enlargement, and the bottom part is golden.
Edited by wierd_w
Edit:
photo?
Edit:
My gosh ... here I am ... 42 ... and still ... laughing like a 12 year old at the word " hole ".
man.. I'd better phone my parents and apologize for something...
On a lighter note, the PLA recycler/maker, has been put on hold for a bit. (like so many projects of mine) in order to learn more about 3D printing in general. I have decided to use 3D Paint to learn more. .. it's free and I already have it installed with my windows version, so far it has been easy to use and rather intuitive. I will also be trying to get my old Xbox IR sensor working for 3D scanning.
(dont make fun of my filthy workbench-- it's where I do painting, and stuff.)
@Mehridian Sanders
You really should get a proper 3D cad suite.  Then you have real sizes in mm or inches, get to model with fantastically more accurate NURBS models, etc.
I use Dassault Systemes Catia.  The educational student version works fine, but is lacking the sterolithography workbench. (I really only use it to generate .stl files, because it does a much better job than the "save as .stl" converter. The sterolithography workbench has options to set how accurate the .stl is. You can make it absurdly tiny triangle size) Others use SolidWorks (a related product, very similar, but not as powerful.)
Edited by wierd_w
The "wood" filament arrived.  Investigating the roll, I was correct- it is wood COLORED filament, not "wood mixture" filament.   Color wise, it is "Dark tan".  I will clip a section and lay it on a bit of waste material made from the "Desert Tan", and some white paper.  Give me a minute.
I find the color to be relatively complimentary, and fairly close to the "dark" accent color of the beige units.
Should I print another bottom from the "wood" color for the final product?
Edited by wierd_w
that color looks a lot like the color I painted my speech with. it wasn't an exact match but really complemented console and looked a lot better than the more yellowish beige I had previously painted the speech.
That's the same material as the base I printed (the large wast swatch that is)-- just with the flash turned on with the camera.  My upstairs is kinda low-light.
The top is approaching the end of the print cycle-- at 98%.  I have mixed some black toner powder with some UV reactive resin, and will fill the lettering in with it before sanding. That should give nice bold black letters.
Since the top portion is many solid layers, it will take some time to finish this last 2%.  I will also have to sit the resin painted text in the sun for several hours (since it has decided to be overcast today) to cure. (I have misplaced my UV lamp)
The above comparison was to illustrate the contrast between the "wood" and the "Desert Tan"
The mixture of toner powder and UV resin appears to work but the text needs to be cut deeper.
Currently the letter groove depth is insufficient, as it is starting to sand through as I sand the surface smooth.  I will revise to make the lettering depth deeper for this purpose.
Edited by wierd_w
  • Like 5
I am going to spend the next few days sanding on this thing, and getting it all pretty.
There are some pretty significant X and Y positioning issues with my printer;  I expect it is because it is a cheap chinese knockoff.  That's OK, this is intended to be a part proving exercise.  I am pretty satisfied with the models. The lettering just needs to be a little deeper now, and I should be able to release.
Still a LOT of sanding left to do; Been hitting this real hard with 80 grit to get the layer artifacts off.
Edited by wierd_w
@Mehridian Sanders
I know you are jonesing to print stuff, and I would like somebody with a printer that is worth a damn to try my models out.
To do the assembly, you will need 6 M3 brass chasis stand-offs, and 6 M3 computer case screws. (and probably a hammer to tap them into the holes before gently touching them with a (El CHEAPO!! Dont use a good one!) soldering iron to set them.
Here's the models in STP and STL formats, REV A.
Top.stp top.stl bottom.stp bottom.stl
Change log:
Move top-left board mounting hole location 1.5mm to the left (toward TI cart slot side), to match position of mating hole in speech synth board
Increase cutout area in bottom section by .5mm all around so that RF shield installs easily.
Add "baked in" support material for top section
Increase text indentation depth to 1mm for reliable black resin material back-fill before sanding operation
I printed at .1mm layer height, with 2mm thick wall, 2mm thick top and bottom, and 20% infill. Supports were disabled. (You will NEVER get them out of the screw holes if you turn them on! This is why the top has baked in support model.) Print time was a little over 3 days total for both top and bottom altogether.  Your printer might print faster/better.
Edited by wierd_w
16 hours ago, wierd_w said:
@Mehridian Sanders
Top.stp 5.16 MB · 2 downloads top.stl 722.25 kB · 2 downloads bottom.stp 197.42 kB · 2 downloads bottom.stl 104.77 kB · 2 downloads
Change log:
ok trying this out with the Wood PLA see how it turns out. Using your Settings as specified. Bottom is going to take about 12 hours 43 mins to print
If It goes well I will start up the print in the beige I picked up.
