tsom Posted January 11, 2021 Share Posted January 11, 2021 (edited) 39 minutes ago, tschak909 said: Did you modify the wpa supplicant config in the boot partition, as it says in the doc? -Thom I certainly did. and I verified it in the /etc/wpa_supplicant/wpa_supplicant.conf file after. Edited January 11, 2021 by tsom Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted January 11, 2021 Author Share Posted January 11, 2021 49 minutes ago, tsom said: While I already had my own manually built TNFS server on an RPi, I thought I'd give this a try. It seemed to work just fine, but then I noticed the Wifi was not enabled - it didn't seem to even recognize there was Wifi available. I didn't notice at first, as my Pi is connected with an ethernet cable to my network. When I went to connect to it via ssh, I was getting errors about 'rfkill' not available. rfkill: cannot open /dev/rfkill: Permission denied rfkill: cannot read /dev/rfkill: Bad file descriptor I traced it to the Wifi not recognized. Doing the 'iwconfig' command returns: pi@tnfs:/etc/network $ iwconfig eth0 no wireless extensions. lo no wireless extensions. pi@tnfs:/etc/network $ iwconfig eth0 no wireless extensions. lo no wireless extensions. I tried to look up the problem and found command to try to manually start up the wifi, but it didn't work: pi@tnfs:/boot $ sudo service wpa_supplicant stop pi@tnfs:/boot $ ps -A | grep 'wpa' pi@tnfs:/boot $ ps -A | grep wpa pi@tnfs:/boot $ sudo wpa_supplicant -iwlan0 -c/etc/wpa_supplicant/wpa_supplicant.conf Successfully initialized wpa_supplicant nl80211: 'nl80211' generic netlink not found Failed to initialize driver 'nl80211' So I gave up and went back to my configured server (but am adding AFP support). What model Raspberry pi did you use? Quote Link to comment Share on other sites More sharing options...
tsom Posted January 11, 2021 Share Posted January 11, 2021 10 minutes ago, Mr Robot said: What model Raspberry pi did you use? 3B I believe. I know Wifi works, as using my original setup, I can access it wlan0 IEEE 802.11 ESSID:"Salem" Mode:Managed Frequency:2.412 GHz Access Point: 14:22:DB:AE:33:06 Bit Rate=11 Mb/s Tx-Power=31 dBm Retry short limit:7 RTS thr:off Fragment thr:off Power Management:on Link Quality=70/70 Signal level=-35 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:1 Invalid misc:0 Missed beacon:0 eth0 no wireless extensions. lo no wireless extensions. Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted January 11, 2021 Author Share Posted January 11, 2021 OK I'll write the image to a card and try it here on a 3B... Quote Link to comment Share on other sites More sharing options...
+x=usr(1536) Posted January 11, 2021 Share Posted January 11, 2021 (edited) 2 hours ago, tsom said: 3B I believe. I know Wifi works, as using my original setup, I can access it Might want to verify if it's a 3B or 3B+ if there's any question as to which one it may be. The plus models substantially changed the wifi chipset over the 3B as well as a number of other things. FWIW, I have both 3Bs and 3B+es here if any testing needs to be done. Edited January 11, 2021 by x=usr(1536) Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted January 11, 2021 Author Share Posted January 11, 2021 I just tried it on a 3B and a 3B+, also a 2B and a 1 with USB wifi dongles in them and it worked fine in all of them. I'd try writing the card and setting up the wpa_supplicant.conf again, it's definitely something screwy at your end @tsom! 1 Quote Link to comment Share on other sites More sharing options...
tsom Posted January 11, 2021 Share Posted January 11, 2021 23 minutes ago, Mr Robot said: I just tried it on a 3B and a 3B+, also a 2B and a 1 with USB wifi dongles in them and it worked fine in all of them. I'd try writing the card and setting up the wpa_supplicant.conf again, it's definitely something screwy at your end @tsom! Ok, I'll give it a try Thanks Quote Link to comment Share on other sites More sharing options...
tsom Posted January 12, 2021 Share Posted January 12, 2021 15 hours ago, Mr Robot said: I just tried it on a 3B and a 3B+, also a 2B and a 1 with USB wifi dongles in them and it worked fine in all of them. I'd try writing the card and setting up the wpa_supplicant.conf again, it's definitely something screwy at your end @tsom! Well, I just tried re-imaging and it still does not see any WIFI. I had to use an ethernet cable to even access the Pi. Warning: the ECDSA host key for 'tnfs.local' differs from the key for the IP address '192.168.7.119' Offending key for IP in /Users/johntsombakos/.ssh/known_hosts:21 Matching host key in /Users/johntsombakos/.ssh/known_hosts:22 Are you sure you want to continue connecting (yes/no)? yes pi@tnfs.local's password: Linux tnfs 5.4.83-v7+ #1379 SMP Mon Dec 14 13:08:57 GMT 2020 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. rfkill: cannot open /dev/rfkill: Permission denied rfkill: cannot read /dev/rfkill: Bad file descriptor pi@tnfs:~ $ iwconfig eth0 no wireless extensions. lo no wireless extensions. from cat /proc/cpuinfo: Hardware : BCM2835 Revision : a02082 Serial : 00000000cec343fd Model : Raspberry Pi 3 Model B Rev 1.2 Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted January 12, 2021 Author Share Posted January 12, 2021 I've replicated that here on another Pi3... leave it with me. 2 Quote Link to comment Share on other sites More sharing options...
tsom Posted January 12, 2021 Share Posted January 12, 2021 37 minutes ago, Mr Robot said: I've replicated that here on another Pi3... leave it with me. Works for me. Seems some sort of missing driver issue, as near as I can tell(?) Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted January 12, 2021 Author Share Posted January 12, 2021 Yeah rfkill isn't running. It's almost like disable_wifi has been set in config.txt it's very odd. I have one pi it happens on. I'm rebuilding the image using that pi, I shall try it on all the others when I'm done and upload a new image to the website if it's ok everywhere. 1 Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted January 12, 2021 Author Share Posted January 12, 2021 OK I've uploaded a new version of the server image to my website. I built this using the Pi3 that didn't work with the old server image and tested it with a PI1B/2B/3B/3B+/4B/Zero/ZeroW. For the non-Wi-Fi equipped Pi's I used Edimax USB Wi-Fi adapters. I don't have any model A boards or compute modules to test with. Give that a try! Quote Link to comment Share on other sites More sharing options...
tsom Posted January 13, 2021 Share Posted January 13, 2021 14 hours ago, Mr Robot said: OK I've uploaded a new version of the server image to my website. I built this using the Pi3 that didn't work with the old server image and tested it with a PI1B/2B/3B/3B+/4B/Zero/ZeroW. For the non-Wi-Fi equipped Pi's I used Edimax USB Wi-Fi adapters. I don't have any model A boards or compute modules to test with. Give that a try! That did it! Wifi is now working! (Initially I wasn't able to see it or connect to it, so had to use the ethernet cable. Then I realized I was a dumb** and forgot to edit the wpa_supplicant.conf file! Doh! Quick edit and it's all set) Thanks! 1 Quote Link to comment Share on other sites More sharing options...
tsom Posted January 13, 2021 Share Posted January 13, 2021 (edited) Looks like there may be an issue with the Samba service. Looking into it now: pi@tnfs:/etc/samba $ sudo systemctl restart smbd Job for smbd.service failed because the control process exited with error code. See "systemctl status smbd.service" and "journalctl -xe" for details. pi@tnfs:/etc/samba $ systemctl status smbd.service ● smbd.service - Samba SMB Daemon Loaded: loaded (/lib/systemd/system/smbd.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Wed 2021-01-13 06:37:35 CST; 12s ago Docs: man:smbd(8) man:samba(7) man:smb.conf(5) Process: 648 ExecStartPre=/usr/share/samba/update-apparmor-samba-profile (code=exited, status=0/SUCCESS) Process: 649 ExecStart=/usr/sbin/smbd --foreground --no-process-group $SMBDOPTIONS (code=exited, status=203/EXEC) Main PID: 649 (code=exited, status=203/EXEC) Jan 13 06:37:35 tnfs systemd[1]: Starting Samba SMB Daemon... Jan 13 06:37:35 tnfs systemd[649]: smbd.service: Failed to execute command: Exec format error Jan 13 06:37:35 tnfs systemd[649]: smbd.service: Failed at step EXEC spawning /usr/sbin/smbd: Exec format error Jan 13 06:37:35 tnfs systemd[1]: smbd.service: Main process exited, code=exited, status=203/EXEC Jan 13 06:37:35 tnfs systemd[1]: smbd.service: Failed with result 'exit-code'. Jan 13 06:37:35 tnfs systemd[1]: Failed to start Samba SMB Daemon. There may be bigger issues here: pi@tnfs:/etc/samba $ testparm testparm: error while loading shared libraries: /lib/arm-linux-gnueabihf/libsmbconf.so.0: invalid ELF header pi@tnfs:/etc/samba $ sudo apt update Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB] Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB] Get:3 http://archive.raspberrypi.org/debian buster/main armhf Packages [351 kB] Fetched 399 kB in 2s (192 kB/s) Reading package lists... Error! E: Encountered a section with no Package: header E: Problem with MergeList /var/lib/dpkg/status E: The package lists or status file could not be parsed or opened. Edited January 13, 2021 by tsom Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted January 13, 2021 Author Share Posted January 13, 2021 hmm do a apt-get update and upgrade Quote Link to comment Share on other sites More sharing options...
tsom Posted January 13, 2021 Share Posted January 13, 2021 (edited) 30 minutes ago, Mr Robot said: hmm do a apt-get update and upgrade I did, that's where I'm getting the error above pi@tnfs:~ $ sudo apt-get update Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Reading package lists... Error! E: Encountered a section with no Package: header E: Problem with MergeList /var/lib/dpkg/status E: The package lists or status file could not be parsed or opened. pi@tnfs:~ $ I did try some solutions I found online (replacing the status file with a backup, etc. but it didn't help) I tried to update the time zone via raspi-config and it threw a boatload of errors also (this is just the end of the errors, most scrolled off) line 1083. Use of uninitialized value $value in substitution (s///) at /usr/share/perl5/Debconf/Format/822.pm line 65, <__ANONIO__> line 1084. Use of uninitialized value $value in substitution (s///) at /usr/share/perl5/Debconf/Format/822.pm line 65, <__ANONIO__> line 1085. Use of uninitialized value $value in substitution (s///) at /usr/share/perl5/Debconf/Format/822.pm line 65, <__ANONIO__> line 1086. Use of uninitialized value $value in substitution (s///) at /usr/share/perl5/Debconf/Format/822.pm line 65, <__ANONIO__> line 1087. Use of uninitialized value $value in substitution (s///) at /usr/share/perl5/Debconf/Format/822.pm line 65, <__ANONIO__> line 1088. Use of uninitialized value $item in hash element at /usr/share/perl5/Debconf/DbDriver/File.pm line 85, <__ANONIO__> chunk 1088. dpkg-query: error: parsing file '/var/lib/dpkg/status' near line 0: end of file during value of field '_ENSC_18_Mod_range_hashingENSC_20_Default_ranged_hashENSC_20_Prime_rehash_policyENSC_17_Hashtable_traitsILb1ELb0ELb1EEEE19_M_allocate_bucketsEj' (missing final newline) dpkg-query: error: parsing file '/var/lib/dpkg/status' near line 0: end of file during value of field '_ENSC_18_Mod_range_hashingENSC_20_Default_ranged_hashENSC_20_Prime_rehash_policyENSC_17_Hashtable_traitsILb1ELb0ELb1EEEE19_M_allocate_bucketsEj' (missing final newline) /usr/sbin/dpkg-reconfigure: tzdata is not installed Edited January 13, 2021 by tsom Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted January 13, 2021 Author Share Posted January 13, 2021 It looks like the pishrink.sh corrupted a few blocks in the image somehow. I'm getting the same issue here with the shrunk image but not the pre shrink image. I'll try rebuilding it later. The 16gb µSD I used is throwing read errors, it looks like I wore it out. I've ordered some more, will be here tomorrow. Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted January 15, 2021 Author Share Posted January 15, 2021 OK V1.3 of the image is now uploaded, this time there are no block errors and I checked the MD5's of the image after backing it up twice to make sure it was OK. I've added a command. If you type 'sudo tnfsupd' at a command prompt it will grab the latest code from github, compile it and replace the existing TNFSD daemon with the new version. 1 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted January 16, 2021 Share Posted January 16, 2021 OK. NOT trying to start a flame war. The version of Windows is irrelevant here. SelfImage works perfectly w/ XP32. But. The problem is the Pi boots the image fine. I can log in at the console. There is no wlan0 device. I believe this a Pi3 device. I am looking for a link to the image of TNFS server for Pi3. Thanks. Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted January 16, 2021 Author Share Posted January 16, 2021 If you downloaded the image before my last post, download it again. The SD card I was using to build the server was nearly end of life and started giving bad blocks. I got some new cards and built a new image today which I've tested on a Pi3 and a PiZeroW 1 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted January 16, 2021 Share Posted January 16, 2021 I just D/L the image again. Still no luck with WiFi. This a Pi 2 Model B Rev. 1.1. Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted January 16, 2021 Author Share Posted January 16, 2021 What USB WiFi dongle are you using? I tested with an Edimax one. Quote Link to comment Share on other sites More sharing options...
tsom Posted January 16, 2021 Share Posted January 16, 2021 16 hours ago, Mr Robot said: If you downloaded the image before my last post, download it again. The SD card I was using to build the server was nearly end of life and started giving bad blocks. I got some new cards and built a new image today which I've tested on a Pi3 and a PiZeroW Will give this a try this afternoon and report back. Quote Link to comment Share on other sites More sharing options...
tsom Posted January 16, 2021 Share Posted January 16, 2021 On 1/15/2021 at 4:16 PM, Mr Robot said: OK V1.3 of the image is now uploaded, this time there are no block errors and I checked the MD5's of the image after backing it up twice to make sure it was OK. I've added a command. If you type 'sudo tnfsupd' at a command prompt it will grab the latest code from github, compile it and replace the existing TNFSD daemon with the new version. I installed this version and noticed that the wpa_supplicant.conf file was not at the root of the image on the SD card. I booted the Pi and had to use the ethernet card to connect to it. I edited the /etc/wpa_supplicant/wpa_supplicant.conf file and rebooted, but that didn't seem to work, but when I used raspi-config to set the SSID and password, that got everything working. So far anyway apt-get update works now too. Thanks! Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted January 17, 2021 Author Share Posted January 17, 2021 Gah I forgot to reset the wifi settings! OK another version is uploading now, should be there in about 20 mins. EDIT: It's there now 1 1 Quote Link to comment Share on other sites More sharing options...
