tschak909 Posted October 22, 2023 Share Posted October 22, 2023 4 minutes ago, craftsman1234 said: Thanks, it is very strange that I can't access it from the Adam but from the PC or Putty is just fine. Can you ping the adam from the Pi? -Thom Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted October 22, 2023 Author Share Posted October 22, 2023 systemctl status tnfsd will show you the status of the service have you forwarded port 16384 to the pi and made sure it isn't being blocked by any firewall in your router? Quote Link to comment Share on other sites More sharing options...
craftsman1234 Posted October 22, 2023 Share Posted October 22, 2023 1 hour ago, Mr Robot said: systemctl status tnfsd will show you the status of the service have you forwarded port 16384 to the pi and made sure it isn't being blocked by any firewall in your router? You were onto something with Pinging the ADAM from the PI. It would not connect from the router WIFI 2.4 to 2.4 but I could PING the Adam from the PC that was connected via the same router but the PC is WIFI 5g. Turns out anything on the network 2.4 to 2.4 could not ping each other but all could be with the anything that was 5g. Very strange. So I had a 5g USB dongle and plugged it into the PI and changed the WIFI settings to the 5g and I could then access the TNFS server from the Adam and load programs. From what I've read it my be an isolation setting on the router that would need to be changed in it. I have T-Mobile home internet is there are no settings to turn it off or on. At least not that I can find. No port forwarding as well. Need to research more. But for now it is kind of working. Quote Link to comment Share on other sites More sharing options...
+skr Posted December 28, 2023 Share Posted December 28, 2023 Just want to give Kudos to @Mr Robot: Downloaded the server zip file, installed like it is described, put it in an Raspi 2 - works right away. Great job! 3 1 Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted February 2 Author Share Posted February 2 Just stumbled onto the info that the tnfsd latest build moved from the original spectranet repo to a tnfsd repo. The little tnfsupd script I put in the server image updates from the spectranet repo so it won't be correctly updating to the latest tnfsd any more. To fix this you will need to do the following to create the code repo sudo -s cd git clone https://github.com/FujiNetWIFI/tnfsd.git then nano $(which tnfsupd) to edit the tnfsupd script, it's very small now edit the script so it matches this. #!/bin/bash # Pull latest TNFSD from github, compile and replace the current one if [[ $(id -u) -ne 0 ]] ; then echo "'sudo tnfsupd' would work better!" ; exit 1 ; fi echo "Stopping TNFSD" systemctl stop tnfsd echo "Updating TNFSD fom GitHub" cd ~/tnfsd git pull origin master >/dev/null 2>&1 cd src make OS=LINUX USAGELOG=Y >/dev/null 2>&1 cp ../bin/tnfsd /usr/local/sbin rm -f *.o echo "Restarting TNFSD" systemctl start tnfsd That should get it updating from the correct repo again. 1 Quote Link to comment Share on other sites More sharing options...
