Panther Posted March 14, 2022 Share Posted March 14, 2022 I just noticed that there's no input for the Start, Select, Option, or Reset lines on the PokeyMAX 3, so how does the PS/2 keyboard function? Quote Link to comment Share on other sites More sharing options...
+mytek Posted March 14, 2022 Share Posted March 14, 2022 29 minutes ago, Panther said: I just noticed that there's no input for the Start, Select, Option, or Reset lines on the PokeyMAX 3, so how does the PS/2 keyboard function? I would imagine that it works like the stock keyboard which also doesn't connect to the 'console' inputs via GTIA. Pokey does not have any connections to the console keys, which are independent. Keep in mind that if you look at the original 800, the console keys were kept very much independent of the actual keyboard. As things progressed this distinction became less so from a physical aspect, but none the less was still electrically an independent aspect. Since the PokeyMax was mainly for the purpose of replacing a Pokey chip, there was no need to even consider the console keys as part of that equation (why would you?). It was later in the development cycle that the PS/2 support was added, with that only requiring 2 free I/O pins. I also kinda doubt that there are enough extra I/O lines to support Start, Select, and Option as well. And even if there are, they probably aren't broken out to a header. I think it's amazing what @foft has managed to cram into the PokeyMax. So it's probably best to look at the PS/2 ability as an unexpected bonus, and not necessarily something on the the same level as the AKI or TK-II. Quote Link to comment Share on other sites More sharing options...
Panther Posted March 14, 2022 Share Posted March 14, 2022 I am absolutely not trying to put down the PokeyMAX, I was just trying to understand if they had worked some magic to manage the full keyboard without the connections. I was surprised to see the PS/2 capability included at all. I actually stuck an AKI USB under the PokeyMAX 3 on my 800, which seems to be working. Quote Link to comment Share on other sites More sharing options...
+mytek Posted March 14, 2022 Share Posted March 14, 2022 51 minutes ago, Panther said: I am absolutely not trying to put down the PokeyMAX, I was just trying to understand if they had worked some magic to manage the full keyboard without the connections. I was surprised to see the PS/2 capability included at all. I actually stuck an AKI USB under the PokeyMAX 3 on my 800, which seems to be working. I didn't think you were putting it down, and I sure hope that you didn't think I was posting something that implied that you had. I just happen to be intimately involved with this subject due to my TK-II creation, and all the years of development that went into it. So because of that, I must remember that i have an awareness that other people perhaps don't about how a PS/2 keyboard can be made to communicate with the Pokey, and I probably forget that when explaining things. Basically whether this be a TK-II, an AKI, or the latest Pokeymax, they all need to do something very similar in order to translate a PS/2 keyboard into something that looks like the stock Atari keyboard. And that is to first read the PS/2 synchronous serial output (only two signal lines - Data and Clock) to determine what key has been pressed, and then mimic the same key, or more specifically the same character as if it were a certain key(s) being pressed on the stock Atari keyboard. To do this, it needs to read Pokey's 6-bit key scan counter and when that matches the number of the key character that has been pressed on the PS/2 keyboard, bring one or both of the Pokey Key Response (KR1 & KR2) inputs low. I say one or both, because KR1 is for the normal keys, and KR2 is for Control, Shift, or Break, and because of the mapping differences between the PS/2 keys and the stock Atari keys, it might require the Control/Shift feedback (KR2) as well as the normal key feedback (KR1) to recreate the same character on the Atari. There's a bit more to it, but that is the essence of it. Now for Start, Select, Option, Reset... those key switches get read by either the GTIA (Start, Select, Option) or go to a circuit that registers the Reset key press (this is handled differently in the 400/800 vs everything that came afterwards). So Pokey has no connection or awareness of those keys, which are normally called the Console and Reset keys. The TK-II and AKI have 4 specific I/O lines that get connected to those switches in order to activate those specific functions. For PokeyMax to do the same, it would also need 4 available I/O pins. This PS/2 to Atari translation is handled by an MCU (Microchip PIC) on the TK-II and AKI running an independent program from the Atari. On PokeyMax it's done via the FPGA being more of a hardware coding then a software one, but in the end it accomplishes the same thing. Neither method depends upon the 6502, and is actually completely transparent to it, with the CPU totally unaware that this is going on in parallel. Pokey also isn't aware that it is being spoken to in this manner, and just assumes that the key presses are coming from its own stock scanned matrix keyboard. If you want to know more about how a PS/2 keyboard works check this out: The PS/2 Mouse/Keyboard Protocol 1 1 Quote Link to comment Share on other sites More sharing options...
foft Posted March 14, 2022 Author Share Posted March 14, 2022 Yes exactly. It’s like the XEGS where just the ‘pokey managed’ keyboard keys are on PS2 and the ‘gtia managed’ console keys remain where they are. Also the layout is, for the moment, fixed to match the Atari layout. So AKI and TK-II remain much fuller featured options. 2 Quote Link to comment Share on other sites More sharing options...
Panther Posted March 16, 2022 Share Posted March 16, 2022 I'm almost finished installing POKEYMAX 3, AKI USB, and Sophia 2 in my Incognito 800. Unfortunately, my time has been limited lately, so I get to put in only a little work at a time on this. I've drilled enough holes in my 800 case and shielding to make Faicuai's head explode. Hey, I do have another 800 that's completely stock. Two actually, but I'm giving one to a friend. 2 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted March 16, 2022 Share Posted March 16, 2022 2 hours ago, Panther said: I've drilled enough holes in my 800 case and shielding to make Faicuai's head explode. It's OK. He drilled a hole in his own case. 1 4 Quote Link to comment Share on other sites More sharing options...
Panther Posted March 16, 2022 Share Posted March 16, 2022 And the truth is out! Even I didn't make a hole in the case for my disk swap button (though the idea for this wasn't mine)... 2 Quote Link to comment Share on other sites More sharing options...
denali Posted March 22, 2022 Share Posted March 22, 2022 Are these still available for purchase? Quote Link to comment Share on other sites More sharing options...
foft Posted March 23, 2022 Author Share Posted March 23, 2022 They are a victim of the chip crisis. Altera (Intel) no longer sell chips to mere mortals. Everything is bought up in large quantities in advance by the big players. 1 Quote Link to comment Share on other sites More sharing options...
XEGS'r Posted June 1, 2022 Share Posted June 1, 2022 (edited) Hi there! Is it still possible to get in line for either the pre-order or straight-up order for the PokeyMAX v3? I'm looking to procure two for a XEGS and a 600XL. Thanx, XEGS'r Edited June 1, 2022 by XEGS'r Quote Link to comment Share on other sites More sharing options...
Retrok7 Posted June 1, 2022 Share Posted June 1, 2022 Yes, is it possible to order PokeyMax v3? Quote Link to comment Share on other sites More sharing options...
foft Posted June 3, 2022 Author Share Posted June 3, 2022 The max 10 chips are still unavailable. The Intel CEO is saying we’re now about half way through the chip crisis, so could be a few more years! Which is a long time for something previously always available ‘next day’! 1 Quote Link to comment Share on other sites More sharing options...
XEGS'r Posted June 3, 2022 Share Posted June 3, 2022 YIKES!!! Alright, I guess it's back in line... Quote Link to comment Share on other sites More sharing options...
Peri Noid Posted July 11, 2022 Share Posted July 11, 2022 I just broke mine ? I wanted to udate its firmware and... the keyboard stopped working. now I'll have to send it back to the producer ? Be carefull. Quote Link to comment Share on other sites More sharing options...
Johny_lovin_it Posted September 18, 2022 Share Posted September 18, 2022 On 6/3/2022 at 12:05 AM, foft said: The max 10 chips are still unavailable. The Intel CEO is saying we’re now about half way through the chip crisis, so could be a few more years! Which is a long time for something previously always available ‘next day’! I'd like to get in line for the pre-order as well as soon as they have what they need to continue production. Quote Link to comment Share on other sites More sharing options...
pjbramley Posted September 18, 2022 Share Posted September 18, 2022 Am I still able to order one? Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted September 18, 2022 Share Posted September 18, 2022 6 hours ago, pjbramley said: Am I still able to order one? I doubt anyone will take pre-orders on items that might be 2-4yrs away...Thank the mass chip shortage and the sell all we got to the big names mantra by intel..Hobby markets destroyed... Quote Link to comment Share on other sites More sharing options...
ricky Posted September 20, 2022 Share Posted September 20, 2022 I'm glad I bought some just in time 😜 Quote Link to comment Share on other sites More sharing options...
Xebec Posted December 31, 2022 Share Posted December 31, 2022 Can someone post a picture of the mod that needs to be done to make this work on an Atari 800 (+Incognito)? Quote Link to comment Share on other sites More sharing options...
Panther Posted December 31, 2022 Share Posted December 31, 2022 1 hour ago, Xebec said: Can someone post a picture of the mod that needs to be done to make this work on an Atari 800 (+Incognito)? There's nothing special with installation on an 800. It fits fine, wire as normal. The only problem I encountered was trying to use the PokeyMAX 3 and an AKI USB together. I ditched the USB. 1 Quote Link to comment Share on other sites More sharing options...
NuClear235 Posted January 25, 2023 Share Posted January 25, 2023 I am interrested about PokeyMax3. Will sell somebody, please? Quote Link to comment Share on other sites More sharing options...
foft Posted January 25, 2023 Author Share Posted January 25, 2023 Crossing my fingers that we’ll finally see some FPGA’s from Intel later this year. Apparently the chip crisis is starting to ease now but still no lead time at Mouser or Digi-Key etc. 3 Quote Link to comment Share on other sites More sharing options...
Panther Posted January 30, 2023 Share Posted January 30, 2023 I finally got around to adding a PS/2 connector to my 800 and wired it up to the PokeyMAX 3. Everything is working well. A Perixx PS/2 keyboard didn't work with it, but a Logitech is working fine. Quote Link to comment Share on other sites More sharing options...
Frankie Posted January 30, 2023 Share Posted January 30, 2023 Add me to the list for 2 pokeyMax. Quote Link to comment Share on other sites More sharing options...
