kyokorn Posted May 1 Share Posted May 1 (edited) Hello friends, recently i get some pluscart duo pcb, I can see the boot logo, after the logo the screens goes to black The version flashed is PlusCart_102.3.16.elf 20240430_220710.mp4 Edited May 1 by kyokorn Quote Link to comment Share on other sites More sharing options...
Capellão Posted May 1 Share Posted May 1 9 minutes ago, kyokorn said: Olá amigos, recentemente recebi um pluscart duo pcb, posso ver o logotipo do boot, depois do logotipo as telas ficam pretas A versão atualizada é PlusCart_102.3.16.elf 20240430_220710.mp4 23.29 MB · 0 downloads Test with fw version 102.3.17. 1 Quote Link to comment Share on other sites More sharing options...
kyokorn Posted May 1 Share Posted May 1 9 minutes ago, Capellão said: Test with fw version 102.3.17. Oiiii Friend, I tested it, but wit the same result Black screen after Plus (+) Logo, Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted May 1 Share Posted May 1 18 hours ago, kyokorn said: Hello friends, recently i get some pluscart duo pcb, I can see the boot logo, after the logo the screens goes to black Maybe a voltage issue. Have you tested a different 2600? has the 2600 you use a video mod? Quote Link to comment Share on other sites More sharing options...
kyokorn Posted May 2 Share Posted May 2 1 hour ago, Al_Nafuur said: Maybe a voltage issue. Have you tested a different 2600? has the 2600 you use a video mod? Hello friend, Yes my 2 ataris have the video mod, and the issue is the same on the 2 ataris, but is strange because on the past i build and test it a couple of pluscart and was working fine, maybe just the AC\DC adapter is another now, your recommendation is test with other AC/DC adapter ? Or maybe the problem is because the video modification ? BR Quote Link to comment Share on other sites More sharing options...
kyokorn Posted May 2 Share Posted May 2 3 hours ago, Al_Nafuur said: Maybe a voltage issue. Have you tested a different 2600? has the 2600 you use a video mod? Jesus, I change the AC/DC Adapter, also I did the test on the 5 ataris that i have with the same result, I have 2 ataris Jr that don't have the video mod, but is the same result. I checked it point by point and the solder points looks good, also i did the test with different firmwares and the result is the same, after plus logo (+) the screen goes black Any ideas? Many Thanks in advance! LB Quote Link to comment Share on other sites More sharing options...
Capellão Posted May 2 Share Posted May 2 9 hours ago, kyokorn said: Jesus, troquei o adaptador AC/DC, também fiz o teste nos 5 ataris que tenho com o mesmo resultado, tenho 2 ataris Jr que não tem o mod de vídeo, mas dá o mesmo resultado. Verifiquei ponto a ponto e os pontos de solda parecem bons, também fiz o teste com firmwares diferentes e o resultado é o mesmo, depois do logo de mais (+) a tela fica preta Alguma ideia? Muito obrigado antecipadamente! LIBRA use a 9v power supply and at least 1A. 1 Quote Link to comment Share on other sites More sharing options...
cfarl Posted May 2 Share Posted May 2 You can do some tests: 1) Check the output voltage from your 7805 regulator. If It is less then 4.7v you can have the same problem as the one I reported above. 2) Use a external DC Power supply, and look at the amps you Atari drains. Your 7805 can be entering in the protection state, that turn It off. The same problem as 1) 3) Remove the wi-fi board and test it. The menu appears? Good Lucky! 1 Quote Link to comment Share on other sites More sharing options...
kyokorn Posted May 2 Share Posted May 2 1 hour ago, Capellão said: use a 9v power supply and at least 1A. I did my friend, I used a new 9V 1A power supply, but i will try to get a new one. 😃 1 hour ago, cfarl said: You can do some tests: 1) Check the output voltage from your 7805 regulator. If It is less then 4.7v you can have the same problem as the one I reported above. 2) Use a external DC Power supply, and look at the amps you Atari drains. Your 7805 can be entering in the protection state, that turn It off. The same problem as 1) 3) Remove the wi-fi board and test it. The menu appears? Good Lucky! Hello friend, nice tips, I will test the voltage drain, and see what happend wihout the wifi board, BR! Quote Link to comment Share on other sites More sharing options...
kyokorn Posted May 4 Share Posted May 4 (edited) Well I'm a little frustated, because i did everthing and same result, here the resume: * The drain voltage looks good. * Without the wifi board when I turned on the atari is on black screen. (I cannot see the plus logo (+)) * I was thinking that maybe the problem is on the PCB (I mean this new PCB pluscart duo), but I have the original PCB just pluscart without sd, and this new atari pluscart that i build is on black screen (either i can't see the pluscart logo) * That I found is the esp show an ssid AI_THINKER_XXXX, I think this is not normal? Well anywway I did the process to load the firmware in to the ESP, but with the same result in the 2 Pluscart original and pluscart DUO (Black screen). I get 4 boards STM32F407VGT6 , 2 of them is imposible put in to flash mode to load the .elf file, maybe can be a bad lote of these boards? Exist anyway to test the boards ? On the past I built 4 pluscart to my close friends (Birtday present) and works without any problem at the first attemp, this time the luck is not with me Edited May 4 by kyokorn Quote Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted May 4 Share Posted May 4 15 hours ago, kyokorn said: * Without the wifi board when I turned on the atari is on black screen. (I cannot see the plus logo (+)) I am not sure, but I think you need a firmware without WiFi (PlusCart Zero or UnoCart firmware) to test this. Quote Link to comment Share on other sites More sharing options...
