HSC18 Round 8 [NEW]: POLE POSITION
After a false start we're back on the grid for Round 8... I've grafted most of this from last time we played.
:music: deeeeer der deeer der der der deeeeeer PREPARE TO QUALIFY it's....
POLE POSITION
Everyone welcome to play: just play and post (screenshots optional)
PAL users - play the Marius version if you can otherwise regular Atari or Datasoft versions.
Pole Position is much harder on NTSC, PAL/European players get more time, more chance to complete laps after crashing and more score but Marius1976 kindly created a version that runs on both systems with adjusted PAL timings (has purple skies). Practice using the erm "practise run" :D
NTSC users - use the regular PP from Atari/Datasoft NOT the one on the disk below - that one is made easy to be comparable to the regular PAL version - you can crash 8+times and still complete an 8 lap on Atari GP.
Clartification on the NTSC vs PAL options here:
https://atariage.com/forums/topic/320014-hsc18-round-8-new-pole-position/?do=findComment&comment=4822253
Settings
Select/F3=Laps
Option/F4=Skill (Easy:Monaco/Malibu, Medium:Namco, Hard:Datasoft/Atari GP)
"1 LAP Series" Play each of the 3 skill settings in a row. NO restarts. Post all 3 scores.
"2 LAP Series" Play each of the 3 skill settings in a row. NO restarts. Post all 3 scores.
(Yes you can play more than once, but must play the 3 races in a row again, it is NOT just your 3 best scores!)
"8 LAP Pro Challenge" Atari GP/Datasoft 500
Space is pause - can use on end of race screens
Downloads
AtariAge Info on  Marius PAL Version ATR (mydos/1050 density): PolePositionMariusPALandFixedNTSCFileVersions.ATR  **do not use NTSC ver here **
Atarimania (instructions & files) ATARI USA DATASOFT UK ATARI UK
Fandal XEX
Atarionline.pl ATR/XEX
Wiki
Info on Post #2
Tables on Post #3
Race finishes SUN 16th May 10am UK Time
Start your engines...
Edited by therealbountybob
Things to look out for in >>>Pole Position>>>
Had the 211Mph bug(?) but I'm now thinking this may be a feature(!) - It happened after I'd overtaken two cars down the middle of the Final Straight - I felt that 'pull' on the car so am wondering if they coded in some sort of slip-stream feature to give you a turbo boost?
Managed to pull off an overtake on the inside kerb was very pleased with that. Reading the posts from last time PP was played here you can overtake on the outside kerb; if you're lucky!
PAL users be careful not to clock up too many seconds on the 8-lapper as the timer bug can come into play - can't remember how many seconds this is?!
The 3 courses are all the same? There's only the one corner that is really tricky so break or use a bit of inside kerb to slow yourslef down.
Change from Low to Hi gear (pull back on stick) at 105mph - can't remember who it was who crawled round the track at 105mph! might have been you littlemanjack :P :D and push forward to go into Low gear after crashing.
When you crash try taking out more than one car, or a car and a sign - is it possible to do 2 cars and a sign - might earn you a HSC bonus point ;)
Marius Ver.' Pro Challenge eventually managed 5 laps without a crash then crossed the line only to encounter the dreaded timer bug (Will let Marius know!) think I had 98 seconds banked on previous lap so was over 100 :mad:
The PAL versions bug happens if you have too much time - guess you'll have to slow down a bit! The Marius version is much tougher but looks like it's still possible to get over 99 seconds at the start of a lap (8 bits eh!)... work out how many seconds it gives you each lap (60?) and make sure you have less than 40 left when you cross the line each time (will check this next time I play) :-o
My Pole Positioning thoughts...
the only really tricky bend is the sharp left hander so it's how to slow down: 3 ways; brake; skid; edges or some combination of the three and then there's the position of the enemy (yes I said it) enemy cars to consider. I'm looking for exit speed on the corner... Generally to reduce skidding seems a good idea, so tap tap tap round some corners is my strategy (but not sure if this is doing a great deal). Could even try reducing speed for certain corners before taking them (not tried this yet). Also considered taking a more real-life driving line (wider start) through the corners but not done this much so far. Then there's this overtaking drag malarkey (and the speed boost perhaps) I'm thinking it's best to take a wider path past cars to stop the turbulence slowing your accelleration :-o
orpheuswaking: on single lap or double lap rounds I usually brake on the sharp turn and dodge the cars... On longer rounds I usually cut the corner and pass the cars on the grass
Pole Position - Final Standings
If everyone can play the Marius version we will not need to adjust the scores.
(For tied 1st place scores the non handicapped score will take preference)
M=Marius P=PAL N=NTSC
REAL HSC POINTS!
1 Lap Series (3 races in order)
(N)TSC SCORES +750 (M)arius PAL SCORES +3350
1st carlsson (M) 27750+27400+28000=83150+3350=86,500 6pts
2nd RedThunder (M-N) 28900+28850+28350=86,100 5pts
3rd trbb (M) 27750+26650+28050=82450+3350=85,800 4pts
4th Deteacher (N) 27950+27900+28050=83900+750=84,650 4pts
5th McKong (M) 27700+27600+25900=81200+3350=84,550 4pts
6th Zylon (N) 27,900+27,900+27,800=83600+750=84,350 4pts
7th graywest (N) 27950+27700+25800+750=82,200 4pts
8th VW (N) 27950+26250+26550=80750+750=81,500 3pts
9th Sikor (M) 27700+26950+25050=79700+3350=82,050 3pts
10th tompateus (P) 28100+27750+25150=81,000 3pts
11th 8BIT 1337 (N) 27750+27000+24600=79,350+750=80,100 3pts
12th Starbug (N) 27,700+25,850+25,000+78,550+750=79,300 3pts
13th AtariSphinx (N) 26300+22500+27800=76600+750=77,350 2pts
14th MrTrust (M) 23850+22350+22800=69000+3350=75,800 2pts
15th pusakat (N) 24350+22550+24300=71,200+3350=74,550 2pts
16th jdh (M) 27300+20350+22700=70,350+3350+73,700 2pts
17th fakecortex (N) 24,350 1pt
2 Lap Series (3 races in order)
(N)TSC SCORES +1250 (M)arius PAL SCORES +4300
1st Redthunder (M-N) 40400+41550+41500=123,450 6pts
2nd trbb (M) 39000+39100+38750=116850+4300=121,150 5pts
3rd Zylon (N) 39,450+39,300+39,150=117,900+1250=119,150 4pts
4th Deteacher (N) 39600+39150+39100=117850+1250=119,100 4pts
5th carlsson (M) 39200+36150+37800=113150+4300=117,450 4pts
6th tompateus (P) 39950+37600+37050=114,600 4pts
7th McKong (M) 37600+36000+36000=109,600+4300=113,900 3pts
8th VW (N) 37400+36200+36050=109650+1250=110,900 3pts
9th 8BIT 1337 (N) 38300 +36750+33600=108,650+1250=109,900 3pts
10th MrTrust (M) 37000+33050+32,650+4300=107,000 2pts
11th graywest 37150+34750+33300+1250=106,450 2pts
12th Starbug (N) 37,800+34,650+32,550=105,000+1250=106,250 2pts
13th AtariSphinx (N) 35650+32550+33950=102150+1250=103,400 1pt
8 Lap Pro Challenge (Atari GP/Datasoft 500)
(N)TSC SCORES +3200
1st Zylon (M-N) 113,100 12pts
2nd trbb (M) 112,250 11pts (2 crashes)
3rd tompateus (P) 106,850 10pts
4th carlsson (M) 105,400 9pts
5th McKong (M) 104,550 9pts (2ish crashes)
6th Redthunder (P) 104,450 8pts (0 crashes)
7th Deteacher (N) 81,400+3200=84,600 7pts
8th Starbug (N) 81,350+3200=84,550 6pts
9th VW (N) 78,750+3200=81,950 5pts
10th  graywest (N) 57,850+3200=61,050 4pts
11th AtariSphinx (N) 54,800+3200=58,000 3pts
12th 8BIT 1337 (N) 54,750+3200+57,950 2pts
13th MrTrust (M) 55,150 2pts
* Previous records
orpheuswaking (M) 112,400
orpheuswaking (N) 108,700+3200=111,900
McKong (P) 110,750
Fun Challenges
Hot Lap on "Practice Run" SET TO ANY NUMBER OF LAPS, FIRST LAP IS SLOWER!
1st trbb (M) 49"19
2nd Redthunder (N) 49"23
3rd McKong (M) 49"35
4th graywest (N) 50"31
Crash Compo
RedThunder My Car + Opponent + Sign !
Highest Speed
zylon (N) 227mph!!
trbb (M) 211mph
Updated
5 minutes ago, RedThunder said:
1 Lap Series
Monaco 22450
Namco13450 DNQ
Atari GP 20600 DNF
Marius Version, Altirra, PAL (I Assume)
2 Lap Series
Monaco 0
Namco 0
Atari GP 0
8 Lap Pro Challenge
AtariGP 0
THanks for starting things off RT :thumbsup: the Marius version should take care of things more or less but I still think it's slighly easier when it runs on PAL systems, the hanidcapping based on last time might be flexible on the 8 lapper, should be a fun round :)
Here's my first go:
1 lap series (Marius NTSC):
Malibu:  27,950 (no crashes)
Namco:  21,650 (1 crash in qualifier, 1 crash in race)
Atari:  23,400 (1 crash in qualifier, 0 crashes in race...rode the brake a lot.)  :)
Edited by Deteacher
  • Like 4
I was just about to confirm that the Marius NTSC version isn't supposed to have a purple sky, and I see Deteacher has posted scores with the same blue sky I see.
As an NTSC player I'm curious if it makes it 'easier' for us in addition to the PAL version making it 'harder'?  Or am I just confused (again :) )
Just played the NTSC version.
Plays nicer than PAL, did'nt notice the 84 v 90 second time.
NTSC 1 LAp
Monaco,
26,750
61"68
1 crash and Pole Position
NTSC 1 LAp
Namco
28,600
54"68
Pole Position
NTSC 1 LAp
60"68
Pole Position
Edited by RedThunder
1 hour ago, Deteacher said:
Not only does the PAL version have the purple sky, but you only get 84 seconds in the qualifier.  NTSC gives you 90 seconds.
Doesn't time go by slower on PAL than NTSC, something to do with 50 vs 60 Hz? So perhaps 84 seconds on the clock on PAL is equivalent to 90 seconds on NTSC.
I'd guess Marius version on NTSC = NTSC Atari/Datasoft versions.
Marius on PAL is harder than PAL Atari/Datasoft versions but still NOT as hard as NTSC.
All good fun :-D
What Deteached posted is perfect so other top players can give a guide to how well they did and we can adjust the fiddle factor based on last times' HSC play.
So far, all played on Marius PAL version on real 130XE.
1 LAP Series
Malibu GP: 25100 pts, time 56"35 (Qual: 27 sec left => position 2, no crashes)
Namco Speedway: 25650 pts, time 54"45 (Qual: 27 sec left => position 2, no crashes)
Atari GP: 23850 pts, time 63"23 (Qual: 26 sec left => position 2, 1 crash in the race)
1 LAP Series
Malibu GP: 27500 pts, 054"23 (Qual 29 sec => pos 1, 0 crash)
Namco Speedway: 27900 pts, 053"55 (Qual 29 sec => pos 1, 0 crash)
Atari GP: 25600 pts, 054"88 (Qual 27 sec => pos 2, 0 crash)
2 LAP Series
Malibu GP: 38100 pts, 106"55 (Qual 29 sec => pos 1, 0 crash)
Namco Speedway: 36750 pts, 114"88 (Qual 29 sec => pos 1, 1 crash)
Atari GP: 36800 pts, 116"56 (Qual 28 sec => pos 1, 1 crash)
8 LAP Pro Challenge
Atari GP: 89200 pts, Lap 7  (Qual 29 sec => pos 1, 7 crash)
I had a really good race up until lap 5, only crashed twice. Then I got sloppy and crashed too many times to finish the race. But next time!
Edited by carlsson
(N)TSC SCORES +750 (M)arius SCORES +3350
So I presume what determines if one should post an improved score is if the total from the three races Malibu + Namco + Atari/Datasoft is better than what one previously posted, since we participate in sets of 3 continuous races? In the beginning it will be easy to improve every score but after a while I believe the improvements will be so small that one has to calculate the total points to see if it is an improvement.
