rcamp48 Posted November 9, 2021 Author Share Posted November 9, 2021 I will try tonight and see what is going on, as far as I know only the rs232 dot com is needed as well as the rlisten dot com Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted November 9, 2021 Share Posted November 9, 2021 5 hours ago, JohnPolka said: At that price, I would have demanded that they allowed 'R' to be used for replying to messages! -JP Agreed...! Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted November 9, 2021 Author Share Posted November 9, 2021 OK here is the problem with Forem XE Professional, in the install manual it says it is looking for a 9600 baud modem, I was running amp850, which is 2400 max, you should be running amp9600, the rlisten program, and rs232, I am still testing it but in the PERM folder once of the files is corrupted even on my master disks, one I retrieve that file and restore it I *should* have a working copy, mind you there still will be one file missing but it will work OK Quote Link to comment Share on other sites More sharing options...
moonlight_mile Posted November 9, 2021 Share Posted November 9, 2021 OK here is the problem with Forem XE Professional, in the install manual it says it is looking for a 9600 baud modem, I was running amp850, which is 2400 max, you should be running amp9600, the rlisten program, and rs232, I am still testing it but in the PERM folder once of the files is corrupted even on my master disks, one I retrieve that file and restore it I *should* have a working copy, mind you there still will be one file missing but it will work OK Since you seem to be picking up the baton on f-xep. I would suggest you document all your changes and create a true install document for it. I fooled with XEP a number of times over the years. Never really getting it to a point where it would run. Each time I would pick it back up I would discover another file that I was missing which prevented the running of the program. I really think the community would benefit from a thorough install document. At least I know I would have. Quote Link to comment Share on other sites More sharing options...
bf2k+ Posted November 9, 2021 Share Posted November 9, 2021 I attempted to make a "BBS on a Stick" version of FXEP 5.4 back in 2008 when I was doing all of my 'stick' projects. I had it running somewhat but some of the menu commands would not execute correctly in the emulator. I abandoned it for this reason although I know I still have the original project files... somewhere. I know it was running correctly, because it ran great on a real machine. @_The Doctor__ I am somewhat sure the fully running BBS can be found on one of those ST-251 HDs you got from me... (maybe). It would be on the 2nd partition. It was internet accessible thru my APE box. Ahh but the more I think about it, the more I think I might have run that one the IDEPlus 2 on a SD card... which is still here. Sorry... The mind is a terrible thing to format. Formatting starts at age 65... 1 Quote Link to comment Share on other sites More sharing options...
JohnPolka Posted November 9, 2021 Share Posted November 9, 2021 3 hours ago, bf2k+ said: I attempted to make a "BBS on a Stick" version of FXEP 5.4 back in 2008 when I was doing all of my 'stick' projects. I had it running somewhat but some of the menu commands would not execute correctly in the emulator. I abandoned it for this reason although I know I still have the original project files... somewhere. I know it was running correctly, because it ran great on a real machine. @_The Doctor__ I am somewhat sure the fully running BBS can be found on one of those ST-251 HDs you got from me... (maybe). It would be on the 2nd partition. It was internet accessible thru my APE box. Ahh but the more I think about it, the more I think I might have run that one the IDEPlus 2 on a SD card... which is still here. Sorry... The mind is a terrible thing to format. Formatting starts at age 65... It would be worth trying it on a current version of Altirra. Perhaps some of those problems you saw with an emulator back then no longer exist in a current version of an emulator. -JP Quote Link to comment Share on other sites More sharing options...
bf2k+ Posted November 9, 2021 Share Posted November 9, 2021 Good point, JP. All of the stick versions ran under a800win 2.5c. Quote Link to comment Share on other sites More sharing options...
Amis Posted November 9, 2021 Share Posted November 9, 2021 Part of the problem with these various versions, The last released version, 5.4, saw TWO versions of AMP, one for the SIO modem interfaces, the other for the PBI interfaces. AMP9600 is for a MIO - @JohnPolka confirm this if you are aware of the same. MIO emulation is not available on the FujiNet - Only the 850 Also - still waiting to hear what file is missing so I can provide you with the file. Now it appears you have another corrupt file. Let us know what you need.. Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted November 9, 2021 Author Share Posted November 9, 2021 I was having problems with the files in the perm directory, but I got it fixed, right now I am working on copying all files to floppies in DD, I have disks one , two and three, and all of the subdirectories on double density disks, the problem comes when you go anything higher than double density single sided on the fujinet, I may rewrite it to store all of the data files on drive 2, instead of drive one , I cannot get anything bigger than 180 K disks to read properly on my Fujinet, so I will probably use all 8 180 K disks on the fujinet, and compensate for that. I will post the 180 K files as soon as I write them as workable atrs. Russ Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted November 10, 2021 Author Share Posted November 10, 2021 I am recreating a whole new atr disk from scratch, I am copying all of the floppies to disc one, should have a working BBS by midnight muy time trying double density double sided disks Russ 1 Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted November 10, 2021 Author Share Posted November 10, 2021 (edited) 2 hours ago, rcamp48 said: I am recreating a whole new atr disk from scratch, I am copying all of the floppies to disc one, should have a working BBS by midnight muy time trying double density double sided disks Russ Here is the new setup disk, I think I have everything in it , really compact set it up as drive 1 and create a 720 K disk in drive 2 then boot from drive 1 on Fujinet or side 3 or sio2sd. , it should set up things pretty well as last time , but only uses one disk as the master. Here is the file: I have to recreate the file properly from my floppy disks , they are all good. It has not been tested on my Fujinet but should work OK. , Let me know if it does not work or has any problems. Russ Edited November 10, 2021 by rcamp48 Bad file, 360 K with 720 K written to it 1 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted November 10, 2021 Share Posted November 10, 2021 29 minutes ago, rcamp48 said: Here is the new setup disk, I think I have everything in it , really compact set it up as drive 1 and create a 720 K disk in drive 2 then boot from drive 1 on Fujinet or side 3 or sio2sd. , it should set up things pretty well as last time , but only uses one disk as the master. Here is the file: I have to recreate the file properly from my floppy disks , they are all good. It has not been tested on my Fujinet but should work OK. , Let me know if it does not work or has any problems. Russ Quoting for the lolz - no file attached Another "working" version. Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted November 10, 2021 Author Share Posted November 10, 2021 1 minute ago, Stephen said: Quoting for the lolz - no file attached Another "working" version. it was a bad file, it will be up in a few minutes, this is not a working BBS just the setup disk 1 Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted November 10, 2021 Author Share Posted November 10, 2021 (edited) Here is the startup disk and it creates a BBS that has no files missing but it still will not connect. Forem XE Newly Created Master.atr, check it out all files are there.... You need to create a 720K program disk for d2:Forem_Xe_Program.atr and a 720 K data disk for drive 3:Forem_data_1.atr OK the forem xe program is complete but for some reason does not log on, does not yet work Atari_8_Bit_Video_Part___-_0052.mp4 Edited November 10, 2021 by rcamp48 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 10, 2021 Share Posted November 10, 2021 only one device I know of can't handle the ATA command correctly.. you know the command that answers a call even if autoanswer isn't set... well... that just might be a problem since just about all modems work that way or have a similar command... so if all else fails use something up to the task like APE, Cygwin, lantronix, pearle, etc... they all work correctly and get along with all of the serial interface devices be they sio2pc cable, Rverter, 850, P:R:, MIO, Black Box etc etc... 1 Quote Link to comment Share on other sites More sharing options...
rcamp48 Posted November 10, 2021 Author Share Posted November 10, 2021 I am now using Forem 2.6M from AMIS,I will customize it and put it online tonight, but I have things to work on until then, I just had one of the two add-on switches in my 130 XE that blocked the Fujinet from plugging in , they are both away from the SIO plug so I can now plug my Fujinet directly into my 130 XE. AS for upgrades I am going with the 800xl, one question: I have the worse keyboard on it (I believe a Mitsumi keyboard, are they replaceable with a better keyboard or am I stuck with that clunky Mitsumi keyboard ??). Russ Quote Link to comment Share on other sites More sharing options...
JohnPolka Posted November 14, 2021 Share Posted November 14, 2021 As the moderator said...we need to start a separate thread for our jokes and memes. So, back by popular demand... BBS Life memes have rebooted here: https://southernamis.wixsite.com/website/forum/general-discussions/bbs-life -JP 2 1 Quote Link to comment Share on other sites More sharing options...
Amis Posted January 15, 2022 Share Posted January 15, 2022 On 11/9/2021 at 6:16 PM, rcamp48 said: it was a bad file, it will be up in a few minutes, this is not a working BBS just the setup disk Just so we can close this thread out... Single Disk, Altirra, FujiNet, Modem... No version 6.0 No 15 ATR's, just Forem XE pro 5.4 Running at foremxepro.ddns.net port 9001 4 Quote Link to comment Share on other sites More sharing options...
