+Larry Posted March 23, 2022 Share Posted March 23, 2022 According to the installation docs, the 810 Archiver (Chip) reads the opening code from sector $2D0 of the disk. It compares that to the code in the rom, and if it is the same, then the Archiver/Editor software becomes functional. So that would mean that if you downloaded an Archiver disk image from the internet, then the correct opening code must be written to $2D0. Is that correct? Which bytes need to be written? Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted March 23, 2022 Share Posted March 23, 2022 Actually, when the 810 is powered down, if you place the Archiver Disk in the drive and then power it up, the 810 will read sector $2D0 of the disk and will try to execute some code (if exists) that will Open the Chip automatically... The Open Code isn't hard coded to sector $2D0. Quote Link to comment Share on other sites More sharing options...
dzzy1982 Posted March 23, 2022 Share Posted March 23, 2022 I don't have an original disk for mine but I can enter the code manually by pressing the "O" key in the Archiver menu. Do you know what your code it? Quote Link to comment Share on other sites More sharing options...
+Larry Posted March 23, 2022 Author Share Posted March 23, 2022 I don't have one -- yet. My only experience is with the Happy Archivers. For them, no code is necessary, since there is no Archiver rom. But I still am not sure that I understand... you have to enter the code each time that you want to use the Archiver software? Or? Quote Link to comment Share on other sites More sharing options...
ijor Posted March 23, 2022 Share Posted March 23, 2022 7 minutes ago, Larry said: I don't have one -- yet. My only experience is with the Happy Archivers. For them, no code is necessary, since there is no Archiver rom. But I still am not sure that I understand... you have to enter the code each time that you want to use the Archiver software? Or? For the original CHIP, yes. You have either to enter the code each time you run the Archiver software. Or either power up the 810 drive with the Archiver disk. For the Happy chip emulator, no. The chip emulator starts as already opened, there is no need to enter any open code. This is true both for the Happy 810 and the Happy 1050. Quote Link to comment Share on other sites More sharing options...
