+Larry Posted July 15, 2022 Share Posted July 15, 2022 I have a 1200XL cartridge extender, and unfortunately, it came with no plating on the edge connectors that fit into the recessed cartridge port. The connectors were left as straight copper, and it corrodes fairly quickly. That necessitates cleaning with an abrasive eraser. Is there anything that I can do to protect it from oxidation? I've applied Pro Gold, but it doesn't seem to help much. Any ideas? Quote Link to comment Share on other sites More sharing options...
+Stephen Posted July 15, 2022 Share Posted July 15, 2022 You could apply the tiniest amount of solder, but remember - anything that gets added could make the contacts too thick which could then damage the cart connector. I have done this in the past though. What you can do, is when applying the solder with one hand, use a damp sponge to wipe it off. This will leave the thinnest of coatings. 1 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted July 15, 2022 Share Posted July 15, 2022 Yeah, be very careful of how much you use, at the very least it will force open the attached devices socket making that same device loosely connecting and another non adjusted edge conn, it might even make some of the connectors not connect and then you have to bend the sockets spring connectors risking breaking them. 1 Quote Link to comment Share on other sites More sharing options...
BillC Posted July 15, 2022 Share Posted July 15, 2022 19 minutes ago, Stephen said: You could apply the tiniest amount of solder, but remember - anything that gets added could make the contacts too thick which could then damage the cart connector. I have done this in the past though. What you can do, is when applying the solder with one hand, use a damp sponge to wipe it off. This will leave the thinnest of coatings. Solderwick could also be used to reduce the thickness of the solder coating. 2 Quote Link to comment Share on other sites More sharing options...
ivop Posted July 15, 2022 Share Posted July 15, 2022 1 hour ago, BillC said: Solderwick could also be used to reduce the thickness of the solder coating. Haha, I was about to say that. It really works very well. Quote Link to comment Share on other sites More sharing options...
+Larry Posted July 15, 2022 Author Share Posted July 15, 2022 Sounds like a good plan. I'll practice on a dead cartridge. Quote Link to comment Share on other sites More sharing options...
Panther Posted July 15, 2022 Share Posted July 15, 2022 I've seen a gold coating application for circuit connectors, but I don't remember the name of it. Gold doesn't oxidize. Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted July 16, 2022 Share Posted July 16, 2022 There used to be this stuff called Cramolin. I don't know if it is still around but I used to treat my Road Mixers (band equipment) with it and it worked well. I remember it was expensive. 1 Quote Link to comment Share on other sites More sharing options...
Chri O. Posted July 16, 2022 Share Posted July 16, 2022 I use this stuff on bare PCB copper it works like a charm but I'm not sure about connectors. 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 16, 2022 Share Posted July 16, 2022 Maybe liquid silver as in from a small vial or demister repair pen. But I suspect inserting and removing would probably wear it off pretty quickly. Of course for exposed traces there's solder mask but you can't use that were a conductive contact is needed. Maybe dielectric grease? Inserting would wipe most of it off but probably still give contact and protection at the same time. 1 Quote Link to comment Share on other sites More sharing options...
Draxxs Posted July 16, 2022 Share Posted July 16, 2022 I agree with Chri on the MG Chemicals tin plating. I used to make a bunch of pcb's at home. Used that to coat and protect the boards. 1 Quote Link to comment Share on other sites More sharing options...
