How do you set up a TNSF server?
I went to the fujinet.online/download site and downloaded the TNSF server for Windows 10.  I placed the file in my "Atari" subdirectory where I have disk images and other Atari files.  I double clicked the tnfsd.exe file, there was a quick flash on the screen but nothing else.  I then went to fujinet and plugged in my IP address that was shown in my WIFI properties on the TNFS host list.  It did not work.  I'm guessing I missed a few steps along the way but I couldn't find any Youtube video that would give me step by step setup instructions.  Any direction you can provide would be appreciated.
The hostname you should use in your hosts lists, should match the machine that the TNFS server is running on.
-Thom
https://github.com/FujiNetWIFI/fujinet-platformio/wiki/Setting-Up-TNFS-On-Windows-10
23 hours ago, Tonyscouter said:
Thom, my PC name is "Toshiba-PC" should I plug in that name instead of the IP address?
3 hours ago, Kenshi said:
I have Linux and can't speak for the Windows setup, but I can say that putting the IP address of my TNFS server into FujiNet worked fine.
Just as a general comment: all of the above are going to very much depend on local network configuration, how the TNFS host has its networking configured, the OS in use, etc.
I know all too well what happens when I try to volunteer time to take something on, particularly when I know what's in my pipeline through the end of the year.  tnfsd is an area of the documentation that could use help in general, however.
  • 4 months later...
On 10/16/2022 at 2:12 AM, MichaG said:
You have to tell tnfsd.exe where your Atari-Files are. Make a small server.bat with
tnfsd.exe D:\FujiNet
and start the bat file.
I think I'll try this next.
I set it up as directed on the site (I think) and wasn't having any luck on my Win10 machine...
(Set up tnfsd.exe to start at boot in Task Scheduler, gave it the path so the details for the Action shows C:\tnfsd/tntfsd.exe "C:\tnfsroot" ... All looks good.)
I could see that it was running in Task Manager after a reboot.  I could see that it was listening with netstat.
When I would telnet to it (on the same Win10 machine), I got a connection, so it looked like it thought it was working...
But I couldn't get my Fujinet to see it without errors.
This morning, I killed the task and ran it manually in a command prompt window...
Works... <sigh>
So something about the way Windows is trying to launch that task.  I mean, it launches and runs, but isn't working.. (path I would guess) I'll try the batch file and see what that does...  (Maybe it's those quotes around the path...  Removing them...)
Worst case, it's not a terrible thing if I just run it manually when needed...
OK, for those following along (just me, but still), it was the quotes.  I guess I was being too literal when following the instructions. ;-)
In the "Add Arguments (optional)" box for the Task Properties, don't put your path in quotes. ;-)
Edited by desiv
  • 3 weeks later...
If the task action says c:\tnfsroot that would be where the atari files go. No need for a bat file. No other location.
I put d:\atari in that spot instead and the server picked up my files there.
