Tursi Posted December 10, 2022 Share Posted December 10, 2022 Someone on my Mastodon list posted a mathematical program for the BBC to render the Death Star. I like this sort of thing, so I ported it to the TI under The Missing Link. Meant to post it here. I used XB 2.9 GEM and The Missing Link in 2 color mode. It could, of course, be optimized a fair bit, and not sure I got everything perfect, but I was happy with it. 100 REM Death Star by Electron Greg 110 REM Adapted by Tursilion - 256x192 version - unoptimized 120 REM TIXB with Missing Link 130 DIM AR(300) 180 DEF RAND(X)=INT(RND*X)+1 210 REM prepare lookup table 215 V=640 :: Z=522 :: R=300 220 A=2*PI/300 :: S=SIN(A):: C=COS(A):: X=R :: Y=0 222 FOR W=1 TO 300 224 B=X*C-Y*S :: Y=X*S+Y*C :: X=B :: AR(W)=600-(V+X) 226 NEXT W 230 CALL LINK("CLEAR") 232 CALL SCREEN(2) 234 CALL LINK("COLOR",8,2) 239 REM draw globe 240 FOR N=115 TO 210 :: REM latitude 250 CALL PROCC(64,(1080-(AR(219-N)*7))/5,AR(N)/2.5,N) 260 NEXT N 270 REM clear out dish area 280 CALL PROCB(100,130,40) 290 REM draw dish 300 FOR N=0 TO 44 STEP 4 :: CALL PROCCG(100,130,N):: NEXT N 310 REM spin forever 320 GOTO 320 330 REM draw the moon itself 340 SUB PROCC(INV,INZ,INR,INN) 345 DEF RAND(X)=INT(RND*X)+1 350 V=INV :: Z=INZ :: R=INR :: N=INN 360 A=2*PI/360 :: S=SIN(A):: C=COS(A):: X=R :: Y=0 370 FOR W=1 TO 360 :: P=(RAND(W))-(N/2):: IF P>100 THEN GOTO 420 380 B=X*C-Y*S :: Y=X*S+Y*C :: X=B :: Q=((V+X)*1.3)-(Z/10)+100 :: O=((Z+Y)/4.0)*1.34+(X/3) 390 IF W<180 THEN GOTO 420 400 IF N>148 AND N<152 THEN CALL PLOT(Q+12,O-1):: GOTO 420 :: REM belt 410 FOR M=1 TO (360-W)/30 :: CALL PLOT(Q+RAND(8),O):: NEXT M :: REM density set by how many random pixels are plotted 420 NEXT W 430 SUBEND 520 REM draw the circles inside the dish 530 SUB PROCCG(INV,INZ,INR) 535 DEF RAND(X)=INT(RND*X)+1 540 V=INV :: Z=INZ :: R=INR :: N=INR 550 A=2*PI/400 :: S=SIN(A):: C=COS(A):: X=R :: Y=0 560 FOR W=1 TO 400 :: B=X*C-Y*S :: Y=X*S+Y*C :: X=B 570 IF N>32 AND N<44 THEN GOTO 590 580 IF INT(RAND((44-N))/5)<>1 THEN GOTO 610 590 IF W>0 AND W<120+RAND(30)THEN CALL PLOT(V+X,Z+Y) 600 IF W>310+RAND(30)AND W<400 THEN CALL PLOT(V+X,Z+Y) 610 NEXT W 620 SUBEND 630 REM wipe the dish section - use the optimized brute force grid search 640 SUB PROCB(INV,INZ,INR) 645 CALL LINK("PE") 650 RAD=INR 660 REM Super fast filled circle (does require a single square root) 670 REM from https:://stackoverflow.com/questions/1201200/fast-algorithm-for-drawing-filled-circles 680 FOR X=-RAD TO RAD 690 HH=SQR(RAD*RAD-X*X) 700 RX=INV+X 710 PH=INZ+HH 720 FOR Y=INZ-HH TO PH 730 CALL PLOT(RX,Y) 740 NEXT Y 750 NEXT X 755 CALL LINK("PD") 760 SUBEND 770 SUB PLOT(X,Y) 780 IF Y<0 OR Y>191 THEN SUBEXIT 790 IF X<0 OR X>255 THEN SUBEXIT 800 MY=191-Y :: REM INVERTED Y AXIS 810 CALL LINK("PIXEL",MY,X) 820 SUBEND 21 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted December 10, 2022 Share Posted December 10, 2022 this takes so long to draw anything i thought i had pasted badly had to turn on maximum overdrive 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted December 10, 2022 Share Posted December 10, 2022 Does the empire know you have the stolen plans to the Death Star? 4 6 Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 11, 2022 Author Share Posted December 11, 2022 1 hour ago, arcadeshopper said: this takes so long to draw anything i thought i had pasted badly had to turn on maximum overdrive That's how I felt, except that I thought I had messed up the draw commands. It was surprisingly tricky to port. First was that the BBC graphics commands were surprisingly multi-featured -- single commands could do dozens of things with just a single number changing. It also ran in a much higher resolution, so I had to reverse engineer the various loops to understand how it worked. Anyway, was a fun exercise. 6 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted December 11, 2022 Share Posted December 11, 2022 20 minutes ago, jedimatt42 said: Does the empire know you have the stolen plans to the Death Star? How many, @Tursi? How many Bothans had to die to get it to you?? 9 Quote Link to comment Share on other sites More sharing options...
SteveB Posted December 11, 2022 Share Posted December 11, 2022 26 minutes ago, jedimatt42 said: Does the empire know you have the stolen plans to the Death Star? He is on a diplomatic mission ... 6 Quote Link to comment Share on other sites More sharing options...
JB Posted December 11, 2022 Share Posted December 11, 2022 Tursi's real name is Kyle Katarn? Never woulda guessed. 2 Quote Link to comment Share on other sites More sharing options...
+DuaneAL Posted December 11, 2022 Share Posted December 11, 2022 2 hours ago, arcadeshopper said: this takes so long to draw anything i thought i had pasted badly had to turn on maximum overdrive Would this benefit from compiling? Is it compiler compatible? I'm not asking because I think it needs it, but more of a general question about what is possible. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted December 11, 2022 Share Posted December 11, 2022 2 hours ago, DuaneAL said: Would this benefit from compiling? Is it compiler compatible? I'm not asking because I think it needs it, but more of a general question about what is possible. Looks like some fractional numbers, so probably not. 1 Quote Link to comment Share on other sites More sharing options...
artrag Posted December 11, 2022 Share Posted December 11, 2022 Very nice I will try to port it to msx 1 Quote Link to comment Share on other sites More sharing options...
artrag Posted December 11, 2022 Share Posted December 11, 2022 Questions about LINK BASIC: 1. CALL LINK("PIXEL",MY,X) does set a pixel at (x,my) on the screen ? 2. CALL LINK("CLEAR")::CALL SCREEN(2)::CALL LINK("COLOR",8,2) does set the screen in bitmap mode (256x192x16 colors 3 nametables), using color 8 as foreground and 2 as background (here colors go from 1 to 16, instead of 0-15) ? 3. CALL LINK("PE") what does it do? 4. CALL LINK("PD") what does it do? Quote Link to comment Share on other sites More sharing options...
artrag Posted December 11, 2022 Share Posted December 11, 2022 Found this https://pixelpedant.com/files/original/4296f6b5e351ab9e1bf8e350c4a4c09f.pdf 2 Quote Link to comment Share on other sites More sharing options...
PeteE Posted December 12, 2022 Share Posted December 12, 2022 I was curious how it looked on BBC and tracked down Electron Greg's mastodon post. In case anyone else is interested... 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted December 12, 2022 Share Posted December 12, 2022 19 hours ago, artrag said: Questions about LINK BASIC: 1. CALL LINK("PIXEL",MY,X) does set a pixel at (x,my) on the screen ? 2. CALL LINK("CLEAR")::CALL SCREEN(2)::CALL LINK("COLOR",8,2) does set the screen in bitmap mode (256x192x16 colors 3 nametables), using color 8 as foreground and 2 as background (here colors go from 1 to 16, instead of 0-15) ? 3. CALL LINK("PE") what does it do? 4. CALL LINK("PD") what does it do? The missing link is the source of these and is included with classic99 under the Harry willhielm folder Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 12, 2022 Author Share Posted December 12, 2022 19 hours ago, artrag said: Questions about LINK BASIC: 1. CALL LINK("PIXEL",MY,X) does set a pixel at (x,my) on the screen ? 2. CALL LINK("CLEAR")::CALL SCREEN(2)::CALL LINK("COLOR",8,2) does set the screen in bitmap mode (256x192x16 colors 3 nametables), using color 8 as foreground and 2 as background (here colors go from 1 to 16, instead of 0-15) ? 3. CALL LINK("PE") what does it do? 4. CALL LINK("PD") what does it do? Sounds like you got it, but yes. PE sets the drawing mode to "erase" and PD sets it to "draw" (Pen Erase and Pen Down - turtle style ). Other tricky bits - using DEF RAND to create a RAND function which is 1-based instead of 0-based like the BBC, and using SUB for the various calls. The SUB PLOT in particular was just so I could be lazy about the screen transform, since the BBC counts from the bottom up. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted December 12, 2022 Share Posted December 12, 2022 Awesome! I'm porting this to the Coleco Adam using Turbo Pascal 3 under CP/M 2.2 with the Adam-specific graphic extensions Since the Adam uses the same video chip, the resolution should be the same. 2 Quote Link to comment Share on other sites More sharing options...
artrag Posted December 12, 2022 Share Posted December 12, 2022 There is something wrong in what I do... I do not get the main base and the small circle is not centered.... @Tursi Any idea on what I did wrong ? 100 ' Death Star by Electron Greg 110 ' Adapted by Tursilion - 256x192 version - unoptimized 120 ' 130 DIM AR(300) 140 DEF FNMYRD(X)=(INT(RND(1)*(X))+1) 150 ' prepare lookup table 160 V=640 : Z=522 : R=300 : PI = 3.1415926535898# 170 A=2*PI/R : S=SIN(A) : C=COS(A) : X=R : Y=0 180 FOR W=1 TO R 190 B=X*C-Y*S : Y=X*S+Y*C : X=B : AR(W)=600-(V+X) 200 NEXT W 210 ' 220 SCREEN 2 230 COLOR 7,1,1:CLS 240 ' draw globe 250 FOR NN=115 TO 210 : ' latitude 260 INV=64:INZ = (1080-(AR(219-NN)*7))/5:INR = AR(NN)/2.5:INN = NN: GOSUB 380 270 NEXT NN 280 ' clear out dish area 290 INV=100:INZ=130:INR=40: GOSUB 660 300 ' draw dish 310 FOR NN=0 TO 44 STEP 4 320 INV=100: INZ=130:INR=NN: GOSUB 530 330 NEXT NN 340 ' spin forever 350 COLOR ,,15 360 GOTO 360 370 ' draw the moon itself 380 ' 390 V=INV : Z=INZ : R=INR : N=INN 400 A=2*PI/360 : S=SIN(A) : C=COS(A) : X=R : Y=0 410 FOR W=1 TO 360 420 P=FNMYRD(W)-(N/2) 430 IF P>100 THEN GOTO 500 440 B=X*C-Y*S : Y=X*S+Y*C : X=B : Q=((V+X)*1.3)-(Z/10)+100 : O=((Z+Y)/4!)*1.34+(X/3) 450 IF W<180 THEN GOTO 500 460 IF N>148 AND N<152 THEN PSET(Q+12,191-(O-1)): GOTO 500 : ' belt 470 FOR M=1 TO (360-W)/30 480 PSET(Q+FNMYRD(8),191-O) : ' density set by how many random pixels are plotted 490 NEXT M 500 NEXT W 510 RETURN 520 ' draw the circles inside the dish 530 ' 540 V=INV : Z=INZ : R=INR : N=INR 550 A=2*PI/400 : S=SIN(A) : C=COS(A) : X=R : Y=0 560 FOR W=1 TO 400 570 B=X*C-Y*S : Y=X*S+Y*C : X=B 580 IF N>32 AND N<44 THEN GOTO 600 590 IF INT(FNMYRD((44-N))/5)<>1 THEN GOTO 620 600 IF W>0 AND W<120+FNMYRD(30) THEN PSET(V+X,191-(Z+Y)) 610 IF W>310+FNMYRD(30) AND W<400 THEN PSET(V+X,191-(Z+Y)) 620 NEXT W 630 RETURN 640 ' wipe the dish section - use the optimized brute force grid search 650 ' 660 ' Super fast filled circle (does require a single square root) 670 ' from https:://stackoverflow.com/questions/1201200/fast-algorithm-for-drawing-filled-circles 680 RAD=INR 690 FOR X=-RAD TO RAD 700 HH=SQR(RAD*RAD-X*X) 710 RX=INV+X 720 PH=INZ+HH 730 FOR Y=INZ-HH TO PH 740 PRESET(RX,191-Y) 750 NEXT Y 760 NEXT X 770 RETURN Quote Link to comment Share on other sites More sharing options...
fabrice montupet Posted December 12, 2022 Share Posted December 12, 2022 The small Circle appears in a second time, do you have waited some time after the main base has been drawn? Quote Link to comment Share on other sites More sharing options...
artrag Posted December 13, 2022 Share Posted December 13, 2022 8 hours ago, fabrice montupet said: The small Circle appears in a second time, do you have waited some time after the main base has been drawn? No I have blindly adapted the code to the msx basic. I do not see pauses in the original code Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 13, 2022 Author Share Posted December 13, 2022 Any suggestions for a good MSX emulator that has speed up and keyboard paste? I typed the whole thing by hand into BlueMSX, then pressed control-break to try and find the breakpoint key and it exited the emulator. So I pasted very slowly into fMSX, but I can't seem to make that run fast, so I saved from there, loaded into Blue... oi. That was a stumper once I got it going though... but I figured it out. Like Applesoft, MSX BASIC only has 2 letter variables. So, for instance, INV and INZ are the same variable (IN). I only used those variables to deal with the fact some subs were modifying the input variables and shouldn't... Fixing up lines 260,290,320,390,540,680,710,720,730 seemed to fix the base (I just changed from INZ,INV etc to IZ, IV, etc. I left RAD alone since there were no conflicts). Quote Link to comment Share on other sites More sharing options...
artrag Posted December 13, 2022 Share Posted December 13, 2022 (edited) Hi Tursi! Openmsx comes with a good GUI (Catapult) where there is a tab to past text to the emulator. BTW thanks for the suggestions ! I think that I have missed the two letters limit for names in msx basic. I will try to fix that tonight and let you know Edited December 13, 2022 by artrag Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted December 13, 2022 Share Posted December 13, 2022 On 12/10/2022 at 4:32 PM, arcadeshopper said: this takes so long to draw anything i thought i had pasted badly had to turn on maximum overdrive The perceived potential of combining massive floating point calculations and bitmap graphics for scientific or demo purposes in an XB environment is quickly hampered by the significant slowness of such calculations on the TI coupled with the need to call AL subroutine for bitmap access. I found that out the hard way with Orbital Rendez-vous (https://tigameshelf.net/edu.htm)... 2 Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 13, 2022 Author Share Posted December 13, 2022 7 hours ago, artrag said: Openmsx comes with a good GUI (Catapult) where there is a tab to past text to the emulator. BTW thanks for the suggestions ! I think that I have missed the two letters limit for names in msx basic. I will try to fix that tonight and let you know Ah, I tried that one, but I deleted it about 2 minutes. Just getting /into/ the emulator was way more complicated than it needed to be. But, if that's the one, I will keep it in mind. msx_workdisk.dsk Anyway, the fix should work. I got the full death star under BlueMSX. I guess I can just paste the disk image. 1 Quote Link to comment Share on other sites More sharing options...
oddemann Posted December 13, 2022 Share Posted December 13, 2022 I cant but wonder... is there other programming lango that can do it faster on the TI! 1 Quote Link to comment Share on other sites More sharing options...
artrag Posted December 13, 2022 Share Posted December 13, 2022 This is my version, the problem was the limit on 2 characters Thanks autoexec.bas 4 Quote Link to comment Share on other sites More sharing options...
