+OLD CS1 Posted December 13, 2022 Share Posted December 13, 2022 56 minutes ago, oddemann said: I cant but wonder... is there other programming lango that can do it faster on the TI! Yeah! Where are the Forth guys? This seems tailor-made for them. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted December 13, 2022 Share Posted December 13, 2022 Coleco Adam version in Turbo Pascal under CP/M 2.2. Takes about 29 minutes to complete. Note to self: avoid future literal translations from an untyped and unstructured language to a strongly typed and structured one. Saves a lot on the Tums... 6 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted December 13, 2022 Share Posted December 13, 2022 2 hours ago, oddemann said: I cant but wonder... is there other programming lango that can do it faster on the TI! many? try pascal, c, forth, cortex basic 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 13, 2022 Author Share Posted December 13, 2022 Apologies to the ports already done, but I had to take a stab at optimizing it. I got rid of the DEF and the SUBs, got rid of the lookup table (each value was only used once and there were a number of unused values in it anyway), and moved some of the processing out of the way when no work was being done. I also skipped a few latitudes that don't draw anyway. The one thing I couldn't optimize was the circle draws - I tried. The X*C-Y*S etc code is used to step through a circle -- but the /entire/ circle is always calculated. On the main base itself, the /back/ is calculated first, and that's wasted time. But because we're stepping, we have to do it. I'm not sure if that math is faster or slower than the corresponding SIN/COS calls, but I ran out of patience and I didn't want to try to calculate the circles to redo them. Still, this version is markedly faster. The screenshot here shows it finished - the new version on the left was started when the old version on the right had already drawn a few rows. (It's still slow, of course, I did this in overdrive ). It'd also be nice if we could do away with the need to invert the Y axis, and the upper bound on the pixel draw in line 320 could be reduced, but I wasn't happy with the simple reductions I tried. 100 REM Death Star by Electron Greg 110 REM Adapted by Tursilion - 256x192 version - optimized 120 REM TIXB with Missing Link 130 AL=2*PI/300 140 REM original lookup table boils down to just (idx=1-300): 150 REM (-COS(AL*IDX)*300)-40 160 REM SINCE NO VALUES ARE USED MORE THAN ONCE, JUST INLINE THAT 170 CALL LINK("CLEAR") 180 CALL SCREEN(2) 190 CALL LINK("COLOR",8,2) 200 REM draw globe 210 V=64 :: A=2*PI/360 :: S=SIN(A):: C=COS(A) 220 FOR N=120 TO 195 230 Z=(1080-(((-COS(AL*(219-N))*300)-40)*7))/5 240 Z2=Z/10 250 R=((-COS(AL*N)*300)-40)/2.5 260 X=R :: Y=0 :: N2=N/2 270 FOR W=1 TO 360 :: P=(INT(RND*W))-N2 :: IF P>99 THEN 340 280 B=X*C-Y*S :: Y=X*S+Y*C :: X=B 290 IF W<180 THEN 340 300 Q=((V+X)*1.3)-(Z/10)+100 :: O=((Z+Y)/4.0)*1.34+(X/3) 310 IF N>148 AND N<152 THEN CALL LINK("PIXEL",192-O,Q+12):: GOTO 340 320 LIM=(360-W)/30 330 FOR M=1 TO LIM :: CALL LINK("PIXEL",191-O,Q+INT(RND*8+1)):: NEXT M 340 NEXT W 350 NEXT N 360 REM clear out dish area 370 CALL LINK("PE") 380 RAD=40 390 REM Super fast filled circle (does require a single square root) 400 REM from https:://stackoverflow.com/questions/1201200/fast-algorithm-for-drawing-filled-circles 410 FOR X=-RAD TO RAD 420 HH=SQR(RAD*RAD-X*X) 430 RX=100+X 440 PH=130+HH 450 CALL LINK("LINE",HH+61,RX,191-PH,RX) 460 NEXT X 470 CALL LINK("PD") 480 REM draw the circles inside the dish 490 V=100 :: Z=130 :: A=2*PI/400 :: S=SIN(A):: C=COS(A) 500 FOR N=0 TO 40 STEP 4 510 X=N :: Y=0 520 FOR W=1 TO 400 :: B=X*C-Y*S :: Y=X*S+Y*C :: X=B 530 IF N>32 AND N<44 THEN 550 540 IF INT((RND*(44-N))/5)<>0 THEN 570 550 IF W>0 AND W<120+INT(RND*30+1)THEN CALL LINK("PIXEL",191-(Z+Y),V+X) 560 IF W>310+INT(RND*30+1)AND W<400 THEN CALL LINK("PIXEL",191-(Z+Y),V+X) 570 NEXT W 580 REM spin forever 590 NEXT N 600 GOTO 600 5 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted December 14, 2022 Share Posted December 14, 2022 5 hours ago, OLD CS1 said: Yeah! Where are the Forth guys? This seems tailor-made for them. I might give it a go when I get tired of pitching horseshoes, ..., on the beach. ...lee 4 1 3 Quote Link to comment Share on other sites More sharing options...
artrag Posted December 14, 2022 Share Posted December 14, 2022 Should I find the time I'll try to port it to C, just for fun. 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted December 14, 2022 Share Posted December 14, 2022 (edited) trying to port this to cortex basic, getting a weird error on line 340 which makes no sense as its just a next statement.. not sure what is up yet but here's the start nm i found it, you can't then line number its then goto.. more bugs ok i fixed a couple more things.. for next loops in xb if the value is <1 then it doesnt run in cortex it tries to do it anyway so added a check for lim <1 other math issues seem to be happening DSTAR Edited December 14, 2022 by arcadeshopper Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 14, 2022 Share Posted December 14, 2022 21 hours ago, OLD CS1 said: Yeah! Where are the Forth guys? This seems tailor-made for them. If I was actually smart, I could do it with integers. But that smart thing gets in my way a lot. 3 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted December 14, 2022 Share Posted December 14, 2022 (edited) 1 hour ago, arcadeshopper said: trying to port this to cortex basic, getting a weird error on line 340 which makes no sense as its just a next statement.. not sure what is up yet but here's the start nm i found it, you can't then line number its then goto.. more bugs ok i fixed a couple more things.. for next loops in xb if the value is <1 then it doesnt run in cortex it tries to do it anyway so added a check for lim <1 other math issues seem to be happening still learning cortex quirks.. heres updated.. still something very wrong but MAN is it faster than tml ah ha, x,y instead of y,x reversed coords.. still wrong tho DSTARR Edited December 14, 2022 by arcadeshopper 2 Quote Link to comment Share on other sites More sharing options...
RXB Posted December 14, 2022 Share Posted December 14, 2022 Been working on release of new version but occurred to me to use CALL PSAVE to copy the image to a file and load it instantly. Would only require running the creation file once. I would only need to find the VDP memory location of the screen and copy it to a file. Here is a previous example from years ago. 1 Quote Link to comment Share on other sites More sharing options...
artrag Posted December 15, 2022 Share Posted December 15, 2022 (edited) Using the compiled msx basic (msxbas2rom v0.2.9.7a) on msx1, it takes about 58 minutes (about the same as the interpreted basic). The compiler is in not very efficient but accept almost all the commands of msx basic autoexec.rom autoexec.bas Edited December 15, 2022 by artrag 4 Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted December 15, 2022 Share Posted December 15, 2022 I've got Greg's code under Cortex BASIC mostly working (still some glitches with the "radar dish"). Running on my 16-bit console, with the entire interpreter loaded into CPU RAM (for speed), the Death Star takes about 21 minutes. 5 Quote Link to comment Share on other sites More sharing options...
RXB Posted December 16, 2022 Share Posted December 16, 2022 Afraid TML will not run in RXB 2022, I think the extra XB ROM just makes it go to hell quickly. I loaded TML and ran DARKSTAR and it just locked up with a horrid sound on Classic99. Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted December 16, 2022 Share Posted December 16, 2022 Attached is the Cortex BASIC version of the DeathStar. I started with Greg’s (Arcade Shopper’s) conversion. Necessary changes were: - I unpacked the single line FOR-NEXT loop at 330 into three statements. That eliminated the strange FOR-NEXT errors being thrown up there (the original should work, but it doesn’t). - IF …… THEN [line number] doesn’t work in Cortex BASiC. IF ……. THEN GOTO [line number] does. - I reversed the axes of most PLOT statements. - When drawlng the filled circle of the radar using lines, it is necessary to UNPLOT the lines to achieve the black disc rather than PLOT them. Otherwise the interior circles don’t draw correctly (color table left in wrong state by PLOT?). - There is no need to repeatedly calculate RAD*RAD in line 420. I moved that calculation outside the loop. On my 16-bit console Cortex BASIC running from FinalGROM99 DeathStar executes in 24 minutes, 28 seconds. Cortex BASIC running from ROM executes DeathStar in 21 minutes, 6 seconds. DSTAR 6 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted December 16, 2022 Share Posted December 16, 2022 What are the main advantages of Cortex Basic versus standard XB? 2 Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted December 16, 2022 Share Posted December 16, 2022 Cortex Basic is dramatically faster than Extended Basic, particularly if you have 16-bit ram available (I'd say it averages 3x faster). It executes instantly (no prescan), lists and prints very quickly, etc. It also enables direct use of bitmap mode in addition to Graphics1, otherwise defaulting to a 40-column screen for program listings. When listing programs it indents loops. RAM is limited, however, even though it requires 32K. When running from the FinalGROM99 it has about 16k available for programs. When running solely out of CPU RAM (20% faster, loaded as an E/A option 3 program) it has only about 6K available for programs. That said, programs do tend to be very compact. Access to system features is very limited. It does have sprites, but no auto-motion. No sound commands. No file handling other than saving and loading programs. No speech. By comparison XB excels in providing access to sound, sprites, speech etc. via GPL routines - a much richer environment in that respect. 4 1 Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted December 16, 2022 Share Posted December 16, 2022 Another data point: Cortex BASIC running on Classic99 with 'Normal' CPU throttling executes the Deathstar in 29 minutes. 5 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 16, 2022 Share Posted December 16, 2022 On 12/13/2022 at 1:43 PM, Vorticon said: Coleco Adam version in Turbo Pascal under CP/M 2.2. Takes about 29 minutes to complete. Note to self: avoid future literal translations from an untyped and unstructured language to a strongly typed and structured one. Saves a lot on the Tums... Could you post your Pascal code? Imagine translating from an untyped and unstructured language to a structured language that has no algebraic notation. Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted December 17, 2022 Share Posted December 17, 2022 23 hours ago, Reciprocating Bill said: Cortex BASIC running from ROM executes DeathStar in 21 minutes, 6 seconds. That should be, "Cortex BASIC running from 16-bit CPU RAM executes DeathStar in 21 mintes, 6 seconds." Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted December 17, 2022 Share Posted December 17, 2022 13 hours ago, TheBF said: Could you post your Pascal code? Imagine translating from an untyped and unstructured language to a structured language that has no algebraic notation. Here you go. It's not very pretty as I just mostly transliterated Tursi's XB code out of laziness. With some extra effort this could leverage the Pascal language features much better. The code also has a couple of include files for the Coleco Adam specific CP/M graphics and text extensions I created with some leverage from some inline Z80 assembly code. Also this was coded directly on real hardware using my homebrew 40 col CP/M text editor (ADAMED) coded in 8080 assembly, hence why the listing is in 40 columns... {Original version for BBC micro} program deathstar; type TextString = String[42]; var ChrSet : array[1..6144] of Byte; AR : array[1..300] of real; V,Z,R : real; A,S,C,X,Y,B : real; N,W : integer; pstatus : boolean; {$I BMPBASE.PAS} {$I BMPTEXT.PAS} procedure plot(X,Y : real); var MY : integer; begin if (Y < 0) or (Y > 191) then exit; if (X < 0) or (X > 255) then exit; MY := 191 - Round(Y); Pixel(MY,Round(X),pstatus,4,1) end; procedure procc(INV,INZ,INR,INN : real); var P,Q,O,N : real; W,M : integer; label endproc; begin V := INV; Z := INZ; R := INR; N := INN; A := 2 * Pi / 360; S := sin(A); C := cos(A); X := R; Y := 0; for W := 1 to 360 do begin P := (Random(W)+1) - (N / 2); if P > 100 then goto endproc; B := X * C - Y * S; Y := X * S + Y * C; X := B; Q := ((V + X) * 1.3) - (Z / 10) + 100; O := ((Z + Y) / 4.0) * 1.34 + (X / 3); if W < 180 then goto endproc; if (N > 148) and (N < 152) then begin plot(Q + 12, O - 1); goto endproc end; for M := 1 to Round((360 - W) / 30) do plot(Q + Random(8) + 1,O); endproc: end; end; procedure proccg(INV,INZ,INR : real); label endproc; var W,N : integer; begin V := INV; Z := INZ; R := INR; N := Round(INR); A := 2 * Pi / 400; S := sin(A); C := cos(A); X := R; Y := 0; for W := 1 to 400 do begin B := X * C - Y * S; Y := X * S + Y * C; X := B; if (N <= 32) or (N >= 44) then if Round((Random(44 - N ) + 1) / 5) <> 1 then goto endproc; if (W > 0) and (W < (120 + Random(30)+1)) then plot(V + X, Z + Y); if (W > (310 + Random(30) + 1 )) and (W < 400) then plot(V + X, Z + Y); endproc: end; end; procedure procb(INV,INZ,INR : real); var IX,IY,PH : integer; RAD,HH,RX : real; begin pstatus := false; RAD := INR; for IX := Round(-RAD) to Round(RAD) do begin HH := Sqrt(Sqr(RAD) - Sqr(IX)); RX := INV + IX; PH := Round(INZ + HH); for IY := Round(INZ - HH) to PH do plot(RX,IY) end; pstatus := true end; begin BitmapInit; ScreenColor(1,1); Randomize; pstatus := true; V := 640; Z := 522; R := 300; A := 2 * Pi / 300; S := sin(A); C := cos(A); X := R; Y := 0; for W := 1 to 300 do begin B := X * C - Y * S; Y := X * S + Y * C; X := B; AR[W] := 600 - (V + X); end; for N := 115 to 210 do procc(64,(1080 - (AR[219 - N] * 7)) / 5,AR[N] / 2.5,N); procb(100,130,40); N := 0; repeat proccg(100,130,N); N := N + 4; until N = 44; repeat until GetKey = 32; VDPInit; end. 4 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 17, 2022 Share Posted December 17, 2022 1 hour ago, Vorticon said: Here you go. It's not very pretty as I just mostly transliterated Tursi's XB code out of laziness. With some extra effort this could leverage the Pascal language features much better. The code also has a couple of include files for the Coleco Adam specific CP/M graphics and text extensions I created with some leverage from some inline Z80 assembly code. Also this was coded directly on real hardware using my homebrew 40 col CP/M text editor (ADAMED) coded in 8080 assembly, hence why the listing is in 40 columns... {Original version for BBC micro} program deathstar; type TextString = String[42]; var ChrSet : array[1..6144] of Byte; AR : array[1..300] of real; V,Z,R : real; A,S,C,X,Y,B : real; N,W : integer; pstatus : boolean; {$I BMPBASE.PAS} {$I BMPTEXT.PAS} procedure plot(X,Y : real); var MY : integer; begin if (Y < 0) or (Y > 191) then exit; if (X < 0) or (X > 255) then exit; MY := 191 - Round(Y); Pixel(MY,Round(X),pstatus,4,1) end; procedure procc(INV,INZ,INR,INN : real); var P,Q,O,N : real; W,M : integer; label endproc; begin V := INV; Z := INZ; R := INR; N := INN; A := 2 * Pi / 360; S := sin(A); C := cos(A); X := R; Y := 0; for W := 1 to 360 do begin P := (Random(W)+1) - (N / 2); if P > 100 then goto endproc; B := X * C - Y * S; Y := X * S + Y * C; X := B; Q := ((V + X) * 1.3) - (Z / 10) + 100; O := ((Z + Y) / 4.0) * 1.34 + (X / 3); if W < 180 then goto endproc; if (N > 148) and (N < 152) then begin plot(Q + 12, O - 1); goto endproc end; for M := 1 to Round((360 - W) / 30) do plot(Q + Random(8) + 1,O); endproc: end; end; procedure proccg(INV,INZ,INR : real); label endproc; var W,N : integer; begin V := INV; Z := INZ; R := INR; N := Round(INR); A := 2 * Pi / 400; S := sin(A); C := cos(A); X := R; Y := 0; for W := 1 to 400 do begin B := X * C - Y * S; Y := X * S + Y * C; X := B; if (N <= 32) or (N >= 44) then if Round((Random(44 - N ) + 1) / 5) <> 1 then goto endproc; if (W > 0) and (W < (120 + Random(30)+1)) then plot(V + X, Z + Y); if (W > (310 + Random(30) + 1 )) and (W < 400) then plot(V + X, Z + Y); endproc: end; end; procedure procb(INV,INZ,INR : real); var IX,IY,PH : integer; RAD,HH,RX : real; begin pstatus := false; RAD := INR; for IX := Round(-RAD) to Round(RAD) do begin HH := Sqrt(Sqr(RAD) - Sqr(IX)); RX := INV + IX; PH := Round(INZ + HH); for IY := Round(INZ - HH) to PH do plot(RX,IY) end; pstatus := true end; begin BitmapInit; ScreenColor(1,1); Randomize; pstatus := true; V := 640; Z := 522; R := 300; A := 2 * Pi / 300; S := sin(A); C := cos(A); X := R; Y := 0; for W := 1 to 300 do begin B := X * C - Y * S; Y := X * S + Y * C; X := B; AR[W] := 600 - (V + X); end; for N := 115 to 210 do procc(64,(1080 - (AR[219 - N] * 7)) / 5,AR[N] / 2.5,N); procb(100,130,40); N := 0; repeat proccg(100,130,N); N := N + 4; until N = 44; repeat until GetKey = 32; VDPInit; end. Thanks very much. It's a thing of beauty. (Says the guy who had a Pascal program pin-up on his locker door) 1 Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted December 17, 2022 Share Posted December 17, 2022 (edited) A light improvement to play with. In the For-Next loop that begins at line 330 (a loop that is on one line in the original, but expanded to three in the Cortex BASIC version), substitute: Plot Q+INT(RND*4)+1 for Plot Q+INT(RND*8)+1 This reduces the randomized wiggle of pixel placement to a degree that is proportionate to the overall reduction in resolution that results from the translation from BBC to TI. I think it gives a result that subtly better resembles the original BBC version. Before and after: Edited December 17, 2022 by Reciprocating Bill 5 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted December 17, 2022 Share Posted December 17, 2022 2 hours ago, TheBF said: (Says the guy who had a Pascal program pin-up on his locker door) 3 Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted December 26, 2022 Share Posted December 26, 2022 (edited) On 12/10/2022 at 7:47 PM, DuaneAL said: Would this benefit from compiling? Is it compiler compatible? I'm not asking because I think it needs it, but more of a general question about what is possible. Yes, and yes. There are a few things to iron out because the compiler does not support floating point. At one point a value is divided by 2.5. To get around that, you can multiply by 2 and divide by 5. There are no trig functions so you have to come up with another way to do that. I made DATA statements that contain sine values from 0 to 90, multiplied by 255. These are read into the array SINE(N). Now when you want the sine of 5 degrees you can use SINE(5). Cosine of 5 degrees is SINE(5+90). And so on. Note that I use degrees and the TI99 uses radians. The FOR N/NEXT N loop uses angles in 1.2 degree steps. I had hoped to be able to round to the nearest degree, but the results were not so good. So I have a subroutine that interpolates and returns a value closer to the right one. You will see that the edge of the death star is not as sharp as the XB version that used floating point. There are 2 possibilities - rounding due to the integer math, or perhaps my math conversions are not quite right. In the video below both Classic99's are running at the normal speed. If you look hard enough, you can probably see that the performance has been somewhat enhanced. 1 !CALL LINK("tml16") 2 !DEATHSTAR modifed to be compatible with XB compiler 100 REM Death Star by Electron Greg 110 REM Adapted by Tursilion - 256x192 version - optimized 120 REM TIXB with Missing Link 121 !MAKE SINE TABLE. All values are *255 and rounded to nearest integer. Could do with 0 to 90, but this should speed it up a bit. 122 DIM SINE(450) 124 FOR I=0 TO 90 :: READ S :: SINE(I)=S :: SINE(180-I)=S :: SINE(180+I)=-S :: SINE(360-I)=-S :: SINE(360+I)=S :: NEXT I 140 REM original lookup table boils down to just (idx=1-300): 170 CALL LINK("CLEAR") 180 CALL SCREEN(2) 190 CALL LINK("COLOR",8,2) 200 REM draw globe 210 V=64 220 FOR N=120 TO 195 231 GOSUB 800 :: Z=(1080-(-COSINE*60/51-40)*7)/5 240 Z2=Z/10 251 GOSUB 810 :: R=(-COSINE*60/51-40)*2/5 260 X=R :: Y=0 :: N2=N/2 268 TOT=0 270 FOR W=1 TO 360 :: P=(INT(RND*W))-N2 :: IF P>99 THEN 340 275 TOT=TOT+1 281 X=R*SINE(TOT+90)/255 :: Y=R*SINE(TOT)/255 290 IF W<180 THEN 340 301 Q=((V+X)*13/10)-(Z/10)+100 :: O=((Z+Y)/4)*134/100+X/3 310 IF N>148 AND N<152 THEN CALL LINK("PIXEL",192-O,Q+12):: GOTO 340 320 LIM=(360-W)/30 330 FOR M=1 TO LIM :: CALL LINK("PIXEL",191-O,Q+INT(RND*8+1)):: NEXT M 340 NEXT W 350 NEXT N 360 REM clear out dish area 370 CALL LINK("PE") 380 RAD=40 390 REM Super fast filled circle (does require a single square root) 400 REM from https:://stackoverflow.com/questions/1201200/fast-algorithm-for-drawing-filled-circles 410 FOR X=-RAD TO RAD 420 HH=SQR(RAD*RAD-X*X) 430 RX=100+X 440 PH=130+HH 450 CALL LINK("LINE",HH+61,RX,191-PH,RX) 460 NEXT X 470 CALL LINK("PD") 480 REM draw the circles inside the dish 490 V=100 :: Z=130 !:: A=2*PI/400 :: S=SIN(A):: C=COS(A) 500 FOR N=0 TO 40 STEP 4 510 !X=N :: Y=0 520 FOR W=1 TO 360 :: Y=SINE(W)*N/255 :: X=SINE(W+90)*N/255 !B=X*C-Y*S :: Y=X*S+Y*C :: X=B 530 IF N>32 AND N<44 THEN 550 540 IF INT((RND*(44-N))/5)<>0 THEN 570 550 IF W>0 AND W<108+INT(RND*30+1)THEN CALL LINK("PIXEL",191-(Z+Y),V+X):: GOTO 570 560 IF W>279+INT(RND*30+1)AND W<400 THEN CALL LINK("PIXEL",191-(Z+Y),V+X) 570 NEXT W 580 REM spin forever 590 NEXT N 600 GOTO 600 800 ANG=219-N :: GOTO 820 810 ANG=N 820 A6=ANG*6 :: A65=INT(A6/5):: RMD=A6-5*A65 830 COS0=SINE(A65+90):: COS1=SINE(A65+91) 840 COSINE=INT(((5-RMD)*COS0+RMD*COS1)/5) 850 RETURN 1000 DATA 0,4,9,13,18,22,27,31,35,40,44,49,53,57,62,66,70,75,79,83,87,91,96,100,104,108,112,116,120,124 1001 DATA 128,131,135,139,143,146,150,153,157,160,164,167,171,174,177,180,183,186,190,192,195,198,201 1002 DATA 204,206,209,211,214,216,219,221,223,225,227,229,231,233,235,236,238,240,241,243,244,245,246 1003 DATA 247,248,249,250,251,252,253,253,254,254,254,255,255,255,255 Edited December 26, 2022 by senior_falcon 6 2 Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 27, 2022 Author Share Posted December 27, 2022 Very nice! 1 Quote Link to comment Share on other sites More sharing options...
