darwinmac Posted January 1 Share Posted January 1 @tschak909, @mozzwald I was testing an ATX file with my new Atari 800XL. It is Micro League Baseball. I thought this ATX file worked with an older version of the Fujinet firmware (I'm not sure about that though), but it does not work with the last two firmware releases (including the December 23rd release). I tested the exact ATX file with my Sdrive Max and it loaded successfully. In this case, Djaybee has created a cracked ATR that works perfectly with my Fujinet. I just wanted to report the problem in case anyone is looking into ATX problems. I have been able to load other ATX files with my Fujinet so I am not having problems with all ATX files. With this file, the game locks up at the starting splash screen. It should continue to the main menu where you can start the game. Here's a link to the file if you're interested: https://www.dropbox.com/s/pnhueyi47dexuhf/Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx?dl=0 Bob C Quote Link to comment Share on other sites More sharing options...
tschak909 Posted January 1 Share Posted January 1 1 minute ago, darwinmac said: @tschak909, @mozzwald I was testing an ATX file with my new Atari 800XL. It is Micro League Baseball. I thought this ATX file worked with an older version of the Fujinet firmware (I'm not sure about that though), but it does not work with the last two firmware releases (including the December 23rd release). I tested the exact ATX file with my Sdrive Max and it loaded successfully. In this case, Djaybee has created a cracked ATR that works perfectly with my Fujinet. I just wanted to report the problem in case anyone is looking into ATX problems. I have been able to load other ATX files with my Fujinet so I am not having problems with all ATX files. With this file, the game locks up at the starting splash screen. It should continue to the main menu where you can start the game. Here's a link to the file if you're interested: https://www.dropbox.com/s/pnhueyi47dexuhf/Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx?dl=0 Bob C Thank you, I will dig into this, as soon as I can shake off the alcohol. Happy New year! -Thom 1 Quote Link to comment Share on other sites More sharing options...
darwinmac Posted January 1 Author Share Posted January 1 Thanks. There’s no hurry. Bob C Quote Link to comment Share on other sites More sharing options...
darwinmac Posted January 10 Author Share Posted January 10 @tschak909 - I was curious if you’ve had a chance to look at the ATX file yet. Bob C Quote Link to comment Share on other sites More sharing options...
DjayBee Posted January 10 Share Posted January 10 This must be a timing issue. The last track contains 18 instances of sector 720. The game loads the sector 10 times and checks the time needed to do this. 1 Quote Link to comment Share on other sites More sharing options...
darwinmac Posted February 7 Author Share Posted February 7 @tschak909 - I found another problematic ATX file. It is Castle Wolfenstein. It appears to be the original 1983 Muse software release and not the later re-release. Since Atarimania doesn't have an ATX file of this title, I could have only gotten it from the large A8 Preservation project. In this case, the disk image stops loading and shows an "@" symbol (or something that looks very much like that). The image does have to be write-enabled. Otherwise, you will get another error after the title screen. That is the error I get when I attempt to load the ATX file on Atari800MacX. I have been able to successfully load the ATX file with Altirra. I haven't gotten out my Sdrive Max again to see if it works there. Bob C Quote Link to comment Share on other sites More sharing options...
darwinmac Posted February 8 Author Share Posted February 8 I’ve also seen one other weird thing with at least some of the ATX files. If I have an ATX file in D2. (maybe the ATX file needs the Translator disk), I’ll get a “BOOT ERROR” message. If I eject the ATX file from D2, the system will boot normally. Bob C 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 8 Share Posted February 8 Iiinteresting... will try to reproduce. Thanks. Quote Link to comment Share on other sites More sharing options...
darwinmac Posted February 12 Author Share Posted February 12 @tschak909 - Thom, I found some behavior differences between running ATX files from my local SD card and using my internal TNFS server (my M1 MacBook Air): From the SD card: - Loading Castle Wolfenstein ATX will result in a blank screen with what looks like a "@" character and the game never loads - Loading the Atari Translator ATR and Bible Baseball ATX file will result in a BOOT ERROR message From my local TNFS server: - Castle Wolfenstein ATX loads but the the write-enable flag on the ATX is not respected because I receive a message that I should write-enable the disk and try again. - Loading the Atari Translator ATR and Bible Baseball ATX file will load correctly when I move Bible Baseball to D1. The SAM capability when I press the button to rotate the disks is quite useful. Along with enjoying trivia-style games, I selected Bible Baseball for this test because I doubt the disk had much, if any, copy protection on it. As a small developer who created religious trivia games for the 8-bit, I doubt they worried about extensive copy protection schemes. Their small user base probably wasn't going to be involved with too many late night disk copy parties. 🙂 I'm hoping this information might be helpful. Bob C 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 12 Share Posted February 12 14 minutes ago, darwinmac said: @tschak909 - Thom, I found some behavior differences between running ATX files from my local SD card and using my internal TNFS server (my M1 MacBook Air): From the SD card: - Loading Castle Wolfenstein ATX will result in a blank screen with what looks like a "@" character and the game never loads - Loading the Atari Translator ATR and Bible Baseball ATX file will result in a BOOT ERROR message From my local TNFS server: - Castle Wolfenstein ATX loads but the the write-enable flag on the ATX is not respected because I receive a message that I should write-enable the disk and try again. - Loading the Atari Translator ATR and Bible Baseball ATX file will load correctly when I move Bible Baseball to D1. The SAM capability when I press the button to rotate the disks is quite useful. Along with enjoying trivia-style games, I selected Bible Baseball for this test because I doubt the disk had much, if any, copy protection on it. As a small developer who created religious trivia games for the 8-bit, I doubt they worried about extensive copy protection schemes. Their small user base probably wasn't going to be involved with too many late night disk copy parties. 🙂 I'm hoping this information might be helpful. Bob C Yes, thank you so much -Thom Quote Link to comment Share on other sites More sharing options...
darwinmac Posted February 12 Author Share Posted February 12 I should also mention that I confirmed that I mounted Castle Wolfenstein as R/W since I knew the game wanted the disk to be write-enabled. Bob C Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 12 Share Posted February 12 14 hours ago, darwinmac said: I should also mention that I confirmed that I mounted Castle Wolfenstein as R/W since I knew the game wanted the disk to be write-enabled. Bob C There currently is no support for read/write in ATX. Would be nice for someone to try and add it. -Thom Quote Link to comment Share on other sites More sharing options...
darwinmac Posted February 12 Author Share Posted February 12 1 hour ago, tschak909 said: There currently is no support for read/write in ATX. Would be nice for someone to try and add it. -Thom I thought that might be the case. I’m still not sure why the same ATX file copied to my SD card produces a different result. Bob C Quote Link to comment Share on other sites More sharing options...
darwinmac Posted February 19 Author Share Posted February 19 @tschak909 - I had a chance to try the original ATXs that caused me problems (Micro League Baseball and Team Disk). When I run the game from my local TNFS server (also known as my M1 MacBook Air), the game loads successfully and I have no problems playing it. I have no idea why the ATX would load successfully from my TNFS server and not from the SD card. Until I am able to move, I do not have space to keep my Mac running all the time. Therefore, I have only used the TNFS for initial testing to know that I knew how to run one and for testing different games that I haven't loaded onto my SD card. While my SD card could be bad, it successfully runs ATR files and most of the ATX files I have put on the card. I admit I have only put a few ATX files on the SD card right now. I'm hoping you may be able to determine why the behavior might be different between streaming it from the TNFS server and loading it from the local SD card. Bob C Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 19 Share Posted February 19 That is another interesting data point, and something I need to try. A debug log from the flasher trying a load from SD card would be useful here. -Thom Quote Link to comment Share on other sites More sharing options...
darwinmac Posted February 20 Author Share Posted February 20 (edited) Thom, I learned something new today. I've never used the Serial Debug Output before. The wiki had a very good explanation on how to use it. I've attached the log in a spoiler tag as you requested. Spoiler Using '/dev/cu.usbserial-10' as serial port. Using '460800' as baud rate. Showing logs: [18:06:57] BUTTON_C: SHORT PRESS [18:06:57] ACTION: Reboot [18:06:57] Shutting down device 5a [18:06:57] Shutting down device 43 [18:06:57] Shutting down device 50 [18:06:57] Shutting down device 40 [18:06:57] Shutting down device 99 [18:06:57] Shutting down device 45 [18:06:57] Shutting down device 70 [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] Shutting down device 5f [18:06:57] Shutting down device 78 [18:06:57] Shutting down device 77 [18:06:57] Shutting down device 76 [18:06:57] Shutting down device 75 [18:06:57] Shutting down device 74 [18:06:57] Shutting down device 73 [18:06:57] Shutting down device 72 [18:06:57] Shutting down device 71 [18:06:57] Shutting down device 38 [18:06:57] Shutting down device 37 [18:06:57] Shutting down device 36 [18:06:57] Shutting down device 35 [18:06:57] Shutting down device 34 [18:06:57] Shutting down device 33 [18:06:57] Shutting down device 32 [18:06:57] Shutting down device 31 [18:06:57] All devices shut down. [18:06:57] WIFI_EVENT_STA_DISCONNECTED [18:06:57] Stopping web service [18:06:57] Shutdown handler called [18:06:57] Shutting down device 5a [18:06:57] Shutting down device 43 [18:06:57] Shutting down device 50 [18:06:57] Shutting down device 40 [18:06:57] Shutting down device 99 [18:06:57] Shutting down device 45 [18:06:57] Shutting down device 70 [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] Shutting down device 5f [18:06:57] Shutting down device 78 [18:06:57] Shutting down device 77 [18:06:57] Shutting down device 76 [18:06:57] Shutting down device 75 [18:06:57] Shutting down device 74 [18:06:57] Shutting down device 73 [18:06:57] Shutting down device 72 [18:06:57] Shutting down device 71 [18:06:57] Shutting down device 38 [18:06:57] Shutting down device 37 [18:06:57] Shutting down device 36 [18:06:57] Shutting down device 35 [18:06:57] Shutting down device 34 [18:06:57] Shutting down device 33 [18:06:57] Shutting down device 32 [18:06:57] Shutting down device 31 [18:06:57] All devices shut down. [18:06:58] [18:06:58] [18:06:58] --~--~--~-- [18:06:58] FujiNet 0.5.13741956 2023-01-30 22:44:10 Started @ 5 [18:06:58] Starting heap: 4365075 [18:06:58] Detected Hardware Version: 1.6.1 and up [18:06:58] Safe Reset Button 😄 ENABLED [18:06:58] SPIFFS mounted. [18:06:58] SD mounted. [18:06:58] fnConfig::load [18:06:58] Load fnconfig.ini from SD [18:06:58] fopen = /fnconfig.ini : ok [18:06:58] fnConfig::load read 1178 bytes from config file [18:06:58] SPIFFS Config Storage: Enabled [18:06:58] fnConfig::load read 1178 bytes from SPIFFS config file [18:06:58] disk UNMOUNT [18:06:58] disk MOUNT [18:06:58] ATR MOUNT [18:06:58] mounted ATR: paragraphs=5760, sect_size=128, sect_count=720, disk_size=0 [18:06:58] Creating a default printer using FS_SDFAT storage and type 12 [18:06:58] ModemSniffer::ModemSniffer(FS_SDFAT) [18:06:58] SIO SETUP [18:06:58] Set HSIO baud from 0 to 67431 (index 6), alt=68209 [18:06:58] Available heap: 4272083 [18:06:58] Setup complete @ 668 (663ms) [18:06:59] WiFiManager::start() complete [18:06:59] WIFI_EVENT_STA_START [18:06:59] WiFi connect attempt to SSID "Paris2015" [18:06:59] esp_wifi_connect returned 0 [18:06:59] WIFI_EVENT_STA_CONNECTED [18:07:00] IP_EVENT_STA_GOT_IP [18:07:00] Obtained IP address: 192.168.7.249 [18:07:00] SNTP client start [18:07:00] Starting web server on port 80 [18:07:01] SNTP time sync event: Sun Feb 19, 18:07:01 2023 -0800 [18:07:10] [18:07:10] CF: 00 e0 e0 e0 e0 [18:07:10] CHECKSUM_ERROR [18:07:10] [18:07:10] CF: 00 e0 e0 e0 e0 [18:07:10] CHECKSUM_ERROR [18:07:10] Toggling baudrate from 19200 to 67431 [18:07:10] [18:07:10] CF: 00 38 38 00 00 [18:07:10] CHECKSUM_ERROR [18:07:10] [18:07:10] CF: 00 38 38 00 00 [18:07:10] CHECKSUM_ERROR [18:07:10] Toggling baudrate from 67431 to 19200 [18:07:10] [18:07:10] CF: 70 f5 00 00 66 [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: CLOSE DIRECTORY [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f9 00 00 6a [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: MOUNT HOST [18:07:10] ::mount {0} "SD" [18:07:10] ::mount_local Attempting mount of "SD" [18:07:10] Setting type to LOCAL [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f7 00 00 68 [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: OPEN DIRECTORY [18:07:10] <-SIO read 256 bytes [18:07:10] ACK! [18:07:10] Opening directory: "/", pattern: "" [18:07:10] ::dir_open {0:1} "/", pattern "" [18:07:10] ::dir_open actual path = "/" [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f6 24 00 8b [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:10] ::dir_nextfile {0:1} [18:07:10] ::read_direntry "0-9" [18:07:10] ->SIO write 36 bytes [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f6 24 00 8b [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:10] ::dir_nextfile {0:1} [18:07:10] ::read_direntry "A" [18:07:10] ->SIO write 36 bytes [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f6 24 00 8b [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:10] ::dir_nextfile {0:1} [18:07:10] ::read_direntry "B" [18:07:10] ->SIO write 36 bytes [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f6 24 00 8b [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:10] ::dir_nextfile {0:1} [18:07:10] ::read_direntry "C" [18:07:10] ->SIO write 36 bytes [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f6 24 00 8b [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:10] ::dir_nextfile {0:1} [18:07:10] ::read_direntry "D" [18:07:10] ->SIO write 36 bytes [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f6 24 00 8b [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:10] ::dir_nextfile {0:1} [18:07:10] ::read_direntry "E" [18:07:10] ->SIO write 36 bytes [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f6 24 00 8b [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:10] ::dir_nextfile {0:1} [18:07:10] ::read_direntry "F" [18:07:11] ->SIO write 36 bytes [18:07:11] COMPLETE! [18:07:11] [18:07:11] CF: 70 f6 24 00 8b [18:07:11] sioFuji::sio_process() called [18:07:11] ACK! [18:07:11] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:11] ::dir_nextfile {0:1} [18:07:11] ::read_direntry "FujiNet" [18:07:11] ->SIO write 36 bytes [18:07:11] COMPLETE! [18:07:11] [18:07:11] CF: 70 f6 24 00 8b [18:07:11] sioFuji::sio_process() called [18:07:11] ACK! [18:07:11] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:11] ::dir_nextfile {0:1} [18:07:11] ::read_direntry "G" [18:07:11] ->SIO write 36 bytes [18:07:11] COMPLETE! [18:07:11] [18:07:11] CF: 70 f6 24 00 8b [18:07:11] sioFuji::sio_process() called [18:07:11] ACK! [18:07:11] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:11] ::dir_nextfile {0:1} [18:07:11] ::read_direntry "H" [18:07:11] ->SIO write 36 bytes [18:07:11] COMPLETE! [18:07:11] [18:07:11] CF: 70 f6 24 00 8b [18:07:11] sioFuji::sio_process() called [18:07:11] ACK! [18:07:11] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:11] ::dir_nextfile {0:1} [18:07:11] ::read_direntry "I" [18:07:11] ->SIO write 36 bytes [18:07:11] COMPLETE! [18:07:11] [18:07:11] CF: 70 f6 24 00 8b [18:07:11] sioFuji::sio_process() called [18:07:11] ACK! [18:07:11] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:11] ::dir_nextfile {0:1} [18:07:11] ::read_direntry "J" [18:07:11] ->SIO write 36 bytes [18:07:11] COMPLETE! [18:07:11] [18:07:11] CF: 70 f6 24 00 8b [18:07:11] sioFuji::sio_process() called [18:07:11] ACK! [18:07:11] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:11] ::dir_nextfile {0:1} [18:07:11] ::read_direntry "K" [18:07:11] ->SIO write 36 bytes [18:07:11] COMPLETE! [18:07:11] [18:07:11] CF: 70 f6 24 00 8b [18:07:11] sioFuji::sio_process() called [18:07:11] ACK! [18:07:11] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:11] ::dir_nextfile {0:1} [18:07:11] ::read_direntry "L" [18:07:11] ->SIO write 36 bytes [18:07:11] COMPLETE! [18:07:11] [18:07:11] CF: 70 f5 00 00 66 [18:07:11] sioFuji::sio_process() called [18:07:11] ACK! [18:07:11] Fuji cmd: CLOSE DIRECTORY [18:07:11] COMPLETE! [18:07:13] [18:07:13] CF: 70 f9 00 00 6a [18:07:13] sioFuji::sio_process() called [18:07:13] ACK! [18:07:13] Fuji cmd: MOUNT HOST [18:07:13] ::mount {0} "SD" [18:07:13] ::mount_local Attempting mount of "SD" [18:07:13] Type is already LOCAL [18:07:13] COMPLETE! [18:07:13] [18:07:13] CF: 70 f7 00 00 68 [18:07:13] sioFuji::sio_process() called [18:07:13] ACK! [18:07:13] Fuji cmd: OPEN DIRECTORY [18:07:13] <-SIO read 256 bytes [18:07:13] ACK! [18:07:13] Opening directory: "/", pattern: "" [18:07:13] ::dir_open {0:1} "/", pattern "" [18:07:13] ::dir_open actual path = "/" [18:07:13] COMPLETE! [18:07:13] [18:07:13] CF: 70 e4 0d 00 62 [18:07:13] sioFuji::sio_process() called [18:07:13] ACK! [18:07:13] Fuji cmd: SET DIRECTORY POSITION [18:07:13] ::dir_seek {0:1} 13 [18:07:13] COMPLETE! [18:07:13] [18:07:13] CF: 70 f6 24 00 8b [18:07:13] sioFuji::sio_process() called [18:07:13] ACK! [18:07:13] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:13] ::dir_nextfile {0:1} [18:07:13] ::read_direntry "L" [18:07:13] ->SIO write 36 bytes [18:07:13] COMPLETE! [18:07:13] [18:07:13] CF: 70 f6 24 00 8b [18:07:13] sioFuji::sio_process() called [18:07:13] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "M" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "N" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "O" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "P" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "Q" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "R" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "S" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "T" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "U" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "W" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "Z" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "ZZdemos" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "weather.atr" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f5 00 00 66 [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: CLOSE DIRECTORY [18:07:14] COMPLETE! [18:07:16] [18:07:16] CF: 70 f7 00 00 68 [18:07:16] sioFuji::sio_process() called [18:07:16] ACK! [18:07:16] Fuji cmd: OPEN DIRECTORY [18:07:16] <-SIO read 256 bytes [18:07:16] ACK! [18:07:16] Opening directory: "/", pattern: "" [18:07:16] ::dir_open {0:1} "/", pattern "" [18:07:16] ::dir_open actual path = "/" [18:07:16] COMPLETE! [18:07:16] [18:07:16] CF: 70 e4 0e 00 63 [18:07:16] sioFuji::sio_process() called [18:07:16] ACK! [18:07:16] Fuji cmd: SET DIRECTORY POSITION [18:07:16] ::dir_seek {0:1} 14 [18:07:16] COMPLETE! [18:07:16] [18:07:16] CF: 70 f6 80 00 e7 [18:07:16] sioFuji::sio_process() called [18:07:16] ACK! [18:07:16] Fuji cmd: READ DIRECTORY ENTRY (max=128) [18:07:16] ::dir_nextfile {0:1} [18:07:16] ::read_direntry "M" [18:07:16] ->SIO write 128 bytes [18:07:16] COMPLETE! [18:07:16] [18:07:16] CF: 70 f5 00 00 66 [18:07:16] sioFuji::sio_process() called [18:07:16] ACK! [18:07:16] Fuji cmd: CLOSE DIRECTORY [18:07:16] COMPLETE! [18:07:16] [18:07:16] CF: 70 f7 00 00 68 [18:07:16] sioFuji::sio_process() called [18:07:16] ACK! [18:07:16] Fuji cmd: OPEN DIRECTORY [18:07:16] <-SIO read 256 bytes [18:07:17] ACK! [18:07:17] Opening directory: "/", pattern: "" [18:07:17] ::dir_open {0:1} "/", pattern "" [18:07:17] ::dir_open actual path = "/" [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 e4 0e 00 63 [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: SET DIRECTORY POSITION [18:07:17] ::dir_seek {0:1} 14 [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 80 01 e8 [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=128) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "M" [18:07:17] ->SIO write 128 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f5 00 00 66 [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: CLOSE DIRECTORY [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f9 00 00 6a [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: MOUNT HOST [18:07:17] ::mount {0} "SD" [18:07:17] ::mount_local Attempting mount of "SD" [18:07:17] Type is already LOCAL [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f7 00 00 68 [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: OPEN DIRECTORY [18:07:17] <-SIO read 256 bytes [18:07:17] ACK! [18:07:17] Opening directory: "/M", pattern: "" [18:07:17] ::dir_open {0:1} "/M", pattern "" [18:07:17] ::dir_open actual path = "/M" [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Major Bronx (bug fixed) (L.K. Avalon - 1992) (AD02392).atr" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Mary Poppins 1.17.atr" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!][cr CSS].atr" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Micro League Baseball - Player Stats + Team Disk - World Series Teams - 1950's.atx" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1983 NL and AL Teams (1984)(Micro League Sports Association)(US).atr" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1984 NL and AL Teams (1984)(Micro League Sports Association)(US)[m].atr" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1985 NL and AL Teams (1985)(Micro League Sports Association)(US)[m].atr" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1986 NL and AL Teams (1986)(Micro League Sports Association)(US)[m].atr" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:18] [18:07:18] CF: 70 f6 24 00 8b [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:18] ::dir_nextfile {0:1} [18:07:18] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1987 NL and AL Teams (1987)(Micro League Sports Association)(US)[m].atr" [18:07:18] ->SIO write 36 bytes [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 f6 24 00 8b [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:18] ::dir_nextfile {0:1} [18:07:18] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1989 NL and AL Teams (1989)(Micro League Sports Association)(US).atr" [18:07:18] ->SIO write 36 bytes [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 f6 24 00 8b [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:18] ::dir_nextfile {0:1} [18:07:18] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - Franchise History - Minnesota Twins (1984)(Micro League Sports Association)(US).atr" [18:07:18] ->SIO write 36 bytes [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 f6 24 00 8b [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:18] ::dir_nextfile {0:1} [18:07:18] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - Franchise History - New York Yankees (1984)(Micro League Sports Association)(US).atr" [18:07:18] ->SIO write 36 bytes [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 f6 24 00 8b [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:18] ::dir_nextfile {0:1} [18:07:18] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - World Series Teams (1950's) (1984)(Micro League Sports Association)(US).atr" [18:07:18] ->SIO write 36 bytes [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 f5 00 00 66 [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: CLOSE DIRECTORY [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 f7 00 00 68 [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: OPEN DIRECTORY [18:07:18] <-SIO read 256 bytes [18:07:18] ACK! [18:07:18] Opening directory: "/M", pattern: "" [18:07:18] ::dir_open {0:1} "/M", pattern "" [18:07:18] ::dir_open actual path = "/M" [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 e4 00 00 55 [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: SET DIRECTORY POSITION [18:07:18] ::dir_seek {0:1} 0 [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 f6 40 00 a7 [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: READ DIRECTORY ENTRY (max=64) [18:07:18] ::dir_nextfile {0:1} [18:07:18] ::read_direntry "Major Bronx (bug fixed) (L.K. Avalon - 1992) (AD02392).atr" [18:07:18] ->SIO write 64 bytes [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 f5 00 00 66 [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: CLOSE DIRECTORY [18:07:18] COMPLETE! [18:07:22] [18:07:22] CF: 70 f9 00 00 6a [18:07:22] sioFuji::sio_process() called [18:07:22] ACK! [18:07:22] Fuji cmd: MOUNT HOST [18:07:22] ::mount {0} "SD" [18:07:22] ::mount_local Attempting mount of "SD" [18:07:22] Type is already LOCAL [18:07:22] COMPLETE! [18:07:22] [18:07:22] CF: 70 f7 00 00 68 [18:07:22] sioFuji::sio_process() called [18:07:22] ACK! [18:07:22] Fuji cmd: OPEN DIRECTORY [18:07:22] <-SIO read 256 bytes [18:07:22] ACK! [18:07:22] Opening directory: "/M", pattern: "micro*" [18:07:22] ::dir_open {0:1} "/M", pattern "micro*" [18:07:22] ::dir_open actual path = "/M" [18:07:22] COMPLETE! [18:07:22] [18:07:22] CF: 70 f6 24 00 8b [18:07:22] sioFuji::sio_process() called [18:07:22] ACK! [18:07:22] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:22] ::dir_nextfile {0:1} [18:07:22] ::read_direntry "Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx" [18:07:22] ->SIO write 36 bytes [18:07:22] COMPLETE! [18:07:22] [18:07:22] CF: 70 f6 24 00 8b [18:07:22] sioFuji::sio_process() called [18:07:22] ACK! [18:07:22] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:22] ::dir_nextfile {0:1} [18:07:22] ::read_direntry "Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!][cr CSS].atr" [18:07:22] ->SIO write 36 bytes [18:07:22] COMPLETE! [18:07:22] [18:07:22] CF: 70 f6 24 00 8b [18:07:22] sioFuji::sio_process() called [18:07:22] ACK! [18:07:22] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:22] ::dir_nextfile {0:1} [18:07:22] ::read_direntry "Micro League Baseball - Player Stats + Team Disk - World Series Teams - 1950's.atx" [18:07:22] ->SIO write 36 bytes [18:07:22] COMPLETE! [18:07:22] [18:07:22] CF: 70 f6 24 00 8b [18:07:22] sioFuji::sio_process() called [18:07:22] ACK! [18:07:22] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:22] ::dir_nextfile {0:1} [18:07:22] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1983 NL and AL Teams (1984)(Micro League Sports Association)(US).atr" [18:07:22] ->SIO write 36 bytes [18:07:22] COMPLETE! [18:07:22] [18:07:22] CF: 70 f6 24 00 8b [18:07:22] sioFuji::sio_process() called [18:07:22] ACK! [18:07:22] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:22] ::dir_nextfile {0:1} [18:07:22] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1984 NL and AL Teams (1984)(Micro League Sports Association)(US)[m].atr" [18:07:22] ->SIO write 36 bytes [18:07:22] COMPLETE! [18:07:22] [18:07:22] CF: 70 f6 24 00 8b [18:07:22] sioFuji::sio_process() called [18:07:22] ACK! [18:07:22] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:22] ::dir_nextfile {0:1} [18:07:22] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1985 NL and AL Teams (1985)(Micro League Sports Association)(US)[m].atr" [18:07:22] ->SIO write 36 bytes [18:07:22] COMPLETE! [18:07:23] [18:07:23] CF: 70 f6 24 00 8b [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:23] ::dir_nextfile {0:1} [18:07:23] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1986 NL and AL Teams (1986)(Micro League Sports Association)(US)[m].atr" [18:07:23] ->SIO write 36 bytes [18:07:23] COMPLETE! [18:07:23] [18:07:23] CF: 70 f6 24 00 8b [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:23] ::dir_nextfile {0:1} [18:07:23] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1987 NL and AL Teams (1987)(Micro League Sports Association)(US)[m].atr" [18:07:23] ->SIO write 36 bytes [18:07:23] COMPLETE! [18:07:23] [18:07:23] CF: 70 f6 24 00 8b [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:23] ::dir_nextfile {0:1} [18:07:23] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1989 NL and AL Teams (1989)(Micro League Sports Association)(US).atr" [18:07:23] ->SIO write 36 bytes [18:07:23] COMPLETE! [18:07:23] [18:07:23] CF: 70 f6 24 00 8b [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:23] ::dir_nextfile {0:1} [18:07:23] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - Franchise History - Minnesota Twins (1984)(Micro League Sports Association)(US).atr" [18:07:23] ->SIO write 36 bytes [18:07:23] COMPLETE! [18:07:23] [18:07:23] CF: 70 f6 24 00 8b [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:23] ::dir_nextfile {0:1} [18:07:23] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - Franchise History - New York Yankees (1984)(Micro League Sports Association)(US).atr" [18:07:23] ->SIO write 36 bytes [18:07:23] COMPLETE! [18:07:23] [18:07:23] CF: 70 f6 24 00 8b [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:23] ::dir_nextfile {0:1} [18:07:23] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - World Series Teams (1950's) (1984)(Micro League Sports Association)(US).atr" [18:07:23] ->SIO write 36 bytes [18:07:23] COMPLETE! [18:07:23] [18:07:23] CF: 70 f6 24 00 8b [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:23] ::dir_nextfile {0:1} [18:07:23] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - World Series Teams (1960's) (1984)(Micro League Sports Association)(US)[f].atr" [18:07:23] ->SIO write 36 bytes [18:07:23] COMPLETE! [18:07:23] [18:07:23] CF: 70 f6 24 00 8b [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:23] ::dir_nextfile {0:1} [18:07:23] ::read_direntry "Micro League Baseball Box Score and Stats Compiler Disk.atr" [18:07:23] ->SIO write 36 bytes [18:07:23] COMPLETE! [18:07:23] [18:07:23] CF: 70 f5 00 00 66 [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: CLOSE DIRECTORY [18:07:23] COMPLETE! [18:07:24] [18:07:24] CF: 70 f7 00 00 68 [18:07:24] sioFuji::sio_process() called [18:07:24] ACK! [18:07:24] Fuji cmd: OPEN DIRECTORY [18:07:24] <-SIO read 256 bytes [18:07:24] ACK! [18:07:24] Opening directory: "/M", pattern: "micro*" [18:07:24] ::dir_open {0:1} "/M", pattern "micro*" [18:07:24] ::dir_open actual path = "/M" [18:07:24] COMPLETE! [18:07:24] [18:07:24] CF: 70 e4 00 00 55 [18:07:24] sioFuji::sio_process() called [18:07:24] ACK! [18:07:24] Fuji cmd: SET DIRECTORY POSITION [18:07:24] ::dir_seek {0:1} 0 [18:07:24] COMPLETE! [18:07:24] [18:07:24] CF: 70 f6 80 00 e7 [18:07:24] sioFuji::sio_process() called [18:07:24] ACK! [18:07:24] Fuji cmd: READ DIRECTORY ENTRY (max=128) [18:07:24] ::dir_nextfile {0:1} [18:07:24] ::read_direntry "Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx" [18:07:24] ->SIO write 128 bytes [18:07:24] COMPLETE! [18:07:25] [18:07:25] CF: 70 f5 00 00 66 [18:07:25] sioFuji::sio_process() called [18:07:25] ACK! [18:07:25] Fuji cmd: CLOSE DIRECTORY [18:07:25] COMPLETE! [18:07:25] [18:07:25] CF: 70 f7 00 00 68 [18:07:25] sioFuji::sio_process() called [18:07:25] ACK! [18:07:25] Fuji cmd: OPEN DIRECTORY [18:07:25] <-SIO read 256 bytes [18:07:25] ACK! [18:07:25] Opening directory: "/M", pattern: "micro*" [18:07:25] ::dir_open {0:1} "/M", pattern "micro*" [18:07:25] ::dir_open actual path = "/M" [18:07:25] COMPLETE! [18:07:25] [18:07:25] CF: 70 e4 00 00 55 [18:07:25] sioFuji::sio_process() called [18:07:25] ACK! [18:07:25] Fuji cmd: SET DIRECTORY POSITION [18:07:25] ::dir_seek {0:1} 0 [18:07:25] COMPLETE! [18:07:25] [18:07:25] CF: 70 f2 00 00 63 [18:07:25] sioFuji::sio_process() called [18:07:25] ACK! [18:07:25] Fuji cmd: READ DEVICE SLOTS [18:07:25] ->SIO write 304 bytes [18:07:25] COMPLETE! [18:07:25] [18:07:25] CF: 70 f6 31 80 19 [18:07:25] sioFuji::sio_process() called [18:07:25] ACK! [18:07:25] Fuji cmd: READ DIRECTORY ENTRY (max=49) [18:07:25] ::dir_nextfile {0:1} [18:07:25] ::read_direntry "Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx" [18:07:25] ->SIO write 49 bytes [18:07:25] COMPLETE! [18:07:25] [18:07:25] CF: 70 f5 00 00 66 [18:07:25] sioFuji::sio_process() called [18:07:25] ACK! [18:07:25] Fuji cmd: CLOSE DIRECTORY [18:07:25] COMPLETE! [18:07:27] [18:07:27] CF: 70 f7 00 00 68 [18:07:27] sioFuji::sio_process() called [18:07:27] ACK! [18:07:27] Fuji cmd: OPEN DIRECTORY [18:07:27] <-SIO read 256 bytes [18:07:27] ACK! [18:07:27] Opening directory: "/M", pattern: "micro*" [18:07:27] ::dir_open {0:1} "/M", pattern "micro*" [18:07:27] ::dir_open actual path = "/M" [18:07:27] COMPLETE! [18:07:27] [18:07:27] CF: 70 e4 00 00 55 [18:07:27] sioFuji::sio_process() called [18:07:27] ACK! [18:07:27] Fuji cmd: SET DIRECTORY POSITION [18:07:27] ::dir_seek {0:1} 0 [18:07:27] COMPLETE! [18:07:27] [18:07:27] CF: 70 f6 fc 00 64 [18:07:27] sioFuji::sio_process() called [18:07:27] ACK! [18:07:27] Fuji cmd: READ DIRECTORY ENTRY (max=252) [18:07:27] ::dir_nextfile {0:1} [18:07:27] ::read_direntry "Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx" [18:07:27] ->SIO write 252 bytes [18:07:27] COMPLETE! [18:07:27] [18:07:27] CF: 70 e2 00 00 53 [18:07:27] sioFuji::sio_process() called [18:07:27] ACK! [18:07:27] <-SIO read 256 bytes [18:07:27] ACK! [18:07:27] Fuji cmd: SET DEVICE SLOT 0x00/00/00 FILENAME: /M/Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx [18:07:27] fnConfig::save [18:07:27] SPIFFS Config Storage: Enabled. Saving config to SPIFFS [18:07:27] fnConfig::save wrote 1176 bytes [18:07:27] Attempting config copy to SD [18:07:27] copy_file "/fnconfig.ini" -> "/fnconfig.ini" [18:07:27] fopen = /fnconfig.ini : ok [18:07:27] copy_file copied 1176 bytes [18:07:27] COMPLETE! [18:07:27] [18:07:27] CF: 70 e4 00 00 55 [18:07:27] sioFuji::sio_process() called [18:07:27] ACK! [18:07:27] Fuji cmd: SET DIRECTORY POSITION [18:07:27] ::dir_seek {0:1} 0 [18:07:27] COMPLETE! [18:07:27] [18:07:27] CF: 70 f6 24 00 8b [18:07:27] sioFuji::sio_process() called [18:07:27] ACK! [18:07:27] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:27] ::dir_nextfile {0:1} [18:07:27] ::read_direntry "Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx" [18:07:27] ->SIO write 36 bytes [18:07:27] COMPLETE! [18:07:27] [18:07:27] CF: 70 f1 00 00 62 [18:07:27] sioFuji::sio_process() called [18:07:27] ACK! [18:07:27] Fuji cmd: WRITE DEVICE SLOTS [18:07:27] <-SIO read 304 bytes [18:07:27] ACK! [18:07:27] fnConfig::save [18:07:27] fnConfig::save not dirty, not saving [18:07:27] COMPLETE! [18:07:27] [18:07:27] CF: 70 f5 00 00 66 [18:07:27] sioFuji::sio_process() called [18:07:27] ACK! [18:07:27] Fuji cmd: CLOSE DIRECTORY [18:07:27] COMPLETE! [18:07:28] [18:07:28] CF: 70 f4 00 00 65 [18:07:28] sioFuji::sio_process() called [18:07:28] ACK! [18:07:28] Fuji cmd: READ HOST SLOTS [18:07:28] ->SIO write 256 bytes [18:07:28] COMPLETE! [18:07:28] [18:07:28] CF: 70 f2 00 00 63 [18:07:28] sioFuji::sio_process() called [18:07:28] ACK! [18:07:28] Fuji cmd: READ DEVICE SLOTS [18:07:28] ->SIO write 304 bytes [18:07:28] COMPLETE! [18:07:28] [18:07:28] CF: 70 f4 00 00 65 [18:07:28] sioFuji::sio_process() called [18:07:28] ACK! [18:07:28] Fuji cmd: READ HOST SLOTS [18:07:28] ->SIO write 256 bytes [18:07:28] COMPLETE! [18:07:28] [18:07:28] CF: 70 f2 00 00 63 [18:07:28] sioFuji::sio_process() called [18:07:28] ACK! [18:07:28] Fuji cmd: READ DEVICE SLOTS [18:07:28] ->SIO write 304 bytes [18:07:28] COMPLETE! [18:07:34] [18:07:34] CF: 70 f2 00 00 63 [18:07:34] sioFuji::sio_process() called [18:07:34] ACK! [18:07:34] Fuji cmd: READ DEVICE SLOTS [18:07:34] ->SIO write 304 bytes [18:07:34] COMPLETE! [18:07:34] [18:07:34] CF: 70 f4 00 00 65 [18:07:34] sioFuji::sio_process() called [18:07:34] ACK! [18:07:34] Fuji cmd: READ HOST SLOTS [18:07:34] ->SIO write 256 bytes [18:07:34] COMPLETE! [18:07:34] [18:07:34] CF: 70 d7 00 00 48 [18:07:34] sioFuji::sio_process() called [18:07:34] ACK! [18:07:34] ::mount {0} "SD" [18:07:34] ::mount_local Attempting mount of "SD" [18:07:34] Type is already LOCAL [18:07:34] Selecting '/M/Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx' from host #0 as r on D1: [18:07:34] fujiHost #0 opening file path "/M/Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx" [18:07:34] fopen = /M/Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx : ok [18:07:34] ::get_filesize [18:07:34] disk MOUNT [18:07:34] ATX MOUNT [18:07:34] ATX image header values: [18:07:34] version: 1, version min: 1 [18:07:34] creator: 0x02, creator ver: 0 [18:07:34] flags: 0x00 [18:07:34] type: 0, density: 0 [18:07:34] imageid: 0x00, image ver: 0 [18:07:34] start: 0x0030 [18:07:34] end: 0x18770 [18:07:34] MediaTypeATX::_load_atx_data starting read [18:07:35] E (38060) diskio_sdmmc: sdmmc_read_blocks failed (257) [18:07:35] failed reading 2304 sector data chunk bytes (248, 5) [18:07:35] WARNING: Number of tracks read = 28 [18:07:35] ATX load completed [18:07:35] COMPLETE! [18:07:35] [18:07:35] CF: 70 d9 00 00 4a [18:07:35] sioFuji::sio_process() called [18:07:35] ACK! [18:07:35] COMPLETE! [18:07:36] [18:07:36] CF: 31 53 00 00 84 [18:07:36] disk sio_process() [18:07:36] ACK! [18:07:36] disk STATUS [18:07:36] response: 0x10, 0xff, 0xe0 [18:07:36] ->SIO write 4 bytes [18:07:36] COMPLETE! [18:07:36] [18:07:36] CF: 31 52 01 00 84 [18:07:36] disk sio_process() [18:07:36] ACK! [18:07:36] ATX READ (1) rots=8 [18:07:36] copy data track 0, sector 1 [18:07:36] ->SIO write 128 bytes [18:07:36] COMPLETE! [18:07:36] [18:07:36] CF: 31 52 02 00 85 [18:07:36] disk sio_process() [18:07:36] ACK! [18:07:36] ATX READ (2) rots=9 [18:07:36] copy data track 0, sector 2 [18:07:37] ->SIO write 128 bytes [18:07:37] COMPLETE! [18:07:37] [18:07:37] CF: 31 52 03 00 86 [18:07:37] disk sio_process() [18:07:37] ACK! [18:07:37] ATX READ (3) rots=11 [18:07:37] copy data track 0, sector 3 [18:07:37] ->SIO write 128 bytes [18:07:37] COMPLETE! [18:07:37] [18:07:37] CF: 31 52 04 00 87 [18:07:37] disk sio_process() [18:07:37] ACK! [18:07:37] ATX READ (4) rots=11 [18:07:37] copy data track 0, sector 4 [18:07:37] ->SIO write 128 bytes [18:07:37] COMPLETE! [18:07:37] [18:07:37] CF: 31 52 05 00 88 [18:07:37] disk sio_process() [18:07:37] ACK! [18:07:37] ATX READ (5) rots=13 [18:07:37] copy data track 0, sector 5 [18:07:37] ->SIO write 128 bytes [18:07:37] COMPLETE! [18:07:37] [18:07:37] CF: 31 52 06 00 89 [18:07:37] disk sio_process() [18:07:37] ACK! [18:07:37] ATX READ (6) rots=13 [18:07:37] copy data track 0, sector 6 [18:07:38] ->SIO write 128 bytes [18:07:38] COMPLETE! [18:07:38] [18:07:38] CF: 31 52 10 00 93 [18:07:38] disk sio_process() [18:07:38] ACK! [18:07:38] ATX READ (16) rots=15 [18:07:38] copy data track 0, sector 16 [18:07:38] ->SIO write 128 bytes [18:07:38] COMPLETE! [18:07:38] [18:07:38] CF: 31 52 11 00 94 [18:07:38] disk sio_process() [18:07:38] ACK! [18:07:38] ATX READ (17) rots=16 [18:07:38] copy data track 0, sector 17 [18:07:38] ->SIO write 128 bytes [18:07:38] COMPLETE! [18:07:38] [18:07:38] CF: 31 52 12 00 95 [18:07:38] disk sio_process() [18:07:38] ACK! [18:07:38] ATX READ (18) rots=17 [18:07:38] copy data track 0, sector 18 [18:07:38] ->SIO write 128 bytes [18:07:38] COMPLETE! [18:07:38] [18:07:38] CF: 31 52 13 00 96 [18:07:38] disk sio_process() [18:07:38] ACK! [18:07:38] ATX READ (19) rots=17 [18:07:38] copy data track 1, sector 1 [18:07:38] ->SIO write 128 bytes [18:07:38] COMPLETE! [18:07:38] [18:07:38] CF: 31 52 14 00 97 [18:07:38] disk sio_process() [18:07:38] ACK! [18:07:38] ATX READ (20) rots=18 [18:07:38] copy data track 1, sector 2 [18:07:39] ->SIO write 128 bytes [18:07:39] COMPLETE! [18:07:39] [18:07:39] CF: 31 52 15 00 98 [18:07:39] disk sio_process() [18:07:39] ACK! [18:07:39] ATX READ (21) rots=20 [18:07:39] copy data track 1, sector 3 [18:07:39] ->SIO write 128 bytes [18:07:39] COMPLETE! [18:07:39] [18:07:39] CF: 31 52 16 00 99 [18:07:39] disk sio_process() [18:07:39] ACK! [18:07:39] ATX READ (22) rots=20 [18:07:39] copy data track 1, sector 4 [18:07:39] ->SIO write 128 bytes [18:07:39] COMPLETE! [18:07:39] [18:07:39] CF: 31 52 17 00 9a [18:07:39] disk sio_process() [18:07:39] ACK! [18:07:39] ATX READ (23) rots=22 [18:07:39] copy data track 1, sector 5 [18:07:39] ->SIO write 128 bytes [18:07:39] COMPLETE! [18:07:39] [18:07:39] CF: 31 52 18 00 9b [18:07:39] disk sio_process() [18:07:39] ACK! [18:07:39] ATX READ (24) rots=22 [18:07:39] copy data track 1, sector 6 [18:07:39] ->SIO write 128 bytes [18:07:39] COMPLETE! [18:07:40] [18:07:40] CF: 31 52 19 00 9c [18:07:40] disk sio_process() [18:07:40] ACK! [18:07:40] ATX READ (25) rots=24 [18:07:40] copy data track 1, sector 7 [18:07:40] ->SIO write 128 bytes [18:07:40] COMPLETE! [18:07:40] [18:07:40] CF: 31 52 1a 00 9d [18:07:40] disk sio_process() [18:07:40] ACK! [18:07:40] ATX READ (26) rots=24 [18:07:40] copy data track 1, sector 8 [18:07:40] ->SIO write 128 bytes [18:07:40] COMPLETE! [18:07:40] [18:07:40] CF: 31 52 1b 00 9e [18:07:40] disk sio_process() [18:07:40] ACK! [18:07:40] ATX READ (27) rots=26 [18:07:40] copy data track 1, sector 9 [18:07:40] ->SIO write 128 bytes [18:07:40] COMPLETE! [18:07:40] [18:07:40] CF: 31 52 1c 00 9f [18:07:40] disk sio_process() [18:07:40] ACK! [18:07:40] ATX READ (28) rots=26 [18:07:40] copy data track 1, sector 10 [18:07:40] ->SIO write 128 bytes [18:07:40] COMPLETE! [18:07:40] [18:07:40] CF: 31 52 1d 00 a0 [18:07:40] disk sio_process() [18:07:40] ACK! [18:07:40] ATX READ (29) rots=28 [18:07:40] copy data track 1, sector 11 [18:07:40] ->SIO write 128 bytes [18:07:40] COMPLETE! [18:07:40] [18:07:40] CF: 31 52 1e 00 a1 [18:07:40] disk sio_process() [18:07:40] ACK! [18:07:40] ATX READ (30) rots=28 [18:07:40] copy data track 1, sector 12 [18:07:41] ->SIO write 128 bytes [18:07:41] COMPLETE! [18:07:41] [18:07:41] CF: 31 52 1f 00 a2 [18:07:41] disk sio_process() [18:07:41] ACK! [18:07:41] ATX READ (31) rots=29 [18:07:41] copy data track 1, sector 13 [18:07:41] ->SIO write 128 bytes [18:07:41] COMPLETE! [18:07:41] [18:07:41] CF: 31 52 20 00 a3 [18:07:41] disk sio_process() [18:07:41] ACK! [18:07:41] ATX READ (32) rots=30 [18:07:41] copy data track 1, sector 14 [18:07:41] ->SIO write 128 bytes [18:07:41] COMPLETE! [18:07:41] [18:07:41] CF: 31 52 21 00 a4 [18:07:41] disk sio_process() [18:07:41] ACK! [18:07:41] ATX READ (33) rots=32 [18:07:41] copy data track 1, sector 15 [18:07:41] ->SIO write 128 bytes [18:07:41] COMPLETE! [18:07:41] [18:07:41] CF: 31 52 22 00 a5 [18:07:41] disk sio_process() [18:07:41] ACK! [18:07:41] ATX READ (34) rots=32 [18:07:41] copy data track 1, sector 16 [18:07:42] ->SIO write 128 bytes [18:07:42] COMPLETE! [18:07:42] [18:07:42] CF: 31 52 23 00 a6 [18:07:42] disk sio_process() [18:07:42] ACK! [18:07:42] ATX READ (35) rots=34 [18:07:42] copy data track 1, sector 17 [18:07:42] ->SIO write 128 bytes [18:07:42] COMPLETE! [18:07:42] [18:07:42] CF: 31 52 24 00 a7 [18:07:42] disk sio_process() [18:07:42] ACK! [18:07:42] ATX READ (36) rots=35 [18:07:42] copy data track 1, sector 18 [18:07:42] ->SIO write 128 bytes [18:07:42] COMPLETE! [18:07:42] [18:07:42] CF: 31 52 25 00 a8 [18:07:42] disk sio_process() [18:07:42] ACK! [18:07:42] ATX READ (37) rots=35 [18:07:42] copy data track 2, sector 1 [18:07:42] ->SIO write 128 bytes [18:07:42] COMPLETE! [18:07:42] [18:07:42] CF: 31 52 26 00 a9 [18:07:42] disk sio_process() [18:07:42] ACK! [18:07:42] ATX READ (38) rots=36 [18:07:42] copy data track 2, sector 2 [18:07:42] ->SIO write 128 bytes [18:07:42] COMPLETE! [18:07:42] [18:07:42] CF: 31 52 27 00 aa [18:07:42] disk sio_process() [18:07:42] ACK! [18:07:42] ATX READ (39) rots=38 [18:07:42] copy data track 2, sector 3 [18:07:42] ->SIO write 128 bytes [18:07:42] COMPLETE! [18:07:43] [18:07:43] CF: 31 52 28 00 ab [18:07:43] disk sio_process() [18:07:43] ACK! [18:07:43] ATX READ (40) rots=38 [18:07:43] copy data track 2, sector 4 [18:07:43] ->SIO write 128 bytes [18:07:43] COMPLETE! [18:07:43] [18:07:43] CF: 31 52 29 00 ac [18:07:43] disk sio_process() [18:07:43] ACK! [18:07:43] ATX READ (41) rots=40 [18:07:43] copy data track 2, sector 5 [18:07:43] ->SIO write 128 bytes [18:07:43] COMPLETE! [18:07:43] [18:07:43] CF: 31 52 2a 00 ad [18:07:43] disk sio_process() [18:07:43] ACK! [18:07:43] ATX READ (42) rots=40 [18:07:43] copy data track 2, sector 6 [18:07:43] ->SIO write 128 bytes [18:07:43] COMPLETE! [18:07:43] [18:07:43] CF: 31 52 2b 00 ae [18:07:43] disk sio_process() [18:07:43] ACK! [18:07:43] ATX READ (43) rots=42 [18:07:43] copy data track 2, sector 7 [18:07:43] ->SIO write 128 bytes [18:07:43] COMPLETE! [18:07:43] [18:07:43] CF: 31 52 2c 00 af [18:07:43] disk sio_process() [18:07:43] ACK! [18:07:43] ATX READ (44) rots=42 [18:07:43] copy data track 2, sector 8 [18:07:44] ->SIO write 128 bytes [18:07:44] COMPLETE! [18:07:44] [18:07:44] CF: 31 52 2d 00 b0 [18:07:44] disk sio_process() [18:07:44] ACK! [18:07:44] ATX READ (45) rots=44 [18:07:44] copy data track 2, sector 9 [18:07:44] ->SIO write 128 bytes [18:07:44] COMPLETE! [18:07:44] [18:07:44] CF: 31 52 2e 00 b1 [18:07:44] disk sio_process() [18:07:44] ACK! [18:07:44] ATX READ (46) rots=44 [18:07:44] copy data track 2, sector 10 [18:07:44] ->SIO write 128 bytes [18:07:44] COMPLETE! [18:07:44] [18:07:44] CF: 31 52 2f 00 b2 [18:07:44] disk sio_process() [18:07:44] ACK! [18:07:44] ATX READ (47) rots=46 [18:07:44] copy data track 2, sector 11 [18:07:44] ->SIO write 128 bytes [18:07:44] COMPLETE! [18:07:44] [18:07:44] CF: 31 52 30 00 b3 [18:07:44] disk sio_process() [18:07:44] ACK! [18:07:44] ATX READ (48) rots=46 [18:07:44] copy data track 2, sector 12 [18:07:44] ->SIO write 128 bytes [18:07:44] COMPLETE! [18:07:45] [18:07:45] CF: 31 52 31 00 b4 [18:07:45] disk sio_process() [18:07:45] ACK! [18:07:45] ATX READ (49) rots=48 [18:07:45] copy data track 2, sector 13 [18:07:45] ->SIO write 128 bytes [18:07:45] COMPLETE! [18:07:45] [18:07:45] CF: 31 52 32 00 b5 [18:07:45] disk sio_process() [18:07:45] ACK! [18:07:45] ATX READ (50) rots=48 [18:07:45] copy data track 2, sector 14 [18:07:45] ->SIO write 128 bytes [18:07:45] COMPLETE! [18:07:45] [18:07:45] CF: 31 52 33 00 b6 [18:07:45] disk sio_process() [18:07:45] ACK! [18:07:45] ATX READ (51) rots=50 [18:07:45] copy data track 2, sector 15 [18:07:45] ->SIO write 128 bytes [18:07:45] COMPLETE! [18:07:45] [18:07:45] CF: 31 52 34 00 b7 [18:07:45] disk sio_process() [18:07:45] ACK! [18:07:45] ATX READ (52) rots=50 [18:07:45] copy data track 2, sector 16 [18:07:45] ->SIO write 128 bytes [18:07:45] COMPLETE! [18:07:45] [18:07:45] CF: 31 52 35 00 b8 [18:07:45] disk sio_process() [18:07:45] ACK! [18:07:45] ATX READ (53) rots=52 [18:07:45] copy data track 2, sector 17 [18:07:45] ->SIO write 128 bytes [18:07:45] COMPLETE! [18:07:46] [18:07:46] CF: 31 52 36 00 b9 [18:07:46] disk sio_process() [18:07:46] ACK! [18:07:46] ATX READ (54) rots=53 [18:07:46] copy data track 2, sector 18 [18:07:46] ->SIO write 128 bytes [18:07:46] COMPLETE! [18:07:46] [18:07:46] CF: 31 52 37 00 ba [18:07:46] disk sio_process() [18:07:46] ACK! [18:07:46] ATX READ (55) rots=53 [18:07:46] copy data track 3, sector 1 [18:07:46] ->SIO write 128 bytes [18:07:46] COMPLETE! [18:07:46] [18:07:46] CF: 31 52 38 00 bb [18:07:46] disk sio_process() [18:07:46] ACK! [18:07:46] ATX READ (56) rots=54 [18:07:46] copy data track 3, sector 2 [18:07:46] ->SIO write 128 bytes [18:07:46] COMPLETE! [18:07:46] [18:07:46] CF: 31 52 39 00 bc [18:07:46] disk sio_process() [18:07:46] ACK! [18:07:46] ATX READ (57) rots=56 [18:07:46] copy data track 3, sector 3 [18:07:46] ->SIO write 128 bytes [18:07:46] COMPLETE! [18:07:46] [18:07:46] CF: 31 52 3a 00 bd [18:07:46] disk sio_process() [18:07:46] ACK! [18:07:46] ATX READ (58) rots=56 [18:07:46] copy data track 3, sector 4 [18:07:46] ->SIO write 128 bytes [18:07:46] COMPLETE! [18:07:47] [18:07:47] CF: 31 52 3b 00 be [18:07:47] disk sio_process() [18:07:47] ACK! [18:07:47] ATX READ (59) rots=58 [18:07:47] copy data track 3, sector 5 [18:07:47] ->SIO write 128 bytes [18:07:47] COMPLETE! [18:07:47] [18:07:47] CF: 31 52 3c 00 bf [18:07:47] disk sio_process() [18:07:47] ACK! [18:07:47] ATX READ (60) rots=58 [18:07:47] copy data track 3, sector 6 [18:07:47] ->SIO write 128 bytes [18:07:47] COMPLETE! [18:07:47] [18:07:47] CF: 31 52 3d 00 c0 [18:07:47] disk sio_process() [18:07:47] ACK! [18:07:47] ATX READ (61) rots=60 [18:07:47] copy data track 3, sector 7 [18:07:47] ->SIO write 128 bytes [18:07:47] COMPLETE! [18:07:47] [18:07:47] CF: 31 52 3e 00 c1 [18:07:47] disk sio_process() [18:07:47] ACK! [18:07:47] ATX READ (62) rots=60 [18:07:47] copy data track 3, sector 8 [18:07:47] ->SIO write 128 bytes [18:07:47] COMPLETE! [18:07:47] [18:07:47] CF: 31 52 3f 00 c2 [18:07:47] disk sio_process() [18:07:47] ACK! [18:07:47] ATX READ (63) rots=62 [18:07:47] copy data track 3, sector 9 [18:07:47] ->SIO write 128 bytes [18:07:47] COMPLETE! [18:07:48] [18:07:48] CF: 31 52 40 00 c3 [18:07:48] disk sio_process() [18:07:48] ACK! [18:07:48] ATX READ (64) rots=62 [18:07:48] copy data track 3, sector 10 [18:07:48] ->SIO write 128 bytes [18:07:48] COMPLETE! [18:07:48] [18:07:48] CF: 31 52 41 00 c4 [18:07:48] disk sio_process() [18:07:48] ACK! [18:07:48] ATX READ (65) rots=64 [18:07:48] copy data track 3, sector 11 [18:07:48] ->SIO write 128 bytes [18:07:48] COMPLETE! [18:07:48] [18:07:48] CF: 31 52 42 00 c5 [18:07:48] disk sio_process() [18:07:48] ACK! [18:07:48] ATX READ (66) rots=64 [18:07:48] copy data track 3, sector 12 [18:07:48] ->SIO write 128 bytes [18:07:48] COMPLETE! [18:07:48] [18:07:48] CF: 31 52 43 00 c6 [18:07:48] disk sio_process() [18:07:48] ACK! [18:07:48] ATX READ (67) rots=66 [18:07:48] copy data track 3, sector 13 [18:07:48] ->SIO write 128 bytes [18:07:48] COMPLETE! [18:07:48] [18:07:48] CF: 31 52 44 00 c7 [18:07:48] disk sio_process() [18:07:48] ACK! [18:07:48] ATX READ (68) rots=66 [18:07:48] copy data track 3, sector 14 [18:07:49] ->SIO write 128 bytes [18:07:49] COMPLETE! [18:07:49] [18:07:49] CF: 31 52 45 00 c8 [18:07:49] disk sio_process() [18:07:49] ACK! [18:07:49] ATX READ (69) rots=68 [18:07:49] copy data track 3, sector 15 [18:07:49] ->SIO write 128 bytes [18:07:49] COMPLETE! [18:07:49] [18:07:49] CF: 31 52 46 00 c9 [18:07:49] disk sio_process() [18:07:49] ACK! [18:07:49] ATX READ (70) rots=68 [18:07:49] copy data track 3, sector 16 [18:07:49] ->SIO write 128 bytes [18:07:49] COMPLETE! [18:07:49] [18:07:49] CF: 31 52 47 00 ca [18:07:49] disk sio_process() [18:07:49] ACK! [18:07:49] ATX READ (71) rots=70 [18:07:49] copy data track 3, sector 17 [18:07:49] ->SIO write 128 bytes [18:07:49] COMPLETE! [18:07:49] [18:07:49] CF: 31 52 48 00 cb [18:07:49] disk sio_process() [18:07:49] ACK! [18:07:49] ATX READ (72) rots=71 [18:07:49] copy data track 3, sector 18 [18:07:49] ->SIO write 128 bytes [18:07:49] COMPLETE! [18:07:49] [18:07:49] CF: 31 52 49 00 cc [18:07:49] disk sio_process() [18:07:49] ACK! [18:07:49] ATX READ (73) rots=71 [18:07:49] copy data track 4, sector 1 [18:07:49] ->SIO write 128 bytes [18:07:49] COMPLETE! [18:07:50] [18:07:50] CF: 31 52 4a 00 cd [18:07:50] disk sio_process() [18:07:50] ACK! [18:07:50] ATX READ (74) rots=72 [18:07:50] copy data track 4, sector 2 [18:07:50] ->SIO write 128 bytes [18:07:50] COMPLETE! [18:07:50] [18:07:50] CF: 31 52 4b 00 ce [18:07:50] disk sio_process() [18:07:50] ACK! [18:07:50] ATX READ (75) rots=74 [18:07:50] copy data track 4, sector 3 [18:07:50] ->SIO write 128 bytes [18:07:50] COMPLETE! [18:07:50] [18:07:50] CF: 31 52 4c 00 cf [18:07:50] disk sio_process() [18:07:50] ACK! [18:07:50] ATX READ (76) rots=74 [18:07:50] copy data track 4, sector 4 [18:07:50] ->SIO write 128 bytes [18:07:50] COMPLETE! [18:07:50] [18:07:50] CF: 31 52 4d 00 d0 [18:07:50] disk sio_process() [18:07:50] ACK! [18:07:50] ATX READ (77) rots=76 [18:07:50] copy data track 4, sector 5 [18:07:50] ->SIO write 128 bytes [18:07:50] COMPLETE! [18:07:50] [18:07:50] CF: 31 52 4e 00 d1 [18:07:50] disk sio_process() [18:07:50] ACK! [18:07:50] ATX READ (78) rots=76 [18:07:50] copy data track 4, sector 6 [18:07:51] ->SIO write 128 bytes [18:07:51] COMPLETE! [18:07:51] [18:07:51] CF: 31 52 4f 00 d2 [18:07:51] disk sio_process() [18:07:51] ACK! [18:07:51] ATX READ (79) rots=78 [18:07:51] copy data track 4, sector 7 [18:07:51] ->SIO write 128 bytes [18:07:51] COMPLETE! [18:07:51] [18:07:51] CF: 31 52 50 00 d3 [18:07:51] disk sio_process() [18:07:51] ACK! [18:07:51] ATX READ (80) rots=78 [18:07:51] copy data track 4, sector 8 [18:07:51] ->SIO write 128 bytes [18:07:51] COMPLETE! [18:07:51] [18:07:51] CF: 31 52 51 00 d4 [18:07:51] disk sio_process() [18:07:51] ACK! [18:07:51] ATX READ (81) rots=80 [18:07:51] copy data track 4, sector 9 [18:07:51] ->SIO write 128 bytes [18:07:51] COMPLETE! [18:07:51] [18:07:51] CF: 31 52 52 00 d5 [18:07:51] disk sio_process() [18:07:51] ACK! [18:07:51] ATX READ (82) rots=80 [18:07:51] copy data track 4, sector 10 [18:07:52] ->SIO write 128 bytes [18:07:52] COMPLETE! [18:07:52] [18:07:52] CF: 31 52 53 00 d6 [18:07:52] disk sio_process() [18:07:52] ACK! [18:07:52] ATX READ (83) rots=82 [18:07:52] copy data track 4, sector 11 [18:07:52] ->SIO write 128 bytes [18:07:52] COMPLETE! [18:07:52] [18:07:52] CF: 31 52 54 00 d7 [18:07:52] disk sio_process() [18:07:52] ACK! [18:07:52] ATX READ (84) rots=82 [18:07:52] copy data track 4, sector 12 [18:07:52] ->SIO write 128 bytes [18:07:52] COMPLETE! [18:07:52] [18:07:52] CF: 31 52 55 00 d8 [18:07:52] disk sio_process() [18:07:52] ACK! [18:07:52] ATX READ (85) rots=84 [18:07:52] copy data track 4, sector 13 [18:07:52] ->SIO write 128 bytes [18:07:52] COMPLETE! [18:07:52] [18:07:52] CF: 31 52 56 00 d9 [18:07:52] disk sio_process() [18:07:52] ACK! [18:07:52] ATX READ (86) rots=84 [18:07:52] copy data track 4, sector 14 [18:07:52] ->SIO write 128 bytes [18:07:52] COMPLETE! [18:07:52] [18:07:52] CF: 31 52 57 00 da [18:07:52] disk sio_process() [18:07:52] ACK! [18:07:52] ATX READ (87) rots=86 [18:07:52] copy data track 4, sector 15 [18:07:52] ->SIO write 128 bytes [18:07:52] COMPLETE! [18:07:53] [18:07:53] CF: 31 52 58 00 db [18:07:53] disk sio_process() [18:07:53] ACK! [18:07:53] ATX READ (88) rots=86 [18:07:53] copy data track 4, sector 16 [18:07:53] ->SIO write 128 bytes [18:07:53] COMPLETE! [18:07:53] [18:07:53] CF: 31 52 59 00 dc [18:07:53] disk sio_process() [18:07:53] ACK! [18:07:53] ATX READ (89) rots=88 [18:07:53] copy data track 4, sector 17 [18:07:53] ->SIO write 128 bytes [18:07:53] COMPLETE! [18:07:53] [18:07:53] CF: 31 52 5a 00 dd [18:07:53] disk sio_process() [18:07:53] ACK! [18:07:53] ATX READ (90) rots=89 [18:07:53] copy data track 4, sector 18 [18:07:53] ->SIO write 128 bytes [18:07:53] COMPLETE! [18:07:53] [18:07:53] CF: 31 52 5b 00 de [18:07:53] disk sio_process() [18:07:53] ACK! [18:07:53] ATX READ (91) rots=89 [18:07:53] copy data track 5, sector 1 [18:07:53] ->SIO write 128 bytes [18:07:53] COMPLETE! [18:07:53] [18:07:53] CF: 31 52 5c 00 df [18:07:53] disk sio_process() [18:07:53] ACK! [18:07:53] ATX READ (92) rots=90 [18:07:53] copy data track 5, sector 2 [18:07:54] ->SIO write 128 bytes [18:07:54] COMPLETE! [18:07:54] [18:07:54] CF: 31 52 5d 00 e0 [18:07:54] disk sio_process() [18:07:54] ACK! [18:07:54] ATX READ (93) rots=92 [18:07:54] copy data track 5, sector 3 [18:07:54] ->SIO write 128 bytes [18:07:54] COMPLETE! [18:07:54] [18:07:54] CF: 31 52 5e 00 e1 [18:07:54] disk sio_process() [18:07:54] ACK! [18:07:54] ATX READ (94) rots=92 [18:07:54] copy data track 5, sector 4 [18:07:54] ->SIO write 128 bytes [18:07:54] COMPLETE! [18:07:54] [18:07:54] CF: 31 52 5f 00 e2 [18:07:54] disk sio_process() [18:07:54] ACK! [18:07:54] ATX READ (95) rots=94 [18:07:54] copy data track 5, sector 5 [18:07:54] ->SIO write 128 bytes [18:07:54] COMPLETE! [18:07:54] [18:07:54] CF: 31 52 60 00 e3 [18:07:54] disk sio_process() [18:07:54] ACK! [18:07:54] ATX READ (96) rots=94 [18:07:54] copy data track 5, sector 6 [18:07:54] ->SIO write 128 bytes [18:07:54] COMPLETE! [18:07:55] [18:07:55] CF: 31 52 61 00 e4 [18:07:55] disk sio_process() [18:07:55] ACK! [18:07:55] ATX READ (97) rots=96 [18:07:55] copy data track 5, sector 7 [18:07:55] ->SIO write 128 bytes [18:07:55] COMPLETE! [18:07:55] [18:07:55] CF: 31 52 62 00 e5 [18:07:55] disk sio_process() [18:07:55] ACK! [18:07:55] ATX READ (98) rots=96 [18:07:55] copy data track 5, sector 8 [18:07:55] ->SIO write 128 bytes [18:07:55] COMPLETE! [18:07:55] [18:07:55] CF: 31 52 63 00 e6 [18:07:55] disk sio_process() [18:07:55] ACK! [18:07:55] ATX READ (99) rots=98 [18:07:55] copy data track 5, sector 9 [18:07:55] ->SIO write 128 bytes [18:07:55] COMPLETE! [18:07:55] [18:07:55] CF: 31 52 64 00 e7 [18:07:55] disk sio_process() [18:07:55] ACK! [18:07:55] ATX READ (100) rots=98 [18:07:55] copy data track 5, sector 10 [18:07:55] ->SIO write 128 bytes [18:07:55] COMPLETE! [18:07:55] [18:07:55] CF: 31 52 65 00 e8 [18:07:55] disk sio_process() [18:07:55] ACK! [18:07:55] ATX READ (101) rots=100 [18:07:55] copy data track 5, sector 11 [18:07:55] ->SIO write 128 bytes [18:07:55] COMPLETE! [18:07:55] [18:07:55] CF: 31 52 66 00 e9 [18:07:55] disk sio_process() [18:07:55] ACK! [18:07:55] ATX READ (102) rots=100 [18:07:55] copy data track 5, sector 12 [18:07:56] ->SIO write 128 bytes [18:07:56] COMPLETE! [18:07:56] [18:07:56] CF: 31 52 68 00 eb [18:07:56] disk sio_process() [18:07:56] ACK! [18:07:56] ATX READ (104) rots=102 [18:07:56] copy data track 5, sector 14 [18:07:56] ->SIO write 128 bytes [18:07:56] COMPLETE! [18:07:56] [18:07:56] CF: 31 52 69 00 ec [18:07:56] disk sio_process() [18:07:56] ACK! [18:07:56] ATX READ (105) rots=103 [18:07:56] copy data track 5, sector 15 [18:07:56] ->SIO write 128 bytes [18:07:56] COMPLETE! [18:07:56] [18:07:56] CF: 31 52 6a 00 ed [18:07:56] disk sio_process() [18:07:56] ACK! [18:07:56] ATX READ (106) rots=103 [18:07:56] copy data track 5, sector 16 [18:07:56] ->SIO write 128 bytes [18:07:56] COMPLETE! [18:07:56] [18:07:56] CF: 31 52 6b 00 ee [18:07:56] disk sio_process() [18:07:56] ACK! [18:07:56] ATX READ (107) rots=105 [18:07:56] copy data track 5, sector 17 [18:07:56] ->SIO write 128 bytes [18:07:56] COMPLETE! [18:07:57] [18:07:57] CF: 31 52 6c 00 ef [18:07:57] disk sio_process() [18:07:57] ACK! [18:07:57] ATX READ (108) rots=106 [18:07:57] copy data track 5, sector 18 [18:07:57] ->SIO write 128 bytes [18:07:57] COMPLETE! [18:07:57] [18:07:57] CF: 31 52 6d 00 f0 [18:07:57] disk sio_process() [18:07:57] ACK! [18:07:57] ATX READ (109) rots=106 [18:07:57] copy data track 6, sector 1 [18:07:57] ->SIO write 128 bytes [18:07:57] COMPLETE! [18:07:57] [18:07:57] CF: 31 52 6e 00 f1 [18:07:57] disk sio_process() [18:07:57] ACK! [18:07:57] ATX READ (110) rots=107 [18:07:57] copy data track 6, sector 2 [18:07:57] ->SIO write 128 bytes [18:07:57] COMPLETE! [18:07:57] [18:07:57] CF: 31 52 6f 00 f2 [18:07:57] disk sio_process() [18:07:57] ACK! [18:07:57] ATX READ (111) rots=109 [18:07:57] copy data track 6, sector 3 [18:07:57] ->SIO write 128 bytes [18:07:57] COMPLETE! [18:07:57] [18:07:57] CF: 31 52 70 00 f3 [18:07:57] disk sio_process() [18:07:57] ACK! [18:07:57] ATX READ (112) rots=109 [18:07:57] copy data track 6, sector 4 [18:07:58] ->SIO write 128 bytes [18:07:58] COMPLETE! [18:07:58] [18:07:58] CF: 31 52 71 00 f4 [18:07:58] disk sio_process() [18:07:58] ACK! [18:07:58] ATX READ (113) rots=111 [18:07:58] copy data track 6, sector 5 [18:07:58] ->SIO write 128 bytes [18:07:58] COMPLETE! [18:07:58] [18:07:58] CF: 31 52 72 00 f5 [18:07:58] disk sio_process() [18:07:58] ACK! [18:07:58] ATX READ (114) rots=111 [18:07:58] copy data track 6, sector 6 [18:07:58] ->SIO write 128 bytes [18:07:58] COMPLETE! [18:07:58] [18:07:58] CF: 31 52 73 00 f6 [18:07:58] disk sio_process() [18:07:58] ACK! [18:07:58] ATX READ (115) rots=113 [18:07:58] copy data track 6, sector 7 [18:07:58] ->SIO write 128 bytes [18:07:58] COMPLETE! [18:07:58] [18:07:58] CF: 31 52 74 00 f7 [18:07:58] disk sio_process() [18:07:58] ACK! [18:07:58] ATX READ (116) rots=113 [18:07:58] copy data track 6, sector 8 [18:07:58] ->SIO write 128 bytes [18:07:58] COMPLETE! [18:07:58] [18:07:58] CF: 31 52 75 00 f8 [18:07:58] disk sio_process() [18:07:58] ACK! [18:07:58] ATX READ (117) rots=115 [18:07:58] copy data track 6, sector 9 [18:07:59] ->SIO write 128 bytes [18:07:59] COMPLETE! [18:07:59] [18:07:59] CF: 31 52 76 00 f9 [18:07:59] disk sio_process() [18:07:59] ACK! [18:07:59] ATX READ (118) rots=115 [18:07:59] copy data track 6, sector 10 [18:07:59] ->SIO write 128 bytes [18:07:59] COMPLETE! [18:07:59] [18:07:59] CF: 31 52 77 00 fa [18:07:59] disk sio_process() [18:07:59] ACK! [18:07:59] ATX READ (119) rots=117 [18:07:59] copy data track 6, sector 11 [18:07:59] ->SIO write 128 bytes [18:07:59] COMPLETE! [18:07:59] [18:07:59] CF: 31 52 78 00 fb [18:07:59] disk sio_process() [18:07:59] ACK! [18:07:59] ATX READ (120) rots=117 [18:07:59] copy data track 6, sector 12 [18:07:59] ->SIO write 128 bytes [18:07:59] COMPLETE! [18:07:59] [18:07:59] CF: 31 52 79 00 fc [18:07:59] disk sio_process() [18:07:59] ACK! [18:07:59] ATX READ (121) rots=119 [18:07:59] copy data track 6, sector 13 [18:07:59] ->SIO write 128 bytes [18:07:59] COMPLETE! [18:07:59] [18:07:59] CF: 31 52 7a 00 fd [18:07:59] disk sio_process() [18:07:59] ACK! [18:07:59] ATX READ (122) rots=119 [18:07:59] copy data track 6, sector 14 [18:08:00] ->SIO write 128 bytes [18:08:00] COMPLETE! [18:08:00] [18:08:00] CF: 31 52 7b 00 fe [18:08:00] disk sio_process() [18:08:00] ACK! [18:08:00] ATX READ (123) rots=121 [18:08:00] copy data track 6, sector 15 [18:08:00] ->SIO write 128 bytes [18:08:00] COMPLETE! [18:08:00] [18:08:00] CF: 31 52 7c 00 ff [18:08:00] disk sio_process() [18:08:00] ACK! [18:08:00] ATX READ (124) rots=121 [18:08:00] copy data track 6, sector 16 [18:08:00] ->SIO write 128 bytes [18:08:00] COMPLETE! [18:08:00] [18:08:00] CF: 31 52 7d 00 01 [18:08:00] disk sio_process() [18:08:00] ACK! [18:08:00] ATX READ (125) rots=123 [18:08:00] copy data track 6, sector 17 [18:08:00] ->SIO write 128 bytes [18:08:00] COMPLETE! [18:08:00] [18:08:00] CF: 31 52 7e 00 02 [18:08:00] disk sio_process() [18:08:00] ACK! [18:08:00] ATX READ (126) rots=124 [18:08:00] copy data track 6, sector 18 [18:08:00] ->SIO write 128 bytes [18:08:00] COMPLETE! [18:08:00] [18:08:00] CF: 31 52 7f 00 03 [18:08:00] disk sio_process() [18:08:00] ACK! [18:08:00] ATX READ (127) rots=124 [18:08:00] copy data track 7, sector 1 [18:08:01] ->SIO write 128 bytes [18:08:01] COMPLETE! [18:08:01] [18:08:01] CF: 31 52 80 00 04 [18:08:01] disk sio_process() [18:08:01] ACK! [18:08:01] ATX READ (128) rots=125 [18:08:01] copy data track 7, sector 2 [18:08:01] ->SIO write 128 bytes [18:08:01] COMPLETE! [18:08:01] [18:08:01] CF: 31 52 81 00 05 [18:08:01] disk sio_process() [18:08:01] ACK! [18:08:01] ATX READ (129) rots=127 [18:08:01] copy data track 7, sector 3 [18:08:01] ->SIO write 128 bytes [18:08:01] COMPLETE! [18:08:01] [18:08:01] CF: 31 52 82 00 06 [18:08:01] disk sio_process() [18:08:01] ACK! [18:08:01] ATX READ (130) rots=127 [18:08:01] copy data track 7, sector 4 [18:08:01] ->SIO write 128 bytes [18:08:01] COMPLETE! [18:08:01] [18:08:01] CF: 31 52 83 00 07 [18:08:01] disk sio_process() [18:08:01] ACK! [18:08:01] ATX READ (131) rots=129 [18:08:01] copy data track 7, sector 5 [18:08:01] ->SIO write 128 bytes [18:08:01] COMPLETE! [18:08:01] [18:08:01] CF: 31 52 84 00 08 [18:08:01] disk sio_process() [18:08:01] ACK! [18:08:01] ATX READ (132) rots=129 [18:08:01] copy data track 7, sector 6 [18:08:02] ->SIO write 128 bytes [18:08:02] COMPLETE! [18:08:02] [18:08:02] CF: 31 52 85 00 09 [18:08:02] disk sio_process() [18:08:02] ACK! [18:08:02] ATX READ (133) rots=131 [18:08:02] copy data track 7, sector 7 [18:08:02] ->SIO write 128 bytes [18:08:02] COMPLETE! [18:08:02] [18:08:02] CF: 31 52 86 00 0a [18:08:02] disk sio_process() [18:08:02] ACK! [18:08:02] ATX READ (134) rots=131 [18:08:02] copy data track 7, sector 8 [18:08:02] ->SIO write 128 bytes [18:08:02] COMPLETE! [18:08:02] [18:08:02] CF: 31 52 87 00 0b [18:08:02] disk sio_process() [18:08:02] ACK! [18:08:02] ATX READ (135) rots=133 [18:08:02] copy data track 7, sector 9 [18:08:02] ->SIO write 128 bytes [18:08:02] COMPLETE! [18:08:02] [18:08:02] CF: 31 52 88 00 0c [18:08:02] disk sio_process() [18:08:02] ACK! [18:08:02] ATX READ (136) rots=133 [18:08:02] copy data track 7, sector 10 [18:08:03] ->SIO write 128 bytes [18:08:03] COMPLETE! [18:08:03] [18:08:03] CF: 31 52 89 00 0d [18:08:03] disk sio_process() [18:08:03] ACK! [18:08:03] ATX READ (137) rots=135 [18:08:03] copy data track 7, sector 11 [18:08:03] ->SIO write 128 bytes [18:08:03] COMPLETE! [18:08:03] [18:08:03] CF: 31 52 8a 00 0e [18:08:03] disk sio_process() [18:08:03] ACK! [18:08:03] ATX READ (138) rots=135 [18:08:03] copy data track 7, sector 12 [18:08:03] ->SIO write 128 bytes [18:08:03] COMPLETE! [18:08:03] [18:08:03] CF: 31 52 8b 00 0f [18:08:03] disk sio_process() [18:08:03] ACK! [18:08:03] ATX READ (139) rots=137 [18:08:03] copy data track 7, sector 13 [18:08:03] ->SIO write 128 bytes [18:08:03] COMPLETE! [18:08:03] [18:08:03] CF: 31 52 8c 00 10 [18:08:03] disk sio_process() [18:08:03] ACK! [18:08:03] ATX READ (140) rots=137 [18:08:03] copy data track 7, sector 14 [18:08:03] ->SIO write 128 bytes [18:08:03] COMPLETE! [18:08:04] [18:08:04] CF: 31 52 8d 00 11 [18:08:04] disk sio_process() [18:08:04] ACK! [18:08:04] ATX READ (141) rots=139 [18:08:04] copy data track 7, sector 15 [18:08:04] ->SIO write 128 bytes [18:08:04] COMPLETE! [18:08:04] [18:08:04] CF: 31 52 8e 00 12 [18:08:04] disk sio_process() [18:08:04] ACK! [18:08:04] ATX READ (142) rots=139 [18:08:04] copy data track 7, sector 16 [18:08:04] ->SIO write 128 bytes [18:08:04] COMPLETE! [18:08:04] [18:08:04] CF: 31 52 8f 00 13 [18:08:04] disk sio_process() [18:08:04] ACK! [18:08:04] ATX READ (143) rots=141 [18:08:04] copy data track 7, sector 17 [18:08:04] ->SIO write 128 bytes [18:08:04] COMPLETE! [18:08:04] [18:08:04] CF: 31 52 90 00 14 [18:08:04] disk sio_process() [18:08:04] ACK! [18:08:04] ATX READ (144) rots=142 [18:08:04] copy data track 7, sector 18 [18:08:04] ->SIO write 128 bytes [18:08:04] COMPLETE! [18:08:04] [18:08:04] CF: 31 52 91 00 15 [18:08:04] disk sio_process() [18:08:04] ACK! [18:08:04] ATX READ (145) rots=142 [18:08:04] copy data track 8, sector 1 [18:08:04] ->SIO write 128 bytes [18:08:04] COMPLETE! [18:08:04] [18:08:04] CF: 31 52 92 00 16 [18:08:04] disk sio_process() [18:08:04] ACK! [18:08:04] ATX READ (146) rots=143 [18:08:04] copy data track 8, sector 2 [18:08:05] ->SIO write 128 bytes [18:08:05] COMPLETE! [18:08:05] [18:08:05] CF: 31 52 93 00 17 [18:08:05] disk sio_process() [18:08:05] ACK! [18:08:05] ATX READ (147) rots=145 [18:08:05] copy data track 8, sector 3 [18:08:05] ->SIO write 128 bytes [18:08:05] COMPLETE! [18:08:05] [18:08:05] CF: 31 52 f2 00 76 [18:08:05] disk sio_process() [18:08:05] ACK! [18:08:05] ATX READ (242) rots=145 [18:08:05] copy data track 13, sector 8 [18:08:05] ->SIO write 128 bytes [18:08:05] COMPLETE! [18:08:05] [18:08:05] CF: 31 52 f3 00 77 [18:08:05] disk sio_process() [18:08:05] ACK! [18:08:05] ATX READ (243) rots=147 [18:08:05] copy data track 13, sector 9 [18:08:05] ->SIO write 128 bytes [18:08:05] COMPLETE! [18:08:05] [18:08:05] CF: 31 52 f4 00 78 [18:08:05] disk sio_process() [18:08:05] ACK! [18:08:05] ATX READ (244) rots=147 [18:08:05] copy data track 13, sector 10 [18:08:05] ->SIO write 128 bytes [18:08:05] COMPLETE! [18:08:06] [18:08:06] CF: 31 52 f5 00 79 [18:08:06] disk sio_process() [18:08:06] ACK! [18:08:06] ATX READ (245) rots=149 [18:08:06] copy data track 13, sector 11 [18:08:06] ->SIO write 128 bytes [18:08:06] COMPLETE! [18:08:06] [18:08:06] CF: 31 52 f6 00 7a [18:08:06] disk sio_process() [18:08:06] ACK! [18:08:06] ATX READ (246) rots=149 [18:08:06] copy data track 13, sector 12 [18:08:06] ->SIO write 128 bytes [18:08:06] COMPLETE! [18:08:06] [18:08:06] CF: 31 52 f7 00 7b [18:08:06] disk sio_process() [18:08:06] ACK! [18:08:06] ATX READ (247) rots=151 [18:08:06] copy data track 13, sector 13 [18:08:06] ->SIO write 128 bytes [18:08:06] COMPLETE! [18:08:06] [18:08:06] CF: 31 52 f8 00 7c [18:08:06] disk sio_process() [18:08:06] ACK! [18:08:06] ATX READ (248) rots=151 [18:08:06] copy data track 13, sector 14 [18:08:06] ->SIO write 128 bytes [18:08:06] COMPLETE! [18:08:06] [18:08:06] CF: 31 52 f9 00 7d [18:08:06] disk sio_process() [18:08:06] ACK! [18:08:06] ATX READ (249) rots=153 [18:08:06] copy data track 13, sector 15 [18:08:06] ->SIO write 128 bytes [18:08:06] COMPLETE! [18:08:07] [18:08:07] CF: 31 52 fa 00 7e [18:08:07] disk sio_process() [18:08:07] ACK! [18:08:07] ATX READ (250) rots=153 [18:08:07] copy data track 13, sector 16 [18:08:07] ->SIO write 128 bytes [18:08:07] COMPLETE! [18:08:07] [18:08:07] CF: 31 52 fb 00 7f [18:08:07] disk sio_process() [18:08:07] ACK! [18:08:07] ATX READ (251) rots=155 [18:08:07] copy data track 13, sector 17 [18:08:07] ->SIO write 128 bytes [18:08:07] COMPLETE! [18:08:07] [18:08:07] CF: 31 52 fc 00 80 [18:08:07] disk sio_process() [18:08:07] ACK! [18:08:07] ATX READ (252) rots=156 [18:08:07] copy data track 13, sector 18 [18:08:07] ->SIO write 128 bytes [18:08:07] COMPLETE! [18:08:07] [18:08:07] CF: 31 52 fd 00 81 [18:08:07] disk sio_process() [18:08:07] ACK! [18:08:07] ATX READ (253) rots=156 [18:08:07] copy data track 14, sector 1 [18:08:07] ->SIO write 128 bytes [18:08:07] COMPLETE! [18:08:07] [18:08:07] CF: 31 52 fe 00 82 [18:08:07] disk sio_process() [18:08:07] ACK! [18:08:07] ATX READ (254) rots=157 [18:08:07] copy data track 14, sector 2 [18:08:08] ->SIO write 128 bytes [18:08:08] COMPLETE! [18:08:08] [18:08:08] CF: 31 52 ff 00 83 [18:08:08] disk sio_process() [18:08:08] ACK! [18:08:08] ATX READ (255) rots=159 [18:08:08] copy data track 14, sector 3 [18:08:08] ->SIO write 128 bytes [18:08:08] COMPLETE! [18:08:08] [18:08:08] CF: 31 52 00 01 84 [18:08:08] disk sio_process() [18:08:08] ACK! [18:08:08] ATX READ (256) rots=159 [18:08:08] copy data track 14, sector 4 [18:08:08] ->SIO write 128 bytes [18:08:08] COMPLETE! [18:08:08] [18:08:08] CF: 31 52 01 01 85 [18:08:08] disk sio_process() [18:08:08] ACK! [18:08:08] ATX READ (257) rots=161 [18:08:08] copy data track 14, sector 5 [18:08:08] ->SIO write 128 bytes [18:08:08] COMPLETE! [18:08:08] [18:08:08] CF: 31 52 02 01 86 [18:08:08] disk sio_process() [18:08:08] ACK! [18:08:08] ATX READ (258) rots=161 [18:08:08] copy data track 14, sector 6 [18:08:08] ->SIO write 128 bytes [18:08:08] COMPLETE! [18:08:08] [18:08:08] CF: 31 52 03 01 87 [18:08:08] disk sio_process() [18:08:08] ACK! [18:08:08] ATX READ (259) rots=163 [18:08:08] copy data track 14, sector 7 [18:08:08] ->SIO write 128 bytes [18:08:08] COMPLETE! [18:08:09] [18:08:09] CF: 31 52 04 01 88 [18:08:09] disk sio_process() [18:08:09] ACK! [18:08:09] ATX READ (260) rots=163 [18:08:09] copy data track 14, sector 8 [18:08:09] ->SIO write 128 bytes [18:08:09] COMPLETE! [18:08:09] [18:08:09] CF: 31 52 05 01 89 [18:08:09] disk sio_process() [18:08:09] ACK! [18:08:09] ATX READ (261) rots=165 [18:08:09] copy data track 14, sector 9 [18:08:09] ->SIO write 128 bytes [18:08:09] COMPLETE! [18:08:09] [18:08:09] CF: 31 52 06 01 8a [18:08:09] disk sio_process() [18:08:09] ACK! [18:08:09] ATX READ (262) rots=165 [18:08:09] copy data track 14, sector 10 [18:08:09] ->SIO write 128 bytes [18:08:09] COMPLETE! [18:08:09] [18:08:09] CF: 31 52 07 01 8b [18:08:09] disk sio_process() [18:08:09] ACK! [18:08:09] ATX READ (263) rots=167 [18:08:09] copy data track 14, sector 11 [18:08:09] ->SIO write 128 bytes [18:08:09] COMPLETE! [18:08:09] [18:08:09] CF: 31 52 08 01 8c [18:08:09] disk sio_process() [18:08:09] ACK! [18:08:09] ATX READ (264) rots=167 [18:08:09] copy data track 14, sector 12 [18:08:10] ->SIO write 128 bytes [18:08:10] COMPLETE! [18:08:10] [18:08:10] CF: 31 52 09 01 8d [18:08:10] disk sio_process() [18:08:10] ACK! [18:08:10] ATX READ (265) rots=169 [18:08:10] copy data track 14, sector 13 [18:08:10] ->SIO write 128 bytes [18:08:10] COMPLETE! [18:08:10] [18:08:10] CF: 31 52 0a 01 8e [18:08:10] disk sio_process() [18:08:10] ACK! [18:08:10] ATX READ (266) rots=169 [18:08:10] copy data track 14, sector 14 [18:08:10] ->SIO write 128 bytes [18:08:10] COMPLETE! [18:08:10] [18:08:10] CF: 31 52 0b 01 8f [18:08:10] disk sio_process() [18:08:10] ACK! [18:08:10] ATX READ (267) rots=171 [18:08:10] copy data track 14, sector 15 [18:08:10] ->SIO write 128 bytes [18:08:10] COMPLETE! [18:08:10] [18:08:10] CF: 31 52 0c 01 90 [18:08:10] disk sio_process() [18:08:10] ACK! [18:08:10] ATX READ (268) rots=171 [18:08:10] copy data track 14, sector 16 [18:08:11] ->SIO write 128 bytes [18:08:11] COMPLETE! [18:08:11] [18:08:11] CF: 31 52 0d 01 91 [18:08:11] disk sio_process() [18:08:11] ACK! [18:08:11] ATX READ (269) rots=173 [18:08:11] copy data track 14, sector 17 [18:08:11] ->SIO write 128 bytes [18:08:11] COMPLETE! [18:08:11] [18:08:11] CF: 31 52 0e 01 92 [18:08:11] disk sio_process() [18:08:11] ACK! [18:08:11] ATX READ (270) rots=174 [18:08:11] copy data track 14, sector 18 [18:08:11] ->SIO write 128 bytes [18:08:11] COMPLETE! [18:08:11] [18:08:11] CF: 31 52 0f 01 93 [18:08:11] disk sio_process() [18:08:11] ACK! [18:08:11] ATX READ (271) rots=174 [18:08:11] copy data track 15, sector 1 [18:08:11] ->SIO write 128 bytes [18:08:11] COMPLETE! [18:08:11] [18:08:11] CF: 31 52 10 01 94 [18:08:11] disk sio_process() [18:08:11] ACK! [18:08:11] ATX READ (272) rots=175 [18:08:11] copy data track 15, sector 2 [18:08:11] ->SIO write 128 bytes [18:08:11] COMPLETE! [18:08:11] [18:08:11] CF: 31 52 11 01 95 [18:08:11] disk sio_process() [18:08:11] ACK! [18:08:11] ATX READ (273) rots=177 [18:08:11] copy data track 15, sector 3 [18:08:11] ->SIO write 128 bytes [18:08:11] COMPLETE! [18:08:11] [18:08:11] CF: 31 52 12 01 96 [18:08:11] disk sio_process() [18:08:11] ACK! [18:08:11] ATX READ (274) rots=177 [18:08:11] copy data track 15, sector 4 [18:08:12] ->SIO write 128 bytes [18:08:12] COMPLETE! [18:08:12] [18:08:12] CF: 31 52 13 01 97 [18:08:12] disk sio_process() [18:08:12] ACK! [18:08:12] ATX READ (275) rots=179 [18:08:12] copy data track 15, sector 5 [18:08:12] ->SIO write 128 bytes [18:08:12] COMPLETE! [18:08:12] [18:08:12] CF: 31 52 1f 01 a3 [18:08:12] disk sio_process() [18:08:12] ACK! [18:08:12] ATX READ (287) rots=179 [18:08:12] copy data track 15, sector 17 [18:08:12] ->SIO write 128 bytes [18:08:12] COMPLETE! [18:08:12] [18:08:12] CF: 31 52 20 01 a4 [18:08:12] disk sio_process() [18:08:12] ACK! [18:08:12] ATX READ (288) rots=181 [18:08:12] copy data track 15, sector 18 [18:08:12] ->SIO write 128 bytes [18:08:12] COMPLETE! [18:08:12] [18:08:12] CF: 31 52 21 01 a5 [18:08:12] disk sio_process() [18:08:12] ACK! [18:08:12] ATX READ (289) rots=181 [18:08:12] copy data track 16, sector 1 [18:08:12] ->SIO write 128 bytes [18:08:12] COMPLETE! [18:08:13] [18:08:13] CF: 31 52 22 01 a6 [18:08:13] disk sio_process() [18:08:13] ACK! [18:08:13] ATX READ (290) rots=182 [18:08:13] copy data track 16, sector 2 [18:08:13] ->SIO write 128 bytes [18:08:13] COMPLETE! [18:08:13] [18:08:13] CF: 31 52 23 01 a7 [18:08:13] disk sio_process() [18:08:13] ACK! [18:08:13] ATX READ (291) rots=184 [18:08:13] copy data track 16, sector 3 [18:08:13] ->SIO write 128 bytes [18:08:13] COMPLETE! [18:08:13] [18:08:13] CF: 31 52 24 01 a8 [18:08:13] disk sio_process() [18:08:13] ACK! [18:08:13] ATX READ (292) rots=184 [18:08:13] copy data track 16, sector 4 [18:08:13] ->SIO write 128 bytes [18:08:13] COMPLETE! [18:08:13] [18:08:13] CF: 31 52 25 01 a9 [18:08:13] disk sio_process() [18:08:13] ACK! [18:08:13] ATX READ (293) rots=186 [18:08:13] copy data track 16, sector 5 [18:08:13] ->SIO write 128 bytes [18:08:13] COMPLETE! [18:08:13] [18:08:13] CF: 31 52 26 01 aa [18:08:13] disk sio_process() [18:08:13] ACK! [18:08:13] ATX READ (294) rots=186 [18:08:13] copy data track 16, sector 6 [18:08:14] ->SIO write 128 bytes [18:08:14] COMPLETE! [18:08:14] [18:08:14] CF: 31 52 27 01 ab [18:08:14] disk sio_process() [18:08:14] ACK! [18:08:14] ATX READ (295) rots=188 [18:08:14] copy data track 16, sector 7 [18:08:14] ->SIO write 128 bytes [18:08:14] COMPLETE! [18:08:14] [18:08:14] CF: 31 52 28 01 ac [18:08:14] disk sio_process() [18:08:14] ACK! [18:08:14] ATX READ (296) rots=188 [18:08:14] copy data track 16, sector 8 [18:08:14] ->SIO write 128 bytes [18:08:14] COMPLETE! [18:08:14] [18:08:14] CF: 31 52 29 01 ad [18:08:14] disk sio_process() [18:08:14] ACK! [18:08:14] ATX READ (297) rots=190 [18:08:14] copy data track 16, sector 9 [18:08:14] ->SIO write 128 bytes [18:08:14] COMPLETE! [18:08:14] [18:08:14] CF: 31 52 2a 01 ae [18:08:14] disk sio_process() [18:08:14] ACK! [18:08:14] ATX READ (298) rots=190 [18:08:14] copy data track 16, sector 10 [18:08:14] ->SIO write 128 bytes [18:08:14] COMPLETE! [18:08:15] [18:08:15] CF: 31 52 2b 01 af [18:08:15] disk sio_process() [18:08:15] ACK! [18:08:15] ATX READ (299) rots=192 [18:08:15] copy data track 16, sector 11 [18:08:15] ->SIO write 128 bytes [18:08:15] COMPLETE! [18:08:15] [18:08:15] CF: 31 52 2c 01 b0 [18:08:15] disk sio_process() [18:08:15] ACK! [18:08:15] ATX READ (300) rots=192 [18:08:15] copy data track 16, sector 12 [18:08:15] ->SIO write 128 bytes [18:08:15] COMPLETE! [18:08:15] [18:08:15] CF: 31 52 2d 01 b1 [18:08:15] disk sio_process() [18:08:15] ACK! [18:08:15] ATX READ (301) rots=194 [18:08:15] copy data track 16, sector 13 [18:08:15] ->SIO write 128 bytes [18:08:15] COMPLETE! [18:08:15] [18:08:15] CF: 31 52 2e 01 b2 [18:08:15] disk sio_process() [18:08:15] ACK! [18:08:15] ATX READ (302) rots=194 [18:08:15] copy data track 16, sector 14 [18:08:15] ->SIO write 128 bytes [18:08:15] COMPLETE! [18:08:15] [18:08:15] CF: 31 52 2f 01 b3 [18:08:15] disk sio_process() [18:08:15] ACK! [18:08:15] ATX READ (303) rots=196 [18:08:15] copy data track 16, sector 15 [18:08:15] ->SIO write 128 bytes [18:08:15] COMPLETE! [18:08:16] [18:08:16] CF: 31 52 30 01 b4 [18:08:16] disk sio_process() [18:08:16] ACK! [18:08:16] ATX READ (304) rots=196 [18:08:16] copy data track 16, sector 16 [18:08:16] ->SIO write 128 bytes [18:08:16] COMPLETE! [18:08:16] [18:08:16] CF: 31 52 31 01 b5 [18:08:16] disk sio_process() [18:08:16] ACK! [18:08:16] ATX READ (305) rots=198 [18:08:16] copy data track 16, sector 17 [18:08:16] ->SIO write 128 bytes [18:08:16] COMPLETE! [18:08:16] [18:08:16] CF: 31 52 32 01 b6 [18:08:16] disk sio_process() [18:08:16] ACK! [18:08:16] ATX READ (306) rots=199 [18:08:16] copy data track 16, sector 18 [18:08:16] ->SIO write 128 bytes [18:08:16] COMPLETE! [18:08:16] [18:08:16] CF: 31 52 33 01 b7 [18:08:16] disk sio_process() [18:08:16] ACK! [18:08:16] ATX READ (307) rots=199 [18:08:16] copy data track 17, sector 1 [18:08:16] ->SIO write 128 bytes [18:08:16] COMPLETE! [18:08:16] [18:08:16] CF: 31 52 34 01 b8 [18:08:16] disk sio_process() [18:08:16] ACK! [18:08:16] ATX READ (308) rots=200 [18:08:16] copy data track 17, sector 2 [18:08:16] ->SIO write 128 bytes [18:08:16] COMPLETE! [18:08:17] [18:08:17] CF: 31 52 35 01 b9 [18:08:17] disk sio_process() [18:08:17] ACK! [18:08:17] ATX READ (309) rots=202 [18:08:17] copy data track 17, sector 3 [18:08:17] ->SIO write 128 bytes [18:08:17] COMPLETE! [18:08:17] [18:08:17] CF: 31 52 36 01 ba [18:08:17] disk sio_process() [18:08:17] ACK! [18:08:17] ATX READ (310) rots=202 [18:08:17] copy data track 17, sector 4 [18:08:17] ->SIO write 128 bytes [18:08:17] COMPLETE! [18:08:17] [18:08:17] CF: 31 52 39 01 bd [18:08:17] disk sio_process() [18:08:17] ACK! [18:08:17] ATX READ (313) rots=204 [18:08:17] copy data track 17, sector 7 [18:08:17] ->SIO write 128 bytes [18:08:17] COMPLETE! [18:08:17] [18:08:17] CF: 31 52 3a 01 be [18:08:17] disk sio_process() [18:08:17] ACK! [18:08:17] ATX READ (314) rots=204 [18:08:17] copy data track 17, sector 8 [18:08:17] ->SIO write 128 bytes [18:08:17] COMPLETE! [18:08:17] [18:08:17] CF: 31 52 3b 01 bf [18:08:17] disk sio_process() [18:08:17] ACK! [18:08:17] ATX READ (315) rots=206 [18:08:17] copy data track 17, sector 9 [18:08:17] ->SIO write 128 bytes [18:08:17] COMPLETE! [18:08:18] [18:08:18] CF: 31 52 3c 01 c0 [18:08:18] disk sio_process() [18:08:18] ACK! [18:08:18] ATX READ (316) rots=206 [18:08:18] copy data track 17, sector 10 [18:08:18] ->SIO write 128 bytes [18:08:18] COMPLETE! [18:08:18] [18:08:18] CF: 31 52 3d 01 c1 [18:08:18] disk sio_process() [18:08:18] ACK! [18:08:18] ATX READ (317) rots=208 [18:08:18] copy data track 17, sector 11 [18:08:18] ->SIO write 128 bytes [18:08:18] COMPLETE! [18:08:18] [18:08:18] CF: 31 52 3e 01 c2 [18:08:18] disk sio_process() [18:08:18] ACK! [18:08:18] ATX READ (318) rots=208 [18:08:18] copy data track 17, sector 12 [18:08:18] ->SIO write 128 bytes [18:08:18] COMPLETE! [18:08:18] [18:08:18] CF: 31 52 3f 01 c3 [18:08:18] disk sio_process() [18:08:18] ACK! [18:08:18] ATX READ (319) rots=210 [18:08:18] copy data track 17, sector 13 [18:08:18] ->SIO write 128 bytes [18:08:18] COMPLETE! [18:08:18] [18:08:18] CF: 31 52 40 01 c4 [18:08:18] disk sio_process() [18:08:18] ACK! [18:08:18] ATX READ (320) rots=210 [18:08:18] copy data track 17, sector 14 [18:08:19] ->SIO write 128 bytes [18:08:19] COMPLETE! [18:08:19] [18:08:19] CF: 31 52 41 01 c5 [18:08:19] disk sio_process() [18:08:19] ACK! [18:08:19] ATX READ (321) rots=212 [18:08:19] copy data track 17, sector 15 [18:08:19] ->SIO write 128 bytes [18:08:19] COMPLETE! [18:08:19] [18:08:19] CF: 31 52 42 01 c6 [18:08:19] disk sio_process() [18:08:19] ACK! [18:08:19] ATX READ (322) rots=212 [18:08:19] copy data track 17, sector 16 [18:08:19] ->SIO write 128 bytes [18:08:19] COMPLETE! [18:08:19] [18:08:19] CF: 31 52 43 01 c7 [18:08:19] disk sio_process() [18:08:19] ACK! [18:08:19] ATX READ (323) rots=214 [18:08:19] copy data track 17, sector 17 [18:08:19] ->SIO write 128 bytes [18:08:19] COMPLETE! [18:08:19] [18:08:19] CF: 31 52 44 01 c8 [18:08:19] disk sio_process() [18:08:19] ACK! [18:08:19] ATX READ (324) rots=215 [18:08:19] copy data track 17, sector 18 [18:08:19] ->SIO write 128 bytes [18:08:19] COMPLETE! [18:08:19] [18:08:19] CF: 31 52 45 01 c9 [18:08:19] disk sio_process() [18:08:19] ACK! [18:08:19] ATX READ (325) rots=215 [18:08:19] copy data track 18, sector 1 [18:08:20] ->SIO write 128 bytes [18:08:20] COMPLETE! [18:08:20] [18:08:20] CF: 31 52 46 01 ca [18:08:20] disk sio_process() [18:08:20] ACK! [18:08:20] ATX READ (326) rots=216 [18:08:20] copy data track 18, sector 2 [18:08:20] ->SIO write 128 bytes [18:08:20] COMPLETE! [18:08:20] [18:08:20] CF: 31 52 47 01 cb [18:08:20] disk sio_process() [18:08:20] ACK! [18:08:20] ATX READ (327) rots=218 [18:08:20] copy data track 18, sector 3 [18:08:20] ->SIO write 128 bytes [18:08:20] COMPLETE! [18:08:20] [18:08:20] CF: 31 52 48 01 cc [18:08:20] disk sio_process() [18:08:20] ACK! [18:08:20] ATX READ (328) rots=218 [18:08:20] copy data track 18, sector 4 [18:08:20] ->SIO write 128 bytes [18:08:20] COMPLETE! [18:08:20] [18:08:20] CF: 31 52 49 01 cd [18:08:20] disk sio_process() [18:08:20] ACK! [18:08:20] ATX READ (329) rots=220 [18:08:20] copy data track 18, sector 5 [18:08:20] ->SIO write 128 bytes [18:08:20] COMPLETE! [18:08:20] [18:08:20] CF: 31 52 4a 01 ce [18:08:20] disk sio_process() [18:08:20] ACK! [18:08:20] ATX READ (330) rots=220 [18:08:20] copy data track 18, sector 6 [18:08:21] ->SIO write 128 bytes [18:08:21] COMPLETE! [18:08:21] [18:08:21] CF: 31 52 4b 01 cf [18:08:21] disk sio_process() [18:08:21] ACK! [18:08:21] ATX READ (331) rots=222 [18:08:21] copy data track 18, sector 7 [18:08:21] ->SIO write 128 bytes [18:08:21] COMPLETE! [18:08:21] [18:08:21] CF: 31 52 4c 01 d0 [18:08:21] disk sio_process() [18:08:21] ACK! [18:08:21] ATX READ (332) rots=222 [18:08:21] copy data track 18, sector 8 [18:08:21] ->SIO write 128 bytes [18:08:21] COMPLETE! [18:08:21] [18:08:21] CF: 31 52 4d 01 d1 [18:08:21] disk sio_process() [18:08:21] ACK! [18:08:21] ATX READ (333) rots=224 [18:08:21] copy data track 18, sector 9 [18:08:21] ->SIO write 128 bytes [18:08:21] COMPLETE! [18:08:21] [18:08:21] CF: 31 52 4e 01 d2 [18:08:21] disk sio_process() [18:08:21] ACK! [18:08:21] ATX READ (334) rots=224 [18:08:21] copy data track 18, sector 10 [18:08:22] ->SIO write 128 bytes [18:08:22] COMPLETE! [18:08:22] [18:08:22] CF: 31 52 4f 01 d3 [18:08:22] disk sio_process() [18:08:22] ACK! [18:08:22] ATX READ (335) rots=226 [18:08:22] copy data track 18, sector 11 [18:08:22] ->SIO write 128 bytes [18:08:22] COMPLETE! [18:08:22] [18:08:22] CF: 31 52 50 01 d4 [18:08:22] disk sio_process() [18:08:22] ACK! [18:08:22] ATX READ (336) rots=226 [18:08:22] copy data track 18, sector 12 [18:08:22] ->SIO write 128 bytes [18:08:22] COMPLETE! [18:08:22] [18:08:22] CF: 31 52 51 01 d5 [18:08:22] disk sio_process() [18:08:22] ACK! [18:08:22] ATX READ (337) rots=228 [18:08:22] copy data track 18, sector 13 [18:08:22] ->SIO write 128 bytes [18:08:22] COMPLETE! [18:08:22] [18:08:22] CF: 31 52 52 01 d6 [18:08:22] disk sio_process() [18:08:22] ACK! [18:08:22] ATX READ (338) rots=228 [18:08:22] copy data track 18, sector 14 [18:08:22] ->SIO write 128 bytes [18:08:22] COMPLETE! [18:08:22] [18:08:22] CF: 31 52 53 01 d7 [18:08:22] disk sio_process() [18:08:22] ACK! [18:08:22] ATX READ (339) rots=230 [18:08:22] copy data track 18, sector 15 [18:08:22] ->SIO write 128 bytes [18:08:22] COMPLETE! [18:08:23] [18:08:23] CF: 31 52 54 01 d8 [18:08:23] disk sio_process() [18:08:23] ACK! [18:08:23] ATX READ (340) rots=230 [18:08:23] copy data track 18, sector 16 [18:08:23] ->SIO write 128 bytes [18:08:23] COMPLETE! [18:08:23] [18:08:23] CF: 31 52 55 01 d9 [18:08:23] disk sio_process() [18:08:23] ACK! [18:08:23] ATX READ (341) rots=232 [18:08:23] copy data track 18, sector 17 [18:08:23] ->SIO write 128 bytes [18:08:23] COMPLETE! [18:08:23] [18:08:23] CF: 31 52 56 01 da [18:08:23] disk sio_process() [18:08:23] ACK! [18:08:23] ATX READ (342) rots=233 [18:08:23] copy data track 18, sector 18 [18:08:23] ->SIO write 128 bytes [18:08:23] COMPLETE! [18:08:23] [18:08:23] CF: 31 52 57 01 db [18:08:23] disk sio_process() [18:08:23] ACK! [18:08:23] ATX READ (343) rots=233 [18:08:23] copy data track 19, sector 1 [18:08:23] ->SIO write 128 bytes [18:08:23] COMPLETE! [18:08:23] [18:08:23] CF: 31 52 58 01 dc [18:08:23] disk sio_process() [18:08:23] ACK! [18:08:23] ATX READ (344) rots=234 [18:08:23] copy data track 19, sector 2 [18:08:24] ->SIO write 128 bytes [18:08:24] COMPLETE! [18:08:24] [18:08:24] CF: 31 52 59 01 dd [18:08:24] disk sio_process() [18:08:24] ACK! [18:08:24] ATX READ (345) rots=236 [18:08:24] copy data track 19, sector 3 [18:08:24] ->SIO write 128 bytes [18:08:24] COMPLETE! [18:08:24] [18:08:24] CF: 31 52 5a 01 de [18:08:24] disk sio_process() [18:08:24] ACK! [18:08:24] ATX READ (346) rots=236 [18:08:24] copy data track 19, sector 4 [18:08:24] ->SIO write 128 bytes [18:08:24] COMPLETE! [18:08:24] [18:08:24] CF: 31 52 5b 01 df [18:08:24] disk sio_process() [18:08:24] ACK! [18:08:24] ATX READ (347) rots=237 [18:08:24] copy data track 19, sector 5 [18:08:24] ->SIO write 128 bytes [18:08:24] COMPLETE! [18:08:24] [18:08:24] CF: 31 52 5c 01 e0 [18:08:24] disk sio_process() [18:08:24] ACK! [18:08:24] ATX READ (348) rots=238 [18:08:24] copy data track 19, sector 6 [18:08:24] ->SIO write 128 bytes [18:08:24] COMPLETE! [18:08:25] [18:08:25] CF: 31 52 5d 01 e1 [18:08:25] disk sio_process() [18:08:25] ACK! [18:08:25] ATX READ (349) rots=240 [18:08:25] copy data track 19, sector 7 [18:08:25] ->SIO write 128 bytes [18:08:25] COMPLETE! [18:08:25] [18:08:25] CF: 31 52 5e 01 e2 [18:08:25] disk sio_process() [18:08:25] ACK! [18:08:25] ATX READ (350) rots=240 [18:08:25] copy data track 19, sector 8 [18:08:25] ->SIO write 128 bytes [18:08:25] COMPLETE! [18:08:25] [18:08:25] CF: 31 52 5f 01 e3 [18:08:25] disk sio_process() [18:08:25] ACK! [18:08:25] ATX READ (351) rots=242 [18:08:25] copy data track 19, sector 9 [18:08:25] ->SIO write 128 bytes [18:08:25] COMPLETE! [18:08:25] [18:08:25] CF: 31 52 60 01 e4 [18:08:25] disk sio_process() [18:08:25] ACK! [18:08:25] ATX READ (352) rots=242 [18:08:25] copy data track 19, sector 10 [18:08:25] ->SIO write 128 bytes [18:08:25] COMPLETE! [18:08:25] [18:08:25] CF: 31 52 61 01 e5 [18:08:25] disk sio_process() [18:08:25] ACK! [18:08:25] ATX READ (353) rots=244 [18:08:25] copy data track 19, sector 11 [18:08:25] ->SIO write 128 bytes [18:08:25] COMPLETE! [18:08:25] [18:08:25] CF: 31 52 62 01 e6 [18:08:25] disk sio_process() [18:08:25] ACK! [18:08:25] ATX READ (354) rots=244 [18:08:25] copy data track 19, sector 12 [18:08:26] ->SIO write 128 bytes [18:08:26] COMPLETE! [18:08:26] [18:08:26] CF: 31 52 63 01 e7 [18:08:26] disk sio_process() [18:08:26] ACK! [18:08:26] ATX READ (355) rots=246 [18:08:26] copy data track 19, sector 13 [18:08:26] ->SIO write 128 bytes [18:08:26] COMPLETE! [18:08:26] [18:08:26] CF: 31 52 64 01 e8 [18:08:26] disk sio_process() [18:08:26] ACK! [18:08:26] ATX READ (356) rots=246 [18:08:26] copy data track 19, sector 14 [18:08:26] ->SIO write 128 bytes [18:08:26] COMPLETE! [18:08:26] [18:08:26] CF: 31 52 65 01 e9 [18:08:26] disk sio_process() [18:08:26] ACK! [18:08:26] ATX READ (357) rots=248 [18:08:26] copy data track 19, sector 15 [18:08:26] ->SIO write 128 bytes [18:08:26] COMPLETE! [18:08:26] [18:08:26] CF: 31 52 66 01 ea [18:08:26] disk sio_process() [18:08:26] ACK! [18:08:26] ATX READ (358) rots=248 [18:08:26] copy data track 19, sector 16 [18:08:27] ->SIO write 128 bytes [18:08:27] COMPLETE! [18:08:27] [18:08:27] CF: 31 52 67 01 eb [18:08:27] disk sio_process() [18:08:27] ACK! [18:08:27] ATX READ (359) rots=250 [18:08:27] copy data track 19, sector 17 [18:08:27] ->SIO write 128 bytes [18:08:27] COMPLETE! [18:08:27] [18:08:27] CF: 31 52 68 01 ec [18:08:27] disk sio_process() [18:08:27] ACK! [18:08:27] ATX READ (360) rots=251 [18:08:27] copy data track 19, sector 18 [18:08:27] ->SIO write 128 bytes [18:08:27] COMPLETE! [18:08:27] [18:08:27] CF: 31 52 69 01 ed [18:08:27] disk sio_process() [18:08:27] ACK! [18:08:27] ATX READ (361) rots=251 [18:08:27] copy data track 20, sector 1 [18:08:27] ->SIO write 128 bytes [18:08:27] COMPLETE! [18:08:27] [18:08:27] CF: 31 52 6a 01 ee [18:08:27] disk sio_process() [18:08:27] ACK! [18:08:27] ATX READ (362) rots=252 [18:08:27] copy data track 20, sector 2 [18:08:27] ->SIO write 128 bytes [18:08:27] COMPLETE! [18:08:27] [18:08:27] CF: 31 52 6b 01 ef [18:08:27] disk sio_process() [18:08:27] ACK! [18:08:27] ATX READ (363) rots=254 [18:08:27] copy data track 20, sector 3 [18:08:27] ->SIO write 128 bytes [18:08:27] COMPLETE! [18:08:28] [18:08:28] CF: 31 52 6c 01 f0 [18:08:28] disk sio_process() [18:08:28] ACK! [18:08:28] ATX READ (364) rots=254 [18:08:28] copy data track 20, sector 4 [18:08:28] ->SIO write 128 bytes [18:08:28] COMPLETE! [18:08:28] [18:08:28] CF: 31 52 6d 01 f1 [18:08:28] disk sio_process() [18:08:28] ACK! [18:08:28] ATX READ (365) rots=256 [18:08:28] copy data track 20, sector 5 [18:08:28] ->SIO write 128 bytes [18:08:28] COMPLETE! [18:08:28] [18:08:28] CF: 31 52 6e 01 f2 [18:08:28] disk sio_process() [18:08:28] ACK! [18:08:28] ATX READ (366) rots=256 [18:08:28] copy data track 20, sector 6 [18:08:28] ->SIO write 128 bytes [18:08:28] COMPLETE! [18:08:28] [18:08:28] CF: 31 52 6f 01 f3 [18:08:28] disk sio_process() [18:08:28] ACK! [18:08:28] ATX READ (367) rots=258 [18:08:28] copy data track 20, sector 7 [18:08:28] ->SIO write 128 bytes [18:08:28] COMPLETE! [18:08:28] [18:08:28] CF: 31 52 70 01 f4 [18:08:28] disk sio_process() [18:08:28] ACK! [18:08:28] ATX READ (368) rots=258 [18:08:28] copy data track 20, sector 8 [18:08:29] ->SIO write 128 bytes [18:08:29] COMPLETE! [18:08:29] [18:08:29] CF: 31 52 71 01 f5 [18:08:29] disk sio_process() [18:08:29] ACK! [18:08:29] ATX READ (369) rots=260 [18:08:29] copy data track 20, sector 9 [18:08:29] ->SIO write 128 bytes [18:08:29] COMPLETE! [18:08:29] [18:08:29] CF: 31 52 72 01 f6 [18:08:29] disk sio_process() [18:08:29] ACK! [18:08:29] ATX READ (370) rots=260 [18:08:29] copy data track 20, sector 10 [18:08:29] ->SIO write 128 bytes [18:08:29] COMPLETE! [18:08:29] [18:08:29] CF: 31 52 73 01 f7 [18:08:29] disk sio_process() [18:08:29] ACK! [18:08:29] ATX READ (371) rots=262 [18:08:29] copy data track 20, sector 11 [18:08:29] ->SIO write 128 bytes [18:08:29] COMPLETE! [18:08:29] [18:08:29] CF: 31 52 74 01 f8 [18:08:29] disk sio_process() [18:08:29] ACK! [18:08:29] ATX READ (372) rots=262 [18:08:29] copy data track 20, sector 12 [18:08:29] ->SIO write 128 bytes [18:08:29] COMPLETE! [18:08:30] [18:08:30] CF: 31 52 75 01 f9 [18:08:30] disk sio_process() [18:08:30] ACK! [18:08:30] ATX READ (373) rots=264 [18:08:30] copy data track 20, sector 13 [18:08:30] ->SIO write 128 bytes [18:08:30] COMPLETE! [18:08:30] [18:08:30] CF: 31 52 76 01 fa [18:08:30] disk sio_process() [18:08:30] ACK! [18:08:30] ATX READ (374) rots=264 [18:08:30] copy data track 20, sector 14 [18:08:30] ->SIO write 128 bytes [18:08:30] COMPLETE! [18:08:30] [18:08:30] CF: 31 52 77 01 fb [18:08:30] disk sio_process() [18:08:30] ACK! [18:08:30] ATX READ (375) rots=266 [18:08:30] copy data track 20, sector 15 [18:08:30] ->SIO write 128 bytes [18:08:30] COMPLETE! [18:08:30] [18:08:30] CF: 31 52 78 01 fc [18:08:30] disk sio_process() [18:08:30] ACK! [18:08:30] ATX READ (376) rots=266 [18:08:30] copy data track 20, sector 16 [18:08:30] ->SIO write 128 bytes [18:08:30] COMPLETE! [18:08:30] [18:08:30] CF: 31 52 79 01 fd [18:08:30] disk sio_process() [18:08:30] ACK! [18:08:30] ATX READ (377) rots=268 [18:08:30] copy data track 20, sector 17 [18:08:30] ->SIO write 128 bytes [18:08:30] COMPLETE! [18:08:31] [18:08:31] CF: 31 52 7a 01 fe [18:08:31] disk sio_process() [18:08:31] ACK! [18:08:31] ATX READ (378) rots=269 [18:08:31] copy data track 20, sector 18 [18:08:31] ->SIO write 128 bytes [18:08:31] COMPLETE! [18:08:31] [18:08:31] CF: 31 52 7b 01 ff [18:08:31] disk sio_process() [18:08:31] ACK! [18:08:31] ATX READ (379) rots=269 [18:08:31] copy data track 21, sector 1 [18:08:31] ->SIO write 128 bytes [18:08:31] COMPLETE! [18:08:31] [18:08:31] CF: 31 52 7c 01 01 [18:08:31] disk sio_process() [18:08:31] ACK! [18:08:31] ATX READ (380) rots=270 [18:08:31] copy data track 21, sector 2 [18:08:31] ->SIO write 128 bytes [18:08:31] COMPLETE! [18:08:31] [18:08:31] CF: 31 52 7d 01 02 [18:08:31] disk sio_process() [18:08:31] ACK! [18:08:31] ATX READ (381) rots=272 [18:08:31] copy data track 21, sector 3 [18:08:31] ->SIO write 128 bytes [18:08:31] COMPLETE! [18:08:31] [18:08:31] CF: 31 52 7e 01 03 [18:08:31] disk sio_process() [18:08:31] ACK! [18:08:31] ATX READ (382) rots=272 [18:08:31] copy data track 21, sector 4 [18:08:31] ->SIO write 128 bytes [18:08:31] COMPLETE! [18:08:32] [18:08:32] CF: 31 52 7f 01 04 [18:08:32] disk sio_process() [18:08:32] ACK! [18:08:32] ATX READ (383) rots=274 [18:08:32] copy data track 21, sector 5 [18:08:32] ->SIO write 128 bytes [18:08:32] COMPLETE! [18:08:32] [18:08:32] CF: 31 52 80 01 05 [18:08:32] disk sio_process() [18:08:32] ACK! [18:08:32] ATX READ (384) rots=274 [18:08:32] copy data track 21, sector 6 [18:08:32] ->SIO write 128 bytes [18:08:32] COMPLETE! [18:08:32] [18:08:32] CF: 31 52 81 01 06 [18:08:32] disk sio_process() [18:08:32] ACK! [18:08:32] ATX READ (385) rots=276 [18:08:32] copy data track 21, sector 7 [18:08:32] ->SIO write 128 bytes [18:08:32] COMPLETE! [18:08:32] [18:08:32] CF: 31 52 82 01 07 [18:08:32] disk sio_process() [18:08:32] ACK! [18:08:32] ATX READ (386) rots=276 [18:08:32] copy data track 21, sector 8 [18:08:32] ->SIO write 128 bytes [18:08:32] COMPLETE! [18:08:32] [18:08:32] CF: 31 52 83 01 08 [18:08:32] disk sio_process() [18:08:32] ACK! [18:08:32] ATX READ (387) rots=278 [18:08:32] copy data track 21, sector 9 [18:08:32] ->SIO write 128 bytes [18:08:32] COMPLETE! [18:08:33] [18:08:33] CF: 31 52 84 01 09 [18:08:33] disk sio_process() [18:08:33] ACK! [18:08:33] ATX READ (388) rots=278 [18:08:33] copy data track 21, sector 10 [18:08:33] ->SIO write 128 bytes [18:08:33] COMPLETE! [18:08:33] [18:08:33] CF: 31 52 85 01 0a [18:08:33] disk sio_process() [18:08:33] ACK! [18:08:33] ATX READ (389) rots=280 [18:08:33] copy data track 21, sector 11 [18:08:33] ->SIO write 128 bytes [18:08:33] COMPLETE! [18:08:33] [18:08:33] CF: 31 52 86 01 0b [18:08:33] disk sio_process() [18:08:33] ACK! [18:08:33] ATX READ (390) rots=280 [18:08:33] copy data track 21, sector 12 [18:08:33] ->SIO write 128 bytes [18:08:33] COMPLETE! [18:08:33] [18:08:33] CF: 31 52 87 01 0c [18:08:33] disk sio_process() [18:08:33] ACK! [18:08:33] ATX READ (391) rots=282 [18:08:33] copy data track 21, sector 13 [18:08:33] ->SIO write 128 bytes [18:08:33] COMPLETE! [18:08:33] [18:08:33] CF: 31 52 88 01 0d [18:08:33] disk sio_process() [18:08:33] ACK! [18:08:33] ATX READ (392) rots=282 [18:08:33] copy data track 21, sector 14 [18:08:34] ->SIO write 128 bytes [18:08:34] COMPLETE! [18:08:34] [18:08:34] CF: 31 52 89 01 0e [18:08:34] disk sio_process() [18:08:34] ACK! [18:08:34] ATX READ (393) rots=284 [18:08:34] copy data track 21, sector 15 [18:08:34] ->SIO write 128 bytes [18:08:34] COMPLETE! [18:08:34] [18:08:34] CF: 31 52 8a 01 0f [18:08:34] disk sio_process() [18:08:34] ACK! [18:08:34] ATX READ (394) rots=284 [18:08:34] copy data track 21, sector 16 [18:08:34] ->SIO write 128 bytes [18:08:34] COMPLETE! [18:08:34] [18:08:34] CF: 31 52 8b 01 10 [18:08:34] disk sio_process() [18:08:34] ACK! [18:08:34] ATX READ (395) rots=286 [18:08:34] copy data track 21, sector 17 [18:08:34] ->SIO write 128 bytes [18:08:34] COMPLETE! [18:08:34] [18:08:34] CF: 31 52 8c 01 11 [18:08:34] disk sio_process() [18:08:34] ACK! [18:08:34] ATX READ (396) rots=287 [18:08:34] copy data track 21, sector 18 [18:08:34] ->SIO write 128 bytes [18:08:34] COMPLETE! [18:08:34] [18:08:34] CF: 31 52 8d 01 12 [18:08:34] disk sio_process() [18:08:34] ACK! [18:08:34] ATX READ (397) rots=287 [18:08:34] copy data track 22, sector 1 [18:08:35] ->SIO write 128 bytes [18:08:35] COMPLETE! [18:08:35] [18:08:35] CF: 31 52 8e 01 13 [18:08:35] disk sio_process() [18:08:35] ACK! [18:08:35] ATX READ (398) rots=288 [18:08:35] copy data track 22, sector 2 [18:08:35] ->SIO write 128 bytes [18:08:35] COMPLETE! [18:08:35] [18:08:35] CF: 31 52 8f 01 14 [18:08:35] disk sio_process() [18:08:35] ACK! [18:08:35] ATX READ (399) rots=290 [18:08:35] copy data track 22, sector 3 [18:08:35] ->SIO write 128 bytes [18:08:35] COMPLETE! [18:08:35] [18:08:35] CF: 31 52 90 01 15 [18:08:35] disk sio_process() [18:08:35] ACK! [18:08:35] ATX READ (400) rots=290 [18:08:35] copy data track 22, sector 4 [18:08:35] ->SIO write 128 bytes [18:08:35] COMPLETE! [18:08:35] [18:08:35] CF: 31 52 91 01 16 [18:08:35] disk sio_process() [18:08:35] ACK! [18:08:35] ATX READ (401) rots=292 [18:08:35] copy data track 22, sector 5 [18:08:35] ->SIO write 128 bytes [18:08:35] COMPLETE! [18:08:35] [18:08:35] CF: 31 52 92 01 17 [18:08:35] disk sio_process() [18:08:35] ACK! [18:08:35] ATX READ (402) rots=292 [18:08:35] copy data track 22, sector 6 [18:08:36] ->SIO write 128 bytes [18:08:36] COMPLETE! [18:08:36] [18:08:36] CF: 31 52 93 01 18 [18:08:36] disk sio_process() [18:08:36] ACK! [18:08:36] ATX READ (403) rots=294 [18:08:36] copy data track 22, sector 7 [18:08:36] ->SIO write 128 bytes [18:08:36] COMPLETE! [18:08:36] [18:08:36] CF: 31 52 94 01 19 [18:08:36] disk sio_process() [18:08:36] ACK! [18:08:36] ATX READ (404) rots=294 [18:08:36] copy data track 22, sector 8 [18:08:36] ->SIO write 128 bytes [18:08:36] COMPLETE! [18:08:36] [18:08:36] CF: 31 52 95 01 1a [18:08:36] disk sio_process() [18:08:36] ACK! [18:08:36] ATX READ (405) rots=296 [18:08:36] copy data track 22, sector 9 [18:08:36] ->SIO write 128 bytes [18:08:36] COMPLETE! [18:08:36] [18:08:36] CF: 31 52 96 01 1b [18:08:36] disk sio_process() [18:08:36] ACK! [18:08:36] ATX READ (406) rots=296 [18:08:36] copy data track 22, sector 10 [18:08:37] ->SIO write 128 bytes [18:08:37] COMPLETE! [18:08:37] [18:08:37] CF: 31 52 97 01 1c [18:08:37] disk sio_process() [18:08:37] ACK! [18:08:37] ATX READ (407) rots=298 [18:08:37] copy data track 22, sector 11 [18:08:37] ->SIO write 128 bytes [18:08:37] COMPLETE! [18:08:37] [18:08:37] CF: 31 52 98 01 1d [18:08:37] disk sio_process() [18:08:37] ACK! [18:08:37] ATX READ (408) rots=298 [18:08:37] copy data track 22, sector 12 [18:08:37] ->SIO write 128 bytes [18:08:37] COMPLETE! [18:08:37] [18:08:37] CF: 31 52 99 01 1e [18:08:37] disk sio_process() [18:08:37] ACK! [18:08:37] ATX READ (409) rots=300 [18:08:37] copy data track 22, sector 13 [18:08:37] ->SIO write 128 bytes [18:08:37] COMPLETE! [18:08:37] [18:08:37] CF: 31 52 9a 01 1f [18:08:37] disk sio_process() [18:08:37] ACK! [18:08:37] ATX READ (410) rots=300 [18:08:37] copy data track 22, sector 14 [18:08:37] ->SIO write 128 bytes [18:08:37] COMPLETE! [18:08:37] [18:08:37] CF: 31 52 9b 01 20 [18:08:37] disk sio_process() [18:08:37] ACK! [18:08:37] ATX READ (411) rots=302 [18:08:37] copy data track 22, sector 15 [18:08:37] ->SIO write 128 bytes [18:08:37] COMPLETE! [18:08:38] [18:08:38] CF: 31 52 9c 01 21 [18:08:38] disk sio_process() [18:08:38] ACK! [18:08:38] ATX READ (412) rots=302 [18:08:38] copy data track 22, sector 16 [18:08:38] ->SIO write 128 bytes [18:08:38] COMPLETE! [18:08:38] [18:08:38] CF: 31 52 9d 01 22 [18:08:38] disk sio_process() [18:08:38] ACK! [18:08:38] ATX READ (413) rots=304 [18:08:38] copy data track 22, sector 17 [18:08:38] ->SIO write 128 bytes [18:08:38] COMPLETE! [18:08:38] [18:08:38] CF: 31 52 9e 01 23 [18:08:38] disk sio_process() [18:08:38] ACK! [18:08:38] ATX READ (414) rots=305 [18:08:38] copy data track 22, sector 18 [18:08:38] ->SIO write 128 bytes [18:08:38] COMPLETE! [18:08:38] [18:08:38] CF: 31 52 9f 01 24 [18:08:38] disk sio_process() [18:08:38] ACK! [18:08:38] ATX READ (415) rots=305 [18:08:38] copy data track 23, sector 1 [18:08:38] ->SIO write 128 bytes [18:08:38] COMPLETE! [18:08:38] [18:08:38] CF: 31 52 a0 01 25 [18:08:38] disk sio_process() [18:08:38] ACK! [18:08:38] ATX READ (416) rots=306 [18:08:38] copy data track 23, sector 2 [18:08:39] ->SIO write 128 bytes [18:08:39] COMPLETE! [18:08:39] [18:08:39] CF: 31 52 a1 01 26 [18:08:39] disk sio_process() [18:08:39] ACK! [18:08:39] ATX READ (417) rots=308 [18:08:39] copy data track 23, sector 3 [18:08:39] ->SIO write 128 bytes [18:08:39] COMPLETE! [18:08:39] [18:08:39] CF: 31 52 a2 01 27 [18:08:39] disk sio_process() [18:08:39] ACK! [18:08:39] ATX READ (418) rots=308 [18:08:39] copy data track 23, sector 4 [18:08:39] ->SIO write 128 bytes [18:08:39] COMPLETE! [18:08:39] [18:08:39] CF: 31 52 a3 01 28 [18:08:39] disk sio_process() [18:08:39] ACK! [18:08:39] ATX READ (419) rots=310 [18:08:39] copy data track 23, sector 5 [18:08:39] ->SIO write 128 bytes [18:08:39] COMPLETE! [18:08:39] [18:08:39] CF: 31 52 a4 01 29 [18:08:39] disk sio_process() [18:08:39] ACK! [18:08:39] ATX READ (420) rots=310 [18:08:39] copy data track 23, sector 6 [18:08:39] ->SIO write 128 bytes [18:08:39] COMPLETE! [18:08:40] [18:08:40] CF: 31 52 a5 01 2a [18:08:40] disk sio_process() [18:08:40] ACK! [18:08:40] ATX READ (421) rots=312 [18:08:40] copy data track 23, sector 7 [18:08:40] ->SIO write 128 bytes [18:08:40] COMPLETE! [18:08:40] [18:08:40] CF: 31 52 a6 01 2b [18:08:40] disk sio_process() [18:08:40] ACK! [18:08:40] ATX READ (422) rots=312 [18:08:40] copy data track 23, sector 8 [18:08:40] ->SIO write 128 bytes [18:08:40] COMPLETE! [18:08:40] [18:08:40] CF: 31 52 a7 01 2c [18:08:40] disk sio_process() [18:08:40] ACK! [18:08:40] ATX READ (423) rots=314 [18:08:40] copy data track 23, sector 9 [18:08:40] ->SIO write 128 bytes [18:08:40] COMPLETE! [18:08:40] [18:08:40] CF: 31 52 a8 01 2d [18:08:40] disk sio_process() [18:08:40] ACK! [18:08:40] ATX READ (424) rots=314 [18:08:40] copy data track 23, sector 10 [18:08:40] ->SIO write 128 bytes [18:08:40] COMPLETE! [18:08:40] [18:08:40] CF: 31 52 a9 01 2e [18:08:40] disk sio_process() [18:08:40] ACK! [18:08:40] ATX READ (425) rots=316 [18:08:40] copy data track 23, sector 11 [18:08:40] ->SIO write 128 bytes [18:08:40] COMPLETE! [18:08:40] [18:08:40] CF: 31 52 aa 01 2f [18:08:40] disk sio_process() [18:08:40] ACK! [18:08:40] ATX READ (426) rots=316 [18:08:40] copy data track 23, sector 12 [18:08:41] ->SIO write 128 bytes [18:08:41] COMPLETE! [18:08:41] [18:08:41] CF: 31 52 ab 01 30 [18:08:41] disk sio_process() [18:08:41] ACK! [18:08:41] ATX READ (427) rots=318 [18:08:41] copy data track 23, sector 13 [18:08:41] ->SIO write 128 bytes [18:08:41] COMPLETE! [18:08:41] [18:08:41] CF: 31 52 ac 01 31 [18:08:41] disk sio_process() [18:08:41] ACK! [18:08:41] ATX READ (428) rots=318 [18:08:41] copy data track 23, sector 14 [18:08:41] ->SIO write 128 bytes [18:08:41] COMPLETE! [18:08:41] [18:08:41] CF: 31 52 ad 01 32 [18:08:41] disk sio_process() [18:08:41] ACK! [18:08:41] ATX READ (429) rots=320 [18:08:41] copy data track 23, sector 15 [18:08:41] ->SIO write 128 bytes [18:08:41] COMPLETE! [18:08:41] [18:08:41] CF: 31 52 ae 01 33 [18:08:41] disk sio_process() [18:08:41] ACK! [18:08:41] ATX READ (430) rots=320 [18:08:41] copy data track 23, sector 16 [18:08:42] ->SIO write 128 bytes [18:08:42] COMPLETE! [18:08:42] [18:08:42] CF: 31 52 af 01 34 [18:08:42] disk sio_process() [18:08:42] ACK! [18:08:42] ATX READ (431) rots=322 [18:08:42] copy data track 23, sector 17 [18:08:42] ->SIO write 128 bytes [18:08:42] COMPLETE! [18:08:42] [18:08:42] CF: 31 52 b0 01 35 [18:08:42] disk sio_process() [18:08:42] ACK! [18:08:42] ATX READ (432) rots=323 [18:08:42] copy data track 23, sector 18 [18:08:42] ->SIO write 128 bytes [18:08:42] COMPLETE! [18:08:42] [18:08:42] CF: 31 52 b1 01 36 [18:08:42] disk sio_process() [18:08:42] ACK! [18:08:42] ATX READ (433) rots=323 [18:08:42] copy data track 24, sector 1 [18:08:42] ->SIO write 128 bytes [18:08:42] COMPLETE! [18:08:42] [18:08:42] CF: 31 52 b2 01 37 [18:08:42] disk sio_process() [18:08:42] ACK! [18:08:42] ATX READ (434) rots=324 [18:08:42] copy data track 24, sector 2 [18:08:42] ->SIO write 128 bytes [18:08:42] COMPLETE! [18:08:42] [18:08:42] CF: 31 52 b3 01 38 [18:08:42] disk sio_process() [18:08:42] ACK! [18:08:42] ATX READ (435) rots=326 [18:08:42] copy data track 24, sector 3 [18:08:42] ->SIO write 128 bytes [18:08:42] COMPLETE! [18:08:43] [18:08:43] CF: 31 52 b4 01 39 [18:08:43] disk sio_process() [18:08:43] ACK! [18:08:43] ATX READ (436) rots=326 [18:08:43] copy data track 24, sector 4 [18:08:43] ->SIO write 128 bytes [18:08:43] COMPLETE! [18:08:43] [18:08:43] CF: 31 52 b5 01 3a [18:08:43] disk sio_process() [18:08:43] ACK! [18:08:43] ATX READ (437) rots=328 [18:08:43] copy data track 24, sector 5 [18:08:43] ->SIO write 128 bytes [18:08:43] COMPLETE! [18:08:43] [18:08:43] CF: 31 52 b6 01 3b [18:08:43] disk sio_process() [18:08:43] ACK! [18:08:43] ATX READ (438) rots=328 [18:08:43] copy data track 24, sector 6 [18:08:43] ->SIO write 128 bytes [18:08:43] COMPLETE! [18:08:43] [18:08:43] CF: 31 52 b7 01 3c [18:08:43] disk sio_process() [18:08:43] ACK! [18:08:43] ATX READ (439) rots=330 [18:08:43] copy data track 24, sector 7 [18:08:43] ->SIO write 128 bytes [18:08:43] COMPLETE! [18:08:43] [18:08:43] CF: 31 52 b8 01 3d [18:08:43] disk sio_process() [18:08:43] ACK! [18:08:43] ATX READ (440) rots=330 [18:08:43] copy data track 24, sector 8 [18:08:44] ->SIO write 128 bytes [18:08:44] COMPLETE! [18:08:44] [18:08:44] CF: 31 52 b9 01 3e [18:08:44] disk sio_process() [18:08:44] ACK! [18:08:44] ATX READ (441) rots=332 [18:08:44] copy data track 24, sector 9 [18:08:44] ->SIO write 128 bytes [18:08:44] COMPLETE! [18:08:44] [18:08:44] CF: 31 52 ba 01 3f [18:08:44] disk sio_process() [18:08:44] ACK! [18:08:44] ATX READ (442) rots=332 [18:08:44] copy data track 24, sector 10 [18:08:44] ->SIO write 128 bytes [18:08:44] COMPLETE! [18:08:44] [18:08:44] CF: 31 52 bb 01 40 [18:08:44] disk sio_process() [18:08:44] ACK! [18:08:44] ATX READ (443) rots=334 [18:08:44] copy data track 24, sector 11 [18:08:44] ->SIO write 128 bytes [18:08:44] COMPLETE! [18:08:44] [18:08:44] CF: 31 52 bc 01 41 [18:08:44] disk sio_process() [18:08:44] ACK! [18:08:44] ATX READ (444) rots=334 [18:08:44] copy data track 24, sector 12 [18:08:44] ->SIO write 128 bytes [18:08:44] COMPLETE! [18:08:45] [18:08:45] CF: 31 52 bd 01 42 [18:08:45] disk sio_process() [18:08:45] ACK! [18:08:45] ATX READ (445) rots=336 [18:08:45] copy data track 24, sector 13 [18:08:45] ->SIO write 128 bytes [18:08:45] COMPLETE! [18:08:45] [18:08:45] CF: 31 52 be 01 43 [18:08:45] disk sio_process() [18:08:45] ACK! [18:08:45] ATX READ (446) rots=336 [18:08:45] copy data track 24, sector 14 [18:08:45] ->SIO write 128 bytes [18:08:45] COMPLETE! [18:08:45] [18:08:45] CF: 31 52 bf 01 44 [18:08:45] disk sio_process() [18:08:45] ACK! [18:08:45] ATX READ (447) rots=338 [18:08:45] copy data track 24, sector 15 [18:08:45] ->SIO write 128 bytes [18:08:45] COMPLETE! [18:08:45] [18:08:45] CF: 31 52 c0 01 45 [18:08:45] disk sio_process() [18:08:45] ACK! [18:08:45] ATX READ (448) rots=338 [18:08:45] copy data track 24, sector 16 [18:08:45] ->SIO write 128 bytes [18:08:45] COMPLETE! [18:08:45] [18:08:45] CF: 31 52 c1 01 46 [18:08:45] disk sio_process() [18:08:45] ACK! [18:08:45] ATX READ (449) rots=340 [18:08:45] copy data track 24, sector 17 [18:08:45] ->SIO write 128 bytes [18:08:45] COMPLETE! [18:08:46] [18:08:46] CF: 31 52 c2 01 47 [18:08:46] disk sio_process() [18:08:46] ACK! [18:08:46] ATX READ (450) rots=341 [18:08:46] copy data track 24, sector 18 [18:08:46] ->SIO write 128 bytes [18:08:46] COMPLETE! [18:08:46] [18:08:46] CF: 31 52 c3 01 48 [18:08:46] disk sio_process() [18:08:46] ACK! [18:08:46] ATX READ (451) rots=341 [18:08:46] copy data track 25, sector 1 [18:08:46] ->SIO write 128 bytes [18:08:46] COMPLETE! [18:08:46] [18:08:46] CF: 31 52 c4 01 49 [18:08:46] disk sio_process() [18:08:46] ACK! [18:08:46] ATX READ (452) rots=342 [18:08:46] copy data track 25, sector 2 [18:08:46] ->SIO write 128 bytes [18:08:46] COMPLETE! [18:08:46] [18:08:46] CF: 31 52 c5 01 4a [18:08:46] disk sio_process() [18:08:46] ACK! [18:08:46] ATX READ (453) rots=344 [18:08:46] copy data track 25, sector 3 [18:08:46] ->SIO write 128 bytes [18:08:46] COMPLETE! [18:08:46] [18:08:46] CF: 31 52 c6 01 4b [18:08:46] disk sio_process() [18:08:46] ACK! [18:08:46] ATX READ (454) rots=344 [18:08:46] copy data track 25, sector 4 [18:08:46] ->SIO write 128 bytes [18:08:46] COMPLETE! [18:08:47] [18:08:47] CF: 31 52 c7 01 4c [18:08:47] disk sio_process() [18:08:47] ACK! [18:08:47] ATX READ (455) rots=346 [18:08:47] copy data track 25, sector 5 [18:08:47] ->SIO write 128 bytes [18:08:47] COMPLETE! [18:08:47] [18:08:47] CF: 31 52 c8 01 4d [18:08:47] disk sio_process() [18:08:47] ACK! [18:08:47] ATX READ (456) rots=346 [18:08:47] copy data track 25, sector 6 [18:08:47] ->SIO write 128 bytes [18:08:47] COMPLETE! [18:08:47] [18:08:47] CF: 31 52 cd 01 52 [18:08:47] disk sio_process() [18:08:47] ACK! [18:08:47] ATX READ (461) rots=348 [18:08:47] copy data track 25, sector 11 [18:08:47] ->SIO write 128 bytes [18:08:47] COMPLETE! [18:08:47] [18:08:47] CF: 31 52 ce 01 53 [18:08:47] disk sio_process() [18:08:47] ACK! [18:08:47] ATX READ (462) rots=348 [18:08:47] copy data track 25, sector 12 [18:08:47] ->SIO write 128 bytes [18:08:47] COMPLETE! [18:08:47] [18:08:47] CF: 31 52 cf 01 54 [18:08:47] disk sio_process() [18:08:47] ACK! [18:08:47] ATX READ (463) rots=350 [18:08:47] copy data track 25, sector 13 [18:08:47] ->SIO write 128 bytes [18:08:47] COMPLETE! [18:08:48] [18:08:48] CF: 31 52 d0 01 55 [18:08:48] disk sio_process() [18:08:48] ACK! [18:08:48] ATX READ (464) rots=350 [18:08:48] copy data track 25, sector 14 [18:08:48] ->SIO write 128 bytes [18:08:48] COMPLETE! [18:08:48] [18:08:48] CF: 31 52 d0 02 56 [18:08:48] disk sio_process() [18:08:48] ACK! [18:08:48] ATX READ (720) rots=352 [18:08:48] copy data track 39, sector 18 [18:08:48] ## Did not find sector with matching number [18:08:48] ## Did not find sector with matching number [18:08:48] ## Did not find sector with matching number [18:08:48] ## Did not find sector with matching number [18:08:48] ->SIO write 128 bytes [18:08:48] ERROR! [18:08:49] [18:08:49] CF: 31 52 d0 02 56 [18:08:49] disk sio_process() [18:08:49] ACK! [18:08:49] ATX READ (720) rots=355 [18:08:49] copy data track 39, sector 18 [18:08:49] ## Did not find sector with matching number [18:08:49] ## Did not find sector with matching number [18:08:49] ## Did not find sector with matching number [18:08:49] ## Did not find sector with matching number [18:08:49] ->SIO write 128 bytes [18:08:49] ERROR! [18:08:49] [18:08:49] CF: 31 52 d0 02 56 [18:08:49] disk sio_process() [18:08:49] ACK! [18:08:49] ATX READ (720) rots=358 [18:08:49] copy data track 39, sector 18 [18:08:49] ## Did not find sector with matching number [18:08:49] ## Did not find sector with matching number [18:08:50] ## Did not find sector with matching number [18:08:50] ## Did not find sector with matching number [18:08:50] ->SIO write 128 bytes [18:08:50] ERROR! [18:08:50] [18:08:50] CF: 31 52 d0 02 56 [18:08:50] disk sio_process() [18:08:50] ACK! [18:08:50] ATX READ (720) rots=362 [18:08:50] copy data track 39, sector 18 [18:08:50] ## Did not find sector with matching number [18:08:50] ## Did not find sector with matching number [18:08:50] ## Did not find sector with matching number [18:08:51] ## Did not find sector with matching number [18:Using '/dev/cu.usbserial-10' as serial port. Using '460800' as baud rate. Showing logs: [18:06:57] BUTTON_C: SHORT PRESS [18:06:57] ACTION: Reboot [18:06:57] Shutting down device 5a [18:06:57] Shutting down device 43 [18:06:57] Shutting down device 50 [18:06:57] Shutting down device 40 [18:06:57] Shutting down device 99 [18:06:57] Shutting down device 45 [18:06:57] Shutting down device 70 [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] Shutting down device 5f [18:06:57] Shutting down device 78 [18:06:57] Shutting down device 77 [18:06:57] Shutting down device 76 [18:06:57] Shutting down device 75 [18:06:57] Shutting down device 74 [18:06:57] Shutting down device 73 [18:06:57] Shutting down device 72 [18:06:57] Shutting down device 71 [18:06:57] Shutting down device 38 [18:06:57] Shutting down device 37 [18:06:57] Shutting down device 36 [18:06:57] Shutting down device 35 [18:06:57] Shutting down device 34 [18:06:57] Shutting down device 33 [18:06:57] Shutting down device 32 [18:06:57] Shutting down device 31 [18:06:57] All devices shut down. [18:06:57] WIFI_EVENT_STA_DISCONNECTED [18:06:57] Stopping web service [18:06:57] Shutdown handler called [18:06:57] Shutting down device 5a [18:06:57] Shutting down device 43 [18:06:57] Shutting down device 50 [18:06:57] Shutting down device 40 [18:06:57] Shutting down device 99 [18:06:57] Shutting down device 45 [18:06:57] Shutting down device 70 [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] disk UNMOUNT [18:06:57] Shutting down device 5f [18:06:57] Shutting down device 78 [18:06:57] Shutting down device 77 [18:06:57] Shutting down device 76 [18:06:57] Shutting down device 75 [18:06:57] Shutting down device 74 [18:06:57] Shutting down device 73 [18:06:57] Shutting down device 72 [18:06:57] Shutting down device 71 [18:06:57] Shutting down device 38 [18:06:57] Shutting down device 37 [18:06:57] Shutting down device 36 [18:06:57] Shutting down device 35 [18:06:57] Shutting down device 34 [18:06:57] Shutting down device 33 [18:06:57] Shutting down device 32 [18:06:57] Shutting down device 31 [18:06:57] All devices shut down. [18:06:58] [18:06:58] [18:06:58] --~--~--~-- [18:06:58] FujiNet 0.5.13741956 2023-01-30 22:44:10 Started @ 5 [18:06:58] Starting heap: 4365075 [18:06:58] Detected Hardware Version: 1.6.1 and up [18:06:58] Safe Reset Button 😄 ENABLED [18:06:58] SPIFFS mounted. [18:06:58] SD mounted. [18:06:58] fnConfig::load [18:06:58] Load fnconfig.ini from SD [18:06:58] fopen = /fnconfig.ini : ok [18:06:58] fnConfig::load read 1178 bytes from config file [18:06:58] SPIFFS Config Storage: Enabled [18:06:58] fnConfig::load read 1178 bytes from SPIFFS config file [18:06:58] disk UNMOUNT [18:06:58] disk MOUNT [18:06:58] ATR MOUNT [18:06:58] mounted ATR: paragraphs=5760, sect_size=128, sect_count=720, disk_size=0 [18:06:58] Creating a default printer using FS_SDFAT storage and type 12 [18:06:58] ModemSniffer::ModemSniffer(FS_SDFAT) [18:06:58] SIO SETUP [18:06:58] Set HSIO baud from 0 to 67431 (index 6), alt=68209 [18:06:58] Available heap: 4272083 [18:06:58] Setup complete @ 668 (663ms) [18:06:59] WiFiManager::start() complete [18:06:59] WIFI_EVENT_STA_START [18:06:59] WiFi connect attempt to SSID "Paris2015" [18:06:59] esp_wifi_connect returned 0 [18:06:59] WIFI_EVENT_STA_CONNECTED [18:07:00] IP_EVENT_STA_GOT_IP [18:07:00] Obtained IP address: 192.168.7.249 [18:07:00] SNTP client start [18:07:00] Starting web server on port 80 [18:07:01] SNTP time sync event: Sun Feb 19, 18:07:01 2023 -0800 [18:07:10] [18:07:10] CF: 00 e0 e0 e0 e0 [18:07:10] CHECKSUM_ERROR [18:07:10] [18:07:10] CF: 00 e0 e0 e0 e0 [18:07:10] CHECKSUM_ERROR [18:07:10] Toggling baudrate from 19200 to 67431 [18:07:10] [18:07:10] CF: 00 38 38 00 00 [18:07:10] CHECKSUM_ERROR [18:07:10] [18:07:10] CF: 00 38 38 00 00 [18:07:10] CHECKSUM_ERROR [18:07:10] Toggling baudrate from 67431 to 19200 [18:07:10] [18:07:10] CF: 70 f5 00 00 66 [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: CLOSE DIRECTORY [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f9 00 00 6a [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: MOUNT HOST [18:07:10] ::mount {0} "SD" [18:07:10] ::mount_local Attempting mount of "SD" [18:07:10] Setting type to LOCAL [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f7 00 00 68 [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: OPEN DIRECTORY [18:07:10] <-SIO read 256 bytes [18:07:10] ACK! [18:07:10] Opening directory: "/", pattern: "" [18:07:10] ::dir_open {0:1} "/", pattern "" [18:07:10] ::dir_open actual path = "/" [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f6 24 00 8b [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:10] ::dir_nextfile {0:1} [18:07:10] ::read_direntry "0-9" [18:07:10] ->SIO write 36 bytes [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f6 24 00 8b [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:10] ::dir_nextfile {0:1} [18:07:10] ::read_direntry "A" [18:07:10] ->SIO write 36 bytes [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f6 24 00 8b [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:10] ::dir_nextfile {0:1} [18:07:10] ::read_direntry "B" [18:07:10] ->SIO write 36 bytes [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f6 24 00 8b [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:10] ::dir_nextfile {0:1} [18:07:10] ::read_direntry "C" [18:07:10] ->SIO write 36 bytes [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f6 24 00 8b [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:10] ::dir_nextfile {0:1} [18:07:10] ::read_direntry "D" [18:07:10] ->SIO write 36 bytes [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f6 24 00 8b [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:10] ::dir_nextfile {0:1} [18:07:10] ::read_direntry "E" [18:07:10] ->SIO write 36 bytes [18:07:10] COMPLETE! [18:07:10] [18:07:10] CF: 70 f6 24 00 8b [18:07:10] sioFuji::sio_process() called [18:07:10] ACK! [18:07:10] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:10] ::dir_nextfile {0:1} [18:07:10] ::read_direntry "F" [18:07:11] ->SIO write 36 bytes [18:07:11] COMPLETE! [18:07:11] [18:07:11] CF: 70 f6 24 00 8b [18:07:11] sioFuji::sio_process() called [18:07:11] ACK! [18:07:11] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:11] ::dir_nextfile {0:1} [18:07:11] ::read_direntry "FujiNet" [18:07:11] ->SIO write 36 bytes [18:07:11] COMPLETE! [18:07:11] [18:07:11] CF: 70 f6 24 00 8b [18:07:11] sioFuji::sio_process() called [18:07:11] ACK! [18:07:11] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:11] ::dir_nextfile {0:1} [18:07:11] ::read_direntry "G" [18:07:11] ->SIO write 36 bytes [18:07:11] COMPLETE! [18:07:11] [18:07:11] CF: 70 f6 24 00 8b [18:07:11] sioFuji::sio_process() called [18:07:11] ACK! [18:07:11] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:11] ::dir_nextfile {0:1} [18:07:11] ::read_direntry "H" [18:07:11] ->SIO write 36 bytes [18:07:11] COMPLETE! [18:07:11] [18:07:11] CF: 70 f6 24 00 8b [18:07:11] sioFuji::sio_process() called [18:07:11] ACK! [18:07:11] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:11] ::dir_nextfile {0:1} [18:07:11] ::read_direntry "I" [18:07:11] ->SIO write 36 bytes [18:07:11] COMPLETE! [18:07:11] [18:07:11] CF: 70 f6 24 00 8b [18:07:11] sioFuji::sio_process() called [18:07:11] ACK! [18:07:11] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:11] ::dir_nextfile {0:1} [18:07:11] ::read_direntry "J" [18:07:11] ->SIO write 36 bytes [18:07:11] COMPLETE! [18:07:11] [18:07:11] CF: 70 f6 24 00 8b [18:07:11] sioFuji::sio_process() called [18:07:11] ACK! [18:07:11] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:11] ::dir_nextfile {0:1} [18:07:11] ::read_direntry "K" [18:07:11] ->SIO write 36 bytes [18:07:11] COMPLETE! [18:07:11] [18:07:11] CF: 70 f6 24 00 8b [18:07:11] sioFuji::sio_process() called [18:07:11] ACK! [18:07:11] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:11] ::dir_nextfile {0:1} [18:07:11] ::read_direntry "L" [18:07:11] ->SIO write 36 bytes [18:07:11] COMPLETE! [18:07:11] [18:07:11] CF: 70 f5 00 00 66 [18:07:11] sioFuji::sio_process() called [18:07:11] ACK! [18:07:11] Fuji cmd: CLOSE DIRECTORY [18:07:11] COMPLETE! [18:07:13] [18:07:13] CF: 70 f9 00 00 6a [18:07:13] sioFuji::sio_process() called [18:07:13] ACK! [18:07:13] Fuji cmd: MOUNT HOST [18:07:13] ::mount {0} "SD" [18:07:13] ::mount_local Attempting mount of "SD" [18:07:13] Type is already LOCAL [18:07:13] COMPLETE! [18:07:13] [18:07:13] CF: 70 f7 00 00 68 [18:07:13] sioFuji::sio_process() called [18:07:13] ACK! [18:07:13] Fuji cmd: OPEN DIRECTORY [18:07:13] <-SIO read 256 bytes [18:07:13] ACK! [18:07:13] Opening directory: "/", pattern: "" [18:07:13] ::dir_open {0:1} "/", pattern "" [18:07:13] ::dir_open actual path = "/" [18:07:13] COMPLETE! [18:07:13] [18:07:13] CF: 70 e4 0d 00 62 [18:07:13] sioFuji::sio_process() called [18:07:13] ACK! [18:07:13] Fuji cmd: SET DIRECTORY POSITION [18:07:13] ::dir_seek {0:1} 13 [18:07:13] COMPLETE! [18:07:13] [18:07:13] CF: 70 f6 24 00 8b [18:07:13] sioFuji::sio_process() called [18:07:13] ACK! [18:07:13] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:13] ::dir_nextfile {0:1} [18:07:13] ::read_direntry "L" [18:07:13] ->SIO write 36 bytes [18:07:13] COMPLETE! [18:07:13] [18:07:13] CF: 70 f6 24 00 8b [18:07:13] sioFuji::sio_process() called [18:07:13] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "M" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "N" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "O" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "P" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "Q" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "R" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "S" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "T" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "U" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "W" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "Z" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "ZZdemos" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f6 24 00 8b [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:14] ::dir_nextfile {0:1} [18:07:14] ::read_direntry "weather.atr" [18:07:14] ->SIO write 36 bytes [18:07:14] COMPLETE! [18:07:14] [18:07:14] CF: 70 f5 00 00 66 [18:07:14] sioFuji::sio_process() called [18:07:14] ACK! [18:07:14] Fuji cmd: CLOSE DIRECTORY [18:07:14] COMPLETE! [18:07:16] [18:07:16] CF: 70 f7 00 00 68 [18:07:16] sioFuji::sio_process() called [18:07:16] ACK! [18:07:16] Fuji cmd: OPEN DIRECTORY [18:07:16] <-SIO read 256 bytes [18:07:16] ACK! [18:07:16] Opening directory: "/", pattern: "" [18:07:16] ::dir_open {0:1} "/", pattern "" [18:07:16] ::dir_open actual path = "/" [18:07:16] COMPLETE! [18:07:16] [18:07:16] CF: 70 e4 0e 00 63 [18:07:16] sioFuji::sio_process() called [18:07:16] ACK! [18:07:16] Fuji cmd: SET DIRECTORY POSITION [18:07:16] ::dir_seek {0:1} 14 [18:07:16] COMPLETE! [18:07:16] [18:07:16] CF: 70 f6 80 00 e7 [18:07:16] sioFuji::sio_process() called [18:07:16] ACK! [18:07:16] Fuji cmd: READ DIRECTORY ENTRY (max=128) [18:07:16] ::dir_nextfile {0:1} [18:07:16] ::read_direntry "M" [18:07:16] ->SIO write 128 bytes [18:07:16] COMPLETE! [18:07:16] [18:07:16] CF: 70 f5 00 00 66 [18:07:16] sioFuji::sio_process() called [18:07:16] ACK! [18:07:16] Fuji cmd: CLOSE DIRECTORY [18:07:16] COMPLETE! [18:07:16] [18:07:16] CF: 70 f7 00 00 68 [18:07:16] sioFuji::sio_process() called [18:07:16] ACK! [18:07:16] Fuji cmd: OPEN DIRECTORY [18:07:16] <-SIO read 256 bytes [18:07:17] ACK! [18:07:17] Opening directory: "/", pattern: "" [18:07:17] ::dir_open {0:1} "/", pattern "" [18:07:17] ::dir_open actual path = "/" [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 e4 0e 00 63 [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: SET DIRECTORY POSITION [18:07:17] ::dir_seek {0:1} 14 [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 80 01 e8 [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=128) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "M" [18:07:17] ->SIO write 128 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f5 00 00 66 [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: CLOSE DIRECTORY [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f9 00 00 6a [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: MOUNT HOST [18:07:17] ::mount {0} "SD" [18:07:17] ::mount_local Attempting mount of "SD" [18:07:17] Type is already LOCAL [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f7 00 00 68 [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: OPEN DIRECTORY [18:07:17] <-SIO read 256 bytes [18:07:17] ACK! [18:07:17] Opening directory: "/M", pattern: "" [18:07:17] ::dir_open {0:1} "/M", pattern "" [18:07:17] ::dir_open actual path = "/M" [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Major Bronx (bug fixed) (L.K. Avalon - 1992) (AD02392).atr" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Mary Poppins 1.17.atr" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!][cr CSS].atr" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Micro League Baseball - Player Stats + Team Disk - World Series Teams - 1950's.atx" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1983 NL and AL Teams (1984)(Micro League Sports Association)(US).atr" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1984 NL and AL Teams (1984)(Micro League Sports Association)(US)[m].atr" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1985 NL and AL Teams (1985)(Micro League Sports Association)(US)[m].atr" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:17] [18:07:17] CF: 70 f6 24 00 8b [18:07:17] sioFuji::sio_process() called [18:07:17] ACK! [18:07:17] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:17] ::dir_nextfile {0:1} [18:07:17] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1986 NL and AL Teams (1986)(Micro League Sports Association)(US)[m].atr" [18:07:17] ->SIO write 36 bytes [18:07:17] COMPLETE! [18:07:18] [18:07:18] CF: 70 f6 24 00 8b [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:18] ::dir_nextfile {0:1} [18:07:18] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1987 NL and AL Teams (1987)(Micro League Sports Association)(US)[m].atr" [18:07:18] ->SIO write 36 bytes [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 f6 24 00 8b [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:18] ::dir_nextfile {0:1} [18:07:18] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1989 NL and AL Teams (1989)(Micro League Sports Association)(US).atr" [18:07:18] ->SIO write 36 bytes [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 f6 24 00 8b [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:18] ::dir_nextfile {0:1} [18:07:18] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - Franchise History - Minnesota Twins (1984)(Micro League Sports Association)(US).atr" [18:07:18] ->SIO write 36 bytes [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 f6 24 00 8b [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:18] ::dir_nextfile {0:1} [18:07:18] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - Franchise History - New York Yankees (1984)(Micro League Sports Association)(US).atr" [18:07:18] ->SIO write 36 bytes [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 f6 24 00 8b [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:18] ::dir_nextfile {0:1} [18:07:18] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - World Series Teams (1950's) (1984)(Micro League Sports Association)(US).atr" [18:07:18] ->SIO write 36 bytes [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 f5 00 00 66 [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: CLOSE DIRECTORY [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 f7 00 00 68 [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: OPEN DIRECTORY [18:07:18] <-SIO read 256 bytes [18:07:18] ACK! [18:07:18] Opening directory: "/M", pattern: "" [18:07:18] ::dir_open {0:1} "/M", pattern "" [18:07:18] ::dir_open actual path = "/M" [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 e4 00 00 55 [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: SET DIRECTORY POSITION [18:07:18] ::dir_seek {0:1} 0 [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 f6 40 00 a7 [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: READ DIRECTORY ENTRY (max=64) [18:07:18] ::dir_nextfile {0:1} [18:07:18] ::read_direntry "Major Bronx (bug fixed) (L.K. Avalon - 1992) (AD02392).atr" [18:07:18] ->SIO write 64 bytes [18:07:18] COMPLETE! [18:07:18] [18:07:18] CF: 70 f5 00 00 66 [18:07:18] sioFuji::sio_process() called [18:07:18] ACK! [18:07:18] Fuji cmd: CLOSE DIRECTORY [18:07:18] COMPLETE! [18:07:22] [18:07:22] CF: 70 f9 00 00 6a [18:07:22] sioFuji::sio_process() called [18:07:22] ACK! [18:07:22] Fuji cmd: MOUNT HOST [18:07:22] ::mount {0} "SD" [18:07:22] ::mount_local Attempting mount of "SD" [18:07:22] Type is already LOCAL [18:07:22] COMPLETE! [18:07:22] [18:07:22] CF: 70 f7 00 00 68 [18:07:22] sioFuji::sio_process() called [18:07:22] ACK! [18:07:22] Fuji cmd: OPEN DIRECTORY [18:07:22] <-SIO read 256 bytes [18:07:22] ACK! [18:07:22] Opening directory: "/M", pattern: "micro*" [18:07:22] ::dir_open {0:1} "/M", pattern "micro*" [18:07:22] ::dir_open actual path = "/M" [18:07:22] COMPLETE! [18:07:22] [18:07:22] CF: 70 f6 24 00 8b [18:07:22] sioFuji::sio_process() called [18:07:22] ACK! [18:07:22] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:22] ::dir_nextfile {0:1} [18:07:22] ::read_direntry "Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx" [18:07:22] ->SIO write 36 bytes [18:07:22] COMPLETE! [18:07:22] [18:07:22] CF: 70 f6 24 00 8b [18:07:22] sioFuji::sio_process() called [18:07:22] ACK! [18:07:22] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:22] ::dir_nextfile {0:1} [18:07:22] ::read_direntry "Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!][cr CSS].atr" [18:07:22] ->SIO write 36 bytes [18:07:22] COMPLETE! [18:07:22] [18:07:22] CF: 70 f6 24 00 8b [18:07:22] sioFuji::sio_process() called [18:07:22] ACK! [18:07:22] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:22] ::dir_nextfile {0:1} [18:07:22] ::read_direntry "Micro League Baseball - Player Stats + Team Disk - World Series Teams - 1950's.atx" [18:07:22] ->SIO write 36 bytes [18:07:22] COMPLETE! [18:07:22] [18:07:22] CF: 70 f6 24 00 8b [18:07:22] sioFuji::sio_process() called [18:07:22] ACK! [18:07:22] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:22] ::dir_nextfile {0:1} [18:07:22] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1983 NL and AL Teams (1984)(Micro League Sports Association)(US).atr" [18:07:22] ->SIO write 36 bytes [18:07:22] COMPLETE! [18:07:22] [18:07:22] CF: 70 f6 24 00 8b [18:07:22] sioFuji::sio_process() called [18:07:22] ACK! [18:07:22] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:22] ::dir_nextfile {0:1} [18:07:22] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1984 NL and AL Teams (1984)(Micro League Sports Association)(US)[m].atr" [18:07:22] ->SIO write 36 bytes [18:07:22] COMPLETE! [18:07:22] [18:07:22] CF: 70 f6 24 00 8b [18:07:22] sioFuji::sio_process() called [18:07:22] ACK! [18:07:22] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:22] ::dir_nextfile {0:1} [18:07:22] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1985 NL and AL Teams (1985)(Micro League Sports Association)(US)[m].atr" [18:07:22] ->SIO write 36 bytes [18:07:22] COMPLETE! [18:07:23] [18:07:23] CF: 70 f6 24 00 8b [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:23] ::dir_nextfile {0:1} [18:07:23] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1986 NL and AL Teams (1986)(Micro League Sports Association)(US)[m].atr" [18:07:23] ->SIO write 36 bytes [18:07:23] COMPLETE! [18:07:23] [18:07:23] CF: 70 f6 24 00 8b [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:23] ::dir_nextfile {0:1} [18:07:23] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1987 NL and AL Teams (1987)(Micro League Sports Association)(US)[m].atr" [18:07:23] ->SIO write 36 bytes [18:07:23] COMPLETE! [18:07:23] [18:07:23] CF: 70 f6 24 00 8b [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:23] ::dir_nextfile {0:1} [18:07:23] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - 1989 NL and AL Teams (1989)(Micro League Sports Association)(US).atr" [18:07:23] ->SIO write 36 bytes [18:07:23] COMPLETE! [18:07:23] [18:07:23] CF: 70 f6 24 00 8b [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:23] ::dir_nextfile {0:1} [18:07:23] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - Franchise History - Minnesota Twins (1984)(Micro League Sports Association)(US).atr" [18:07:23] ->SIO write 36 bytes [18:07:23] COMPLETE! [18:07:23] [18:07:23] CF: 70 f6 24 00 8b [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:23] ::dir_nextfile {0:1} [18:07:23] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - Franchise History - New York Yankees (1984)(Micro League Sports Association)(US).atr" [18:07:23] ->SIO write 36 bytes [18:07:23] COMPLETE! [18:07:23] [18:07:23] CF: 70 f6 24 00 8b [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:23] ::dir_nextfile {0:1} [18:07:23] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - World Series Teams (1950's) (1984)(Micro League Sports Association)(US).atr" [18:07:23] ->SIO write 36 bytes [18:07:23] COMPLETE! [18:07:23] [18:07:23] CF: 70 f6 24 00 8b [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:23] ::dir_nextfile {0:1} [18:07:23] ::read_direntry "Micro League Baseball - Player Stats-Team Disk - World Series Teams (1960's) (1984)(Micro League Sports Association)(US)[f].atr" [18:07:23] ->SIO write 36 bytes [18:07:23] COMPLETE! [18:07:23] [18:07:23] CF: 70 f6 24 00 8b [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:23] ::dir_nextfile {0:1} [18:07:23] ::read_direntry "Micro League Baseball Box Score and Stats Compiler Disk.atr" [18:07:23] ->SIO write 36 bytes [18:07:23] COMPLETE! [18:07:23] [18:07:23] CF: 70 f5 00 00 66 [18:07:23] sioFuji::sio_process() called [18:07:23] ACK! [18:07:23] Fuji cmd: CLOSE DIRECTORY [18:07:23] COMPLETE! [18:07:24] [18:07:24] CF: 70 f7 00 00 68 [18:07:24] sioFuji::sio_process() called [18:07:24] ACK! [18:07:24] Fuji cmd: OPEN DIRECTORY [18:07:24] <-SIO read 256 bytes [18:07:24] ACK! [18:07:24] Opening directory: "/M", pattern: "micro*" [18:07:24] ::dir_open {0:1} "/M", pattern "micro*" [18:07:24] ::dir_open actual path = "/M" [18:07:24] COMPLETE! [18:07:24] [18:07:24] CF: 70 e4 00 00 55 [18:07:24] sioFuji::sio_process() called [18:07:24] ACK! [18:07:24] Fuji cmd: SET DIRECTORY POSITION [18:07:24] ::dir_seek {0:1} 0 [18:07:24] COMPLETE! [18:07:24] [18:07:24] CF: 70 f6 80 00 e7 [18:07:24] sioFuji::sio_process() called [18:07:24] ACK! [18:07:24] Fuji cmd: READ DIRECTORY ENTRY (max=128) [18:07:24] ::dir_nextfile {0:1} [18:07:24] ::read_direntry "Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx" [18:07:24] ->SIO write 128 bytes [18:07:24] COMPLETE! [18:07:25] [18:07:25] CF: 70 f5 00 00 66 [18:07:25] sioFuji::sio_process() called [18:07:25] ACK! [18:07:25] Fuji cmd: CLOSE DIRECTORY [18:07:25] COMPLETE! [18:07:25] [18:07:25] CF: 70 f7 00 00 68 [18:07:25] sioFuji::sio_process() called [18:07:25] ACK! [18:07:25] Fuji cmd: OPEN DIRECTORY [18:07:25] <-SIO read 256 bytes [18:07:25] ACK! [18:07:25] Opening directory: "/M", pattern: "micro*" [18:07:25] ::dir_open {0:1} "/M", pattern "micro*" [18:07:25] ::dir_open actual path = "/M" [18:07:25] COMPLETE! [18:07:25] [18:07:25] CF: 70 e4 00 00 55 [18:07:25] sioFuji::sio_process() called [18:07:25] ACK! [18:07:25] Fuji cmd: SET DIRECTORY POSITION [18:07:25] ::dir_seek {0:1} 0 [18:07:25] COMPLETE! [18:07:25] [18:07:25] CF: 70 f2 00 00 63 [18:07:25] sioFuji::sio_process() called [18:07:25] ACK! [18:07:25] Fuji cmd: READ DEVICE SLOTS [18:07:25] ->SIO write 304 bytes [18:07:25] COMPLETE! [18:07:25] [18:07:25] CF: 70 f6 31 80 19 [18:07:25] sioFuji::sio_process() called [18:07:25] ACK! [18:07:25] Fuji cmd: READ DIRECTORY ENTRY (max=49) [18:07:25] ::dir_nextfile {0:1} [18:07:25] ::read_direntry "Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx" [18:07:25] ->SIO write 49 bytes [18:07:25] COMPLETE! [18:07:25] [18:07:25] CF: 70 f5 00 00 66 [18:07:25] sioFuji::sio_process() called [18:07:25] ACK! [18:07:25] Fuji cmd: CLOSE DIRECTORY [18:07:25] COMPLETE! [18:07:27] [18:07:27] CF: 70 f7 00 00 68 [18:07:27] sioFuji::sio_process() called [18:07:27] ACK! [18:07:27] Fuji cmd: OPEN DIRECTORY [18:07:27] <-SIO read 256 bytes [18:07:27] ACK! [18:07:27] Opening directory: "/M", pattern: "micro*" [18:07:27] ::dir_open {0:1} "/M", pattern "micro*" [18:07:27] ::dir_open actual path = "/M" [18:07:27] COMPLETE! [18:07:27] [18:07:27] CF: 70 e4 00 00 55 [18:07:27] sioFuji::sio_process() called [18:07:27] ACK! [18:07:27] Fuji cmd: SET DIRECTORY POSITION [18:07:27] ::dir_seek {0:1} 0 [18:07:27] COMPLETE! [18:07:27] [18:07:27] CF: 70 f6 fc 00 64 [18:07:27] sioFuji::sio_process() called [18:07:27] ACK! [18:07:27] Fuji cmd: READ DIRECTORY ENTRY (max=252) [18:07:27] ::dir_nextfile {0:1} [18:07:27] ::read_direntry "Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx" [18:07:27] ->SIO write 252 bytes [18:07:27] COMPLETE! [18:07:27] [18:07:27] CF: 70 e2 00 00 53 [18:07:27] sioFuji::sio_process() called [18:07:27] ACK! [18:07:27] <-SIO read 256 bytes [18:07:27] ACK! [18:07:27] Fuji cmd: SET DEVICE SLOT 0x00/00/00 FILENAME: /M/Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx [18:07:27] fnConfig::save [18:07:27] SPIFFS Config Storage: Enabled. Saving config to SPIFFS [18:07:27] fnConfig::save wrote 1176 bytes [18:07:27] Attempting config copy to SD [18:07:27] copy_file "/fnconfig.ini" -> "/fnconfig.ini" [18:07:27] fopen = /fnconfig.ini : ok [18:07:27] copy_file copied 1176 bytes [18:07:27] COMPLETE! [18:07:27] [18:07:27] CF: 70 e4 00 00 55 [18:07:27] sioFuji::sio_process() called [18:07:27] ACK! [18:07:27] Fuji cmd: SET DIRECTORY POSITION [18:07:27] ::dir_seek {0:1} 0 [18:07:27] COMPLETE! [18:07:27] [18:07:27] CF: 70 f6 24 00 8b [18:07:27] sioFuji::sio_process() called [18:07:27] ACK! [18:07:27] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:07:27] ::dir_nextfile {0:1} [18:07:27] ::read_direntry "Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx" [18:07:27] ->SIO write 36 bytes [18:07:27] COMPLETE! [18:07:27] [18:07:27] CF: 70 f1 00 00 62 [18:07:27] sioFuji::sio_process() called [18:07:27] ACK! [18:07:27] Fuji cmd: WRITE DEVICE SLOTS [18:07:27] <-SIO read 304 bytes [18:07:27] ACK! [18:07:27] fnConfig::save [18:07:27] fnConfig::save not dirty, not saving [18:07:27] COMPLETE! [18:07:27] [18:07:27] CF: 70 f5 00 00 66 [18:07:27] sioFuji::sio_process() called [18:07:27] ACK! [18:07:27] Fuji cmd: CLOSE DIRECTORY [18:07:27] COMPLETE! [18:07:28] [18:07:28] CF: 70 f4 00 00 65 [18:07:28] sioFuji::sio_process() called [18:07:28] ACK! [18:07:28] Fuji cmd: READ HOST SLOTS [18:07:28] ->SIO write 256 bytes [18:07:28] COMPLETE! [18:07:28] [18:07:28] CF: 70 f2 00 00 63 [18:07:28] sioFuji::sio_process() called [18:07:28] ACK! [18:07:28] Fuji cmd: READ DEVICE SLOTS [18:07:28] ->SIO write 304 bytes [18:07:28] COMPLETE! [18:07:28] [18:07:28] CF: 70 f4 00 00 65 [18:07:28] sioFuji::sio_process() called [18:07:28] ACK! [18:07:28] Fuji cmd: READ HOST SLOTS [18:07:28] ->SIO write 256 bytes [18:07:28] COMPLETE! [18:07:28] [18:07:28] CF: 70 f2 00 00 63 [18:07:28] sioFuji::sio_process() called [18:07:28] ACK! [18:07:28] Fuji cmd: READ DEVICE SLOTS [18:07:28] ->SIO write 304 bytes [18:07:28] COMPLETE! [18:07:34] [18:07:34] CF: 70 f2 00 00 63 [18:07:34] sioFuji::sio_process() called [18:07:34] ACK! [18:07:34] Fuji cmd: READ DEVICE SLOTS [18:07:34] ->SIO write 304 bytes [18:07:34] COMPLETE! [18:07:34] [18:07:34] CF: 70 f4 00 00 65 [18:07:34] sioFuji::sio_process() called [18:07:34] ACK! [18:07:34] Fuji cmd: READ HOST SLOTS [18:07:34] ->SIO write 256 bytes [18:07:34] COMPLETE! [18:07:34] [18:07:34] CF: 70 d7 00 00 48 [18:07:34] sioFuji::sio_process() called [18:07:34] ACK! [18:07:34] ::mount {0} "SD" [18:07:34] ::mount_local Attempting mount of "SD" [18:07:34] Type is already LOCAL [18:07:34] Selecting '/M/Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx' from host #0 as r on D1: [18:07:34] fujiHost #0 opening file path "/M/Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx" [18:07:34] fopen = /M/Micro League Baseball (1984)(Micro League Sports Association)(US)(Game Disk)[!].atx : ok [18:07:34] ::get_filesize [18:07:34] disk MOUNT [18:07:34] ATX MOUNT [18:07:34] ATX image header values: [18:07:34] version: 1, version min: 1 [18:07:34] creator: 0x02, creator ver: 0 [18:07:34] flags: 0x00 [18:07:34] type: 0, density: 0 [18:07:34] imageid: 0x00, image ver: 0 [18:07:34] start: 0x0030 [18:07:34] end: 0x18770 [18:07:34] MediaTypeATX::_load_atx_data starting read [18:07:35] E (38060) diskio_sdmmc: sdmmc_read_blocks failed (257) [18:07:35] failed reading 2304 sector data chunk bytes (248, 5) [18:07:35] WARNING: Number of tracks read = 28 [18:07:35] ATX load completed [18:07:35] COMPLETE! [18:07:35] [18:07:35] CF: 70 d9 00 00 4a [18:07:35] sioFuji::sio_process() called [18:07:35] ACK! [18:07:35] COMPLETE! [18:07:36] [18:07:36] CF: 31 53 00 00 84 [18:07:36] disk sio_process() [18:07:36] ACK! [18:07:36] disk STATUS [18:07:36] response: 0x10, 0xff, 0xe0 [18:07:36] ->SIO write 4 bytes [18:07:36] COMPLETE! [18:07:36] [18:07:36] CF: 31 52 01 00 84 [18:07:36] disk sio_process() [18:07:36] ACK! [18:07:36] ATX READ (1) rots=8 [18:07:36] copy data track 0, sector 1 [18:07:36] ->SIO write 128 bytes [18:07:36] COMPLETE! [18:07:36] [18:07:36] CF: 31 52 02 00 85 [18:07:36] disk sio_process() [18:07:36] ACK! [18:07:36] ATX READ (2) rots=9 [18:07:36] copy data track 0, sector 2 [18:07:37] ->SIO write 128 bytes [18:07:37] COMPLETE! [18:07:37] [18:07:37] CF: 31 52 03 00 86 [18:07:37] disk sio_process() [18:07:37] ACK! [18:07:37] ATX READ (3) rots=11 [18:07:37] copy data track 0, sector 3 [18:07:37] ->SIO write 128 bytes [18:07:37] COMPLETE! [18:07:37] [18:07:37] CF: 31 52 04 00 87 [18:07:37] disk sio_process() [18:07:37] ACK! [18:07:37] ATX READ (4) rots=11 [18:07:37] copy data track 0, sector 4 [18:07:37] ->SIO write 128 bytes [18:07:37] COMPLETE! [18:07:37] [18:07:37] CF: 31 52 05 00 88 [18:07:37] disk sio_process() [18:07:37] ACK! [18:07:37] ATX READ (5) rots=13 [18:07:37] copy data track 0, sector 5 [18:07:37] ->SIO write 128 bytes [18:07:37] COMPLETE! [18:07:37] [18:07:37] CF: 31 52 06 00 89 [18:07:37] disk sio_process() [18:07:37] ACK! [18:07:37] ATX READ (6) rots=13 [18:07:37] copy data track 0, sector 6 [18:07:38] ->SIO write 128 bytes [18:07:38] COMPLETE! [18:07:38] [18:07:38] CF: 31 52 10 00 93 [18:07:38] disk sio_process() [18:07:38] ACK! [18:07:38] ATX READ (16) rots=15 [18:07:38] copy data track 0, sector 16 [18:07:38] ->SIO write 128 bytes [18:07:38] COMPLETE! [18:07:38] [18:07:38] CF: 31 52 11 00 94 [18:07:38] disk sio_process() [18:07:38] ACK! [18:07:38] ATX READ (17) rots=16 [18:07:38] copy data track 0, sector 17 [18:07:38] ->SIO write 128 bytes [18:07:38] COMPLETE! [18:07:38] [18:07:38] CF: 31 52 12 00 95 [18:07:38] disk sio_process() [18:07:38] ACK! [18:07:38] ATX READ (18) rots=17 [18:07:38] copy data track 0, sector 18 [18:07:38] ->SIO write 128 bytes [18:07:38] COMPLETE! [18:07:38] [18:07:38] CF: 31 52 13 00 96 [18:07:38] disk sio_process() [18:07:38] ACK! [18:07:38] ATX READ (19) rots=17 [18:07:38] copy data track 1, sector 1 [18:07:38] ->SIO write 128 bytes [18:07:38] COMPLETE! [18:07:38] [18:07:38] CF: 31 52 14 00 97 [18:07:38] disk sio_process() [18:07:38] ACK! [18:07:38] ATX READ (20) rots=18 [18:07:38] copy data track 1, sector 2 [18:07:39] ->SIO write 128 bytes [18:07:39] COMPLETE! [18:07:39] [18:07:39] CF: 31 52 15 00 98 [18:07:39] disk sio_process() [18:07:39] ACK! [18:07:39] ATX READ (21) rots=20 [18:07:39] copy data track 1, sector 3 [18:07:39] ->SIO write 128 bytes [18:07:39] COMPLETE! [18:07:39] [18:07:39] CF: 31 52 16 00 99 [18:07:39] disk sio_process() [18:07:39] ACK! [18:07:39] ATX READ (22) rots=20 [18:07:39] copy data track 1, sector 4 [18:07:39] ->SIO write 128 bytes [18:07:39] COMPLETE! [18:07:39] [18:07:39] CF: 31 52 17 00 9a [18:07:39] disk sio_process() [18:07:39] ACK! [18:07:39] ATX READ (23) rots=22 [18:07:39] copy data track 1, sector 5 [18:07:39] ->SIO write 128 bytes [18:07:39] COMPLETE! [18:07:39] [18:07:39] CF: 31 52 18 00 9b [18:07:39] disk sio_process() [18:07:39] ACK! [18:07:39] ATX READ (24) rots=22 [18:07:39] copy data track 1, sector 6 [18:07:39] ->SIO write 128 bytes [18:07:39] COMPLETE! [18:07:40] [18:07:40] CF: 31 52 19 00 9c [18:07:40] disk sio_process() [18:07:40] ACK! [18:07:40] ATX READ (25) rots=24 [18:07:40] copy data track 1, sector 7 [18:07:40] ->SIO write 128 bytes [18:07:40] COMPLETE! [18:07:40] [18:07:40] CF: 31 52 1a 00 9d [18:07:40] disk sio_process() [18:07:40] ACK! [18:07:40] ATX READ (26) rots=24 [18:07:40] copy data track 1, sector 8 [18:07:40] ->SIO write 128 bytes [18:07:40] COMPLETE! [18:07:40] [18:07:40] CF: 31 52 1b 00 9e [18:07:40] disk sio_process() [18:07:40] ACK! [18:07:40] ATX READ (27) rots=26 [18:07:40] copy data track 1, sector 9 [18:07:40] ->SIO write 128 bytes [18:07:40] COMPLETE! [18:07:40] [18:07:40] CF: 31 52 1c 00 9f [18:07:40] disk sio_process() [18:07:40] ACK! [18:07:40] ATX READ (28) rots=26 [18:07:40] copy data track 1, sector 10 [18:07:40] ->SIO write 128 bytes [18:07:40] COMPLETE! [18:07:40] [18:07:40] CF: 31 52 1d 00 a0 [18:07:40] disk sio_process() [18:07:40] ACK! [18:07:40] ATX READ (29) rots=28 [18:07:40] copy data track 1, sector 11 [18:07:40] ->SIO write 128 bytes [18:07:40] COMPLETE! [18:07:40] [18:07:40] CF: 31 52 1e 00 a1 [18:07:40] disk sio_process() [18:07:40] ACK! [18:07:40] ATX READ (30) rots=28 [18:07:40] copy data track 1, sector 12 [18:07:41] ->SIO write 128 bytes [18:07:41] COMPLETE! [18:07:41] [18:07:41] CF: 31 52 1f 00 a2 [18:07:41] disk sio_process() [18:07:41] ACK! [18:07:41] ATX READ (31) rots=29 [18:07:41] copy data track 1, sector 13 [18:07:41] ->SIO write 128 bytes [18:07:41] COMPLETE! [18:07:41] [18:07:41] CF: 31 52 20 00 a3 [18:07:41] disk sio_process() [18:07:41] ACK! [18:07:41] ATX READ (32) rots=30 [18:07:41] copy data track 1, sector 14 [18:07:41] ->SIO write 128 bytes [18:07:41] COMPLETE! [18:07:41] [18:07:41] CF: 31 52 21 00 a4 [18:07:41] disk sio_process() [18:07:41] ACK! [18:07:41] ATX READ (33) rots=32 [18:07:41] copy data track 1, sector 15 [18:07:41] ->SIO write 128 bytes [18:07:41] COMPLETE! [18:07:41] [18:07:41] CF: 31 52 22 00 a5 [18:07:41] disk sio_process() [18:07:41] ACK! [18:07:41] ATX READ (34) rots=32 [18:07:41] copy data track 1, sector 16 [18:07:42] ->SIO write 128 bytes [18:07:42] COMPLETE! [18:07:42] [18:07:42] CF: 31 52 23 00 a6 [18:07:42] disk sio_process() [18:07:42] ACK! [18:07:42] ATX READ (35) rots=34 [18:07:42] copy data track 1, sector 17 [18:07:42] ->SIO write 128 bytes [18:07:42] COMPLETE! [18:07:42] [18:07:42] CF: 31 52 24 00 a7 [18:07:42] disk sio_process() [18:07:42] ACK! [18:07:42] ATX READ (36) rots=35 [18:07:42] copy data track 1, sector 18 [18:07:42] ->SIO write 128 bytes [18:07:42] COMPLETE! [18:07:42] [18:07:42] CF: 31 52 25 00 a8 [18:07:42] disk sio_process() [18:07:42] ACK! [18:07:42] ATX READ (37) rots=35 [18:07:42] copy data track 2, sector 1 [18:07:42] ->SIO write 128 bytes [18:07:42] COMPLETE! [18:07:42] [18:07:42] CF: 31 52 26 00 a9 [18:07:42] disk sio_process() [18:07:42] ACK! [18:07:42] ATX READ (38) rots=36 [18:07:42] copy data track 2, sector 2 [18:07:42] ->SIO write 128 bytes [18:07:42] COMPLETE! [18:07:42] [18:07:42] CF: 31 52 27 00 aa [18:07:42] disk sio_process() [18:07:42] ACK! [18:07:42] ATX READ (39) rots=38 [18:07:42] copy data track 2, sector 3 [18:07:42] ->SIO write 128 bytes [18:07:42] COMPLETE! [18:07:43] [18:07:43] CF: 31 52 28 00 ab [18:07:43] disk sio_process() [18:07:43] ACK! [18:07:43] ATX READ (40) rots=38 [18:07:43] copy data track 2, sector 4 [18:07:43] ->SIO write 128 bytes [18:07:43] COMPLETE! [18:07:43] [18:07:43] CF: 31 52 29 00 ac [18:07:43] disk sio_process() [18:07:43] ACK! [18:07:43] ATX READ (41) rots=40 [18:07:43] copy data track 2, sector 5 [18:07:43] ->SIO write 128 bytes [18:07:43] COMPLETE! [18:07:43] [18:07:43] CF: 31 52 2a 00 ad [18:07:43] disk sio_process() [18:07:43] ACK! [18:07:43] ATX READ (42) rots=40 [18:07:43] copy data track 2, sector 6 [18:07:43] ->SIO write 128 bytes [18:07:43] COMPLETE! [18:07:43] [18:07:43] CF: 31 52 2b 00 ae [18:07:43] disk sio_process() [18:07:43] ACK! [18:07:43] ATX READ (43) rots=42 [18:07:43] copy data track 2, sector 7 [18:07:43] ->SIO write 128 bytes [18:07:43] COMPLETE! [18:07:43] [18:07:43] CF: 31 52 2c 00 af [18:07:43] disk sio_process() [18:07:43] ACK! [18:07:43] ATX READ (44) rots=42 [18:07:43] copy data track 2, sector 8 [18:07:44] ->SIO write 128 bytes [18:07:44] COMPLETE! [18:07:44] [18:07:44] CF: 31 52 2d 00 b0 [18:07:44] disk sio_process() [18:07:44] ACK! [18:07:44] ATX READ (45) rots=44 [18:07:44] copy data track 2, sector 9 [18:07:44] ->SIO write 128 bytes [18:07:44] COMPLETE! [18:07:44] [18:07:44] CF: 31 52 2e 00 b1 [18:07:44] disk sio_process() [18:07:44] ACK! [18:07:44] ATX READ (46) rots=44 [18:07:44] copy data track 2, sector 10 [18:07:44] ->SIO write 128 bytes [18:07:44] COMPLETE! [18:07:44] [18:07:44] CF: 31 52 2f 00 b2 [18:07:44] disk sio_process() [18:07:44] ACK! [18:07:44] ATX READ (47) rots=46 [18:07:44] copy data track 2, sector 11 [18:07:44] ->SIO write 128 bytes [18:07:44] COMPLETE! [18:07:44] [18:07:44] CF: 31 52 30 00 b3 [18:07:44] disk sio_process() [18:07:44] ACK! [18:07:44] ATX READ (48) rots=46 [18:07:44] copy data track 2, sector 12 [18:07:44] ->SIO write 128 bytes [18:07:44] COMPLETE! [18:07:45] [18:07:45] CF: 31 52 31 00 b4 [18:07:45] disk sio_process() [18:07:45] ACK! [18:07:45] ATX READ (49) rots=48 [18:07:45] copy data track 2, sector 13 [18:07:45] ->SIO write 128 bytes [18:07:45] COMPLETE! [18:07:45] [18:07:45] CF: 31 52 32 00 b5 [18:07:45] disk sio_process() [18:07:45] ACK! [18:07:45] ATX READ (50) rots=48 [18:07:45] copy data track 2, sector 14 [18:07:45] ->SIO write 128 bytes [18:07:45] COMPLETE! [18:07:45] [18:07:45] CF: 31 52 33 00 b6 [18:07:45] disk sio_process() [18:07:45] ACK! [18:07:45] ATX READ (51) rots=50 [18:07:45] copy data track 2, sector 15 [18:07:45] ->SIO write 128 bytes [18:07:45] COMPLETE! [18:07:45] [18:07:45] CF: 31 52 34 00 b7 [18:07:45] disk sio_process() [18:07:45] ACK! [18:07:45] ATX READ (52) rots=50 [18:07:45] copy data track 2, sector 16 [18:07:45] ->SIO write 128 bytes [18:07:45] COMPLETE! [18:07:45] [18:07:45] CF: 31 52 35 00 b8 [18:07:45] disk sio_process() [18:07:45] ACK! [18:07:45] ATX READ (53) rots=52 [18:07:45] copy data track 2, sector 17 [18:07:45] ->SIO write 128 bytes [18:07:45] COMPLETE! [18:07:46] [18:07:46] CF: 31 52 36 00 b9 [18:07:46] disk sio_process() [18:07:46] ACK! [18:07:46] ATX READ (54) rots=53 [18:07:46] copy data track 2, sector 18 [18:07:46] ->SIO write 128 bytes [18:07:46] COMPLETE! [18:07:46] [18:07:46] CF: 31 52 37 00 ba [18:07:46] disk sio_process() [18:07:46] ACK! [18:07:46] ATX READ (55) rots=53 [18:07:46] copy data track 3, sector 1 [18:07:46] ->SIO write 128 bytes [18:07:46] COMPLETE! [18:07:46] [18:07:46] CF: 31 52 38 00 bb [18:07:46] disk sio_process() [18:07:46] ACK! [18:07:46] ATX READ (56) rots=54 [18:07:46] copy data track 3, sector 2 [18:07:46] ->SIO write 128 bytes [18:07:46] COMPLETE! [18:07:46] [18:07:46] CF: 31 52 39 00 bc [18:07:46] disk sio_process() [18:07:46] ACK! [18:07:46] ATX READ (57) rots=56 [18:07:46] copy data track 3, sector 3 [18:07:46] ->SIO write 128 bytes [18:07:46] COMPLETE! [18:07:46] [18:07:46] CF: 31 52 3a 00 bd [18:07:46] disk sio_process() [18:07:46] ACK! [18:07:46] ATX READ (58) rots=56 [18:07:46] copy data track 3, sector 4 [18:07:46] ->SIO write 128 bytes [18:07:46] COMPLETE! [18:07:47] [18:07:47] CF: 31 52 3b 00 be [18:07:47] disk sio_process() [18:07:47] ACK! [18:07:47] ATX READ (59) rots=58 [18:07:47] copy data track 3, sector 5 [18:07:47] ->SIO write 128 bytes [18:07:47] COMPLETE! [18:07:47] [18:07:47] CF: 31 52 3c 00 bf [18:07:47] disk sio_process() [18:07:47] ACK! [18:07:47] ATX READ (60) rots=58 [18:07:47] copy data track 3, sector 6 [18:07:47] ->SIO write 128 bytes [18:07:47] COMPLETE! [18:07:47] [18:07:47] CF: 31 52 3d 00 c0 [18:07:47] disk sio_process() [18:07:47] ACK! [18:07:47] ATX READ (61) rots=60 [18:07:47] copy data track 3, sector 7 [18:07:47] ->SIO write 128 bytes [18:07:47] COMPLETE! [18:07:47] [18:07:47] CF: 31 52 3e 00 c1 [18:07:47] disk sio_process() [18:07:47] ACK! [18:07:47] ATX READ (62) rots=60 [18:07:47] copy data track 3, sector 8 [18:07:47] ->SIO write 128 bytes [18:07:47] COMPLETE! [18:07:47] [18:07:47] CF: 31 52 3f 00 c2 [18:07:47] disk sio_process() [18:07:47] ACK! [18:07:47] ATX READ (63) rots=62 [18:07:47] copy data track 3, sector 9 [18:07:47] ->SIO write 128 bytes [18:07:47] COMPLETE! [18:07:48] [18:07:48] CF: 31 52 40 00 c3 [18:07:48] disk sio_process() [18:07:48] ACK! [18:07:48] ATX READ (64) rots=62 [18:07:48] copy data track 3, sector 10 [18:07:48] ->SIO write 128 bytes [18:07:48] COMPLETE! [18:07:48] [18:07:48] CF: 31 52 41 00 c4 [18:07:48] disk sio_process() [18:07:48] ACK! [18:07:48] ATX READ (65) rots=64 [18:07:48] copy data track 3, sector 11 [18:07:48] ->SIO write 128 bytes [18:07:48] COMPLETE! [18:07:48] [18:07:48] CF: 31 52 42 00 c5 [18:07:48] disk sio_process() [18:07:48] ACK! [18:07:48] ATX READ (66) rots=64 [18:07:48] copy data track 3, sector 12 [18:07:48] ->SIO write 128 bytes [18:07:48] COMPLETE! [18:07:48] [18:07:48] CF: 31 52 43 00 c6 [18:07:48] disk sio_process() [18:07:48] ACK! [18:07:48] ATX READ (67) rots=66 [18:07:48] copy data track 3, sector 13 [18:07:48] ->SIO write 128 bytes [18:07:48] COMPLETE! [18:07:48] [18:07:48] CF: 31 52 44 00 c7 [18:07:48] disk sio_process() [18:07:48] ACK! [18:07:48] ATX READ (68) rots=66 [18:07:48] copy data track 3, sector 14 [18:07:49] ->SIO write 128 bytes [18:07:49] COMPLETE! [18:07:49] [18:07:49] CF: 31 52 45 00 c8 [18:07:49] disk sio_process() [18:07:49] ACK! [18:07:49] ATX READ (69) rots=68 [18:07:49] copy data track 3, sector 15 [18:07:49] ->SIO write 128 bytes [18:07:49] COMPLETE! [18:07:49] [18:07:49] CF: 31 52 46 00 c9 [18:07:49] disk sio_process() [18:07:49] ACK! [18:07:49] ATX READ (70) rots=68 [18:07:49] copy data track 3, sector 16 [18:07:49] ->SIO write 128 bytes [18:07:49] COMPLETE! [18:07:49] [18:07:49] CF: 31 52 47 00 ca [18:07:49] disk sio_process() [18:07:49] ACK! [18:07:49] ATX READ (71) rots=70 [18:07:49] copy data track 3, sector 17 [18:07:49] ->SIO write 128 bytes [18:07:49] COMPLETE! [18:07:49] [18:07:49] CF: 31 52 48 00 cb [18:07:49] disk sio_process() [18:07:49] ACK! [18:07:49] ATX READ (72) rots=71 [18:07:49] copy data track 3, sector 18 [18:07:49] ->SIO write 128 bytes [18:07:49] COMPLETE! [18:07:49] [18:07:49] CF: 31 52 49 00 cc [18:07:49] disk sio_process() [18:07:49] ACK! [18:07:49] ATX READ (73) rots=71 [18:07:49] copy data track 4, sector 1 [18:07:49] ->SIO write 128 bytes [18:07:49] COMPLETE! [18:07:50] [18:07:50] CF: 31 52 4a 00 cd [18:07:50] disk sio_process() [18:07:50] ACK! [18:07:50] ATX READ (74) rots=72 [18:07:50] copy data track 4, sector 2 [18:07:50] ->SIO write 128 bytes [18:07:50] COMPLETE! [18:07:50] [18:07:50] CF: 31 52 4b 00 ce [18:07:50] disk sio_process() [18:07:50] ACK! [18:07:50] ATX READ (75) rots=74 [18:07:50] copy data track 4, sector 3 [18:07:50] ->SIO write 128 bytes [18:07:50] COMPLETE! [18:07:50] [18:07:50] CF: 31 52 4c 00 cf [18:07:50] disk sio_process() [18:07:50] ACK! [18:07:50] ATX READ (76) rots=74 [18:07:50] copy data track 4, sector 4 [18:07:50] ->SIO write 128 bytes [18:07:50] COMPLETE! [18:07:50] [18:07:50] CF: 31 52 4d 00 d0 [18:07:50] disk sio_process() [18:07:50] ACK! [18:07:50] ATX READ (77) rots=76 [18:07:50] copy data track 4, sector 5 [18:07:50] ->SIO write 128 bytes [18:07:50] COMPLETE! [18:07:50] [18:07:50] CF: 31 52 4e 00 d1 [18:07:50] disk sio_process() [18:07:50] ACK! [18:07:50] ATX READ (78) rots=76 [18:07:50] copy data track 4, sector 6 [18:07:51] ->SIO write 128 bytes [18:07:51] COMPLETE! [18:07:51] [18:07:51] CF: 31 52 4f 00 d2 [18:07:51] disk sio_process() [18:07:51] ACK! [18:07:51] ATX READ (79) rots=78 [18:07:51] copy data track 4, sector 7 [18:07:51] ->SIO write 128 bytes [18:07:51] COMPLETE! [18:07:51] [18:07:51] CF: 31 52 50 00 d3 [18:07:51] disk sio_process() [18:07:51] ACK! [18:07:51] ATX READ (80) rots=78 [18:07:51] copy data track 4, sector 8 [18:07:51] ->SIO write 128 bytes [18:07:51] COMPLETE! [18:07:51] [18:07:51] CF: 31 52 51 00 d4 [18:07:51] disk sio_process() [18:07:51] ACK! [18:07:51] ATX READ (81) rots=80 [18:07:51] copy data track 4, sector 9 [18:07:51] ->SIO write 128 bytes [18:07:51] COMPLETE! [18:07:51] [18:07:51] CF: 31 52 52 00 d5 [18:07:51] disk sio_process() [18:07:51] ACK! [18:07:51] ATX READ (82) rots=80 [18:07:51] copy data track 4, sector 10 [18:07:52] ->SIO write 128 bytes [18:07:52] COMPLETE! [18:07:52] [18:07:52] CF: 31 52 53 00 d6 [18:07:52] disk sio_process() [18:07:52] ACK! [18:07:52] ATX READ (83) rots=82 [18:07:52] copy data track 4, sector 11 [18:07:52] ->SIO write 128 bytes [18:07:52] COMPLETE! [18:07:52] [18:07:52] CF: 31 52 54 00 d7 [18:07:52] disk sio_process() [18:07:52] ACK! [18:07:52] ATX READ (84) rots=82 [18:07:52] copy data track 4, sector 12 [18:07:52] ->SIO write 128 bytes [18:07:52] COMPLETE! [18:07:52] [18:07:52] CF: 31 52 55 00 d8 [18:07:52] disk sio_process() [18:07:52] ACK! [18:07:52] ATX READ (85) rots=84 [18:07:52] copy data track 4, sector 13 [18:07:52] ->SIO write 128 bytes [18:07:52] COMPLETE! [18:07:52] [18:07:52] CF: 31 52 56 00 d9 [18:07:52] disk sio_process() [18:07:52] ACK! [18:07:52] ATX READ (86) rots=84 [18:07:52] copy data track 4, sector 14 [18:07:52] ->SIO write 128 bytes [18:07:52] COMPLETE! [18:07:52] [18:07:52] CF: 31 52 57 00 da [18:07:52] disk sio_process() [18:07:52] ACK! [18:07:52] ATX READ (87) rots=86 [18:07:52] copy data track 4, sector 15 [18:07:52] ->SIO write 128 bytes [18:07:52] COMPLETE! [18:07:53] [18:07:53] CF: 31 52 58 00 db [18:07:53] disk sio_process() [18:07:53] ACK! [18:07:53] ATX READ (88) rots=86 [18:07:53] copy data track 4, sector 16 [18:07:53] ->SIO write 128 bytes [18:07:53] COMPLETE! [18:07:53] [18:07:53] CF: 31 52 59 00 dc [18:07:53] disk sio_process() [18:07:53] ACK! [18:07:53] ATX READ (89) rots=88 [18:07:53] copy data track 4, sector 17 [18:07:53] ->SIO write 128 bytes [18:07:53] COMPLETE! [18:07:53] [18:07:53] CF: 31 52 5a 00 dd [18:07:53] disk sio_process() [18:07:53] ACK! [18:07:53] ATX READ (90) rots=89 [18:07:53] copy data track 4, sector 18 [18:07:53] ->SIO write 128 bytes [18:07:53] COMPLETE! [18:07:53] [18:07:53] CF: 31 52 5b 00 de [18:07:53] disk sio_process() [18:07:53] ACK! [18:07:53] ATX READ (91) rots=89 [18:07:53] copy data track 5, sector 1 [18:07:53] ->SIO write 128 bytes [18:07:53] COMPLETE! [18:07:53] [18:07:53] CF: 31 52 5c 00 df [18:07:53] disk sio_process() [18:07:53] ACK! [18:07:53] ATX READ (92) rots=90 [18:07:53] copy data track 5, sector 2 [18:07:54] ->SIO write 128 bytes [18:07:54] COMPLETE! [18:07:54] [18:07:54] CF: 31 52 5d 00 e0 [18:07:54] disk sio_process() [18:07:54] ACK! [18:07:54] ATX READ (93) rots=92 [18:07:54] copy data track 5, sector 3 [18:07:54] ->SIO write 128 bytes [18:07:54] COMPLETE! [18:07:54] [18:07:54] CF: 31 52 5e 00 e1 [18:07:54] disk sio_process() [18:07:54] ACK! [18:07:54] ATX READ (94) rots=92 [18:07:54] copy data track 5, sector 4 [18:07:54] ->SIO write 128 bytes [18:07:54] COMPLETE! [18:07:54] [18:07:54] CF: 31 52 5f 00 e2 [18:07:54] disk sio_process() [18:07:54] ACK! [18:07:54] ATX READ (95) rots=94 [18:07:54] copy data track 5, sector 5 [18:07:54] ->SIO write 128 bytes [18:07:54] COMPLETE! [18:07:54] [18:07:54] CF: 31 52 60 00 e3 [18:07:54] disk sio_process() [18:07:54] ACK! [18:07:54] ATX READ (96) rots=94 [18:07:54] copy data track 5, sector 6 [18:07:54] ->SIO write 128 bytes [18:07:54] COMPLETE! [18:07:55] [18:07:55] CF: 31 52 61 00 e4 [18:07:55] disk sio_process() [18:07:55] ACK! [18:07:55] ATX READ (97) rots=96 [18:07:55] copy data track 5, sector 7 [18:07:55] ->SIO write 128 bytes [18:07:55] COMPLETE! [18:07:55] [18:07:55] CF: 31 52 62 00 e5 [18:07:55] disk sio_process() [18:07:55] ACK! [18:07:55] ATX READ (98) rots=96 [18:07:55] copy data track 5, sector 8 [18:07:55] ->SIO write 128 bytes [18:07:55] COMPLETE! [18:07:55] [18:07:55] CF: 31 52 63 00 e6 [18:07:55] disk sio_process() [18:07:55] ACK! [18:07:55] ATX READ (99) rots=98 [18:07:55] copy data track 5, sector 9 [18:07:55] ->SIO write 128 bytes [18:07:55] COMPLETE! [18:07:55] [18:07:55] CF: 31 52 64 00 e7 [18:07:55] disk sio_process() [18:07:55] ACK! [18:07:55] ATX READ (100) rots=98 [18:07:55] copy data track 5, sector 10 [18:07:55] ->SIO write 128 bytes [18:07:55] COMPLETE! [18:07:55] [18:07:55] CF: 31 52 65 00 e8 [18:07:55] disk sio_process() [18:07:55] ACK! [18:07:55] ATX READ (101) rots=100 [18:07:55] copy data track 5, sector 11 [18:07:55] ->SIO write 128 bytes [18:07:55] COMPLETE! [18:07:55] [18:07:55] CF: 31 52 66 00 e9 [18:07:55] disk sio_process() [18:07:55] ACK! [18:07:55] ATX READ (102) rots=100 [18:07:55] copy data track 5, sector 12 [18:07:56] ->SIO write 128 bytes [18:07:56] COMPLETE! [18:07:56] [18:07:56] CF: 31 52 68 00 eb [18:07:56] disk sio_process() [18:07:56] ACK! [18:07:56] ATX READ (104) rots=102 [18:07:56] copy data track 5, sector 14 [18:07:56] ->SIO write 128 bytes [18:07:56] COMPLETE! [18:07:56] [18:07:56] CF: 31 52 69 00 ec [18:07:56] disk sio_process() [18:07:56] ACK! [18:07:56] ATX READ (105) rots=103 [18:07:56] copy data track 5, sector 15 [18:07:56] ->SIO write 128 bytes [18:07:56] COMPLETE! [18:07:56] [18:07:56] CF: 31 52 6a 00 ed [18:07:56] disk sio_process() [18:07:56] ACK! [18:07:56] ATX READ (106) rots=103 [18:07:56] copy data track 5, sector 16 [18:07:56] ->SIO write 128 bytes [18:07:56] COMPLETE! [18:07:56] [18:07:56] CF: 31 52 6b 00 ee [18:07:56] disk sio_process() [18:07:56] ACK! [18:07:56] ATX READ (107) rots=105 [18:07:56] copy data track 5, sector 17 [18:07:56] ->SIO write 128 bytes [18:07:56] COMPLETE! [18:07:57] [18:07:57] CF: 31 52 6c 00 ef [18:07:57] disk sio_process() [18:07:57] ACK! [18:07:57] ATX READ (108) rots=106 [18:07:57] copy data track 5, sector 18 [18:07:57] ->SIO write 128 bytes [18:07:57] COMPLETE! [18:07:57] [18:07:57] CF: 31 52 6d 00 f0 [18:07:57] disk sio_process() [18:07:57] ACK! [18:07:57] ATX READ (109) rots=106 [18:07:57] copy data track 6, sector 1 [18:07:57] ->SIO write 128 bytes [18:07:57] COMPLETE! [18:07:57] [18:07:57] CF: 31 52 6e 00 f1 [18:07:57] disk sio_process() [18:07:57] ACK! [18:07:57] ATX READ (110) rots=107 [18:07:57] copy data track 6, sector 2 [18:07:57] ->SIO write 128 bytes [18:07:57] COMPLETE! [18:07:57] [18:07:57] CF: 31 52 6f 00 f2 [18:07:57] disk sio_process() [18:07:57] ACK! [18:07:57] ATX READ (111) rots=109 [18:07:57] copy data track 6, sector 3 [18:07:57] ->SIO write 128 bytes [18:07:57] COMPLETE! [18:07:57] [18:07:57] CF: 31 52 70 00 f3 [18:07:57] disk sio_process() [18:07:57] ACK! [18:07:57] ATX READ (112) rots=109 [18:07:57] copy data track 6, sector 4 [18:07:58] ->SIO write 128 bytes [18:07:58] COMPLETE! [18:07:58] [18:07:58] CF: 31 52 71 00 f4 [18:07:58] disk sio_process() [18:07:58] ACK! [18:07:58] ATX READ (113) rots=111 [18:07:58] copy data track 6, sector 5 [18:07:58] ->SIO write 128 bytes [18:07:58] COMPLETE! [18:07:58] [18:07:58] CF: 31 52 72 00 f5 [18:07:58] disk sio_process() [18:07:58] ACK! [18:07:58] ATX READ (114) rots=111 [18:07:58] copy data track 6, sector 6 [18:07:58] ->SIO write 128 bytes [18:07:58] COMPLETE! [18:07:58] [18:07:58] CF: 31 52 73 00 f6 [18:07:58] disk sio_process() [18:07:58] ACK! [18:07:58] ATX READ (115) rots=113 [18:07:58] copy data track 6, sector 7 [18:07:58] ->SIO write 128 bytes [18:07:58] COMPLETE! [18:07:58] [18:07:58] CF: 31 52 74 00 f7 [18:07:58] disk sio_process() [18:07:58] ACK! [18:07:58] ATX READ (116) rots=113 [18:07:58] copy data track 6, sector 8 [18:07:58] ->SIO write 128 bytes [18:07:58] COMPLETE! [18:07:58] [18:07:58] CF: 31 52 75 00 f8 [18:07:58] disk sio_process() [18:07:58] ACK! [18:07:58] ATX READ (117) rots=115 [18:07:58] copy data track 6, sector 9 [18:07:59] ->SIO write 128 bytes [18:07:59] COMPLETE! [18:07:59] [18:07:59] CF: 31 52 76 00 f9 [18:07:59] disk sio_process() [18:07:59] ACK! [18:07:59] ATX READ (118) rots=115 [18:07:59] copy data track 6, sector 10 [18:07:59] ->SIO write 128 bytes [18:07:59] COMPLETE! [18:07:59] [18:07:59] CF: 31 52 77 00 fa [18:07:59] disk sio_process() [18:07:59] ACK! [18:07:59] ATX READ (119) rots=117 [18:07:59] copy data track 6, sector 11 [18:07:59] ->SIO write 128 bytes [18:07:59] COMPLETE! [18:07:59] [18:07:59] CF: 31 52 78 00 fb [18:07:59] disk sio_process() [18:07:59] ACK! [18:07:59] ATX READ (120) rots=117 [18:07:59] copy data track 6, sector 12 [18:07:59] ->SIO write 128 bytes [18:07:59] COMPLETE! [18:07:59] [18:07:59] CF: 31 52 79 00 fc [18:07:59] disk sio_process() [18:07:59] ACK! [18:07:59] ATX READ (121) rots=119 [18:07:59] copy data track 6, sector 13 [18:07:59] ->SIO write 128 bytes [18:07:59] COMPLETE! [18:07:59] [18:07:59] CF: 31 52 7a 00 fd [18:07:59] disk sio_process() [18:07:59] ACK! [18:07:59] ATX READ (122) rots=119 [18:07:59] copy data track 6, sector 14 [18:08:00] ->SIO write 128 bytes [18:08:00] COMPLETE! [18:08:00] [18:08:00] CF: 31 52 7b 00 fe [18:08:00] disk sio_process() [18:08:00] ACK! [18:08:00] ATX READ (123) rots=121 [18:08:00] copy data track 6, sector 15 [18:08:00] ->SIO write 128 bytes [18:08:00] COMPLETE! [18:08:00] [18:08:00] CF: 31 52 7c 00 ff [18:08:00] disk sio_process() [18:08:00] ACK! [18:08:00] ATX READ (124) rots=121 [18:08:00] copy data track 6, sector 16 [18:08:00] ->SIO write 128 bytes [18:08:00] COMPLETE! [18:08:00] [18:08:00] CF: 31 52 7d 00 01 [18:08:00] disk sio_process() [18:08:00] ACK! [18:08:00] ATX READ (125) rots=123 [18:08:00] copy data track 6, sector 17 [18:08:00] ->SIO write 128 bytes [18:08:00] COMPLETE! [18:08:00] [18:08:00] CF: 31 52 7e 00 02 [18:08:00] disk sio_process() [18:08:00] ACK! [18:08:00] ATX READ (126) rots=124 [18:08:00] copy data track 6, sector 18 [18:08:00] ->SIO write 128 bytes [18:08:00] COMPLETE! [18:08:00] [18:08:00] CF: 31 52 7f 00 03 [18:08:00] disk sio_process() [18:08:00] ACK! [18:08:00] ATX READ (127) rots=124 [18:08:00] copy data track 7, sector 1 [18:08:01] ->SIO write 128 bytes [18:08:01] COMPLETE! [18:08:01] [18:08:01] CF: 31 52 80 00 04 [18:08:01] disk sio_process() [18:08:01] ACK! [18:08:01] ATX READ (128) rots=125 [18:08:01] copy data track 7, sector 2 [18:08:01] ->SIO write 128 bytes [18:08:01] COMPLETE! [18:08:01] [18:08:01] CF: 31 52 81 00 05 [18:08:01] disk sio_process() [18:08:01] ACK! [18:08:01] ATX READ (129) rots=127 [18:08:01] copy data track 7, sector 3 [18:08:01] ->SIO write 128 bytes [18:08:01] COMPLETE! [18:08:01] [18:08:01] CF: 31 52 82 00 06 [18:08:01] disk sio_process() [18:08:01] ACK! [18:08:01] ATX READ (130) rots=127 [18:08:01] copy data track 7, sector 4 [18:08:01] ->SIO write 128 bytes [18:08:01] COMPLETE! [18:08:01] [18:08:01] CF: 31 52 83 00 07 [18:08:01] disk sio_process() [18:08:01] ACK! [18:08:01] ATX READ (131) rots=129 [18:08:01] copy data track 7, sector 5 [18:08:01] ->SIO write 128 bytes [18:08:01] COMPLETE! [18:08:01] [18:08:01] CF: 31 52 84 00 08 [18:08:01] disk sio_process() [18:08:01] ACK! [18:08:01] ATX READ (132) rots=129 [18:08:01] copy data track 7, sector 6 [18:08:02] ->SIO write 128 bytes [18:08:02] COMPLETE! [18:08:02] [18:08:02] CF: 31 52 85 00 09 [18:08:02] disk sio_process() [18:08:02] ACK! [18:08:02] ATX READ (133) rots=131 [18:08:02] copy data track 7, sector 7 [18:08:02] ->SIO write 128 bytes [18:08:02] COMPLETE! [18:08:02] [18:08:02] CF: 31 52 86 00 0a [18:08:02] disk sio_process() [18:08:02] ACK! [18:08:02] ATX READ (134) rots=131 [18:08:02] copy data track 7, sector 8 [18:08:02] ->SIO write 128 bytes [18:08:02] COMPLETE! [18:08:02] [18:08:02] CF: 31 52 87 00 0b [18:08:02] disk sio_process() [18:08:02] ACK! [18:08:02] ATX READ (135) rots=133 [18:08:02] copy data track 7, sector 9 [18:08:02] ->SIO write 128 bytes [18:08:02] COMPLETE! [18:08:02] [18:08:02] CF: 31 52 88 00 0c [18:08:02] disk sio_process() [18:08:02] ACK! [18:08:02] ATX READ (136) rots=133 [18:08:02] copy data track 7, sector 10 [18:08:03] ->SIO write 128 bytes [18:08:03] COMPLETE! [18:08:03] [18:08:03] CF: 31 52 89 00 0d [18:08:03] disk sio_process() [18:08:03] ACK! [18:08:03] ATX READ (137) rots=135 [18:08:03] copy data track 7, sector 11 [18:08:03] ->SIO write 128 bytes [18:08:03] COMPLETE! [18:08:03] [18:08:03] CF: 31 52 8a 00 0e [18:08:03] disk sio_process() [18:08:03] ACK! [18:08:03] ATX READ (138) rots=135 [18:08:03] copy data track 7, sector 12 [18:08:03] ->SIO write 128 bytes [18:08:03] COMPLETE! [18:08:03] [18:08:03] CF: 31 52 8b 00 0f [18:08:03] disk sio_process() [18:08:03] ACK! [18:08:03] ATX READ (139) rots=137 [18:08:03] copy data track 7, sector 13 [18:08:03] ->SIO write 128 bytes [18:08:03] COMPLETE! [18:08:03] [18:08:03] CF: 31 52 8c 00 10 [18:08:03] disk sio_process() [18:08:03] ACK! [18:08:03] ATX READ (140) rots=137 [18:08:03] copy data track 7, sector 14 [18:08:03] ->SIO write 128 bytes [18:08:03] COMPLETE! [18:08:04] [18:08:04] CF: 31 52 8d 00 11 [18:08:04] disk sio_process() [18:08:04] ACK! [18:08:04] ATX READ (141) rots=139 [18:08:04] copy data track 7, sector 15 [18:08:04] ->SIO write 128 bytes [18:08:04] COMPLETE! [18:08:04] [18:08:04] CF: 31 52 8e 00 12 [18:08:04] disk sio_process() [18:08:04] ACK! [18:08:04] ATX READ (142) rots=139 [18:08:04] copy data track 7, sector 16 [18:08:04] ->SIO write 128 bytes [18:08:04] COMPLETE! [18:08:04] [18:08:04] CF: 31 52 8f 00 13 [18:08:04] disk sio_process() [18:08:04] ACK! [18:08:04] ATX READ (143) rots=141 [18:08:04] copy data track 7, sector 17 [18:08:04] ->SIO write 128 bytes [18:08:04] COMPLETE! [18:08:04] [18:08:04] CF: 31 52 90 00 14 [18:08:04] disk sio_process() [18:08:04] ACK! [18:08:04] ATX READ (144) rots=142 [18:08:04] copy data track 7, sector 18 [18:08:04] ->SIO write 128 bytes [18:08:04] COMPLETE! [18:08:04] [18:08:04] CF: 31 52 91 00 15 [18:08:04] disk sio_process() [18:08:04] ACK! [18:08:04] ATX READ (145) rots=142 [18:08:04] copy data track 8, sector 1 [18:08:04] ->SIO write 128 bytes [18:08:04] COMPLETE! [18:08:04] [18:08:04] CF: 31 52 92 00 16 [18:08:04] disk sio_process() [18:08:04] ACK! [18:08:04] ATX READ (146) rots=143 [18:08:04] copy data track 8, sector 2 [18:08:05] ->SIO write 128 bytes [18:08:05] COMPLETE! [18:08:05] [18:08:05] CF: 31 52 93 00 17 [18:08:05] disk sio_process() [18:08:05] ACK! [18:08:05] ATX READ (147) rots=145 [18:08:05] copy data track 8, sector 3 [18:08:05] ->SIO write 128 bytes [18:08:05] COMPLETE! [18:08:05] [18:08:05] CF: 31 52 f2 00 76 [18:08:05] disk sio_process() [18:08:05] ACK! [18:08:05] ATX READ (242) rots=145 [18:08:05] copy data track 13, sector 8 [18:08:05] ->SIO write 128 bytes [18:08:05] COMPLETE! [18:08:05] [18:08:05] CF: 31 52 f3 00 77 [18:08:05] disk sio_process() [18:08:05] ACK! [18:08:05] ATX READ (243) rots=147 [18:08:05] copy data track 13, sector 9 [18:08:05] ->SIO write 128 bytes [18:08:05] COMPLETE! [18:08:05] [18:08:05] CF: 31 52 f4 00 78 [18:08:05] disk sio_process() [18:08:05] ACK! [18:08:05] ATX READ (244) rots=147 [18:08:05] copy data track 13, sector 10 [18:08:05] ->SIO write 128 bytes [18:08:05] COMPLETE! [18:08:06] [18:08:06] CF: 31 52 f5 00 79 [18:08:06] disk sio_process() [18:08:06] ACK! [18:08:06] ATX READ (245) rots=149 [18:08:06] copy data track 13, sector 11 [18:08:06] ->SIO write 128 bytes [18:08:06] COMPLETE! [18:08:06] [18:08:06] CF: 31 52 f6 00 7a [18:08:06] disk sio_process() [18:08:06] ACK! [18:08:06] ATX READ (246) rots=149 [18:08:06] copy data track 13, sector 12 [18:08:06] ->SIO write 128 bytes [18:08:06] COMPLETE! [18:08:06] [18:08:06] CF: 31 52 f7 00 7b [18:08:06] disk sio_process() [18:08:06] ACK! [18:08:06] ATX READ (247) rots=151 [18:08:06] copy data track 13, sector 13 [18:08:06] ->SIO write 128 bytes [18:08:06] COMPLETE! [18:08:06] [18:08:06] CF: 31 52 f8 00 7c [18:08:06] disk sio_process() [18:08:06] ACK! [18:08:06] ATX READ (248) rots=151 [18:08:06] copy data track 13, sector 14 [18:08:06] ->SIO write 128 bytes [18:08:06] COMPLETE! [18:08:06] [18:08:06] CF: 31 52 f9 00 7d [18:08:06] disk sio_process() [18:08:06] ACK! [18:08:06] ATX READ (249) rots=153 [18:08:06] copy data track 13, sector 15 [18:08:06] ->SIO write 128 bytes [18:08:06] COMPLETE! [18:08:07] [18:08:07] CF: 31 52 fa 00 7e [18:08:07] disk sio_process() [18:08:07] ACK! [18:08:07] ATX READ (250) rots=153 [18:08:07] copy data track 13, sector 16 [18:08:07] ->SIO write 128 bytes [18:08:07] COMPLETE! [18:08:07] [18:08:07] CF: 31 52 fb 00 7f [18:08:07] disk sio_process() [18:08:07] ACK! [18:08:07] ATX READ (251) rots=155 [18:08:07] copy data track 13, sector 17 [18:08:07] ->SIO write 128 bytes [18:08:07] COMPLETE! [18:08:07] [18:08:07] CF: 31 52 fc 00 80 [18:08:07] disk sio_process() [18:08:07] ACK! [18:08:07] ATX READ (252) rots=156 [18:08:07] copy data track 13, sector 18 [18:08:07] ->SIO write 128 bytes [18:08:07] COMPLETE! [18:08:07] [18:08:07] CF: 31 52 fd 00 81 [18:08:07] disk sio_process() [18:08:07] ACK! [18:08:07] ATX READ (253) rots=156 [18:08:07] copy data track 14, sector 1 [18:08:07] ->SIO write 128 bytes [18:08:07] COMPLETE! [18:08:07] [18:08:07] CF: 31 52 fe 00 82 [18:08:07] disk sio_process() [18:08:07] ACK! [18:08:07] ATX READ (254) rots=157 [18:08:07] copy data track 14, sector 2 [18:08:08] ->SIO write 128 bytes [18:08:08] COMPLETE! [18:08:08] [18:08:08] CF: 31 52 ff 00 83 [18:08:08] disk sio_process() [18:08:08] ACK! [18:08:08] ATX READ (255) rots=159 [18:08:08] copy data track 14, sector 3 [18:08:08] ->SIO write 128 bytes [18:08:08] COMPLETE! [18:08:08] [18:08:08] CF: 31 52 00 01 84 [18:08:08] disk sio_process() [18:08:08] ACK! [18:08:08] ATX READ (256) rots=159 [18:08:08] copy data track 14, sector 4 [18:08:08] ->SIO write 128 bytes [18:08:08] COMPLETE! [18:08:08] [18:08:08] CF: 31 52 01 01 85 [18:08:08] disk sio_process() [18:08:08] ACK! [18:08:08] ATX READ (257) rots=161 [18:08:08] copy data track 14, sector 5 [18:08:08] ->SIO write 128 bytes [18:08:08] COMPLETE! [18:08:08] [18:08:08] CF: 31 52 02 01 86 [18:08:08] disk sio_process() [18:08:08] ACK! [18:08:08] ATX READ (258) rots=161 [18:08:08] copy data track 14, sector 6 [18:08:08] ->SIO write 128 bytes [18:08:08] COMPLETE! [18:08:08] [18:08:08] CF: 31 52 03 01 87 [18:08:08] disk sio_process() [18:08:08] ACK! [18:08:08] ATX READ (259) rots=163 [18:08:08] copy data track 14, sector 7 [18:08:08] ->SIO write 128 bytes [18:08:08] COMPLETE! [18:08:09] [18:08:09] CF: 31 52 04 01 88 [18:08:09] disk sio_process() [18:08:09] ACK! [18:08:09] ATX READ (260) rots=163 [18:08:09] copy data track 14, sector 8 [18:08:09] ->SIO write 128 bytes [18:08:09] COMPLETE! [18:08:09] [18:08:09] CF: 31 52 05 01 89 [18:08:09] disk sio_process() [18:08:09] ACK! [18:08:09] ATX READ (261) rots=165 [18:08:09] copy data track 14, sector 9 [18:08:09] ->SIO write 128 bytes [18:08:09] COMPLETE! [18:08:09] [18:08:09] CF: 31 52 06 01 8a [18:08:09] disk sio_process() [18:08:09] ACK! [18:08:09] ATX READ (262) rots=165 [18:08:09] copy data track 14, sector 10 [18:08:09] ->SIO write 128 bytes [18:08:09] COMPLETE! [18:08:09] [18:08:09] CF: 31 52 07 01 8b [18:08:09] disk sio_process() [18:08:09] ACK! [18:08:09] ATX READ (263) rots=167 [18:08:09] copy data track 14, sector 11 [18:08:09] ->SIO write 128 bytes [18:08:09] COMPLETE! [18:08:09] [18:08:09] CF: 31 52 08 01 8c [18:08:09] disk sio_process() [18:08:09] ACK! [18:08:09] ATX READ (264) rots=167 [18:08:09] copy data track 14, sector 12 [18:08:10] ->SIO write 128 bytes [18:08:10] COMPLETE! [18:08:10] [18:08:10] CF: 31 52 09 01 8d [18:08:10] disk sio_process() [18:08:10] ACK! [18:08:10] ATX READ (265) rots=169 [18:08:10] copy data track 14, sector 13 [18:08:10] ->SIO write 128 bytes [18:08:10] COMPLETE! [18:08:10] [18:08:10] CF: 31 52 0a 01 8e [18:08:10] disk sio_process() [18:08:10] ACK! [18:08:10] ATX READ (266) rots=169 [18:08:10] copy data track 14, sector 14 [18:08:10] ->SIO write 128 bytes [18:08:10] COMPLETE! [18:08:10] [18:08:10] CF: 31 52 0b 01 8f [18:08:10] disk sio_process() [18:08:10] ACK! [18:08:10] ATX READ (267) rots=171 [18:08:10] copy data track 14, sector 15 [18:08:10] ->SIO write 128 bytes [18:08:10] COMPLETE! [18:08:10] [18:08:10] CF: 31 52 0c 01 90 [18:08:10] disk sio_process() [18:08:10] ACK! [18:08:10] ATX READ (268) rots=171 [18:08:10] copy data track 14, sector 16 [18:08:11] ->SIO write 128 bytes [18:08:11] COMPLETE! [18:08:11] [18:08:11] CF: 31 52 0d 01 91 [18:08:11] disk sio_process() [18:08:11] ACK! [18:08:11] ATX READ (269) rots=173 [18:08:11] copy data track 14, sector 17 [18:08:11] ->SIO write 128 bytes [18:08:11] COMPLETE! [18:08:11] [18:08:11] CF: 31 52 0e 01 92 [18:08:11] disk sio_process() [18:08:11] ACK! [18:08:11] ATX READ (270) rots=174 [18:08:11] copy data track 14, sector 18 [18:08:11] ->SIO write 128 bytes [18:08:11] COMPLETE! [18:08:11] [18:08:11] CF: 31 52 0f 01 93 [18:08:11] disk sio_process() [18:08:11] ACK! [18:08:11] ATX READ (271) rots=174 [18:08:11] copy data track 15, sector 1 [18:08:11] ->SIO write 128 bytes [18:08:11] COMPLETE! [18:08:11] [18:08:11] CF: 31 52 10 01 94 [18:08:11] disk sio_process() [18:08:11] ACK! [18:08:11] ATX READ (272) rots=175 [18:08:11] copy data track 15, sector 2 [18:08:11] ->SIO write 128 bytes [18:08:11] COMPLETE! [18:08:11] [18:08:11] CF: 31 52 11 01 95 [18:08:11] disk sio_process() [18:08:11] ACK! [18:08:11] ATX READ (273) rots=177 [18:08:11] copy data track 15, sector 3 [18:08:11] ->SIO write 128 bytes [18:08:11] COMPLETE! [18:08:11] [18:08:11] CF: 31 52 12 01 96 [18:08:11] disk sio_process() [18:08:11] ACK! [18:08:11] ATX READ (274) rots=177 [18:08:11] copy data track 15, sector 4 [18:08:12] ->SIO write 128 bytes [18:08:12] COMPLETE! [18:08:12] [18:08:12] CF: 31 52 13 01 97 [18:08:12] disk sio_process() [18:08:12] ACK! [18:08:12] ATX READ (275) rots=179 [18:08:12] copy data track 15, sector 5 [18:08:12] ->SIO write 128 bytes [18:08:12] COMPLETE! [18:08:12] [18:08:12] CF: 31 52 1f 01 a3 [18:08:12] disk sio_process() [18:08:12] ACK! [18:08:12] ATX READ (287) rots=179 [18:08:12] copy data track 15, sector 17 [18:08:12] ->SIO write 128 bytes [18:08:12] COMPLETE! [18:08:12] [18:08:12] CF: 31 52 20 01 a4 [18:08:12] disk sio_process() [18:08:12] ACK! [18:08:12] ATX READ (288) rots=181 [18:08:12] copy data track 15, sector 18 [18:08:12] ->SIO write 128 bytes [18:08:12] COMPLETE! [18:08:12] [18:08:12] CF: 31 52 21 01 a5 [18:08:12] disk sio_process() [18:08:12] ACK! [18:08:12] ATX READ (289) rots=181 [18:08:12] copy data track 16, sector 1 [18:08:12] ->SIO write 128 bytes [18:08:12] COMPLETE! [18:08:13] [18:08:13] CF: 31 52 22 01 a6 [18:08:13] disk sio_process() [18:08:13] ACK! [18:08:13] ATX READ (290) rots=182 [18:08:13] copy data track 16, sector 2 [18:08:13] ->SIO write 128 bytes [18:08:13] COMPLETE! [18:08:13] [18:08:13] CF: 31 52 23 01 a7 [18:08:13] disk sio_process() [18:08:13] ACK! [18:08:13] ATX READ (291) rots=184 [18:08:13] copy data track 16, sector 3 [18:08:13] ->SIO write 128 bytes [18:08:13] COMPLETE! [18:08:13] [18:08:13] CF: 31 52 24 01 a8 [18:08:13] disk sio_process() [18:08:13] ACK! [18:08:13] ATX READ (292) rots=184 [18:08:13] copy data track 16, sector 4 [18:08:13] ->SIO write 128 bytes [18:08:13] COMPLETE! [18:08:13] [18:08:13] CF: 31 52 25 01 a9 [18:08:13] disk sio_process() [18:08:13] ACK! [18:08:13] ATX READ (293) rots=186 [18:08:13] copy data track 16, sector 5 [18:08:13] ->SIO write 128 bytes [18:08:13] COMPLETE! [18:08:13] [18:08:13] CF: 31 52 26 01 aa [18:08:13] disk sio_process() [18:08:13] ACK! [18:08:13] ATX READ (294) rots=186 [18:08:13] copy data track 16, sector 6 [18:08:14] ->SIO write 128 bytes [18:08:14] COMPLETE! [18:08:14] [18:08:14] CF: 31 52 27 01 ab [18:08:14] disk sio_process() [18:08:14] ACK! [18:08:14] ATX READ (295) rots=188 [18:08:14] copy data track 16, sector 7 [18:08:14] ->SIO write 128 bytes [18:08:14] COMPLETE! [18:08:14] [18:08:14] CF: 31 52 28 01 ac [18:08:14] disk sio_process() [18:08:14] ACK! [18:08:14] ATX READ (296) rots=188 [18:08:14] copy data track 16, sector 8 [18:08:14] ->SIO write 128 bytes [18:08:14] COMPLETE! [18:08:14] [18:08:14] CF: 31 52 29 01 ad [18:08:14] disk sio_process() [18:08:14] ACK! [18:08:14] ATX READ (297) rots=190 [18:08:14] copy data track 16, sector 9 [18:08:14] ->SIO write 128 bytes [18:08:14] COMPLETE! [18:08:14] [18:08:14] CF: 31 52 2a 01 ae [18:08:14] disk sio_process() [18:08:14] ACK! [18:08:14] ATX READ (298) rots=190 [18:08:14] copy data track 16, sector 10 [18:08:14] ->SIO write 128 bytes [18:08:14] COMPLETE! [18:08:15] [18:08:15] CF: 31 52 2b 01 af [18:08:15] disk sio_process() [18:08:15] ACK! [18:08:15] ATX READ (299) rots=192 [18:08:15] copy data track 16, sector 11 [18:08:15] ->SIO write 128 bytes [18:08:15] COMPLETE! [18:08:15] [18:08:15] CF: 31 52 2c 01 b0 [18:08:15] disk sio_process() [18:08:15] ACK! [18:08:15] ATX READ (300) rots=192 [18:08:15] copy data track 16, sector 12 [18:08:15] ->SIO write 128 bytes [18:08:15] COMPLETE! [18:08:15] [18:08:15] CF: 31 52 2d 01 b1 [18:08:15] disk sio_process() [18:08:15] ACK! [18:08:15] ATX READ (301) rots=194 [18:08:15] copy data track 16, sector 13 [18:08:15] ->SIO write 128 bytes [18:08:15] COMPLETE! [18:08:15] [18:08:15] CF: 31 52 2e 01 b2 [18:08:15] disk sio_process() [18:08:15] ACK! [18:08:15] ATX READ (302) rots=194 [18:08:15] copy data track 16, sector 14 [18:08:15] ->SIO write 128 bytes [18:08:15] COMPLETE! [18:08:15] [18:08:15] CF: 31 52 2f 01 b3 [18:08:15] disk sio_process() [18:08:15] ACK! [18:08:15] ATX READ (303) rots=196 [18:08:15] copy data track 16, sector 15 [18:08:15] ->SIO write 128 bytes [18:08:15] COMPLETE! [18:08:16] [18:08:16] CF: 31 52 30 01 b4 [18:08:16] disk sio_process() [18:08:16] ACK! [18:08:16] ATX READ (304) rots=196 [18:08:16] copy data track 16, sector 16 [18:08:16] ->SIO write 128 bytes [18:08:16] COMPLETE! [18:08:16] [18:08:16] CF: 31 52 31 01 b5 [18:08:16] disk sio_process() [18:08:16] ACK! [18:08:16] ATX READ (305) rots=198 [18:08:16] copy data track 16, sector 17 [18:08:16] ->SIO write 128 bytes [18:08:16] COMPLETE! [18:08:16] [18:08:16] CF: 31 52 32 01 b6 [18:08:16] disk sio_process() [18:08:16] ACK! [18:08:16] ATX READ (306) rots=199 [18:08:16] copy data track 16, sector 18 [18:08:16] ->SIO write 128 bytes [18:08:16] COMPLETE! [18:08:16] [18:08:16] CF: 31 52 33 01 b7 [18:08:16] disk sio_process() [18:08:16] ACK! [18:08:16] ATX READ (307) rots=199 [18:08:16] copy data track 17, sector 1 [18:08:16] ->SIO write 128 bytes [18:08:16] COMPLETE! [18:08:16] [18:08:16] CF: 31 52 34 01 b8 [18:08:16] disk sio_process() [18:08:16] ACK! [18:08:16] ATX READ (308) rots=200 [18:08:16] copy data track 17, sector 2 [18:08:16] ->SIO write 128 bytes [18:08:16] COMPLETE! [18:08:17] [18:08:17] CF: 31 52 35 01 b9 [18:08:17] disk sio_process() [18:08:17] ACK! [18:08:17] ATX READ (309) rots=202 [18:08:17] copy data track 17, sector 3 [18:08:17] ->SIO write 128 bytes [18:08:17] COMPLETE! [18:08:17] [18:08:17] CF: 31 52 36 01 ba [18:08:17] disk sio_process() [18:08:17] ACK! [18:08:17] ATX READ (310) rots=202 [18:08:17] copy data track 17, sector 4 [18:08:17] ->SIO write 128 bytes [18:08:17] COMPLETE! [18:08:17] [18:08:17] CF: 31 52 39 01 bd [18:08:17] disk sio_process() [18:08:17] ACK! [18:08:17] ATX READ (313) rots=204 [18:08:17] copy data track 17, sector 7 [18:08:17] ->SIO write 128 bytes [18:08:17] COMPLETE! [18:08:17] [18:08:17] CF: 31 52 3a 01 be [18:08:17] disk sio_process() [18:08:17] ACK! [18:08:17] ATX READ (314) rots=204 [18:08:17] copy data track 17, sector 8 [18:08:17] ->SIO write 128 bytes [18:08:17] COMPLETE! [18:08:17] [18:08:17] CF: 31 52 3b 01 bf [18:08:17] disk sio_process() [18:08:17] ACK! [18:08:17] ATX READ (315) rots=206 [18:08:17] copy data track 17, sector 9 [18:08:17] ->SIO write 128 bytes [18:08:17] COMPLETE! [18:08:18] [18:08:18] CF: 31 52 3c 01 c0 [18:08:18] disk sio_process() [18:08:18] ACK! [18:08:18] ATX READ (316) rots=206 [18:08:18] copy data track 17, sector 10 [18:08:18] ->SIO write 128 bytes [18:08:18] COMPLETE! [18:08:18] [18:08:18] CF: 31 52 3d 01 c1 [18:08:18] disk sio_process() [18:08:18] ACK! [18:08:18] ATX READ (317) rots=208 [18:08:18] copy data track 17, sector 11 [18:08:18] ->SIO write 128 bytes [18:08:18] COMPLETE! [18:08:18] [18:08:18] CF: 31 52 3e 01 c2 [18:08:18] disk sio_process() [18:08:18] ACK! [18:08:18] ATX READ (318) rots=208 [18:08:18] copy data track 17, sector 12 [18:08:18] ->SIO write 128 bytes [18:08:18] COMPLETE! [18:08:18] [18:08:18] CF: 31 52 3f 01 c3 [18:08:18] disk sio_process() [18:08:18] ACK! [18:08:18] ATX READ (319) rots=210 [18:08:18] copy data track 17, sector 13 [18:08:18] ->SIO write 128 bytes [18:08:18] COMPLETE! [18:08:18] [18:08:18] CF: 31 52 40 01 c4 [18:08:18] disk sio_process() [18:08:18] ACK! [18:08:18] ATX READ (320) rots=210 [18:08:18] copy data track 17, sector 14 [18:08:19] ->SIO write 128 bytes [18:08:19] COMPLETE! [18:08:19] [18:08:19] CF: 31 52 41 01 c5 [18:08:19] disk sio_process() [18:08:19] ACK! [18:08:19] ATX READ (321) rots=212 [18:08:19] copy data track 17, sector 15 [18:08:19] ->SIO write 128 bytes [18:08:19] COMPLETE! [18:08:19] [18:08:19] CF: 31 52 42 01 c6 [18:08:19] disk sio_process() [18:08:19] ACK! [18:08:19] ATX READ (322) rots=212 [18:08:19] copy data track 17, sector 16 [18:08:19] ->SIO write 128 bytes [18:08:19] COMPLETE! [18:08:19] [18:08:19] CF: 31 52 43 01 c7 [18:08:19] disk sio_process() [18:08:19] ACK! [18:08:19] ATX READ (323) rots=214 [18:08:19] copy data track 17, sector 17 [18:08:19] ->SIO write 128 bytes [18:08:19] COMPLETE! [18:08:19] [18:08:19] CF: 31 52 44 01 c8 [18:08:19] disk sio_process() [18:08:19] ACK! [18:08:19] ATX READ (324) rots=215 [18:08:19] copy data track 17, sector 18 [18:08:19] ->SIO write 128 bytes [18:08:19] COMPLETE! [18:08:19] [18:08:19] CF: 31 52 45 01 c9 [18:08:19] disk sio_process() [18:08:19] ACK! [18:08:19] ATX READ (325) rots=215 [18:08:19] copy data track 18, sector 1 [18:08:20] ->SIO write 128 bytes [18:08:20] COMPLETE! [18:08:20] [18:08:20] CF: 31 52 46 01 ca [18:08:20] disk sio_process() [18:08:20] ACK! [18:08:20] ATX READ (326) rots=216 [18:08:20] copy data track 18, sector 2 [18:08:20] ->SIO write 128 bytes [18:08:20] COMPLETE! [18:08:20] [18:08:20] CF: 31 52 47 01 cb [18:08:20] disk sio_process() [18:08:20] ACK! [18:08:20] ATX READ (327) rots=218 [18:08:20] copy data track 18, sector 3 [18:08:20] ->SIO write 128 bytes [18:08:20] COMPLETE! [18:08:20] [18:08:20] CF: 31 52 48 01 cc [18:08:20] disk sio_process() [18:08:20] ACK! [18:08:20] ATX READ (328) rots=218 [18:08:20] copy data track 18, sector 4 [18:08:20] ->SIO write 128 bytes [18:08:20] COMPLETE! [18:08:20] [18:08:20] CF: 31 52 49 01 cd [18:08:20] disk sio_process() [18:08:20] ACK! [18:08:20] ATX READ (329) rots=220 [18:08:20] copy data track 18, sector 5 [18:08:20] ->SIO write 128 bytes [18:08:20] COMPLETE! [18:08:20] [18:08:20] CF: 31 52 4a 01 ce [18:08:20] disk sio_process() [18:08:20] ACK! [18:08:20] ATX READ (330) rots=220 [18:08:20] copy data track 18, sector 6 [18:08:21] ->SIO write 128 bytes [18:08:21] COMPLETE! [18:08:21] [18:08:21] CF: 31 52 4b 01 cf [18:08:21] disk sio_process() [18:08:21] ACK! [18:08:21] ATX READ (331) rots=222 [18:08:21] copy data track 18, sector 7 [18:08:21] ->SIO write 128 bytes [18:08:21] COMPLETE! [18:08:21] [18:08:21] CF: 31 52 4c 01 d0 [18:08:21] disk sio_process() [18:08:21] ACK! [18:08:21] ATX READ (332) rots=222 [18:08:21] copy data track 18, sector 8 [18:08:21] ->SIO write 128 bytes [18:08:21] COMPLETE! [18:08:21] [18:08:21] CF: 31 52 4d 01 d1 [18:08:21] disk sio_process() [18:08:21] ACK! [18:08:21] ATX READ (333) rots=224 [18:08:21] copy data track 18, sector 9 [18:08:21] ->SIO write 128 bytes [18:08:21] COMPLETE! [18:08:21] [18:08:21] CF: 31 52 4e 01 d2 [18:08:21] disk sio_process() [18:08:21] ACK! [18:08:21] ATX READ (334) rots=224 [18:08:21] copy data track 18, sector 10 [18:08:22] ->SIO write 128 bytes [18:08:22] COMPLETE! [18:08:22] [18:08:22] CF: 31 52 4f 01 d3 [18:08:22] disk sio_process() [18:08:22] ACK! [18:08:22] ATX READ (335) rots=226 [18:08:22] copy data track 18, sector 11 [18:08:22] ->SIO write 128 bytes [18:08:22] COMPLETE! [18:08:22] [18:08:22] CF: 31 52 50 01 d4 [18:08:22] disk sio_process() [18:08:22] ACK! [18:08:22] ATX READ (336) rots=226 [18:08:22] copy data track 18, sector 12 [18:08:22] ->SIO write 128 bytes [18:08:22] COMPLETE! [18:08:22] [18:08:22] CF: 31 52 51 01 d5 [18:08:22] disk sio_process() [18:08:22] ACK! [18:08:22] ATX READ (337) rots=228 [18:08:22] copy data track 18, sector 13 [18:08:22] ->SIO write 128 bytes [18:08:22] COMPLETE! [18:08:22] [18:08:22] CF: 31 52 52 01 d6 [18:08:22] disk sio_process() [18:08:22] ACK! [18:08:22] ATX READ (338) rots=228 [18:08:22] copy data track 18, sector 14 [18:08:22] ->SIO write 128 bytes [18:08:22] COMPLETE! [18:08:22] [18:08:22] CF: 31 52 53 01 d7 [18:08:22] disk sio_process() [18:08:22] ACK! [18:08:22] ATX READ (339) rots=230 [18:08:22] copy data track 18, sector 15 [18:08:22] ->SIO write 128 bytes [18:08:22] COMPLETE! [18:08:23] [18:08:23] CF: 31 52 54 01 d8 [18:08:23] disk sio_process() [18:08:23] ACK! [18:08:23] ATX READ (340) rots=230 [18:08:23] copy data track 18, sector 16 [18:08:23] ->SIO write 128 bytes [18:08:23] COMPLETE! [18:08:23] [18:08:23] CF: 31 52 55 01 d9 [18:08:23] disk sio_process() [18:08:23] ACK! [18:08:23] ATX READ (341) rots=232 [18:08:23] copy data track 18, sector 17 [18:08:23] ->SIO write 128 bytes [18:08:23] COMPLETE! [18:08:23] [18:08:23] CF: 31 52 56 01 da [18:08:23] disk sio_process() [18:08:23] ACK! [18:08:23] ATX READ (342) rots=233 [18:08:23] copy data track 18, sector 18 [18:08:23] ->SIO write 128 bytes [18:08:23] COMPLETE! [18:08:23] [18:08:23] CF: 31 52 57 01 db [18:08:23] disk sio_process() [18:08:23] ACK! [18:08:23] ATX READ (343) rots=233 [18:08:23] copy data track 19, sector 1 [18:08:23] ->SIO write 128 bytes [18:08:23] COMPLETE! [18:08:23] [18:08:23] CF: 31 52 58 01 dc [18:08:23] disk sio_process() [18:08:23] ACK! [18:08:23] ATX READ (344) rots=234 [18:08:23] copy data track 19, sector 2 [18:08:24] ->SIO write 128 bytes [18:08:24] COMPLETE! [18:08:24] [18:08:24] CF: 31 52 59 01 dd [18:08:24] disk sio_process() [18:08:24] ACK! [18:08:24] ATX READ (345) rots=236 [18:08:24] copy data track 19, sector 3 [18:08:24] ->SIO write 128 bytes [18:08:24] COMPLETE! [18:08:24] [18:08:24] CF: 31 52 5a 01 de [18:08:24] disk sio_process() [18:08:24] ACK! [18:08:24] ATX READ (346) rots=236 [18:08:24] copy data track 19, sector 4 [18:08:24] ->SIO write 128 bytes [18:08:24] COMPLETE! [18:08:24] [18:08:24] CF: 31 52 5b 01 df [18:08:24] disk sio_process() [18:08:24] ACK! [18:08:24] ATX READ (347) rots=237 [18:08:24] copy data track 19, sector 5 [18:08:24] ->SIO write 128 bytes [18:08:24] COMPLETE! [18:08:24] [18:08:24] CF: 31 52 5c 01 e0 [18:08:24] disk sio_process() [18:08:24] ACK! [18:08:24] ATX READ (348) rots=238 [18:08:24] copy data track 19, sector 6 [18:08:24] ->SIO write 128 bytes [18:08:24] COMPLETE! [18:08:25] [18:08:25] CF: 31 52 5d 01 e1 [18:08:25] disk sio_process() [18:08:25] ACK! [18:08:25] ATX READ (349) rots=240 [18:08:25] copy data track 19, sector 7 [18:08:25] ->SIO write 128 bytes [18:08:25] COMPLETE! [18:08:25] [18:08:25] CF: 31 52 5e 01 e2 [18:08:25] disk sio_process() [18:08:25] ACK! [18:08:25] ATX READ (350) rots=240 [18:08:25] copy data track 19, sector 8 [18:08:25] ->SIO write 128 bytes [18:08:25] COMPLETE! [18:08:25] [18:08:25] CF: 31 52 5f 01 e3 [18:08:25] disk sio_process() [18:08:25] ACK! [18:08:25] ATX READ (351) rots=242 [18:08:25] copy data track 19, sector 9 [18:08:25] ->SIO write 128 bytes [18:08:25] COMPLETE! [18:08:25] [18:08:25] CF: 31 52 60 01 e4 [18:08:25] disk sio_process() [18:08:25] ACK! [18:08:25] ATX READ (352) rots=242 [18:08:25] copy data track 19, sector 10 [18:08:25] ->SIO write 128 bytes [18:08:25] COMPLETE! [18:08:25] [18:08:25] CF: 31 52 61 01 e5 [18:08:25] disk sio_process() [18:08:25] ACK! [18:08:25] ATX READ (353) rots=244 [18:08:25] copy data track 19, sector 11 [18:08:25] ->SIO write 128 bytes [18:08:25] COMPLETE! [18:08:25] [18:08:25] CF: 31 52 62 01 e6 [18:08:25] disk sio_process() [18:08:25] ACK! [18:08:25] ATX READ (354) rots=244 [18:08:25] copy data track 19, sector 12 [18:08:26] ->SIO write 128 bytes [18:08:26] COMPLETE! [18:08:26] [18:08:26] CF: 31 52 63 01 e7 [18:08:26] disk sio_process() [18:08:26] ACK! [18:08:26] ATX READ (355) rots=246 [18:08:26] copy data track 19, sector 13 [18:08:26] ->SIO write 128 bytes [18:08:26] COMPLETE! [18:08:26] [18:08:26] CF: 31 52 64 01 e8 [18:08:26] disk sio_process() [18:08:26] ACK! [18:08:26] ATX READ (356) rots=246 [18:08:26] copy data track 19, sector 14 [18:08:26] ->SIO write 128 bytes [18:08:26] COMPLETE! [18:08:26] [18:08:26] CF: 31 52 65 01 e9 [18:08:26] disk sio_process() [18:08:26] ACK! [18:08:26] ATX READ (357) rots=248 [18:08:26] copy data track 19, sector 15 [18:08:26] ->SIO write 128 bytes [18:08:26] COMPLETE! [18:08:26] [18:08:26] CF: 31 52 66 01 ea [18:08:26] disk sio_process() [18:08:26] ACK! [18:08:26] ATX READ (358) rots=248 [18:08:26] copy data track 19, sector 16 [18:08:27] ->SIO write 128 bytes [18:08:27] COMPLETE! [18:08:27] [18:08:27] CF: 31 52 67 01 eb [18:08:27] disk sio_process() [18:08:27] ACK! [18:08:27] ATX READ (359) rots=250 [18:08:27] copy data track 19, sector 17 [18:08:27] ->SIO write 128 bytes [18:08:27] COMPLETE! [18:08:27] [18:08:27] CF: 31 52 68 01 ec [18:08:27] disk sio_process() [18:08:27] ACK! [18:08:27] ATX READ (360) rots=251 [18:08:27] copy data track 19, sector 18 [18:08:27] ->SIO write 128 bytes [18:08:27] COMPLETE! [18:08:27] [18:08:27] CF: 31 52 69 01 ed [18:08:27] disk sio_process() [18:08:27] ACK! [18:08:27] ATX READ (361) rots=251 [18:08:27] copy data track 20, sector 1 [18:08:27] ->SIO write 128 bytes [18:08:27] COMPLETE! [18:08:27] [18:08:27] CF: 31 52 6a 01 ee [18:08:27] disk sio_process() [18:08:27] ACK! [18:08:27] ATX READ (362) rots=252 [18:08:27] copy data track 20, sector 2 [18:08:27] ->SIO write 128 bytes [18:08:27] COMPLETE! [18:08:27] [18:08:27] CF: 31 52 6b 01 ef [18:08:27] disk sio_process() [18:08:27] ACK! [18:08:27] ATX READ (363) rots=254 [18:08:27] copy data track 20, sector 3 [18:08:27] ->SIO write 128 bytes [18:08:27] COMPLETE! [18:08:28] [18:08:28] CF: 31 52 6c 01 f0 [18:08:28] disk sio_process() [18:08:28] ACK! [18:08:28] ATX READ (364) rots=254 [18:08:28] copy data track 20, sector 4 [18:08:28] ->SIO write 128 bytes [18:08:28] COMPLETE! [18:08:28] [18:08:28] CF: 31 52 6d 01 f1 [18:08:28] disk sio_process() [18:08:28] ACK! [18:08:28] ATX READ (365) rots=256 [18:08:28] copy data track 20, sector 5 [18:08:28] ->SIO write 128 bytes [18:08:28] COMPLETE! [18:08:28] [18:08:28] CF: 31 52 6e 01 f2 [18:08:28] disk sio_process() [18:08:28] ACK! [18:08:28] ATX READ (366) rots=256 [18:08:28] copy data track 20, sector 6 [18:08:28] ->SIO write 128 bytes [18:08:28] COMPLETE! [18:08:28] [18:08:28] CF: 31 52 6f 01 f3 [18:08:28] disk sio_process() [18:08:28] ACK! [18:08:28] ATX READ (367) rots=258 [18:08:28] copy data track 20, sector 7 [18:08:28] ->SIO write 128 bytes [18:08:28] COMPLETE! [18:08:28] [18:08:28] CF: 31 52 70 01 f4 [18:08:28] disk sio_process() [18:08:28] ACK! [18:08:28] ATX READ (368) rots=258 [18:08:28] copy data track 20, sector 8 [18:08:29] ->SIO write 128 bytes [18:08:29] COMPLETE! [18:08:29] [18:08:29] CF: 31 52 71 01 f5 [18:08:29] disk sio_process() [18:08:29] ACK! [18:08:29] ATX READ (369) rots=260 [18:08:29] copy data track 20, sector 9 [18:08:29] ->SIO write 128 bytes [18:08:29] COMPLETE! [18:08:29] [18:08:29] CF: 31 52 72 01 f6 [18:08:29] disk sio_process() [18:08:29] ACK! [18:08:29] ATX READ (370) rots=260 [18:08:29] copy data track 20, sector 10 [18:08:29] ->SIO write 128 bytes [18:08:29] COMPLETE! [18:08:29] [18:08:29] CF: 31 52 73 01 f7 [18:08:29] disk sio_process() [18:08:29] ACK! [18:08:29] ATX READ (371) rots=262 [18:08:29] copy data track 20, sector 11 [18:08:29] ->SIO write 128 bytes [18:08:29] COMPLETE! [18:08:29] [18:08:29] CF: 31 52 74 01 f8 [18:08:29] disk sio_process() [18:08:29] ACK! [18:08:29] ATX READ (372) rots=262 [18:08:29] copy data track 20, sector 12 [18:08:29] ->SIO write 128 bytes [18:08:29] COMPLETE! [18:08:30] [18:08:30] CF: 31 52 75 01 f9 [18:08:30] disk sio_process() [18:08:30] ACK! [18:08:30] ATX READ (373) rots=264 [18:08:30] copy data track 20, sector 13 [18:08:30] ->SIO write 128 bytes [18:08:30] COMPLETE! [18:08:30] [18:08:30] CF: 31 52 76 01 fa [18:08:30] disk sio_process() [18:08:30] ACK! [18:08:30] ATX READ (374) rots=264 [18:08:30] copy data track 20, sector 14 [18:08:30] ->SIO write 128 bytes [18:08:30] COMPLETE! [18:08:30] [18:08:30] CF: 31 52 77 01 fb [18:08:30] disk sio_process() [18:08:30] ACK! [18:08:30] ATX READ (375) rots=266 [18:08:30] copy data track 20, sector 15 [18:08:30] ->SIO write 128 bytes [18:08:30] COMPLETE! [18:08:30] [18:08:30] CF: 31 52 78 01 fc [18:08:30] disk sio_process() [18:08:30] ACK! [18:08:30] ATX READ (376) rots=266 [18:08:30] copy data track 20, sector 16 [18:08:30] ->SIO write 128 bytes [18:08:30] COMPLETE! [18:08:30] [18:08:30] CF: 31 52 79 01 fd [18:08:30] disk sio_process() [18:08:30] ACK! [18:08:30] ATX READ (377) rots=268 [18:08:30] copy data track 20, sector 17 [18:08:30] ->SIO write 128 bytes [18:08:30] COMPLETE! [18:08:31] [18:08:31] CF: 31 52 7a 01 fe [18:08:31] disk sio_process() [18:08:31] ACK! [18:08:31] ATX READ (378) rots=269 [18:08:31] copy data track 20, sector 18 [18:08:31] ->SIO write 128 bytes [18:08:31] COMPLETE! [18:08:31] [18:08:31] CF: 31 52 7b 01 ff [18:08:31] disk sio_process() [18:08:31] ACK! [18:08:31] ATX READ (379) rots=269 [18:08:31] copy data track 21, sector 1 [18:08:31] ->SIO write 128 bytes [18:08:31] COMPLETE! [18:08:31] [18:08:31] CF: 31 52 7c 01 01 [18:08:31] disk sio_process() [18:08:31] ACK! [18:08:31] ATX READ (380) rots=270 [18:08:31] copy data track 21, sector 2 [18:08:31] ->SIO write 128 bytes [18:08:31] COMPLETE! [18:08:31] [18:08:31] CF: 31 52 7d 01 02 [18:08:31] disk sio_process() [18:08:31] ACK! [18:08:31] ATX READ (381) rots=272 [18:08:31] copy data track 21, sector 3 [18:08:31] ->SIO write 128 bytes [18:08:31] COMPLETE! [18:08:31] [18:08:31] CF: 31 52 7e 01 03 [18:08:31] disk sio_process() [18:08:31] ACK! [18:08:31] ATX READ (382) rots=272 [18:08:31] copy data track 21, sector 4 [18:08:31] ->SIO write 128 bytes [18:08:31] COMPLETE! [18:08:32] [18:08:32] CF: 31 52 7f 01 04 [18:08:32] disk sio_process() [18:08:32] ACK! [18:08:32] ATX READ (383) rots=274 [18:08:32] copy data track 21, sector 5 [18:08:32] ->SIO write 128 bytes [18:08:32] COMPLETE! [18:08:32] [18:08:32] CF: 31 52 80 01 05 [18:08:32] disk sio_process() [18:08:32] ACK! [18:08:32] ATX READ (384) rots=274 [18:08:32] copy data track 21, sector 6 [18:08:32] ->SIO write 128 bytes [18:08:32] COMPLETE! [18:08:32] [18:08:32] CF: 31 52 81 01 06 [18:08:32] disk sio_process() [18:08:32] ACK! [18:08:32] ATX READ (385) rots=276 [18:08:32] copy data track 21, sector 7 [18:08:32] ->SIO write 128 bytes [18:08:32] COMPLETE! [18:08:32] [18:08:32] CF: 31 52 82 01 07 [18:08:32] disk sio_process() [18:08:32] ACK! [18:08:32] ATX READ (386) rots=276 [18:08:32] copy data track 21, sector 8 [18:08:32] ->SIO write 128 bytes [18:08:32] COMPLETE! [18:08:32] [18:08:32] CF: 31 52 83 01 08 [18:08:32] disk sio_process() [18:08:32] ACK! [18:08:32] ATX READ (387) rots=278 [18:08:32] copy data track 21, sector 9 [18:08:32] ->SIO write 128 bytes [18:08:32] COMPLETE! [18:08:33] [18:08:33] CF: 31 52 84 01 09 [18:08:33] disk sio_process() [18:08:33] ACK! [18:08:33] ATX READ (388) rots=278 [18:08:33] copy data track 21, sector 10 [18:08:33] ->SIO write 128 bytes [18:08:33] COMPLETE! [18:08:33] [18:08:33] CF: 31 52 85 01 0a [18:08:33] disk sio_process() [18:08:33] ACK! [18:08:33] ATX READ (389) rots=280 [18:08:33] copy data track 21, sector 11 [18:08:33] ->SIO write 128 bytes [18:08:33] COMPLETE! [18:08:33] [18:08:33] CF: 31 52 86 01 0b [18:08:33] disk sio_process() [18:08:33] ACK! [18:08:33] ATX READ (390) rots=280 [18:08:33] copy data track 21, sector 12 [18:08:33] ->SIO write 128 bytes [18:08:33] COMPLETE! [18:08:33] [18:08:33] CF: 31 52 87 01 0c [18:08:33] disk sio_process() [18:08:33] ACK! [18:08:33] ATX READ (391) rots=282 [18:08:33] copy data track 21, sector 13 [18:08:33] ->SIO write 128 bytes [18:08:33] COMPLETE! [18:08:33] [18:08:33] CF: 31 52 88 01 0d [18:08:33] disk sio_process() [18:08:33] ACK! [18:08:33] ATX READ (392) rots=282 [18:08:33] copy data track 21, sector 14 [18:08:34] ->SIO write 128 bytes [18:08:34] COMPLETE! [18:08:34] [18:08:34] CF: 31 52 89 01 0e [18:08:34] disk sio_process() [18:08:34] ACK! [18:08:34] ATX READ (393) rots=284 [18:08:34] copy data track 21, sector 15 [18:08:34] ->SIO write 128 bytes [18:08:34] COMPLETE! [18:08:34] [18:08:34] CF: 31 52 8a 01 0f [18:08:34] disk sio_process() [18:08:34] ACK! [18:08:34] ATX READ (394) rots=284 [18:08:34] copy data track 21, sector 16 [18:08:34] ->SIO write 128 bytes [18:08:34] COMPLETE! [18:08:34] [18:08:34] CF: 31 52 8b 01 10 [18:08:34] disk sio_process() [18:08:34] ACK! [18:08:34] ATX READ (395) rots=286 [18:08:34] copy data track 21, sector 17 [18:08:34] ->SIO write 128 bytes [18:08:34] COMPLETE! [18:08:34] [18:08:34] CF: 31 52 8c 01 11 [18:08:34] disk sio_process() [18:08:34] ACK! [18:08:34] ATX READ (396) rots=287 [18:08:34] copy data track 21, sector 18 [18:08:34] ->SIO write 128 bytes [18:08:34] COMPLETE! [18:08:34] [18:08:34] CF: 31 52 8d 01 12 [18:08:34] disk sio_process() [18:08:34] ACK! [18:08:34] ATX READ (397) rots=287 [18:08:34] copy data track 22, sector 1 [18:08:35] ->SIO write 128 bytes [18:08:35] COMPLETE! [18:08:35] [18:08:35] CF: 31 52 8e 01 13 [18:08:35] disk sio_process() [18:08:35] ACK! [18:08:35] ATX READ (398) rots=288 [18:08:35] copy data track 22, sector 2 [18:08:35] ->SIO write 128 bytes [18:08:35] COMPLETE! [18:08:35] [18:08:35] CF: 31 52 8f 01 14 [18:08:35] disk sio_process() [18:08:35] ACK! [18:08:35] ATX READ (399) rots=290 [18:08:35] copy data track 22, sector 3 [18:08:35] ->SIO write 128 bytes [18:08:35] COMPLETE! [18:08:35] [18:08:35] CF: 31 52 90 01 15 [18:08:35] disk sio_process() [18:08:35] ACK! [18:08:35] ATX READ (400) rots=290 [18:08:35] copy data track 22, sector 4 [18:08:35] ->SIO write 128 bytes [18:08:35] COMPLETE! [18:08:35] [18:08:35] CF: 31 52 91 01 16 [18:08:35] disk sio_process() [18:08:35] ACK! [18:08:35] ATX READ (401) rots=292 [18:08:35] copy data track 22, sector 5 [18:08:35] ->SIO write 128 bytes [18:08:35] COMPLETE! [18:08:35] [18:08:35] CF: 31 52 92 01 17 [18:08:35] disk sio_process() [18:08:35] ACK! [18:08:35] ATX READ (402) rots=292 [18:08:35] copy data track 22, sector 6 [18:08:36] ->SIO write 128 bytes [18:08:36] COMPLETE! [18:08:36] [18:08:36] CF: 31 52 93 01 18 [18:08:36] disk sio_process() [18:08:36] ACK! [18:08:36] ATX READ (403) rots=294 [18:08:36] copy data track 22, sector 7 [18:08:36] ->SIO write 128 bytes [18:08:36] COMPLETE! [18:08:36] [18:08:36] CF: 31 52 94 01 19 [18:08:36] disk sio_process() [18:08:36] ACK! [18:08:36] ATX READ (404) rots=294 [18:08:36] copy data track 22, sector 8 [18:08:36] ->SIO write 128 bytes [18:08:36] COMPLETE! [18:08:36] [18:08:36] CF: 31 52 95 01 1a [18:08:36] disk sio_process() [18:08:36] ACK! [18:08:36] ATX READ (405) rots=296 [18:08:36] copy data track 22, sector 9 [18:08:36] ->SIO write 128 bytes [18:08:36] COMPLETE! [18:08:36] [18:08:36] CF: 31 52 96 01 1b [18:08:36] disk sio_process() [18:08:36] ACK! [18:08:36] ATX READ (406) rots=296 [18:08:36] copy data track 22, sector 10 [18:08:37] ->SIO write 128 bytes [18:08:37] COMPLETE! [18:08:37] [18:08:37] CF: 31 52 97 01 1c [18:08:37] disk sio_process() [18:08:37] ACK! [18:08:37] ATX READ (407) rots=298 [18:08:37] copy data track 22, sector 11 [18:08:37] ->SIO write 128 bytes [18:08:37] COMPLETE! [18:08:37] [18:08:37] CF: 31 52 98 01 1d [18:08:37] disk sio_process() [18:08:37] ACK! [18:08:37] ATX READ (408) rots=298 [18:08:37] copy data track 22, sector 12 [18:08:37] ->SIO write 128 bytes [18:08:37] COMPLETE! [18:08:37] [18:08:37] CF: 31 52 99 01 1e [18:08:37] disk sio_process() [18:08:37] ACK! [18:08:37] ATX READ (409) rots=300 [18:08:37] copy data track 22, sector 13 [18:08:37] ->SIO write 128 bytes [18:08:37] COMPLETE! [18:08:37] [18:08:37] CF: 31 52 9a 01 1f [18:08:37] disk sio_process() [18:08:37] ACK! [18:08:37] ATX READ (410) rots=300 [18:08:37] copy data track 22, sector 14 [18:08:37] ->SIO write 128 bytes [18:08:37] COMPLETE! [18:08:37] [18:08:37] CF: 31 52 9b 01 20 [18:08:37] disk sio_process() [18:08:37] ACK! [18:08:37] ATX READ (411) rots=302 [18:08:37] copy data track 22, sector 15 [18:08:37] ->SIO write 128 bytes [18:08:37] COMPLETE! [18:08:38] [18:08:38] CF: 31 52 9c 01 21 [18:08:38] disk sio_process() [18:08:38] ACK! [18:08:38] ATX READ (412) rots=302 [18:08:38] copy data track 22, sector 16 [18:08:38] ->SIO write 128 bytes [18:08:38] COMPLETE! [18:08:38] [18:08:38] CF: 31 52 9d 01 22 [18:08:38] disk sio_process() [18:08:38] ACK! [18:08:38] ATX READ (413) rots=304 [18:08:38] copy data track 22, sector 17 [18:08:38] ->SIO write 128 bytes [18:08:38] COMPLETE! [18:08:38] [18:08:38] CF: 31 52 9e 01 23 [18:08:38] disk sio_process() [18:08:38] ACK! [18:08:38] ATX READ (414) rots=305 [18:08:38] copy data track 22, sector 18 [18:08:38] ->SIO write 128 bytes [18:08:38] COMPLETE! [18:08:38] [18:08:38] CF: 31 52 9f 01 24 [18:08:38] disk sio_process() [18:08:38] ACK! [18:08:38] ATX READ (415) rots=305 [18:08:38] copy data track 23, sector 1 [18:08:38] ->SIO write 128 bytes [18:08:38] COMPLETE! [18:08:38] [18:08:38] CF: 31 52 a0 01 25 [18:08:38] disk sio_process() [18:08:38] ACK! [18:08:38] ATX READ (416) rots=306 [18:08:38] copy data track 23, sector 2 [18:08:39] ->SIO write 128 bytes [18:08:39] COMPLETE! [18:08:39] [18:08:39] CF: 31 52 a1 01 26 [18:08:39] disk sio_process() [18:08:39] ACK! [18:08:39] ATX READ (417) rots=308 [18:08:39] copy data track 23, sector 3 [18:08:39] ->SIO write 128 bytes [18:08:39] COMPLETE! [18:08:39] [18:08:39] CF: 31 52 a2 01 27 [18:08:39] disk sio_process() [18:08:39] ACK! [18:08:39] ATX READ (418) rots=308 [18:08:39] copy data track 23, sector 4 [18:08:39] ->SIO write 128 bytes [18:08:39] COMPLETE! [18:08:39] [18:08:39] CF: 31 52 a3 01 28 [18:08:39] disk sio_process() [18:08:39] ACK! [18:08:39] ATX READ (419) rots=310 [18:08:39] copy data track 23, sector 5 [18:08:39] ->SIO write 128 bytes [18:08:39] COMPLETE! [18:08:39] [18:08:39] CF: 31 52 a4 01 29 [18:08:39] disk sio_process() [18:08:39] ACK! [18:08:39] ATX READ (420) rots=310 [18:08:39] copy data track 23, sector 6 [18:08:39] ->SIO write 128 bytes [18:08:39] COMPLETE! [18:08:40] [18:08:40] CF: 31 52 a5 01 2a [18:08:40] disk sio_process() [18:08:40] ACK! [18:08:40] ATX READ (421) rots=312 [18:08:40] copy data track 23, sector 7 [18:08:40] ->SIO write 128 bytes [18:08:40] COMPLETE! [18:08:40] [18:08:40] CF: 31 52 a6 01 2b [18:08:40] disk sio_process() [18:08:40] ACK! [18:08:40] ATX READ (422) rots=312 [18:08:40] copy data track 23, sector 8 [18:08:40] ->SIO write 128 bytes [18:08:40] COMPLETE! [18:08:40] [18:08:40] CF: 31 52 a7 01 2c [18:08:40] disk sio_process() [18:08:40] ACK! [18:08:40] ATX READ (423) rots=314 [18:08:40] copy data track 23, sector 9 [18:08:40] ->SIO write 128 bytes [18:08:40] COMPLETE! [18:08:40] [18:08:40] CF: 31 52 a8 01 2d [18:08:40] disk sio_process() [18:08:40] ACK! [18:08:40] ATX READ (424) rots=314 [18:08:40] copy data track 23, sector 10 [18:08:40] ->SIO write 128 bytes [18:08:40] COMPLETE! [18:08:40] [18:08:40] CF: 31 52 a9 01 2e [18:08:40] disk sio_process() [18:08:40] ACK! [18:08:40] ATX READ (425) rots=316 [18:08:40] copy data track 23, sector 11 [18:08:40] ->SIO write 128 bytes [18:08:40] COMPLETE! [18:08:40] [18:08:40] CF: 31 52 aa 01 2f [18:08:40] disk sio_process() [18:08:40] ACK! [18:08:40] ATX READ (426) rots=316 [18:08:40] copy data track 23, sector 12 [18:08:41] ->SIO write 128 bytes [18:08:41] COMPLETE! [18:08:41] [18:08:41] CF: 31 52 ab 01 30 [18:08:41] disk sio_process() [18:08:41] ACK! [18:08:41] ATX READ (427) rots=318 [18:08:41] copy data track 23, sector 13 [18:08:41] ->SIO write 128 bytes [18:08:41] COMPLETE! [18:08:41] [18:08:41] CF: 31 52 ac 01 31 [18:08:41] disk sio_process() [18:08:41] ACK! [18:08:41] ATX READ (428) rots=318 [18:08:41] copy data track 23, sector 14 [18:08:41] ->SIO write 128 bytes [18:08:41] COMPLETE! [18:08:41] [18:08:41] CF: 31 52 ad 01 32 [18:08:41] disk sio_process() [18:08:41] ACK! [18:08:41] ATX READ (429) rots=320 [18:08:41] copy data track 23, sector 15 [18:08:41] ->SIO write 128 bytes [18:08:41] COMPLETE! [18:08:41] [18:08:41] CF: 31 52 ae 01 33 [18:08:41] disk sio_process() [18:08:41] ACK! [18:08:41] ATX READ (430) rots=320 [18:08:41] copy data track 23, sector 16 [18:08:42] ->SIO write 128 bytes [18:08:42] COMPLETE! [18:08:42] [18:08:42] CF: 31 52 af 01 34 [18:08:42] disk sio_process() [18:08:42] ACK! [18:08:42] ATX READ (431) rots=322 [18:08:42] copy data track 23, sector 17 [18:08:42] ->SIO write 128 bytes [18:08:42] COMPLETE! [18:08:42] [18:08:42] CF: 31 52 b0 01 35 [18:08:42] disk sio_process() [18:08:42] ACK! [18:08:42] ATX READ (432) rots=323 [18:08:42] copy data track 23, sector 18 [18:08:42] ->SIO write 128 bytes [18:08:42] COMPLETE! [18:08:42] [18:08:42] CF: 31 52 b1 01 36 [18:08:42] disk sio_process() [18:08:42] ACK! [18:08:42] ATX READ (433) rots=323 [18:08:42] copy data track 24, sector 1 [18:08:42] ->SIO write 128 bytes [18:08:42] COMPLETE! [18:08:42] [18:08:42] CF: 31 52 b2 01 37 [18:08:42] disk sio_process() [18:08:42] ACK! [18:08:42] ATX READ (434) rots=324 [18:08:42] copy data track 24, sector 2 [18:08:42] ->SIO write 128 bytes [18:08:42] COMPLETE! [18:08:42] [18:08:42] CF: 31 52 b3 01 38 [18:08:42] disk sio_process() [18:08:42] ACK! [18:08:42] ATX READ (435) rots=326 [18:08:42] copy data track 24, sector 3 [18:08:42] ->SIO write 128 bytes [18:08:42] COMPLETE! [18:08:43] [18:08:43] CF: 31 52 b4 01 39 [18:08:43] disk sio_process() [18:08:43] ACK! [18:08:43] ATX READ (436) rots=326 [18:08:43] copy data track 24, sector 4 [18:08:43] ->SIO write 128 bytes [18:08:43] COMPLETE! [18:08:43] [18:08:43] CF: 31 52 b5 01 3a [18:08:43] disk sio_process() [18:08:43] ACK! [18:08:43] ATX READ (437) rots=328 [18:08:43] copy data track 24, sector 5 [18:08:43] ->SIO write 128 bytes [18:08:43] COMPLETE! [18:08:43] [18:08:43] CF: 31 52 b6 01 3b [18:08:43] disk sio_process() [18:08:43] ACK! [18:08:43] ATX READ (438) rots=328 [18:08:43] copy data track 24, sector 6 [18:08:43] ->SIO write 128 bytes [18:08:43] COMPLETE! [18:08:43] [18:08:43] CF: 31 52 b7 01 3c [18:08:43] disk sio_process() [18:08:43] ACK! [18:08:43] ATX READ (439) rots=330 [18:08:43] copy data track 24, sector 7 [18:08:43] ->SIO write 128 bytes [18:08:43] COMPLETE! [18:08:43] [18:08:43] CF: 31 52 b8 01 3d [18:08:43] disk sio_process() [18:08:43] ACK! [18:08:43] ATX READ (440) rots=330 [18:08:43] copy data track 24, sector 8 [18:08:44] ->SIO write 128 bytes [18:08:44] COMPLETE! [18:08:44] [18:08:44] CF: 31 52 b9 01 3e [18:08:44] disk sio_process() [18:08:44] ACK! [18:08:44] ATX READ (441) rots=332 [18:08:44] copy data track 24, sector 9 [18:08:44] ->SIO write 128 bytes [18:08:44] COMPLETE! [18:08:44] [18:08:44] CF: 31 52 ba 01 3f [18:08:44] disk sio_process() [18:08:44] ACK! [18:08:44] ATX READ (442) rots=332 [18:08:44] copy data track 24, sector 10 [18:08:44] ->SIO write 128 bytes [18:08:44] COMPLETE! [18:08:44] [18:08:44] CF: 31 52 bb 01 40 [18:08:44] disk sio_process() [18:08:44] ACK! [18:08:44] ATX READ (443) rots=334 [18:08:44] copy data track 24, sector 11 [18:08:44] ->SIO write 128 bytes [18:08:44] COMPLETE! [18:08:44] [18:08:44] CF: 31 52 bc 01 41 [18:08:44] disk sio_process() [18:08:44] ACK! [18:08:44] ATX READ (444) rots=334 [18:08:44] copy data track 24, sector 12 [18:08:44] ->SIO write 128 bytes [18:08:44] COMPLETE! [18:08:45] [18:08:45] CF: 31 52 bd 01 42 [18:08:45] disk sio_process() [18:08:45] ACK! [18:08:45] ATX READ (445) rots=336 [18:08:45] copy data track 24, sector 13 [18:08:45] ->SIO write 128 bytes [18:08:45] COMPLETE! [18:08:45] [18:08:45] CF: 31 52 be 01 43 [18:08:45] disk sio_process() [18:08:45] ACK! [18:08:45] ATX READ (446) rots=336 [18:08:45] copy data track 24, sector 14 [18:08:45] ->SIO write 128 bytes [18:08:45] COMPLETE! [18:08:45] [18:08:45] CF: 31 52 bf 01 44 [18:08:45] disk sio_process() [18:08:45] ACK! [18:08:45] ATX READ (447) rots=338 [18:08:45] copy data track 24, sector 15 [18:08:45] ->SIO write 128 bytes [18:08:45] COMPLETE! [18:08:45] [18:08:45] CF: 31 52 c0 01 45 [18:08:45] disk sio_process() [18:08:45] ACK! [18:08:45] ATX READ (448) rots=338 [18:08:45] copy data track 24, sector 16 [18:08:45] ->SIO write 128 bytes [18:08:45] COMPLETE! [18:08:45] [18:08:45] CF: 31 52 c1 01 46 [18:08:45] disk sio_process() [18:08:45] ACK! [18:08:45] ATX READ (449) rots=340 [18:08:45] copy data track 24, sector 17 [18:08:45] ->SIO write 128 bytes [18:08:45] COMPLETE! [18:08:46] [18:08:46] CF: 31 52 c2 01 47 [18:08:46] disk sio_process() [18:08:46] ACK! [18:08:46] ATX READ (450) rots=341 [18:08:46] copy data track 24, sector 18 [18:08:46] ->SIO write 128 bytes [18:08:46] COMPLETE! [18:08:46] [18:08:46] CF: 31 52 c3 01 48 [18:08:46] disk sio_process() [18:08:46] ACK! [18:08:46] ATX READ (451) rots=341 [18:08:46] copy data track 25, sector 1 [18:08:46] ->SIO write 128 bytes [18:08:46] COMPLETE! [18:08:46] [18:08:46] CF: 31 52 c4 01 49 [18:08:46] disk sio_process() [18:08:46] ACK! [18:08:46] ATX READ (452) rots=342 [18:08:46] copy data track 25, sector 2 [18:08:46] ->SIO write 128 bytes [18:08:46] COMPLETE! [18:08:46] [18:08:46] CF: 31 52 c5 01 4a [18:08:46] disk sio_process() [18:08:46] ACK! [18:08:46] ATX READ (453) rots=344 [18:08:46] copy data track 25, sector 3 [18:08:46] ->SIO write 128 bytes [18:08:46] COMPLETE! [18:08:46] [18:08:46] CF: 31 52 c6 01 4b [18:08:46] disk sio_process() [18:08:46] ACK! [18:08:46] ATX READ (454) rots=344 [18:08:46] copy data track 25, sector 4 [18:08:46] ->SIO write 128 bytes [18:08:46] COMPLETE! [18:08:47] [18:08:47] CF: 31 52 c7 01 4c [18:08:47] disk sio_process() [18:08:47] ACK! [18:08:47] ATX READ (455) rots=346 [18:08:47] copy data track 25, sector 5 [18:08:47] ->SIO write 128 bytes [18:08:47] COMPLETE! [18:08:47] [18:08:47] CF: 31 52 c8 01 4d [18:08:47] disk sio_process() [18:08:47] ACK! [18:08:47] ATX READ (456) rots=346 [18:08:47] copy data track 25, sector 6 [18:08:47] ->SIO write 128 bytes [18:08:47] COMPLETE! [18:08:47] [18:08:47] CF: 31 52 cd 01 52 [18:08:47] disk sio_process() [18:08:47] ACK! [18:08:47] ATX READ (461) rots=348 [18:08:47] copy data track 25, sector 11 [18:08:47] ->SIO write 128 bytes [18:08:47] COMPLETE! [18:08:47] [18:08:47] CF: 31 52 ce 01 53 [18:08:47] disk sio_process() [18:08:47] ACK! [18:08:47] ATX READ (462) rots=348 [18:08:47] copy data track 25, sector 12 [18:08:47] ->SIO write 128 bytes [18:08:47] COMPLETE! [18:08:47] [18:08:47] CF: 31 52 cf 01 54 [18:08:47] disk sio_process() [18:08:47] ACK! [18:08:47] ATX READ (463) rots=350 [18:08:47] copy data track 25, sector 13 [18:08:47] ->SIO write 128 bytes [18:08:47] COMPLETE! [18:08:48] [18:08:48] CF: 31 52 d0 01 55 [18:08:48] disk sio_process() [18:08:48] ACK! [18:08:48] ATX READ (464) rots=350 [18:08:48] copy data track 25, sector 14 [18:08:48] ->SIO write 128 bytes [18:08:48] COMPLETE! [18:08:48] [18:08:48] CF: 31 52 d0 02 56 [18:08:48] disk sio_process() [18:08:48] ACK! [18:08:48] ATX READ (720) rots=352 [18:08:48] copy data track 39, sector 18 [18:08:48] ## Did not find sector with matching number [18:08:48] ## Did not find sector with matching number [18:08:48] ## Did not find sector with matching number [18:08:48] ## Did not find sector with matching number [18:08:48] ->SIO write 128 bytes [18:08:48] ERROR! [18:08:49] [18:08:49] CF: 31 52 d0 02 56 [18:08:49] disk sio_process() [18:08:49] ACK! [18:08:49] ATX READ (720) rots=355 [18:08:49] copy data track 39, sector 18 [18:08:49] ## Did not find sector with matching number [18:08:49] ## Did not find sector with matching number [18:08:49] ## Did not find sector with matching number [18:08:49] ## Did not find sector with matching number [18:08:49] ->SIO write 128 bytes [18:08:49] ERROR! [18:08:49] [18:08:49] CF: 31 52 d0 02 56 [18:08:49] disk sio_process() [18:08:49] ACK! [18:08:49] ATX READ (720) rots=358 [18:08:49] copy data track 39, sector 18 [18:08:49] ## Did not find sector with matching number [18:08:49] ## Did not find sector with matching number [18:08:50] ## Did not find sector with matching number [18:08:50] ## Did not find sector with matching number [18:08:50] ->SIO write 128 bytes [18:08:50] ERROR! [18:08:50] [18:08:50] CF: 31 52 d0 02 56 [18:08:50] disk sio_process() [18:08:50] ACK! [18:08:50] ATX READ (720) rots=362 [18:08:50] copy data track 39, sector 18 [18:08:50] ## Did not find sector with matching number [18:08:50] ## Did not find sector with matching number [18:08:50] ## Did not find sector with matching number [18:08:51] ## Did not find sector with matching number [18:08:51] ->SIO write 128 bytes [18:08:51] ERROR! 08:51] ->SIO write 128 bytes [18:08:51] ERROR! Edited February 20 by darwinmac Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 20 Share Posted February 20 This tells me right here that the ESP32 ran out of low memory to mount the ATX file from the SD. [18:07:35] E (38060) diskio_sdmmc: sdmmc_read_blocks failed (257) Ok, looks like this will need some more investigation. Do you have anything else mounted into the other device slots? if so, are they also mounted from SD? -Thom Quote Link to comment Share on other sites More sharing options...
darwinmac Posted February 20 Author Share Posted February 20 No, for this test, I only had the Micro League Baseball ATX file loaded in slot 1. Bob C Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 20 Share Posted February 20 ok, this one is going to be a challenge to track down... we have to VERY carefully balance low memory (the first 320k of RAM) usage. -Thom Quote Link to comment Share on other sites More sharing options...
darwinmac Posted February 20 Author Share Posted February 20 I am also attaching the debug log of the situation where I have the Atari Translator disk in Slot 1 and the Bible Baseball ATX file in Slot 2. When I do this, I get an immediate BOOT ERROR. If I eject the Bible Baseball ATX from Slot 2, the Translator disk boots normally. I deleted a bunch of text at the bottom of the debug log because the exact same error appeared over and over again. As I mentioned previously, this exact situation works if the Translator and Bible Baseball are loaded from my TNFS server. Very strange. I'm going to try loading the Translator locally (from SD) and the Bible Baseball ATX from TNFS to see if that works. Bob C Spoiler Using '/dev/cu.usbserial-110' as serial port. Using '460800' as baud rate. Showing logs: [18:25:28] BUTTON_C: SHORT PRESS [18:25:28] ACTION: Reboot [18:25:28] Shutting down device 5a [18:25:28] Shutting down device 43 [18:25:28] Shutting down device 50 [18:25:28] Shutting down device 40 [18:25:28] Shutting down device 99 [18:25:28] Shutting down device 45 [18:25:28] Shutting down device 70 [18:25:28] disk UNMOUNT [18:25:28] disk UNMOUNT [18:25:28] disk UNMOUNT [18:25:28] disk UNMOUNT [18:25:28] disk UNMOUNT [18:25:28] disk UNMOUNT [18:25:28] disk UNMOUNT [18:25:28] disk UNMOUNT [18:25:28] Shutting down device 5f [18:25:28] Shutting down device 78 [18:25:28] Shutting down device 77 [18:25:28] Shutting down device 76 [18:25:28] Shutting down device 75 [18:25:28] Shutting down device 74 [18:25:28] Shutting down device 73 [18:25:28] Shutting down device 72 [18:25:28] Shutting down device 71 [18:25:28] Shutting down device 38 [18:25:28] Shutting down device 37 [18:25:28] Shutting down device 36 [18:25:28] Shutting down device 35 [18:25:28] Shutting down device 34 [18:25:28] Shutting down device 33 [18:25:28] Shutting down device 32 [18:25:28] Shutting down device 31 [18:25:28] All devices shut down. [18:25:28] WIFI_EVENT_STA_DISCONNECTED [18:25:28] Stopping web service [18:25:28] Shutdown handler called [18:25:28] Shutting down device 5a [18:25:28] Shutting down device 43 [18:25:28] Shutting down device 50 [18:25:28] Shutting down device 40 [18:25:28] Shutting down device 99 [18:25:28] Shutting down device 45 [18:25:28] Shutting down device 70 [18:25:28] disk UNMOUNT [18:25:28] disk UNMOUNT [18:25:28] disk UNMOUNT [18:25:28] disk UNMOUNT [18:25:28] disk UNMOUNT [18:25:28] disk UNMOUNT [18:25:28] disk UNMOUNT [18:25:28] disk UNMOUNT [18:25:28] Shutting down device 5f [18:25:28] Shutting down device 78 [18:25:28] Shutting down device 77 [18:25:28] Shutting down device 76 [18:25:28] Shutting down device 75 [18:25:28] Shutting down device 74 [18:25:28] Shutting down device 73 [18:25:28] Shutting down device 72 [18:25:28] Shutting down device 71 [18:25:28] Shutting down device 38 [18:25:28] Shutting down device 37 [18:25:28] Shutting down device 36 [18:25:28] Shutting down device 35 [18:25:28] Shutting down device 34 [18:25:28] Shutting down device 33 [18:25:28] Shutting down device 32 [18:25:28] Shutting down device 31 [18:25:28] All devices shut down. [18:25:29] [18:25:29] [18:25:29] --~--~--~-- [18:25:29] FujiNet 0.5.13741956 2023-01-30 22:44:10 Started @ 5 [18:25:29] Starting heap: 4365075 [18:25:29] Detected Hardware Version: 1.6.1 and up [18:25:29] Safe Reset Button 😄 ENABLED [18:25:29] SPIFFS mounted. [18:25:29] SD mounted. [18:25:29] fnConfig::load [18:25:29] Load fnconfig.ini from SD [18:25:29] fopen = /fnconfig.ini : ok [18:25:29] fnConfig::load read 1176 bytes from config file [18:25:29] SPIFFS Config Storage: Enabled [18:25:29] fnConfig::load read 1176 bytes from SPIFFS config file [18:25:29] disk UNMOUNT [18:25:29] disk MOUNT [18:25:29] ATR MOUNT [18:25:29] mounted ATR: paragraphs=5760, sect_size=128, sect_count=720, disk_size=0 [18:25:29] Creating a default printer using FS_SDFAT storage and type 12 [18:25:29] ModemSniffer::ModemSniffer(FS_SDFAT) [18:25:29] SIO SETUP [18:25:29] Set HSIO baud from 0 to 67431 (index 6), alt=68209 [18:25:29] Available heap: 4272075 [18:25:29] Setup complete @ 668 (663ms) [18:25:29] WiFiManager::start() complete [18:25:29] WIFI_EVENT_STA_START [18:25:29] WiFi connect attempt to SSID "Paris2015" [18:25:29] esp_wifi_connect returned 0 [18:25:29] WIFI_EVENT_STA_CONNECTED [18:25:30] IP_EVENT_STA_GOT_IP [18:25:30] Obtained IP address: 192.168.7.249 [18:25:30] SNTP client start [18:25:30] Starting web server on port 80 [18:25:35] SNTP time sync event: Sun Feb 19, 18:25:35 2023 -0800 [18:25:48] [18:25:48] CF: 00 e0 e0 e0 e0 [18:25:48] CHECKSUM_ERROR [18:25:48] [18:25:48] CF: 00 e0 e0 e0 e0 [18:25:48] CHECKSUM_ERROR [18:25:48] Toggling baudrate from 19200 to 67431 [18:25:48] [18:25:48] CF: 00 38 38 00 00 [18:25:48] CHECKSUM_ERROR [18:25:48] [18:25:48] CF: 00 38 38 00 00 [18:25:48] CHECKSUM_ERROR [18:25:48] Toggling baudrate from 67431 to 19200 [18:25:48] [18:25:48] CF: 70 f5 00 00 66 [18:25:48] sioFuji::sio_process() called [18:25:48] ACK! [18:25:48] Fuji cmd: CLOSE DIRECTORY [18:25:48] COMPLETE! [18:25:48] [18:25:48] CF: 70 f9 00 00 6a [18:25:48] sioFuji::sio_process() called [18:25:48] ACK! [18:25:48] Fuji cmd: MOUNT HOST [18:25:48] ::mount {0} "SD" [18:25:48] ::mount_local Attempting mount of "SD" [18:25:48] Setting type to LOCAL [18:25:48] COMPLETE! [18:25:48] [18:25:48] CF: 70 f7 00 00 68 [18:25:48] sioFuji::sio_process() called [18:25:48] ACK! [18:25:48] Fuji cmd: OPEN DIRECTORY [18:25:48] <-SIO read 256 bytes [18:25:49] ACK! [18:25:49] Opening directory: "/", pattern: "" [18:25:49] ::dir_open {0:1} "/", pattern "" [18:25:49] ::dir_open actual path = "/" [18:25:49] COMPLETE! [18:25:49] [18:25:49] CF: 70 f6 24 00 8b [18:25:49] sioFuji::sio_process() called [18:25:49] ACK! [18:25:49] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:49] ::dir_nextfile {0:1} [18:25:49] ::read_direntry "0-9" [18:25:49] ->SIO write 36 bytes [18:25:49] COMPLETE! [18:25:49] [18:25:49] CF: 70 f6 24 00 8b [18:25:49] sioFuji::sio_process() called [18:25:49] ACK! [18:25:49] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:49] ::dir_nextfile {0:1} [18:25:49] ::read_direntry "A" [18:25:49] ->SIO write 36 bytes [18:25:49] COMPLETE! [18:25:49] [18:25:49] CF: 70 f6 24 00 8b [18:25:49] sioFuji::sio_process() called [18:25:49] ACK! [18:25:49] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:49] ::dir_nextfile {0:1} [18:25:49] ::read_direntry "B" [18:25:49] ->SIO write 36 bytes [18:25:49] COMPLETE! [18:25:49] [18:25:49] CF: 70 f6 24 00 8b [18:25:49] sioFuji::sio_process() called [18:25:49] ACK! [18:25:49] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:49] ::dir_nextfile {0:1} [18:25:49] ::read_direntry "C" [18:25:49] ->SIO write 36 bytes [18:25:49] COMPLETE! [18:25:49] [18:25:49] CF: 70 f6 24 00 8b [18:25:49] sioFuji::sio_process() called [18:25:49] ACK! [18:25:49] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:49] ::dir_nextfile {0:1} [18:25:49] ::read_direntry "D" [18:25:49] ->SIO write 36 bytes [18:25:49] COMPLETE! [18:25:49] [18:25:49] CF: 70 f6 24 00 8b [18:25:49] sioFuji::sio_process() called [18:25:49] ACK! [18:25:49] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:49] ::dir_nextfile {0:1} [18:25:49] ::read_direntry "E" [18:25:49] ->SIO write 36 bytes [18:25:49] COMPLETE! [18:25:49] [18:25:49] CF: 70 f6 24 00 8b [18:25:49] sioFuji::sio_process() called [18:25:49] ACK! [18:25:49] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:49] ::dir_nextfile {0:1} [18:25:49] ::read_direntry "F" [18:25:49] ->SIO write 36 bytes [18:25:49] COMPLETE! [18:25:49] [18:25:49] CF: 70 f6 24 00 8b [18:25:49] sioFuji::sio_process() called [18:25:49] ACK! [18:25:49] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:49] ::dir_nextfile {0:1} [18:25:49] ::read_direntry "FujiNet" [18:25:49] ->SIO write 36 bytes [18:25:49] COMPLETE! [18:25:49] [18:25:49] CF: 70 f6 24 00 8b [18:25:49] sioFuji::sio_process() called [18:25:49] ACK! [18:25:49] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:49] ::dir_nextfile {0:1} [18:25:49] ::read_direntry "G" [18:25:49] ->SIO write 36 bytes [18:25:49] COMPLETE! [18:25:49] [18:25:49] CF: 70 f6 24 00 8b [18:25:49] sioFuji::sio_process() called [18:25:49] ACK! [18:25:49] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:49] ::dir_nextfile {0:1} [18:25:49] ::read_direntry "H" [18:25:49] ->SIO write 36 bytes [18:25:49] COMPLETE! [18:25:49] [18:25:49] CF: 70 f6 24 00 8b [18:25:49] sioFuji::sio_process() called [18:25:49] ACK! [18:25:49] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:49] ::dir_nextfile {0:1} [18:25:49] ::read_direntry "I" [18:25:49] ->SIO write 36 bytes [18:25:49] COMPLETE! [18:25:49] [18:25:49] CF: 70 f6 24 00 8b [18:25:49] sioFuji::sio_process() called [18:25:49] ACK! [18:25:49] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:49] ::dir_nextfile {0:1} [18:25:49] ::read_direntry "J" [18:25:49] ->SIO write 36 bytes [18:25:49] COMPLETE! [18:25:49] [18:25:49] CF: 70 f6 24 00 8b [18:25:49] sioFuji::sio_process() called [18:25:49] ACK! [18:25:49] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:49] ::dir_nextfile {0:1} [18:25:49] ::read_direntry "K" [18:25:49] ->SIO write 36 bytes [18:25:49] COMPLETE! [18:25:49] [18:25:49] CF: 70 f6 24 00 8b [18:25:49] sioFuji::sio_process() called [18:25:49] ACK! [18:25:49] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:49] ::dir_nextfile {0:1} [18:25:49] ::read_direntry "L" [18:25:49] ->SIO write 36 bytes [18:25:49] COMPLETE! [18:25:49] [18:25:49] CF: 70 f5 00 00 66 [18:25:49] sioFuji::sio_process() called [18:25:49] ACK! [18:25:49] Fuji cmd: CLOSE DIRECTORY [18:25:49] COMPLETE! [18:25:51] [18:25:51] CF: 70 f7 00 00 68 [18:25:51] sioFuji::sio_process() called [18:25:51] ACK! [18:25:51] Fuji cmd: OPEN DIRECTORY [18:25:51] <-SIO read 256 bytes [18:25:51] ACK! [18:25:51] Opening directory: "/", pattern: "" [18:25:51] ::dir_open {0:1} "/", pattern "" [18:25:51] ::dir_open actual path = "/" [18:25:51] COMPLETE! [18:25:51] [18:25:51] CF: 70 e4 02 00 57 [18:25:51] sioFuji::sio_process() called [18:25:51] ACK! [18:25:51] Fuji cmd: SET DIRECTORY POSITION [18:25:51] ::dir_seek {0:1} 2 [18:25:51] COMPLETE! [18:25:51] [18:25:51] CF: 70 f6 80 00 e7 [18:25:51] sioFuji::sio_process() called [18:25:51] ACK! [18:25:51] Fuji cmd: READ DIRECTORY ENTRY (max=128) [18:25:51] ::dir_nextfile {0:1} [18:25:51] ::read_direntry "B" [18:25:51] ->SIO write 128 bytes [18:25:51] COMPLETE! [18:25:51] [18:25:51] CF: 70 f5 00 00 66 [18:25:51] sioFuji::sio_process() called [18:25:51] ACK! [18:25:51] Fuji cmd: CLOSE DIRECTORY [18:25:51] COMPLETE! [18:25:51] [18:25:51] CF: 70 f7 00 00 68 [18:25:51] sioFuji::sio_process() called [18:25:51] ACK! [18:25:51] Fuji cmd: OPEN DIRECTORY [18:25:51] <-SIO read 256 bytes [18:25:51] ACK! [18:25:51] Opening directory: "/", pattern: "" [18:25:51] ::dir_open {0:1} "/", pattern "" [18:25:51] ::dir_open actual path = "/" [18:25:51] COMPLETE! [18:25:51] [18:25:51] CF: 70 e4 02 00 57 [18:25:51] sioFuji::sio_process() called [18:25:51] ACK! [18:25:51] Fuji cmd: SET DIRECTORY POSITION [18:25:51] ::dir_seek {0:1} 2 [18:25:51] COMPLETE! [18:25:51] [18:25:51] CF: 70 f6 80 01 e8 [18:25:51] sioFuji::sio_process() called [18:25:51] ACK! [18:25:51] Fuji cmd: READ DIRECTORY ENTRY (max=128) [18:25:51] ::dir_nextfile {0:1} [18:25:51] ::read_direntry "B" [18:25:51] ->SIO write 128 bytes [18:25:51] COMPLETE! [18:25:51] [18:25:51] CF: 70 f5 00 00 66 [18:25:51] sioFuji::sio_process() called [18:25:51] ACK! [18:25:51] Fuji cmd: CLOSE DIRECTORY [18:25:51] COMPLETE! [18:25:51] [18:25:51] CF: 70 f9 00 00 6a [18:25:51] sioFuji::sio_process() called [18:25:51] ACK! [18:25:51] Fuji cmd: MOUNT HOST [18:25:51] ::mount {0} "SD" [18:25:51] ::mount_local Attempting mount of "SD" [18:25:51] Type is already LOCAL [18:25:51] COMPLETE! [18:25:51] [18:25:51] CF: 70 f7 00 00 68 [18:25:51] sioFuji::sio_process() called [18:25:51] ACK! [18:25:51] Fuji cmd: OPEN DIRECTORY [18:25:51] <-SIO read 256 bytes [18:25:52] ACK! [18:25:52] Opening directory: "/B", pattern: "" [18:25:52] ::dir_open {0:1} "/B", pattern "" [18:25:52] ::dir_open actual path = "/B" [18:25:52] COMPLETE! [18:25:52] [18:25:52] CF: 70 f6 24 00 8b [18:25:52] sioFuji::sio_process() called [18:25:52] ACK! [18:25:52] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:52] ::dir_nextfile {0:1} [18:25:52] ::read_direntry "Battle of Antietam v1.3 (1985)(SSI)(US)(Side A)(Scenario Disk).atx" [18:25:52] ->SIO write 36 bytes [18:25:52] COMPLETE! [18:25:52] [18:25:52] CF: 70 f6 24 00 8b [18:25:52] sioFuji::sio_process() called [18:25:52] ACK! [18:25:52] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:52] ::dir_nextfile {0:1} [18:25:52] ::read_direntry "Battle of Antietam v1.3 (1985)(SSI)(US)(Side B)(Game Disk).atx" [18:25:52] ->SIO write 36 bytes [18:25:52] COMPLETE! [18:25:52] [18:25:52] CF: 70 f6 24 00 8b [18:25:52] sioFuji::sio_process() called [18:25:52] ACK! [18:25:52] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:52] ::dir_nextfile {0:1} [18:25:52] ::read_direntry "BattleOfEris.ATR" [18:25:52] ->SIO write 36 bytes [18:25:52] COMPLETE! [18:25:52] [18:25:52] CF: 70 f6 24 00 8b [18:25:52] sioFuji::sio_process() called [18:25:52] ACK! [18:25:52] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:52] ::dir_nextfile {0:1} [18:25:52] ::read_direntry "BC's Quest for Tires (1983)(Sierra On-Line)(US)[m].atx" [18:25:52] ->SIO write 36 bytes [18:25:52] COMPLETE! [18:25:52] [18:25:52] CF: 70 f6 24 00 8b [18:25:52] sioFuji::sio_process() called [18:25:52] ACK! [18:25:52] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:52] ::dir_nextfile {0:1} [18:25:52] ::read_direntry "Berks Four.ATR" [18:25:52] ->SIO write 36 bytes [18:25:52] COMPLETE! [18:25:52] [18:25:52] CF: 70 f6 24 00 8b [18:25:52] sioFuji::sio_process() called [18:25:52] ACK! [18:25:52] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:52] ::dir_nextfile {0:1} [18:25:52] ::read_direntry "Bible Baseball (1983)(Davka Corporation)(US)[!][Trans][BASIC].atx" [18:25:52] ->SIO write 36 bytes [18:25:52] COMPLETE! [18:25:52] [18:25:52] CF: 70 f6 24 00 8b [18:25:52] sioFuji::sio_process() called [18:25:52] ACK! [18:25:52] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:52] ::dir_nextfile {0:1} [18:25:52] ::read_direntry "Bible Baseball (1983)(Davka Corporation)(US)[!][Trans][BASIC][cr CSS].atr" [18:25:52] ->SIO write 36 bytes [18:25:52] COMPLETE! [18:25:52] [18:25:52] CF: 70 f6 24 00 8b [18:25:52] sioFuji::sio_process() called [18:25:52] ACK! [18:25:52] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:52] ::dir_nextfile {0:1} [18:25:52] ::read_direntry "Bijets, The (non-original, not protected).atr" [18:25:52] ->SIO write 36 bytes [18:25:52] COMPLETE! [18:25:52] [18:25:52] CF: 70 f6 24 00 8b [18:25:52] sioFuji::sio_process() called [18:25:52] ACK! [18:25:52] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:52] ::dir_nextfile {0:1} [18:25:52] ::read_direntry "Binary Parasite r040.xex" [18:25:52] ->SIO write 36 bytes [18:25:52] COMPLETE! [18:25:52] [18:25:52] CF: 70 f6 24 00 8b [18:25:52] sioFuji::sio_process() called [18:25:52] ACK! [18:25:52] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:52] ::dir_nextfile {0:1} [18:25:52] ::read_direntry "Block On Legs v1.1.ATR" [18:25:52] ->SIO write 36 bytes [18:25:52] COMPLETE! [18:25:52] [18:25:52] CF: 70 f6 24 00 8b [18:25:52] sioFuji::sio_process() called [18:25:52] ACK! [18:25:52] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:52] ::dir_nextfile {0:1} [18:25:52] ::read_direntry "Bomber Jack (1991-03)(KE-Soft)(DE)(Side A).atr" [18:25:52] ->SIO write 36 bytes [18:25:52] COMPLETE! [18:25:52] [18:25:52] CF: 70 f6 24 00 8b [18:25:52] sioFuji::sio_process() called [18:25:52] ACK! [18:25:52] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:52] ::dir_nextfile {0:1} [18:25:52] ::read_direntry "Bomber Jack (1991-03)(KE-Soft)(DE)(Side B).atr" [18:25:52] ->SIO write 36 bytes [18:25:52] COMPLETE! [18:25:52] [18:25:52] CF: 70 f6 24 00 8b [18:25:52] sioFuji::sio_process() called [18:25:52] ACK! [18:25:52] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:52] ::dir_nextfile {0:1} [18:25:52] ::read_direntry "Bounty Hunter-[BAS].ATR" [18:25:52] ->SIO write 36 bytes [18:25:52] COMPLETE! [18:25:52] [18:25:52] CF: 70 f6 24 00 8b [18:25:52] sioFuji::sio_process() called [18:25:52] ACK! [18:25:52] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:52] ::dir_nextfile {0:1} [18:25:52] ::read_direntry "Bruce Lee Return of Fury-Tix graphics.atr" [18:25:52] ->SIO write 36 bytes [18:25:52] COMPLETE! [18:25:52] [18:25:52] CF: 70 f5 00 00 66 [18:25:52] sioFuji::sio_process() called [18:25:52] ACK! [18:25:52] Fuji cmd: CLOSE DIRECTORY [18:25:52] COMPLETE! [18:25:52] [18:25:52] CF: 70 f7 00 00 68 [18:25:52] sioFuji::sio_process() called [18:25:52] ACK! [18:25:52] Fuji cmd: OPEN DIRECTORY [18:25:52] <-SIO read 256 bytes [18:25:53] ACK! [18:25:53] Opening directory: "/B", pattern: "" [18:25:53] ::dir_open {0:1} "/B", pattern "" [18:25:53] ::dir_open actual path = "/B" [18:25:53] COMPLETE! [18:25:53] [18:25:53] CF: 70 e4 00 00 55 [18:25:53] sioFuji::sio_process() called [18:25:53] ACK! [18:25:53] Fuji cmd: SET DIRECTORY POSITION [18:25:53] ::dir_seek {0:1} 0 [18:25:53] COMPLETE! [18:25:53] [18:25:53] CF: 70 f6 40 00 a7 [18:25:53] sioFuji::sio_process() called [18:25:53] ACK! [18:25:53] Fuji cmd: READ DIRECTORY ENTRY (max=64) [18:25:53] ::dir_nextfile {0:1} [18:25:53] ::read_direntry "Battle of Antietam v1.3 (1985)(SSI)(US)(Side A)(Scenario Disk).atx" [18:25:53] ->SIO write 64 bytes [18:25:53] COMPLETE! [18:25:53] [18:25:53] CF: 70 f5 00 00 66 [18:25:53] sioFuji::sio_process() called [18:25:53] ACK! [18:25:53] Fuji cmd: CLOSE DIRECTORY [18:25:53] COMPLETE! [18:25:56] [18:25:56] CF: 70 f4 00 00 65 [18:25:56] sioFuji::sio_process() called [18:25:56] ACK! [18:25:56] Fuji cmd: READ HOST SLOTS [18:25:56] ->SIO write 256 bytes [18:25:56] COMPLETE! [18:25:56] [18:25:56] CF: 70 f2 00 00 63 [18:25:56] sioFuji::sio_process() called [18:25:56] ACK! [18:25:56] Fuji cmd: READ DEVICE SLOTS [18:25:56] ->SIO write 304 bytes [18:25:56] COMPLETE! [18:25:56] [18:25:56] CF: 70 f4 00 00 70 [18:25:56] CHECKSUM_ERROR [18:25:57] [18:25:57] CF: 70 f4 00 00 65 [18:25:57] sioFuji::sio_process() called [18:25:57] ACK! [18:25:57] Fuji cmd: READ HOST SLOTS [18:25:57] ->SIO write 256 bytes [18:25:57] COMPLETE! [18:25:57] [18:25:57] CF: 70 f2 00 00 63 [18:25:57] sioFuji::sio_process() called [18:25:57] ACK! [18:25:57] Fuji cmd: READ DEVICE SLOTS [18:25:57] ->SIO write 304 bytes [18:25:57] COMPLETE! [18:25:59] [18:25:59] CF: 70 f5 00 00 66 [18:25:59] sioFuji::sio_process() called [18:25:59] ACK! [18:25:59] Fuji cmd: CLOSE DIRECTORY [18:25:59] COMPLETE! [18:25:59] [18:25:59] CF: 70 f9 00 00 6a [18:25:59] sioFuji::sio_process() called [18:25:59] ACK! [18:25:59] Fuji cmd: MOUNT HOST [18:25:59] ::mount {0} "SD" [18:25:59] ::mount_local Attempting mount of "SD" [18:25:59] Type is already LOCAL [18:25:59] COMPLETE! [18:25:59] [18:25:59] CF: 70 f7 00 00 68 [18:25:59] sioFuji::sio_process() called [18:25:59] ACK! [18:25:59] Fuji cmd: OPEN DIRECTORY [18:25:59] <-SIO read 256 bytes [18:25:59] ACK! [18:25:59] Opening directory: "/", pattern: "" [18:25:59] ::dir_open {0:1} "/", pattern "" [18:25:59] ::dir_open actual path = "/" [18:25:59] COMPLETE! [18:25:59] [18:25:59] CF: 70 f6 24 00 8b [18:25:59] sioFuji::sio_process() called [18:25:59] ACK! [18:25:59] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:59] ::dir_nextfile {0:1} [18:25:59] ::read_direntry "0-9" [18:25:59] ->SIO write 36 bytes [18:25:59] COMPLETE! [18:25:59] [18:25:59] CF: 70 f6 24 00 8b [18:25:59] sioFuji::sio_process() called [18:25:59] ACK! [18:25:59] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:59] ::dir_nextfile {0:1} [18:25:59] ::read_direntry "A" [18:25:59] ->SIO write 36 bytes [18:25:59] COMPLETE! [18:25:59] [18:25:59] CF: 70 f6 24 00 8b [18:25:59] sioFuji::sio_process() called [18:25:59] ACK! [18:25:59] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:59] ::dir_nextfile {0:1} [18:25:59] ::read_direntry "B" [18:25:59] ->SIO write 36 bytes [18:25:59] COMPLETE! [18:25:59] [18:25:59] CF: 70 f6 24 00 8b [18:25:59] sioFuji::sio_process() called [18:25:59] ACK! [18:25:59] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:59] ::dir_nextfile {0:1} [18:25:59] ::read_direntry "C" [18:25:59] ->SIO write 36 bytes [18:25:59] COMPLETE! [18:25:59] [18:25:59] CF: 70 f6 24 00 8b [18:25:59] sioFuji::sio_process() called [18:25:59] ACK! [18:25:59] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:59] ::dir_nextfile {0:1} [18:25:59] ::read_direntry "D" [18:25:59] ->SIO write 36 bytes [18:25:59] COMPLETE! [18:25:59] [18:25:59] CF: 70 f6 24 00 8b [18:25:59] sioFuji::sio_process() called [18:25:59] ACK! [18:25:59] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:59] ::dir_nextfile {0:1} [18:25:59] ::read_direntry "E" [18:25:59] ->SIO write 36 bytes [18:25:59] COMPLETE! [18:25:59] [18:25:59] CF: 70 f6 24 00 8b [18:25:59] sioFuji::sio_process() called [18:25:59] ACK! [18:25:59] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:59] ::dir_nextfile {0:1} [18:25:59] ::read_direntry "F" [18:25:59] ->SIO write 36 bytes [18:25:59] COMPLETE! [18:25:59] [18:25:59] CF: 70 f6 24 00 8b [18:25:59] sioFuji::sio_process() called [18:25:59] ACK! [18:25:59] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:59] ::dir_nextfile {0:1} [18:25:59] ::read_direntry "FujiNet" [18:25:59] ->SIO write 36 bytes [18:25:59] COMPLETE! [18:25:59] [18:25:59] CF: 70 f6 24 00 8b [18:25:59] sioFuji::sio_process() called [18:25:59] ACK! [18:25:59] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:59] ::dir_nextfile {0:1} [18:25:59] ::read_direntry "G" [18:25:59] ->SIO write 36 bytes [18:25:59] COMPLETE! [18:25:59] [18:25:59] CF: 70 f6 24 00 8b [18:25:59] sioFuji::sio_process() called [18:25:59] ACK! [18:25:59] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:59] ::dir_nextfile {0:1} [18:25:59] ::read_direntry "H" [18:25:59] ->SIO write 36 bytes [18:25:59] COMPLETE! [18:25:59] [18:25:59] CF: 70 f6 24 00 8b [18:25:59] sioFuji::sio_process() called [18:25:59] ACK! [18:25:59] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:59] ::dir_nextfile {0:1} [18:25:59] ::read_direntry "I" [18:25:59] ->SIO write 36 bytes [18:25:59] COMPLETE! [18:25:59] [18:25:59] CF: 70 f6 24 00 8b [18:25:59] sioFuji::sio_process() called [18:25:59] ACK! [18:25:59] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:25:59] ::dir_nextfile {0:1} [18:25:59] ::read_direntry "J" [18:25:59] ->SIO write 36 bytes [18:25:59] COMPLETE! [18:26:00] [18:26:00] CF: 70 f6 24 00 8b [18:26:00] sioFuji::sio_process() called [18:26:00] ACK! [18:26:00] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:00] ::dir_nextfile {0:1} [18:26:00] ::read_direntry "K" [18:26:00] ->SIO write 36 bytes [18:26:00] COMPLETE! [18:26:00] [18:26:00] CF: 70 f6 24 00 8b [18:26:00] sioFuji::sio_process() called [18:26:00] ACK! [18:26:00] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:00] ::dir_nextfile {0:1} [18:26:00] ::read_direntry "L" [18:26:00] ->SIO write 36 bytes [18:26:00] COMPLETE! [18:26:00] [18:26:00] CF: 70 f5 00 00 66 [18:26:00] sioFuji::sio_process() called [18:26:00] ACK! [18:26:00] Fuji cmd: CLOSE DIRECTORY [18:26:00] COMPLETE! [18:26:04] [18:26:04] CF: 70 f9 00 00 6a [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:04] Fuji cmd: MOUNT HOST [18:26:04] ::mount {0} "SD" [18:26:04] ::mount_local Attempting mount of "SD" [18:26:04] Type is already LOCAL [18:26:04] COMPLETE! [18:26:04] [18:26:04] CF: 70 f7 00 00 68 [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:04] Fuji cmd: OPEN DIRECTORY [18:26:04] <-SIO read 256 bytes [18:26:04] ACK! [18:26:04] Opening directory: "/", pattern: "" [18:26:04] ::dir_open {0:1} "/", pattern "" [18:26:04] ::dir_open actual path = "/" [18:26:04] COMPLETE! [18:26:04] [18:26:04] CF: 70 e4 0d 00 62 [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:04] Fuji cmd: SET DIRECTORY POSITION [18:26:04] ::dir_seek {0:1} 13 [18:26:04] COMPLETE! [18:26:04] [18:26:04] CF: 70 f6 24 00 8b [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:04] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:04] ::dir_nextfile {0:1} [18:26:04] ::read_direntry "L" [18:26:04] ->SIO write 36 bytes [18:26:04] COMPLETE! [18:26:04] [18:26:04] CF: 70 f6 24 00 8b [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:04] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:04] ::dir_nextfile {0:1} [18:26:04] ::read_direntry "M" [18:26:04] ->SIO write 36 bytes [18:26:04] COMPLETE! [18:26:04] [18:26:04] CF: 70 f6 24 00 8b [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:04] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:04] ::dir_nextfile {0:1} [18:26:04] ::read_direntry "N" [18:26:04] ->SIO write 36 bytes [18:26:04] COMPLETE! [18:26:04] [18:26:04] CF: 70 f6 24 00 8b [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:04] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:04] ::dir_nextfile {0:1} [18:26:04] ::read_direntry "O" [18:26:04] ->SIO write 36 bytes [18:26:04] COMPLETE! [18:26:04] [18:26:04] CF: 70 f6 24 00 8b [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:04] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:04] ::dir_nextfile {0:1} [18:26:04] ::read_direntry "P" [18:26:04] ->SIO write 36 bytes [18:26:04] COMPLETE! [18:26:04] [18:26:04] CF: 70 f6 24 00 8b [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:04] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:04] ::dir_nextfile {0:1} [18:26:04] ::read_direntry "Q" [18:26:04] ->SIO write 36 bytes [18:26:04] COMPLETE! [18:26:04] [18:26:04] CF: 70 f6 24 00 8b [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:04] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:04] ::dir_nextfile {0:1} [18:26:04] ::read_direntry "R" [18:26:04] ->SIO write 36 bytes [18:26:04] COMPLETE! [18:26:04] [18:26:04] CF: 70 f6 24 00 8b [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:04] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:04] ::dir_nextfile {0:1} [18:26:04] ::read_direntry "S" [18:26:04] ->SIO write 36 bytes [18:26:04] COMPLETE! [18:26:04] [18:26:04] CF: 70 f6 24 00 8b [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:04] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:04] ::dir_nextfile {0:1} [18:26:04] ::read_direntry "T" [18:26:04] ->SIO write 36 bytes [18:26:04] COMPLETE! [18:26:04] [18:26:04] CF: 70 f6 24 00 8b [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:04] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:04] ::dir_nextfile {0:1} [18:26:04] ::read_direntry "U" [18:26:04] ->SIO write 36 bytes [18:26:04] COMPLETE! [18:26:04] [18:26:04] CF: 70 f6 24 00 8b [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:04] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:04] ::dir_nextfile {0:1} [18:26:04] ::read_direntry "W" [18:26:04] ->SIO write 36 bytes [18:26:04] COMPLETE! [18:26:04] [18:26:04] CF: 70 f6 24 00 8b [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:04] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:04] ::dir_nextfile {0:1} [18:26:04] ::read_direntry "Z" [18:26:04] ->SIO write 36 bytes [18:26:04] COMPLETE! [18:26:04] [18:26:04] CF: 70 f6 24 00 8b [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:04] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:04] ::dir_nextfile {0:1} [18:26:04] ::read_direntry "ZZdemos" [18:26:04] ->SIO write 36 bytes [18:26:04] COMPLETE! [18:26:04] [18:26:04] CF: 70 f6 24 00 8b [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:04] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:04] ::dir_nextfile {0:1} [18:26:04] ::read_direntry "weather.atr" [18:26:04] ->SIO write 36 bytes [18:26:04] COMPLETE! [18:26:04] [18:26:04] CF: 70 f5 00 00 66 [18:26:04] sioFuji::sio_process() called [18:26:04] ACK! [18:26:05] Fuji cmd: CLOSE DIRECTORY [18:26:05] COMPLETE! [18:26:07] [18:26:07] CF: 70 f7 00 00 68 [18:26:07] sioFuji::sio_process() called [18:26:07] ACK! [18:26:07] Fuji cmd: OPEN DIRECTORY [18:26:07] <-SIO read 256 bytes [18:26:07] ACK! [18:26:07] Opening directory: "/", pattern: "" [18:26:07] ::dir_open {0:1} "/", pattern "" [18:26:07] ::dir_open actual path = "/" [18:26:07] COMPLETE! [18:26:07] [18:26:07] CF: 70 e4 15 00 6a [18:26:07] sioFuji::sio_process() called [18:26:07] ACK! [18:26:07] Fuji cmd: SET DIRECTORY POSITION [18:26:07] ::dir_seek {0:1} 21 [18:26:07] COMPLETE! [18:26:07] [18:26:07] CF: 70 f6 80 00 e7 [18:26:07] sioFuji::sio_process() called [18:26:07] ACK! [18:26:07] Fuji cmd: READ DIRECTORY ENTRY (max=128) [18:26:07] ::dir_nextfile {0:1} [18:26:07] ::read_direntry "T" [18:26:07] ->SIO write 128 bytes [18:26:07] COMPLETE! [18:26:08] [18:26:08] CF: 70 f5 00 00 66 [18:26:08] sioFuji::sio_process() called [18:26:08] ACK! [18:26:08] Fuji cmd: CLOSE DIRECTORY [18:26:08] COMPLETE! [18:26:08] [18:26:08] CF: 70 f7 00 00 68 [18:26:08] sioFuji::sio_process() called [18:26:08] ACK! [18:26:08] Fuji cmd: OPEN DIRECTORY [18:26:08] <-SIO read 256 bytes [18:26:08] ACK! [18:26:08] Opening directory: "/", pattern: "" [18:26:08] ::dir_open {0:1} "/", pattern "" [18:26:08] ::dir_open actual path = "/" [18:26:08] COMPLETE! [18:26:08] [18:26:08] CF: 70 e4 15 00 6a [18:26:08] sioFuji::sio_process() called [18:26:08] ACK! [18:26:08] Fuji cmd: SET DIRECTORY POSITION [18:26:08] ::dir_seek {0:1} 21 [18:26:08] COMPLETE! [18:26:08] [18:26:08] CF: 70 f6 80 01 e8 [18:26:08] sioFuji::sio_process() called [18:26:08] ACK! [18:26:08] Fuji cmd: READ DIRECTORY ENTRY (max=128) [18:26:08] ::dir_nextfile {0:1} [18:26:08] ::read_direntry "T" [18:26:08] ->SIO write 128 bytes [18:26:08] COMPLETE! [18:26:08] [18:26:08] CF: 70 f5 00 00 66 [18:26:08] sioFuji::sio_process() called [18:26:08] ACK! [18:26:08] Fuji cmd: CLOSE DIRECTORY [18:26:08] COMPLETE! [18:26:08] [18:26:08] CF: 70 f9 00 00 6a [18:26:08] sioFuji::sio_process() called [18:26:08] ACK! [18:26:08] Fuji cmd: MOUNT HOST [18:26:08] ::mount {0} "SD" [18:26:08] ::mount_local Attempting mount of "SD" [18:26:08] Type is already LOCAL [18:26:08] COMPLETE! [18:26:08] [18:26:08] CF: 70 f7 00 00 68 [18:26:08] sioFuji::sio_process() called [18:26:08] ACK! [18:26:08] Fuji cmd: OPEN DIRECTORY [18:26:08] <-SIO read 256 bytes [18:26:08] ACK! [18:26:08] Opening directory: "/T", pattern: "" [18:26:08] ::dir_open {0:1} "/T", pattern "" [18:26:08] ::dir_open actual path = "/T" [18:26:08] COMPLETE! [18:26:08] [18:26:08] CF: 70 f6 24 00 8b [18:26:08] sioFuji::sio_process() called [18:26:08] ACK! [18:26:08] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:08] ::dir_nextfile {0:1} [18:26:08] ::read_direntry "Tagalon.ATR" [18:26:08] ->SIO write 36 bytes [18:26:08] COMPLETE! [18:26:08] [18:26:08] CF: 70 f6 24 00 8b [18:26:08] sioFuji::sio_process() called [18:26:08] ACK! [18:26:08] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:08] ::dir_nextfile {0:1} [18:26:08] ::read_direntry "TBXL-Save 1.atr" [18:26:08] ->SIO write 36 bytes [18:26:08] COMPLETE! [18:26:08] [18:26:08] CF: 70 f6 24 00 8b [18:26:08] sioFuji::sio_process() called [18:26:08] ACK! [18:26:08] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:08] ::dir_nextfile {0:1} [18:26:08] ::read_direntry "TBXL-Save 2.atr" [18:26:08] ->SIO write 36 bytes [18:26:08] COMPLETE! [18:26:08] [18:26:08] CF: 70 f6 24 00 8b [18:26:08] sioFuji::sio_process() called [18:26:08] ACK! [18:26:08] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:08] ::dir_nextfile {0:1} [18:26:08] ::read_direntry "Temple of Apshai Trilogy.atx" [18:26:08] ->SIO write 36 bytes [18:26:08] COMPLETE! [18:26:08] [18:26:08] CF: 70 f6 24 00 8b [18:26:08] sioFuji::sio_process() called [18:26:08] ACK! [18:26:08] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:08] ::dir_nextfile {0:1} [18:26:08] ::read_direntry "Tensor Trzaskowskiego.atr" [18:26:08] ->SIO write 36 bytes [18:26:08] COMPLETE! [18:26:08] [18:26:08] CF: 70 f6 24 00 8b [18:26:08] sioFuji::sio_process() called [18:26:08] ACK! [18:26:08] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:08] ::dir_nextfile {0:1} [18:26:08] ::read_direntry "Tornado Pinball.atr" [18:26:08] ->SIO write 36 bytes [18:26:08] COMPLETE! [18:26:08] [18:26:08] CF: 70 f6 24 00 8b [18:26:08] sioFuji::sio_process() called [18:26:08] ACK! [18:26:08] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:08] ::dir_nextfile {0:1} [18:26:08] ::read_direntry "Translator_Side_A_OS_B.ATR" [18:26:08] ->SIO write 36 bytes [18:26:08] COMPLETE! [18:26:09] [18:26:09] CF: 70 f6 24 00 8b [18:26:09] sioFuji::sio_process() called [18:26:09] ACK! [18:26:09] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:09] ::dir_nextfile {0:1} [18:26:09] ::read_direntry "Translator_Side_B_OS_A.ATR" [18:26:09] ->SIO write 36 bytes [18:26:09] COMPLETE! [18:26:09] [18:26:09] CF: 70 f6 24 00 8b [18:26:09] sioFuji::sio_process() called [18:26:09] ACK! [18:26:09] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:09] ::dir_nextfile {0:1} [18:26:09] ::read_direntry "Trax.ATR" [18:26:09] ->SIO write 36 bytes [18:26:09] COMPLETE! [18:26:09] [18:26:09] CF: 70 f6 24 00 8b [18:26:09] sioFuji::sio_process() called [18:26:09] ACK! [18:26:09] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:09] ::dir_nextfile {0:1} [18:26:09] ::read_direntry "Tristam Island Save Disk.atr" [18:26:09] ->SIO write 36 bytes [18:26:09] COMPLETE! [18:26:09] [18:26:09] CF: 70 f6 24 00 8b [18:26:09] sioFuji::sio_process() called [18:26:09] ACK! [18:26:09] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:09] ::dir_nextfile {0:1} [18:26:09] ::read_direntry "Tristam Island.atr" [18:26:09] ->SIO write 36 bytes [18:26:09] COMPLETE! [18:26:09] [18:26:09] CF: 70 f6 24 00 8b [18:26:09] sioFuji::sio_process() called [18:26:09] ACK! [18:26:09] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:09] ::dir_nextfile {0:1} [18:26:09] ::read_direntry "Troll's Treasure.atr" [18:26:09] ->SIO write 36 bytes [18:26:09] COMPLETE! [18:26:09] [18:26:09] CF: 70 f6 24 00 8b [18:26:09] sioFuji::sio_process() called [18:26:09] ACK! [18:26:09] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:09] ::dir_nextfile {0:1} [18:26:09] ::read_direntry "Tube Trooper-Prototype.atr" [18:26:09] ->SIO write 36 bytes [18:26:09] COMPLETE! [18:26:09] [18:26:09] CF: 70 f6 24 00 8b [18:26:09] sioFuji::sio_process() called [18:26:09] ACK! [18:26:09] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:09] ::dir_nextfile {0:1} [18:26:09] ::read_direntry "Turbo Basic XL.atr" [18:26:09] ->SIO write 36 bytes [18:26:09] COMPLETE! [18:26:09] [18:26:09] CF: 70 f5 00 00 66 [18:26:09] sioFuji::sio_process() called [18:26:09] ACK! [18:26:09] Fuji cmd: CLOSE DIRECTORY [18:26:09] COMPLETE! [18:26:14] [18:26:14] CF: 70 f9 00 00 6a [18:26:14] sioFuji::sio_process() called [18:26:14] ACK! [18:26:14] Fuji cmd: MOUNT HOST [18:26:14] ::mount {0} "SD" [18:26:14] ::mount_local Attempting mount of "SD" [18:26:14] Type is already LOCAL [18:26:14] COMPLETE! [18:26:14] [18:26:14] CF: 70 f7 00 00 68 [18:26:14] sioFuji::sio_process() called [18:26:14] ACK! [18:26:14] Fuji cmd: OPEN DIRECTORY [18:26:14] <-SIO read 256 bytes [18:26:14] ACK! [18:26:14] Opening directory: "/T", pattern: "trans*" [18:26:14] ::dir_open {0:1} "/T", pattern "trans*" [18:26:14] ::dir_open actual path = "/T" [18:26:14] COMPLETE! [18:26:14] [18:26:14] CF: 70 f6 24 00 8b [18:26:14] sioFuji::sio_process() called [18:26:14] ACK! [18:26:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:14] ::dir_nextfile {0:1} [18:26:14] ::read_direntry "Translator_Side_A_OS_B.ATR" [18:26:14] ->SIO write 36 bytes [18:26:14] COMPLETE! [18:26:14] [18:26:14] CF: 70 f6 24 00 8b [18:26:14] sioFuji::sio_process() called [18:26:14] ACK! [18:26:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:14] ::dir_nextfile {0:1} [18:26:14] ::read_direntry "Translator_Side_B_OS_A.ATR" [18:26:14] ->SIO write 36 bytes [18:26:14] COMPLETE! [18:26:14] [18:26:14] CF: 70 f6 24 00 8b [18:26:14] sioFuji::sio_process() called [18:26:14] ACK! [18:26:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:14] ::dir_nextfile {0:1} [18:26:14] Reached end of of directory [18:26:14] ->SIO write 36 bytes [18:26:14] COMPLETE! [18:26:14] [18:26:14] CF: 70 f6 24 00 8b [18:26:14] sioFuji::sio_process() called [18:26:14] ACK! [18:26:14] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:14] ::dir_nextfile {0:1} [18:26:14] Reached end of of directory [18:26:14] ->SIO write 36 bytes [18:26:14] COMPLETE! [18:26:15] [18:26:15] CF: 70 f5 00 00 66 [18:26:15] sioFuji::sio_process() called [18:26:15] ACK! [18:26:15] Fuji cmd: CLOSE DIRECTORY [18:26:15] COMPLETE! [18:26:16] [18:26:16] CF: 70 f7 00 00 68 [18:26:16] sioFuji::sio_process() called [18:26:16] ACK! [18:26:16] Fuji cmd: OPEN DIRECTORY [18:26:16] <-SIO read 256 bytes [18:26:16] ACK! [18:26:16] Opening directory: "/T", pattern: "trans*" [18:26:16] ::dir_open {0:1} "/T", pattern "trans*" [18:26:16] ::dir_open actual path = "/T" [18:26:16] COMPLETE! [18:26:16] [18:26:16] CF: 70 e4 00 00 55 [18:26:16] sioFuji::sio_process() called [18:26:16] ACK! [18:26:16] Fuji cmd: SET DIRECTORY POSITION [18:26:16] ::dir_seek {0:1} 0 [18:26:16] COMPLETE! [18:26:16] [18:26:16] CF: 70 f6 80 00 e7 [18:26:16] sioFuji::sio_process() called [18:26:16] ACK! [18:26:16] Fuji cmd: READ DIRECTORY ENTRY (max=128) [18:26:16] ::dir_nextfile {0:1} [18:26:16] ::read_direntry "Translator_Side_A_OS_B.ATR" [18:26:16] ->SIO write 128 bytes [18:26:16] COMPLETE! [18:26:16] [18:26:16] CF: 70 f5 00 00 66 [18:26:16] sioFuji::sio_process() called [18:26:16] ACK! [18:26:16] Fuji cmd: CLOSE DIRECTORY [18:26:16] COMPLETE! [18:26:16] [18:26:16] CF: 70 f7 00 00 68 [18:26:16] sioFuji::sio_process() called [18:26:16] ACK! [18:26:16] Fuji cmd: OPEN DIRECTORY [18:26:16] <-SIO read 256 bytes [18:26:17] ACK! [18:26:17] Opening directory: "/T", pattern: "trans*" [18:26:17] ::dir_open {0:1} "/T", pattern "trans*" [18:26:17] ::dir_open actual path = "/T" [18:26:17] COMPLETE! [18:26:17] [18:26:17] CF: 70 e4 00 00 55 [18:26:17] sioFuji::sio_process() called [18:26:17] ACK! [18:26:17] Fuji cmd: SET DIRECTORY POSITION [18:26:17] ::dir_seek {0:1} 0 [18:26:17] COMPLETE! [18:26:17] [18:26:17] CF: 70 f2 00 00 63 [18:26:17] sioFuji::sio_process() called [18:26:17] ACK! [18:26:17] Fuji cmd: READ DEVICE SLOTS [18:26:17] ->SIO write 304 bytes [18:26:17] COMPLETE! [18:26:17] [18:26:17] CF: 70 f6 31 80 19 [18:26:17] sioFuji::sio_process() called [18:26:17] ACK! [18:26:17] Fuji cmd: READ DIRECTORY ENTRY (max=49) [18:26:17] ::dir_nextfile {0:1} [18:26:17] ::read_direntry "Translator_Side_A_OS_B.ATR" [18:26:17] ->SIO write 49 bytes [18:26:17] COMPLETE! [18:26:17] [18:26:17] CF: 70 f5 00 00 66 [18:26:17] sioFuji::sio_process() called [18:26:17] ACK! [18:26:17] Fuji cmd: CLOSE DIRECTORY [18:26:17] COMPLETE! [18:26:20] [18:26:20] CF: 70 f7 00 00 68 [18:26:20] sioFuji::sio_process() called [18:26:20] ACK! [18:26:20] Fuji cmd: OPEN DIRECTORY [18:26:20] <-SIO read 256 bytes [18:26:20] ACK! [18:26:20] Opening directory: "/T", pattern: "trans*" [18:26:20] ::dir_open {0:1} "/T", pattern "trans*" [18:26:20] ::dir_open actual path = "/T" [18:26:20] COMPLETE! [18:26:20] [18:26:20] CF: 70 e4 00 00 55 [18:26:20] sioFuji::sio_process() called [18:26:20] ACK! [18:26:20] Fuji cmd: SET DIRECTORY POSITION [18:26:20] ::dir_seek {0:1} 0 [18:26:20] COMPLETE! [18:26:20] [18:26:20] CF: 70 f6 fc 00 64 [18:26:20] sioFuji::sio_process() called [18:26:20] ACK! [18:26:20] Fuji cmd: READ DIRECTORY ENTRY (max=252) [18:26:20] ::dir_nextfile {0:1} [18:26:20] ::read_direntry "Translator_Side_A_OS_B.ATR" [18:26:20] ->SIO write 252 bytes [18:26:20] COMPLETE! [18:26:20] [18:26:20] CF: 70 e2 00 00 53 [18:26:20] sioFuji::sio_process() called [18:26:20] ACK! [18:26:20] <-SIO read 256 bytes [18:26:20] ACK! [18:26:20] Fuji cmd: SET DEVICE SLOT 0x00/00/00 FILENAME: /T/Translator_Side_A_OS_B.ATR [18:26:20] fnConfig::save [18:26:20] SPIFFS Config Storage: Enabled. Saving config to SPIFFS [18:26:20] fnConfig::save wrote 1119 bytes [18:26:20] Attempting config copy to SD [18:26:20] copy_file "/fnconfig.ini" -> "/fnconfig.ini" [18:26:20] fopen = /fnconfig.ini : ok [18:26:20] copy_file copied 1119 bytes [18:26:20] COMPLETE! [18:26:20] [18:26:20] CF: 70 e4 00 00 55 [18:26:20] sioFuji::sio_process() called [18:26:20] ACK! [18:26:20] Fuji cmd: SET DIRECTORY POSITION [18:26:20] ::dir_seek {0:1} 0 [18:26:20] COMPLETE! [18:26:20] [18:26:20] CF: 70 f6 24 00 8b [18:26:20] sioFuji::sio_process() called [18:26:20] ACK! [18:26:20] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:20] ::dir_nextfile {0:1} [18:26:20] ::read_direntry "Translator_Side_A_OS_B.ATR" [18:26:20] ->SIO write 36 bytes [18:26:20] COMPLETE! [18:26:20] [18:26:20] CF: 70 f1 00 00 62 [18:26:20] sioFuji::sio_process() called [18:26:20] ACK! [18:26:20] Fuji cmd: WRITE DEVICE SLOTS [18:26:20] <-SIO read 304 bytes [18:26:21] ACK! [18:26:21] fnConfig::save [18:26:21] fnConfig::save not dirty, not saving [18:26:21] COMPLETE! [18:26:21] [18:26:21] CF: 70 f5 00 00 66 [18:26:21] sioFuji::sio_process() called [18:26:21] ACK! [18:26:21] Fuji cmd: CLOSE DIRECTORY [18:26:21] COMPLETE! [18:26:21] [18:26:21] CF: 70 f4 00 00 65 [18:26:21] sioFuji::sio_process() called [18:26:21] ACK! [18:26:21] Fuji cmd: READ HOST SLOTS [18:26:21] ->SIO write 256 bytes [18:26:21] COMPLETE! [18:26:21] [18:26:21] CF: 70 f2 00 00 63 [18:26:21] sioFuji::sio_process() called [18:26:21] ACK! [18:26:21] Fuji cmd: READ DEVICE SLOTS [18:26:21] ->SIO write 304 bytes [18:26:21] COMPLETE! [18:26:21] [18:26:21] CF: 70 f4 00 00 65 [18:26:21] sioFuji::sio_process() called [18:26:21] ACK! [18:26:21] Fuji cmd: READ HOST SLOTS [18:26:21] ->SIO write 256 bytes [18:26:21] COMPLETE! [18:26:21] [18:26:21] CF: 70 f2 00 00 63 [18:26:21] sioFuji::sio_process() called [18:26:21] ACK! [18:26:21] Fuji cmd: READ DEVICE SLOTS [18:26:21] ->SIO write 304 bytes [18:26:21] COMPLETE! [18:26:23] [18:26:23] CF: 70 f5 00 00 66 [18:26:23] sioFuji::sio_process() called [18:26:23] ACK! [18:26:23] Fuji cmd: CLOSE DIRECTORY [18:26:23] COMPLETE! [18:26:23] [18:26:23] CF: 70 f9 00 00 6a [18:26:23] sioFuji::sio_process() called [18:26:23] ACK! [18:26:23] Fuji cmd: MOUNT HOST [18:26:23] ::mount {0} "SD" [18:26:23] ::mount_local Attempting mount of "SD" [18:26:23] Type is already LOCAL [18:26:23] COMPLETE! [18:26:23] [18:26:23] CF: 70 f7 00 00 68 [18:26:23] sioFuji::sio_process() called [18:26:23] ACK! [18:26:23] Fuji cmd: OPEN DIRECTORY [18:26:23] <-SIO read 256 bytes [18:26:23] ACK! [18:26:23] Opening directory: "/", pattern: "" [18:26:23] ::dir_open {0:1} "/", pattern "" [18:26:23] ::dir_open actual path = "/" [18:26:23] COMPLETE! [18:26:23] [18:26:23] CF: 70 f6 24 00 8b [18:26:23] sioFuji::sio_process() called [18:26:23] ACK! [18:26:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:23] ::dir_nextfile {0:1} [18:26:23] ::read_direntry "0-9" [18:26:23] ->SIO write 36 bytes [18:26:23] COMPLETE! [18:26:23] [18:26:23] CF: 70 f6 24 00 8b [18:26:23] sioFuji::sio_process() called [18:26:23] ACK! [18:26:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:23] ::dir_nextfile {0:1} [18:26:23] ::read_direntry "A" [18:26:23] ->SIO write 36 bytes [18:26:23] COMPLETE! [18:26:23] [18:26:23] CF: 70 f6 24 00 8b [18:26:23] sioFuji::sio_process() called [18:26:23] ACK! [18:26:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:23] ::dir_nextfile {0:1} [18:26:23] ::read_direntry "B" [18:26:23] ->SIO write 36 bytes [18:26:23] COMPLETE! [18:26:23] [18:26:23] CF: 70 f6 24 00 8b [18:26:23] sioFuji::sio_process() called [18:26:23] ACK! [18:26:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:23] ::dir_nextfile {0:1} [18:26:23] ::read_direntry "C" [18:26:23] ->SIO write 36 bytes [18:26:23] COMPLETE! [18:26:23] [18:26:23] CF: 70 f6 24 00 8b [18:26:23] sioFuji::sio_process() called [18:26:23] ACK! [18:26:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:23] ::dir_nextfile {0:1} [18:26:23] ::read_direntry "D" [18:26:23] ->SIO write 36 bytes [18:26:23] COMPLETE! [18:26:23] [18:26:23] CF: 70 f6 24 00 8b [18:26:23] sioFuji::sio_process() called [18:26:23] ACK! [18:26:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:23] ::dir_nextfile {0:1} [18:26:23] ::read_direntry "E" [18:26:23] ->SIO write 36 bytes [18:26:23] COMPLETE! [18:26:23] [18:26:23] CF: 70 f6 24 00 8b [18:26:23] sioFuji::sio_process() called [18:26:23] ACK! [18:26:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:23] ::dir_nextfile {0:1} [18:26:23] ::read_direntry "F" [18:26:23] ->SIO write 36 bytes [18:26:23] COMPLETE! [18:26:23] [18:26:23] CF: 70 f6 24 00 8b [18:26:23] sioFuji::sio_process() called [18:26:23] ACK! [18:26:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:23] ::dir_nextfile {0:1} [18:26:23] ::read_direntry "FujiNet" [18:26:23] ->SIO write 36 bytes [18:26:23] COMPLETE! [18:26:23] [18:26:23] CF: 70 f6 24 00 8b [18:26:23] sioFuji::sio_process() called [18:26:23] ACK! [18:26:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:23] ::dir_nextfile {0:1} [18:26:23] ::read_direntry "G" [18:26:23] ->SIO write 36 bytes [18:26:23] COMPLETE! [18:26:23] [18:26:23] CF: 70 f6 24 00 8b [18:26:23] sioFuji::sio_process() called [18:26:23] ACK! [18:26:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:23] ::dir_nextfile {0:1} [18:26:23] ::read_direntry "H" [18:26:23] ->SIO write 36 bytes [18:26:23] COMPLETE! [18:26:23] [18:26:23] CF: 70 f6 24 00 8b [18:26:23] sioFuji::sio_process() called [18:26:23] ACK! [18:26:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:23] ::dir_nextfile {0:1} [18:26:23] ::read_direntry "I" [18:26:23] ->SIO write 36 bytes [18:26:23] COMPLETE! [18:26:23] [18:26:23] CF: 70 f6 24 00 8b [18:26:23] sioFuji::sio_process() called [18:26:23] ACK! [18:26:23] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:23] ::dir_nextfile {0:1} [18:26:23] ::read_direntry "J" [18:26:23] ->SIO write 36 bytes [18:26:23] COMPLETE! [18:26:24] [18:26:24] CF: 70 f6 24 00 8b [18:26:24] sioFuji::sio_process() called [18:26:24] ACK! [18:26:24] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:24] ::dir_nextfile {0:1} [18:26:24] ::read_direntry "K" [18:26:24] ->SIO write 36 bytes [18:26:24] COMPLETE! [18:26:24] [18:26:24] CF: 70 f6 24 00 8b [18:26:24] sioFuji::sio_process() called [18:26:24] ACK! [18:26:24] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:24] ::dir_nextfile {0:1} [18:26:24] ::read_direntry "L" [18:26:24] ->SIO write 36 bytes [18:26:24] COMPLETE! [18:26:24] [18:26:24] CF: 70 f5 00 00 66 [18:26:24] sioFuji::sio_process() called [18:26:24] ACK! [18:26:24] Fuji cmd: CLOSE DIRECTORY [18:26:24] COMPLETE! [18:26:26] [18:26:26] CF: 70 f7 00 00 68 [18:26:26] sioFuji::sio_process() called [18:26:26] ACK! [18:26:26] Fuji cmd: OPEN DIRECTORY [18:26:26] <-SIO read 256 bytes [18:26:26] ACK! [18:26:26] Opening directory: "/", pattern: "" [18:26:26] ::dir_open {0:1} "/", pattern "" [18:26:26] ::dir_open actual path = "/" [18:26:26] COMPLETE! [18:26:26] [18:26:26] CF: 70 e4 02 00 57 [18:26:26] sioFuji::sio_process() called [18:26:26] ACK! [18:26:26] Fuji cmd: SET DIRECTORY POSITION [18:26:26] ::dir_seek {0:1} 2 [18:26:26] COMPLETE! [18:26:26] [18:26:26] CF: 70 f6 80 00 e7 [18:26:26] sioFuji::sio_process() called [18:26:26] ACK! [18:26:26] Fuji cmd: READ DIRECTORY ENTRY (max=128) [18:26:26] ::dir_nextfile {0:1} [18:26:26] ::read_direntry "B" [18:26:26] ->SIO write 128 bytes [18:26:26] COMPLETE! [18:26:26] [18:26:26] CF: 70 f5 00 00 66 [18:26:26] sioFuji::sio_process() called [18:26:26] ACK! [18:26:26] Fuji cmd: CLOSE DIRECTORY [18:26:26] COMPLETE! [18:26:26] [18:26:26] CF: 70 f7 00 00 68 [18:26:26] sioFuji::sio_process() called [18:26:26] ACK! [18:26:26] Fuji cmd: OPEN DIRECTORY [18:26:26] <-SIO read 256 bytes [18:26:26] ACK! [18:26:26] Opening directory: "/", pattern: "" [18:26:26] ::dir_open {0:1} "/", pattern "" [18:26:26] ::dir_open actual path = "/" [18:26:26] COMPLETE! [18:26:26] [18:26:26] CF: 70 e4 02 00 57 [18:26:26] sioFuji::sio_process() called [18:26:26] ACK! [18:26:26] Fuji cmd: SET DIRECTORY POSITION [18:26:26] ::dir_seek {0:1} 2 [18:26:26] COMPLETE! [18:26:27] [18:26:27] CF: 70 f6 80 01 e8 [18:26:27] sioFuji::sio_process() called [18:26:27] ACK! [18:26:27] Fuji cmd: READ DIRECTORY ENTRY (max=128) [18:26:27] ::dir_nextfile {0:1} [18:26:27] ::read_direntry "B" [18:26:27] ->SIO write 128 bytes [18:26:27] COMPLETE! [18:26:27] [18:26:27] CF: 70 f5 00 00 66 [18:26:27] sioFuji::sio_process() called [18:26:27] ACK! [18:26:27] Fuji cmd: CLOSE DIRECTORY [18:26:27] COMPLETE! [18:26:27] [18:26:27] CF: 70 f9 00 00 6a [18:26:27] sioFuji::sio_process() called [18:26:27] ACK! [18:26:27] Fuji cmd: MOUNT HOST [18:26:27] ::mount {0} "SD" [18:26:27] ::mount_local Attempting mount of "SD" [18:26:27] Type is already LOCAL [18:26:27] COMPLETE! [18:26:27] [18:26:27] CF: 70 f7 00 00 68 [18:26:27] sioFuji::sio_process() called [18:26:27] ACK! [18:26:27] Fuji cmd: OPEN DIRECTORY [18:26:27] <-SIO read 256 bytes [18:26:27] ACK! [18:26:27] Opening directory: "/B", pattern: "" [18:26:27] ::dir_open {0:1} "/B", pattern "" [18:26:27] ::dir_open actual path = "/B" [18:26:27] COMPLETE! [18:26:27] [18:26:27] CF: 70 f6 24 00 8b [18:26:27] sioFuji::sio_process() called [18:26:27] ACK! [18:26:27] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:27] ::dir_nextfile {0:1} [18:26:27] ::read_direntry "Battle of Antietam v1.3 (1985)(SSI)(US)(Side A)(Scenario Disk).atx" [18:26:27] ->SIO write 36 bytes [18:26:27] COMPLETE! [18:26:27] [18:26:27] CF: 70 f6 24 00 8b [18:26:27] sioFuji::sio_process() called [18:26:27] ACK! [18:26:27] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:27] ::dir_nextfile {0:1} [18:26:27] ::read_direntry "Battle of Antietam v1.3 (1985)(SSI)(US)(Side B)(Game Disk).atx" [18:26:27] ->SIO write 36 bytes [18:26:27] COMPLETE! [18:26:27] [18:26:27] CF: 70 f6 24 00 8b [18:26:27] sioFuji::sio_process() called [18:26:27] ACK! [18:26:27] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:27] ::dir_nextfile {0:1} [18:26:27] ::read_direntry "BattleOfEris.ATR" [18:26:27] ->SIO write 36 bytes [18:26:27] COMPLETE! [18:26:27] [18:26:27] CF: 70 f6 24 00 8b [18:26:27] sioFuji::sio_process() called [18:26:27] ACK! [18:26:27] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:27] ::dir_nextfile {0:1} [18:26:27] ::read_direntry "BC's Quest for Tires (1983)(Sierra On-Line)(US)[m].atx" [18:26:27] ->SIO write 36 bytes [18:26:27] COMPLETE! [18:26:27] [18:26:27] CF: 70 f6 24 00 8b [18:26:27] sioFuji::sio_process() called [18:26:27] ACK! [18:26:27] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:27] ::dir_nextfile {0:1} [18:26:27] ::read_direntry "Berks Four.ATR" [18:26:27] ->SIO write 36 bytes [18:26:27] COMPLETE! [18:26:27] [18:26:27] CF: 70 f6 24 00 8b [18:26:27] sioFuji::sio_process() called [18:26:27] ACK! [18:26:27] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:27] ::dir_nextfile {0:1} [18:26:27] ::read_direntry "Bible Baseball (1983)(Davka Corporation)(US)[!][Trans][BASIC].atx" [18:26:27] ->SIO write 36 bytes [18:26:27] COMPLETE! [18:26:27] [18:26:27] CF: 70 f6 24 00 8b [18:26:27] sioFuji::sio_process() called [18:26:27] ACK! [18:26:27] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:27] ::dir_nextfile {0:1} [18:26:27] ::read_direntry "Bible Baseball (1983)(Davka Corporation)(US)[!][Trans][BASIC][cr CSS].atr" [18:26:27] ->SIO write 36 bytes [18:26:27] COMPLETE! [18:26:27] [18:26:27] CF: 70 f6 24 00 8b [18:26:27] sioFuji::sio_process() called [18:26:27] ACK! [18:26:27] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:27] ::dir_nextfile {0:1} [18:26:27] ::read_direntry "Bijets, The (non-original, not protected).atr" [18:26:27] ->SIO write 36 bytes [18:26:27] COMPLETE! [18:26:27] [18:26:27] CF: 70 f6 24 00 8b [18:26:27] sioFuji::sio_process() called [18:26:27] ACK! [18:26:27] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:27] ::dir_nextfile {0:1} [18:26:27] ::read_direntry "Binary Parasite r040.xex" [18:26:27] ->SIO write 36 bytes [18:26:27] COMPLETE! [18:26:27] [18:26:27] CF: 70 f6 24 00 8b [18:26:27] sioFuji::sio_process() called [18:26:27] ACK! [18:26:27] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:27] ::dir_nextfile {0:1} [18:26:27] ::read_direntry "Block On Legs v1.1.ATR" [18:26:27] ->SIO write 36 bytes [18:26:27] COMPLETE! [18:26:27] [18:26:27] CF: 70 f6 24 00 8b [18:26:27] sioFuji::sio_process() called [18:26:27] ACK! [18:26:27] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:27] ::dir_nextfile {0:1} [18:26:27] ::read_direntry "Bomber Jack (1991-03)(KE-Soft)(DE)(Side A).atr" [18:26:27] ->SIO write 36 bytes [18:26:27] COMPLETE! [18:26:27] [18:26:27] CF: 70 f6 24 00 8b [18:26:27] sioFuji::sio_process() called [18:26:27] ACK! [18:26:27] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:27] ::dir_nextfile {0:1} [18:26:27] ::read_direntry "Bomber Jack (1991-03)(KE-Soft)(DE)(Side B).atr" [18:26:27] ->SIO write 36 bytes [18:26:27] COMPLETE! [18:26:28] [18:26:28] CF: 70 f6 24 00 8b [18:26:28] sioFuji::sio_process() called [18:26:28] ACK! [18:26:28] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:28] ::dir_nextfile {0:1} [18:26:28] ::read_direntry "Bounty Hunter-[BAS].ATR" [18:26:28] ->SIO write 36 bytes [18:26:28] COMPLETE! [18:26:28] [18:26:28] CF: 70 f6 24 00 8b [18:26:28] sioFuji::sio_process() called [18:26:28] ACK! [18:26:28] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:28] ::dir_nextfile {0:1} [18:26:28] ::read_direntry "Bruce Lee Return of Fury-Tix graphics.atr" [18:26:28] ->SIO write 36 bytes [18:26:28] COMPLETE! [18:26:28] [18:26:28] CF: 70 f5 00 00 66 [18:26:28] sioFuji::sio_process() called [18:26:28] ACK! [18:26:28] Fuji cmd: CLOSE DIRECTORY [18:26:28] COMPLETE! [18:26:28] [18:26:28] CF: 70 f7 00 00 68 [18:26:28] sioFuji::sio_process() called [18:26:28] ACK! [18:26:28] Fuji cmd: OPEN DIRECTORY [18:26:28] <-SIO read 256 bytes [18:26:28] ACK! [18:26:28] Opening directory: "/B", pattern: "" [18:26:28] ::dir_open {0:1} "/B", pattern "" [18:26:28] ::dir_open actual path = "/B" [18:26:28] COMPLETE! [18:26:28] [18:26:28] CF: 70 e4 00 00 55 [18:26:28] sioFuji::sio_process() called [18:26:28] ACK! [18:26:28] Fuji cmd: SET DIRECTORY POSITION [18:26:28] ::dir_seek {0:1} 0 [18:26:28] COMPLETE! [18:26:28] [18:26:28] CF: 70 f6 40 00 a7 [18:26:28] sioFuji::sio_process() called [18:26:28] ACK! [18:26:28] Fuji cmd: READ DIRECTORY ENTRY (max=64) [18:26:28] ::dir_nextfile {0:1} [18:26:28] ::read_direntry "Battle of Antietam v1.3 (1985)(SSI)(US)(Side A)(Scenario Disk).atx" [18:26:28] ->SIO write 64 bytes [18:26:28] COMPLETE! [18:26:28] [18:26:28] CF: 70 f5 00 00 66 [18:26:28] sioFuji::sio_process() called [18:26:28] ACK! [18:26:28] Fuji cmd: CLOSE DIRECTORY [18:26:28] COMPLETE! [18:26:31] [18:26:31] CF: 70 f7 00 00 68 [18:26:31] sioFuji::sio_process() called [18:26:31] ACK! [18:26:31] Fuji cmd: OPEN DIRECTORY [18:26:31] <-SIO read 256 bytes [18:26:31] ACK! [18:26:31] Opening directory: "/B", pattern: "" [18:26:31] ::dir_open {0:1} "/B", pattern "" [18:26:31] ::dir_open actual path = "/B" [18:26:31] COMPLETE! [18:26:31] [18:26:31] CF: 70 e4 05 00 5a [18:26:31] sioFuji::sio_process() called [18:26:31] ACK! [18:26:31] Fuji cmd: SET DIRECTORY POSITION [18:26:31] ::dir_seek {0:1} 5 [18:26:31] COMPLETE! [18:26:31] [18:26:31] CF: 70 f6 40 00 a7 [18:26:31] sioFuji::sio_process() called [18:26:31] ACK! [18:26:31] Fuji cmd: READ DIRECTORY ENTRY (max=64) [18:26:31] ::dir_nextfile {0:1} [18:26:31] ::read_direntry "Bible Baseball (1983)(Davka Corporation)(US)[!][Trans][BASIC].atx" [18:26:31] ->SIO write 64 bytes [18:26:31] COMPLETE! [18:26:31] [18:26:31] CF: 70 f5 00 00 66 [18:26:31] sioFuji::sio_process() called [18:26:31] ACK! [18:26:31] Fuji cmd: CLOSE DIRECTORY [18:26:31] COMPLETE! [18:26:32] [18:26:32] CF: 70 f7 00 00 68 [18:26:32] sioFuji::sio_process() called [18:26:32] ACK! [18:26:32] Fuji cmd: OPEN DIRECTORY [18:26:32] <-SIO read 256 bytes [18:26:32] ACK! [18:26:32] Opening directory: "/B", pattern: "" [18:26:32] ::dir_open {0:1} "/B", pattern "" [18:26:32] ::dir_open actual path = "/B" [18:26:32] COMPLETE! [18:26:32] [18:26:32] CF: 70 e4 05 00 5a [18:26:32] sioFuji::sio_process() called [18:26:32] ACK! [18:26:32] Fuji cmd: SET DIRECTORY POSITION [18:26:32] ::dir_seek {0:1} 5 [18:26:32] COMPLETE! [18:26:32] [18:26:32] CF: 70 f6 80 00 e7 [18:26:32] sioFuji::sio_process() called [18:26:32] ACK! [18:26:32] Fuji cmd: READ DIRECTORY ENTRY (max=128) [18:26:32] ::dir_nextfile {0:1} [18:26:32] ::read_direntry "Bible Baseball (1983)(Davka Corporation)(US)[!][Trans][BASIC].atx" [18:26:32] ->SIO write 128 bytes [18:26:32] COMPLETE! [18:26:32] [18:26:32] CF: 70 f5 00 00 66 [18:26:32] sioFuji::sio_process() called [18:26:32] ACK! [18:26:32] Fuji cmd: CLOSE DIRECTORY [18:26:32] COMPLETE! [18:26:32] [18:26:32] CF: 70 f7 00 00 68 [18:26:32] sioFuji::sio_process() called [18:26:32] ACK! [18:26:32] Fuji cmd: OPEN DIRECTORY [18:26:32] <-SIO read 256 bytes [18:26:32] ACK! [18:26:32] Opening directory: "/B", pattern: "" [18:26:32] ::dir_open {0:1} "/B", pattern "" [18:26:32] ::dir_open actual path = "/B" [18:26:32] COMPLETE! [18:26:32] [18:26:32] CF: 70 e4 05 00 5a [18:26:32] sioFuji::sio_process() called [18:26:32] ACK! [18:26:32] Fuji cmd: SET DIRECTORY POSITION [18:26:32] ::dir_seek {0:1} 5 [18:26:32] COMPLETE! [18:26:32] [18:26:32] CF: 70 f2 00 00 63 [18:26:32] sioFuji::sio_process() called [18:26:32] ACK! [18:26:32] Fuji cmd: READ DEVICE SLOTS [18:26:32] ->SIO write 304 bytes [18:26:32] COMPLETE! [18:26:32] [18:26:32] CF: 70 f6 31 80 19 [18:26:32] sioFuji::sio_process() called [18:26:32] ACK! [18:26:32] Fuji cmd: READ DIRECTORY ENTRY (max=49) [18:26:32] ::dir_nextfile {0:1} [18:26:32] ::read_direntry "Bible Baseball (1983)(Davka Corporation)(US)[!][Trans][BASIC].atx" [18:26:32] ->SIO write 49 bytes [18:26:32] COMPLETE! [18:26:33] [18:26:33] CF: 70 f5 00 00 66 [18:26:33] sioFuji::sio_process() called [18:26:33] ACK! [18:26:33] Fuji cmd: CLOSE DIRECTORY [18:26:33] COMPLETE! [18:26:36] [18:26:36] CF: 70 f7 00 00 68 [18:26:36] sioFuji::sio_process() called [18:26:36] ACK! [18:26:36] Fuji cmd: OPEN DIRECTORY [18:26:36] <-SIO read 256 bytes [18:26:36] ACK! [18:26:36] Opening directory: "/B", pattern: "" [18:26:36] ::dir_open {0:1} "/B", pattern "" [18:26:36] ::dir_open actual path = "/B" [18:26:36] COMPLETE! [18:26:36] [18:26:36] CF: 70 e4 05 00 5a [18:26:36] sioFuji::sio_process() called [18:26:36] ACK! [18:26:36] Fuji cmd: SET DIRECTORY POSITION [18:26:36] ::dir_seek {0:1} 5 [18:26:36] COMPLETE! [18:26:36] [18:26:36] CF: 70 f6 fc 00 64 [18:26:36] sioFuji::sio_process() called [18:26:36] ACK! [18:26:36] Fuji cmd: READ DIRECTORY ENTRY (max=252) [18:26:36] ::dir_nextfile {0:1} [18:26:36] ::read_direntry "Bible Baseball (1983)(Davka Corporation)(US)[!][Trans][BASIC].atx" [18:26:36] ->SIO write 252 bytes [18:26:36] COMPLETE! [18:26:36] [18:26:36] CF: 70 e2 01 00 54 [18:26:36] sioFuji::sio_process() called [18:26:36] ACK! [18:26:36] <-SIO read 256 bytes [18:26:36] ACK! [18:26:36] Fuji cmd: SET DEVICE SLOT 0x01/00/00 FILENAME: /B/Bible Baseball (1983)(Davka Corporation)(US)[!][Trans][BASIC].atx [18:26:36] fnConfig::save [18:26:36] fnConfig::save not dirty, not saving [18:26:36] COMPLETE! [18:26:36] [18:26:36] CF: 70 e4 05 00 5a [18:26:36] sioFuji::sio_process() called [18:26:36] ACK! [18:26:36] Fuji cmd: SET DIRECTORY POSITION [18:26:36] ::dir_seek {0:1} 5 [18:26:36] COMPLETE! [18:26:36] [18:26:36] CF: 70 f6 24 00 8b [18:26:36] sioFuji::sio_process() called [18:26:36] ACK! [18:26:36] Fuji cmd: READ DIRECTORY ENTRY (max=36) [18:26:36] ::dir_nextfile {0:1} [18:26:36] ::read_direntry "Bible Baseball (1983)(Davka Corporation)(US)[!][Trans][BASIC].atx" [18:26:36] ->SIO write 36 bytes [18:26:36] COMPLETE! [18:26:36] [18:26:36] CF: 70 f1 00 00 62 [18:26:36] sioFuji::sio_process() called [18:26:36] ACK! [18:26:36] Fuji cmd: WRITE DEVICE SLOTS [18:26:36] <-SIO read 304 bytes [18:26:37] ACK! [18:26:37] fnConfig::save [18:26:37] SPIFFS Config Storage: Enabled. Saving config to SPIFFS [18:26:37] fnConfig::save wrote 1226 bytes [18:26:37] Attempting config copy to SD [18:26:37] copy_file "/fnconfig.ini" -> "/fnconfig.ini" [18:26:37] fopen = /fnconfig.ini : ok [18:26:37] copy_file copied 1226 bytes [18:26:37] COMPLETE! [18:26:37] [18:26:37] CF: 70 f5 00 00 66 [18:26:37] sioFuji::sio_process() called [18:26:37] ACK! [18:26:37] Fuji cmd: CLOSE DIRECTORY [18:26:37] COMPLETE! [18:26:37] [18:26:37] CF: 70 f4 00 00 65 [18:26:37] sioFuji::sio_process() called [18:26:37] ACK! [18:26:37] Fuji cmd: READ HOST SLOTS [18:26:37] ->SIO write 256 bytes [18:26:37] COMPLETE! [18:26:37] [18:26:37] CF: 70 f2 00 00 63 [18:26:37] sioFuji::sio_process() called [18:26:37] ACK! [18:26:37] Fuji cmd: READ DEVICE SLOTS [18:26:37] ->SIO write 304 bytes [18:26:37] COMPLETE! [18:26:37] [18:26:37] CF: 70 f4 00 00 65 [18:26:37] sioFuji::sio_process() called [18:26:37] ACK! [18:26:37] Fuji cmd: READ HOST SLOTS [18:26:37] ->SIO write 256 bytes [18:26:37] COMPLETE! [18:26:37] [18:26:37] CF: 70 f2 00 00 63 [18:26:37] sioFuji::sio_process() called [18:26:37] ACK! [18:26:37] Fuji cmd: READ DEVICE SLOTS [18:26:37] ->SIO write 304 bytes [18:26:37] COMPLETE! [18:26:42] [18:26:42] CF: 70 f2 00 00 63 [18:26:42] sioFuji::sio_process() called [18:26:42] ACK! [18:26:42] Fuji cmd: READ DEVICE SLOTS [18:26:42] ->SIO write 304 bytes [18:26:42] COMPLETE! [18:26:42] [18:26:42] CF: 70 f4 00 00 65 [18:26:42] sioFuji::sio_process() called [18:26:42] ACK! [18:26:42] Fuji cmd: READ HOST SLOTS [18:26:42] ->SIO write 256 bytes [18:26:42] COMPLETE! [18:26:42] [18:26:42] CF: 70 d7 00 00 48 [18:26:42] sioFuji::sio_process() called [18:26:42] ACK! [18:26:42] ::mount {0} "SD" [18:26:42] ::mount_local Attempting mount of "SD" [18:26:42] Type is already LOCAL [18:26:42] Selecting '/T/Translator_Side_A_OS_B.ATR' from host #0 as r on D1: [18:26:42] fujiHost #0 opening file path "/T/Translator_Side_A_OS_B.ATR" [18:26:42] fopen = /T/Translator_Side_A_OS_B.ATR : ok [18:26:42] ::get_filesize [18:26:42] disk MOUNT [18:26:43] ATR MOUNT [18:26:43] mounted ATR: paragraphs=5760, sect_size=128, sect_count=720, disk_size=92176 [18:26:43] ::mount {0} "SD" [18:26:43] ::mount_local Attempting mount of "SD" [18:26:43] Type is already LOCAL [18:26:43] Selecting '/B/Bible Baseball (1983)(Davka Corporation)(US)[!][Trans][BASIC].atx' from host #0 as r on D2: [18:26:43] fujiHost #0 opening file path "/B/Bible Baseball (1983)(Davka Corporation)(US)[!][Trans][BASIC].atx" [18:26:43] fopen = /B/Bible Baseball (1983)(Davka Corporation)(US)[!][Trans][BASIC].atx : ok [18:26:43] ::get_filesize [18:26:43] disk MOUNT [18:26:43] ATX MOUNT [18:26:43] ATX image header values: [18:26:43] version: 1, version min: 1 [18:26:43] creator: 0x02, creator ver: 0 [18:26:43] flags: 0x00 [18:26:43] type: 0, density: 0 [18:26:43] imageid: 0x00, image ver: 0 [18:26:43] start: 0x0030 [18:26:43] end: 0x18770 [18:26:43] MediaTypeATX::_load_atx_data starting read [18:26:43] E (75280) diskio_sdmmc: sdmmc_read_blocks failed (257) [18:26:43] failed reading sector list chunk bytes (64, 5) [18:26:43] WARNING: Number of tracks read = 22 [18:26:43] ATX load completed [18:26:43] COMPLETE! [18:26:43] [18:26:43] CF: 70 d9 00 00 4a [18:26:43] sioFuji::sio_process() called [18:26:43] ACK! [18:26:43] COMPLETE! [18:26:44] [18:26:44] CF: 31 53 00 00 84 [18:26:44] disk sio_process() [18:26:44] ACK! [18:26:44] disk STATUS [18:26:44] response: 0x00, 0xff, 0xe0 [18:26:44] ->SIO write 4 bytes [18:26:44] COMPLETE! [18:26:44] [18:26:44] CF: 31 52 01 00 84 [18:26:44] disk sio_process() [18:26:44] ACK! [18:26:44] ATR READ [18:26:44] ->SIO write 128 bytes [18:26:44] COMPLETE! [18:26:44] [18:26:44] CF: 31 52 02 00 85 [18:26:44] disk sio_process() [18:26:44] ACK! [18:26:44] ATR READ [18:26:44] ->SIO write 128 bytes [18:26:44] COMPLETE! [18:26:44] [18:26:44] CF: 31 52 03 00 86 [18:26:44] disk sio_process() [18:26:44] ACK! [18:26:44] ATR READ [18:26:44] ->SIO write 128 bytes [18:26:44] COMPLETE! [18:26:44] [18:26:44] CF: 31 52 04 00 87 [18:26:44] disk sio_process() [18:26:44] ACK! [18:26:44] ATR READ [18:26:44] E (77080) diskio_sdmmc: sdmmc_read_blocks failed (257) [18:26:44] ->SIO write 128 bytes [18:26:44] ERROR! [18:26:44] [18:26:44] CF: 31 52 04 00 87 [18:26:44] disk sio_process() [18:26:44] ACK! [18:26:44] ATR READ [18:26:44] ->SIO write 128 bytes [18:26:44] ERROR! [18:26:45] [18:26:45] CF: 31 52 04 00 87 [18:26:45] disk sio_process() [18:26:45] ACK! [18:26:45] ATR READ [18:26:45] ->SIO write 128 bytes [18:26:45] ERROR! [18:26:45] [18:26:45] CF: 31 52 04 00 87 [18:26:45] disk sio_process() [18:26:45] ACK! [18:26:45] ATR READ [18:26:45] ->SIO write 128 bytes [18:26:45] ERROR! [18:26:45] [18:26:45] CF: 31 52 04 00 87 [18:26:45] disk sio_process() [18:26:45] ACK! [18:26:45] ATR READ [18:26:45] ->SIO write 128 bytes [18:26:45] ERROR! [18:26:45] [18:26:45] CF: 31 52 04 00 87 [18:26:45] disk sio_process() [18:26:45] ACK! [18:26:45] ATR READ [18:26:45] ->SIO write 128 bytes [18:26:45] ERROR! [18:26:45] [18:26:45] CF: 31 52 04 00 87 [18:26:45] disk sio_process() [18:26:45] ACK! [18:26:45] ATR READ [18:26:45] ->SIO write 128 bytes [18:26:45] ERROR! [18:26:45] [18:26:45] CF: 31 52 04 00 87 [18:26:45] disk sio_process() [18:26:45] ACK! [18:26:45] ATR READ [18:26:45] ->SIO write 128 bytes [18:26:45] ERROR! [18:26:45] [18:26:45] CF: 31 52 04 00 87 [18:26:45] disk sio_process() [18:26:45] ACK! [18:26:45] ATR READ [18:26:45] ->SIO write 128 bytes [18:26:45] ERROR! Quote Link to comment Share on other sites More sharing options...
mozzwald Posted February 21 Share Posted February 21 On 1/1/2023 at 12:07 AM, darwinmac said: I thought this ATX file worked with an older version of the Fujinet firmware (I'm not sure about that though), but it does not work with the last two firmware releases (including the December 23rd release). Can you confirm this by flashing something older and testing? With latest firmware I just loaded the Micro League Baseball ATX from a 32GB SD card on FujiNet and it worked fine. I suspect a SD card issue is the culprit. Do you have another card you can try? If not, check the card for errors with a computer. Maybe backup the card, reformat it and copy everything back is worth a try too. Quote Link to comment Share on other sites More sharing options...
darwinmac Posted February 21 Author Share Posted February 21 I have a 16GB microSD card in my Sdrive Max that I can try to use. The SD card that came with my Fujinet was a generic brand. The SD card for my Sdrive Max is a Sandisk. As far as I know, there’s no preparation for using an SD card on the Fujinet other than it needs to be FAT-32 and <= 32 GB. Is that correct? Unfortunately, for me, I tried the SD card that came with my Sdrive Max and had the same result. I unplugged my Syscheck II to make sure there was no conflict with the external memory expansion. It didn’t help. As far as checking the current card, I know about chkdsk on Windows. I haven’t had to do it much on my Mac. I’m thinking Disk Utility can check a disk. I’m using firmware version 0.5.13741956 which is dated January 30th, 2023. Bob C Quote Link to comment Share on other sites More sharing options...
mozzwald Posted February 21 Share Posted February 21 9 hours ago, darwinmac said: I have a 16GB microSD card in my Sdrive Max that I can try to use. The SD card that came with my Fujinet was a generic brand. The SD card for my Sdrive Max is a Sandisk. As far as I know, there’s no preparation for using an SD card on the Fujinet other than it needs to be FAT-32 and <= 32 GB. Is that correct? Formatted as FAT32 is correct 9 hours ago, darwinmac said: I’m using firmware version 0.5.13741956 which is dated January 30th, 2023. Can you try a firmware from early last year and see if that works? You mentioned it *might* have been working before. I still think it's an SD card (or socket) issue, but this is worth a shot. Quote Link to comment Share on other sites More sharing options...
darwinmac Posted February 22 Author Share Posted February 22 (edited) @mozzwald, I'm not crazy! Ok, maybe I am, but it's good to know I wasn't imagining Micro League Baseball working on Fujinet. It works perfectly on the 06/05/2022 firmware build. After that, it only works on the builds labeled "SIO2BT". Since I don't use that functionality, I've skipped those builds in the past. However, I was able to get MLB to run on 2023-01-30 0.5.adfa332c-SIO2BT. If I try the non-SIO2BT build, I get the errors that I posted earlier to @tschak909. The Atari Translator disk/Bible Baseball combination also works with this firmware. As far as hardware, I'm running the 1.6 hardware version that was built by Gavin at Vintage Computer Center. Since his store is no longer open, I knew I was out of luck if I couldn't get it working. We won't be moving until later this year and that's the earliest I can have the MacBook Air set up as a TNFS server. Bob C Edited February 22 by darwinmac Additional information 1 Quote Link to comment Share on other sites More sharing options...
mozzwald Posted February 22 Share Posted February 22 17 minutes ago, darwinmac said: However, I was able to get MLB to run on 2023-01-30 0.5.adfa332c-SIO2BT. If I try the non-SIO2BT build, I get the errors that I posted earlier This is interesting. SIO2BT firmware uses PlatformIO Espressif32 v3.2 and the 'normal' builds use v3.4. Still, if it worked on 6/5/22, I wonder what might be the cause. So you've tested all normal builds newer than 6/5/22 and confirmed the issue is present in all of those? Quote Link to comment Share on other sites More sharing options...
