Bomb Squad 2
intvdave
Now the tuning of the game....
Some thought I was making the game easy. Here are some changes to fix this.
- The randomness of a board being CUT OUT vs REPLACE increased the more digit you selected to solve. It is now in reverse.
- There will be more fires.
- More board shaking.
- With the option of not having all the parts called out in sequence, parts of a circuit can be either REPLACE or CUT OUT. It is no longer the entire circuit is one or the other. No more easy circuits.
These changes will definitely increase the difficulty of the game and change the dynamics.
  • 4 weeks later...
Super Pro Bomb Squad seems to be wrapped up. Below is the full list of changes to the game. Off to Super Pro B-17....
; options screen to allow player to play with different settings
; when circuit board first comes up, the first selected tool will appear in center of screen
; tools remain in relative position to prior tool
; set new color for fire extinguisher
; only call out first piece to fix
; do not show score on circuit board - show how many pieces are left to fix
; when a piece is properly replaced, call out the next piece to fix if any are left
; piece flashes black instead of white - flashes quicker and easier to see
; message shows "EXIT NOW" when a circuit board is completely solved
; when a piece is dropped off on top of screen, it exits at top right of screen
; pieces move off the screen quicker
; show a preview of the last piece removed (color or shape) from the circuit board. No need to remember what it was.
; both lower side buttons pick up and drop - no need to use left and right side buttons
; on the code screen, press the number on the controller corresponding to the code digit to see possible solutions
; must complete 3 boards before being able to solve digit
; background of time matches screen background - code screen had green background
; countdown timer shows (left of preview piece) when "wrong order" or part is on fire
; circuit explodes in 9 seconds for all levels
; can enter codes with 45 seconds left in the game
; option to black out on code screen 3 boxes that do not help solve the code
; show stats when you win - fomat: D:y C:y T:2 L:x D:x || coDe hint - Circuit hint - Time  - Level - Digits
; originally, CUT THIS OUT was more likely the more digits to solve. Now, it is less likely at higher levels
; game time defaults to 10 x amount of digits to solve - time can be changed
; can exit the circuit with 20 seconds instead of 15
  • Like 6
