82-T/A Posted November 17, 2023 Share Posted November 17, 2023 Hey guys, I'm not so fancy, most of my stuff is still USB Micro-B. So I'm going to order a USB-C power brick and cable off Amazon today, and just wanted to know what I should get. I realize it's a power standard, but is there a minimum wattage I should get? Quote Link to comment Share on other sites More sharing options...
Blinky Posted November 17, 2023 Share Posted November 17, 2023 Just wondering. doesn't your TV have a USB port that you can use? 2 Quote Link to comment Share on other sites More sharing options...
Laner Posted November 17, 2023 Share Posted November 17, 2023 7 minutes ago, Blinky said: Just wondering. doesn't your TV have a USB port that you can use? A lot of TV USB ports provide minimal power (and I don't know of many with usb-c ports); It may be better to get a separate power supply. Something like this should be more than sufficient: https://www.amazon.com/iPhone-Charger-Delivery-AirPods-Samsung/dp/B09CKBPZ34/ref=sr_1_2_sspa?crid=2RP6N1VAOUND8&keywords=usb-c+power+adapter&qid=1700233183&sprefix=usb-c+power%2Caps%2C107&sr=8-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1 1 Quote Link to comment Share on other sites More sharing options...
Flyindrew Posted November 17, 2023 Share Posted November 17, 2023 I was also wondering if one cant simply use their old original 2600 power brick or Atari VCS power brick? 1 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted November 17, 2023 Share Posted November 17, 2023 We should address this to @Ben from Plaion. I am sure he will notice now. 1 Quote Link to comment Share on other sites More sharing options...
82-T/A Posted November 17, 2023 Author Share Posted November 17, 2023 28 minutes ago, Blinky said: Just wondering. doesn't your TV have a USB port that you can use? It does, but it's not exactly ideal for my set-up since everything runs through the wall... 14 minutes ago, Laner said: A lot of TV USB ports provide minimal power (and I don't know of many with usb-c ports); It may be better to get a separate power supply. Something like this should be more than sufficient: https://www.amazon.com/iPhone-Charger-Delivery-AirPods-Samsung/dp/B09CKBPZ34/ref=sr_1_2_sspa?crid=2RP6N1VAOUND8&keywords=usb-c+power+adapter&qid=1700233183&sprefix=usb-c+power%2Caps%2C107&sr=8-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1 Thanks, I was looking at those... but I'm curious before I buy, if anyone can take a screen shot of the back of their Atari 2600+... it should show the power requirements, and then I'll probably get something specific for that. Ideally, I don't want to get something that's made for iPhones, but more like a power brick like what I have for the Atari VCS (new one). Thank you though, I appreciate it! 1 Quote Link to comment Share on other sites More sharing options...
Ben from Plaion Posted November 17, 2023 Share Posted November 17, 2023 It needs a 1A USB plug. The Atari 2600+ draws very little power. The one posted above will be more then adequate Quote Link to comment Share on other sites More sharing options...
Ben from Plaion Posted November 17, 2023 Share Posted November 17, 2023 (edited) deleted Edited November 17, 2023 by Ben from Plaion wrong thread Quote Link to comment Share on other sites More sharing options...
Mockduck Posted November 17, 2023 Share Posted November 17, 2023 Any old USB brick from a phone or other device should work, and your TV's USB can also handle it just fine. I've already read someone using a portable USB power bank to run it as well. 2 Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted November 17, 2023 Share Posted November 17, 2023 I'm likely to just use an old Apple iPad charger brick I've got sitting here as I've a few of those. Pretty sure the 2600+ comes with a USB-A to USB-C cable right? 1 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted November 17, 2023 Share Posted November 17, 2023 (edited) 13 minutes ago, Mockduck said: Any old USB brick from a phone or other device should work, and your TV's USB can also handle it just fine. I've already read someone using a portable USB power bank to run it as well. Not any, older ones used to have only 500mA. But any a bit more modern one should do. Edited November 17, 2023 by Thomas Jentzsch 1 Quote Link to comment Share on other sites More sharing options...
Blinky Posted November 17, 2023 Share Posted November 17, 2023 . 59 minutes ago, Laner said: I don't know of many with usb-c ports The USB-C cable included has a type A connector on one side which fits into regular USB ports of TVs. Quote Link to comment Share on other sites More sharing options...
+LS650 Posted November 17, 2023 Share Posted November 17, 2023 2 hours ago, Blinky said: Just wondering. doesn't your TV have a USB port that you can use? I have a couple of HDMI screens that do not have USB ports. 1 Quote Link to comment Share on other sites More sharing options...
MittyOz Posted November 17, 2023 Share Posted November 17, 2023 I plugged mine into my computer to start with, worked fine off that. What didn't work was a Lenovo USB C Power Supply for a laptop, which I was surprised at. An Apple USB A Charger worked as well. Quote Link to comment Share on other sites More sharing options...
MaxDiehard Posted November 17, 2023 Share Posted November 17, 2023 Doesn't require a power brick. I've got mine plugged into the front USB port of my PS5. Quote Link to comment Share on other sites More sharing options...
Blinky Posted November 18, 2023 Share Posted November 18, 2023 Got mine today and powered mine throug TV. doesn't even consume 0.1A (100mA) when playing games 2 Quote Link to comment Share on other sites More sharing options...
82-T/A Posted November 18, 2023 Author Share Posted November 18, 2023 10 minutes ago, Blinky said: Got mine today and powered mine throug TV. doesn't even consume 0.1A (100mA) when playing games That is a super cool little gadget! I ended up getting this: https://www.amazon.com/gp/product/B08M6D7LXM/ Quote Link to comment Share on other sites More sharing options...
Blinky Posted November 18, 2023 Share Posted November 18, 2023 3 minutes ago, 82-T/A said: That is a super cool little gadget! Yes it is very convenient and cost just a few buck from Aliexpress. I sometimes use it to see if I got the correct fast charger for my phone. 8 minutes ago, 82-T/A said: I ended up getting this More then enough and when you don't use your 2600+ you can charge your phone with it too! Quote Link to comment Share on other sites More sharing options...
Sean_1970 Posted November 18, 2023 Share Posted November 18, 2023 I have a mains-powered USB hub that is used to power the hard drive for my Wii U and has a spare port, which is working well. Only needs 1amp at 5v according to the sticker on the bottom and my old USB-A iPhone charger outputs 1.5amp so that’s a viable alternative too. I was surprised the cable wasn’t USB-C on both ends, but this worked out better for me. Oh and a nice touch on the USB cable is the Atari Fuji logo replacing the USB trident - the pack-in HDMI cable similarly has the Fuji on it - pretty neat! Quote Link to comment Share on other sites More sharing options...
Spanner Posted November 19, 2023 Share Posted November 19, 2023 I use the one I use for my THEC64 Mini, THEVIC20 and THEA500 Mini, its from the Capcom Home Arcade. its v5 3A it a green UK plug USB. Quote Link to comment Share on other sites More sharing options...
Brad_from_the_80s Posted November 21, 2023 Share Posted November 21, 2023 I use my TV's USB for a small thumb drive that allows me to pause/rewind OTA TV. They don't put out a lot of power anyway. For anybody who happens to have or use a newer Atari Flashback or similar AtGames products, these usually include a micro usb 5V/1A AC adapter. It works great with other retro mini consoles too, like the NES/SNES Classic, Genesis mini, PC Engine mini, PS Classic, etc. And with just a cheap little 1-inch micro usb to usb-c adapter it will power your 2600+ just fine. Ask me how I know. They come in bags of maybe 10 for a few dollars. So with that small adapter I can swap my 2600+ out in the same spot where I use other mini consoles with the same power and HDMI cables. Or you can do the same thing with any other working micro-usb power solution you might have. Quote Link to comment Share on other sites More sharing options...
tradyblix Posted November 22, 2023 Share Posted November 22, 2023 (edited) On 11/17/2023 at 9:01 AM, Laner said: A lot of TV USB ports provide minimal power (and I don't know of many with usb-c ports); It may be better to get a separate power supply. Something like this should be more than sufficient: https://www.amazon.com/iPhone-Charger-Delivery-AirPods-Samsung/dp/B09CKBPZ34/ref=sr_1_2_sspa?crid=2RP6N1VAOUND8&keywords=usb-c+power+adapter&qid=1700233183&sprefix=usb-c+power%2Caps%2C107&sr=8-2-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1 Runs off recent LG TV (C series) USB ports with no issues. HDMI 4 with adjacent USB for the win. Thank you LG for giving me 4 HDMIS and 3 USBs. Finally halfway adequate inputs lol Edited November 22, 2023 by tradyblix 1 Quote Link to comment Share on other sites More sharing options...
E. King Posted November 23, 2023 Share Posted November 23, 2023 This is the best power brick you can get for your 2600+ You can use 1 of the 4 USB ports on the VCS to power your 2600+ 2 Quote Link to comment Share on other sites More sharing options...
T.A.P. Posted December 6, 2023 Share Posted December 6, 2023 Will this work? https://www.bestbuy.com/site/best-buy-essentials-45-w-usb-c-compact-and-foldable-wall-charger-for-smartphones-tablet-and-more-black/6471947.p?skuId=6471947 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 6, 2023 Share Posted December 6, 2023 5 minutes ago, T.A.P. said: Will this work? https://www.bestbuy.com/site/best-buy-essentials-45-w-usb-c-compact-and-foldable-wall-charger-for-smartphones-tablet-and-more-black/6471947.p?skuId=6471947 Waaay too strong. You can use the USB port of your TV or almost any cheap or old USB power supply that fits. 1A is plenty. Quote Link to comment Share on other sites More sharing options...
