+Intellivision Master Posted December 22, 2023 Share Posted December 22, 2023 I had the dipswitch set for the Video Pinball game. I inserted the cart into the console. The cart loaded and the right game displayed. But when using the controller, nothing would happen. I had to use the reset button on the console. Then I was able to use the controller & the game worked fine. This is the only game I played so far on the multi-cart. I wasn't expecting to do a reset in order to get the game working. At first I thought something was wrong with the controller. Anyway, I'm glad the reset fixed the issue. Has anyone else had this happen when using the multi-cart? Quote Link to comment Share on other sites More sharing options...
Ben from Plaion Posted December 22, 2023 Share Posted December 22, 2023 Yes thats exactly how you start to play in most 2600 games. Press Game Reset lever to start. Was the same back in the day. 6 Quote Link to comment Share on other sites More sharing options...
+Intellivision Master Posted December 22, 2023 Author Share Posted December 22, 2023 (edited) 4 minutes ago, Ben from Plaion said: Yes thats exactly how you start to play in most 2600 games. Press Game Reset lever to start. Was the same back in the day. Good to know. When I play Berzerk, I just press the fire button to start. No need to use reset. That's why I questioned it because I didn't know if it was normal. I thought reset was for starting the game over or if there was a problem. I never had an Atari console before and I never used a multi-cart on one. I used to have the Atari FB 9 but that only played digital games. Having an Atari console with physical games is a new experience for me. Edited December 22, 2023 by Intellivision Master 1 Quote Link to comment Share on other sites More sharing options...
Brad_from_the_80s Posted December 22, 2023 Share Posted December 22, 2023 There are conventions for starting a 2600 game, but Atari conventions were never strictly followed. But overall it's pretty simple. Early games (1977-1980-ish?): select game mode with Select switch or accept default, start game with Reset switch Later games (1981+): select game mode with Select switch or accept default, start game with Reset switch OR maybe Fire button 3rd party games: follow Atari conventions except when they don't 🤔 ??? When in doubt, check the game manual, or just try it out. 4 Quote Link to comment Share on other sites More sharing options...
Ben from Plaion Posted December 22, 2023 Share Posted December 22, 2023 Yup thats right Berzerk can start with a fire button press but a lot of 2600 games need the Game Reset Lever to start. Hope you get many hours of enjoyment out of your machine. 1 Quote Link to comment Share on other sites More sharing options...
+littaum Posted December 22, 2023 Share Posted December 22, 2023 "Couch compliance" was a very rare thing back then. I think they expected you to be playing on the floor cross legged next to the console staring up at the TV. Which in their defense was how you had to do it with the early pong consoles (some of which had the control dials built directly into the system!) 2 Quote Link to comment Share on other sites More sharing options...
+Intellivision Master Posted December 22, 2023 Author Share Posted December 22, 2023 1 minute ago, Brad_from_the_80s said: There are conventions for starting a 2600 game, but Atari conventions were never strictly followed. But overall it's pretty simple. Early games (1977-1980-ish?): select game mode with Select switch or accept default, start game with Reset switch Later games (1981+): select game mode with Select switch or accept default, start game with Reset switch OR maybe Fire button 3rd party games: follow Atari conventions except when they don't 🤔 ??? When in doubt, check the game manual, or just try it out. Thanks for the detailed information. If I had a manual I would have looked into that. Luckily I knew to just hit reset. 1 Quote Link to comment Share on other sites More sharing options...
+Intellivision Master Posted December 22, 2023 Author Share Posted December 22, 2023 3 minutes ago, Ben from Plaion said: Yup thats right Berzerk can start with a fire button press but a lot of 2600 games need the Game Reset Lever to start. Hope you get many hours of enjoyment out of your machine. I'll remember to use the reset lever from now on if a game doesn't start with the controller. I'm liking the console. It's neat to have an Atari 2600 that really looks like the original from back in the day. And it plays carts which is great. Nothing like putting in a real cart and taking it out. You can't get that with digital. 2 Quote Link to comment Share on other sites More sharing options...
Brad_from_the_80s Posted December 22, 2023 Share Posted December 22, 2023 1 minute ago, Intellivision Master said: Thanks for the detailed information. If I had a manual I would have looked into that. Luckily I knew to just hit reset. Just FYI, click "2600" at the top of the screen here and then find your game and go to the manual scan. All the manual contents (or enough of them) should be there. 4 Quote Link to comment Share on other sites More sharing options...
desiv Posted December 22, 2023 Share Posted December 22, 2023 (edited) 13 minutes ago, Brad_from_the_80s said: All the manual contents (or enough of them) should be there. Good info... Although I kind of wondered when I saw this thread and decided to check. The manual is there for Video Olympics, but unless I missed it, it doesn't say to hit Reset to start the game... OK, page 5 of what I think is the original VCS manual does say it: Depress the RESET switch. Game action will begin. By depressing the RESET switch anytime during the game, the score will reset to 0-0. Edited December 22, 2023 by desiv 2 Quote Link to comment Share on other sites More sharing options...
Video Posted December 22, 2023 Share Posted December 22, 2023 I was going to say, many Atari games actually do use the console to start, rather than just push fire. 2600 intended to use the console for options and its why the short stubby 4' controller cord, while the system cables are a mile long, to keep the system close at hand. I think its why so many have said, instructions pls. I love the cardboard sleeve, but the 2600 isn't very intuitive, especially for those that didn't grow up with it. And many games aren't standardized. Some fire to start, some reset, some select...don't get me started on choosing difficulty, which is all over the place. Luckily, this day in age, we have help. Atariage is your friend, most instructions are scanned and easily accessible here. Don't know how "printer friendly" they are, but I often never look at one again once I know game settings and start. 3 Quote Link to comment Share on other sites More sharing options...
Sean_1970 Posted December 23, 2023 Share Posted December 23, 2023 (edited) I don’t know if this is true of any other games, but Dark Cavern from M-Network starts when you move the joystick. Nothing is consistent from game to game; especially with third parties: difficulty switches can be for difficulty one game, for another it just changes a feature or they aren’t used. Some games use the B&W/Colour switch for a function like displaying a map. Manuals are really useful! Edited December 23, 2023 by Sean_1970 2 Quote Link to comment Share on other sites More sharing options...
MysticSword Posted December 23, 2023 Share Posted December 23, 2023 26 minutes ago, Sean_1970 said: I don’t know if this is true of any other games, but Dark Cavern from M-Network starts when you move the joystick. Nothing is consistent from game to game; especially with third parties: difficulty switches can be for difficulty one game, for another it just changes a feature or they aren’t used. Some games use the B&W/Colour switch for a function like displaying a map. Manuals are really useful! Pitfall is like that too, where the countdown timer starts when you first move. Though when you run out of lives, it requires using the Reset switch to start a new game, then it waits again until moving to start the countdown timer. Yeah, it can be inconsistent between various games. What can throw me off though is where the majority (or most) of games (especially single player games) require the controller / joystick plugged into the left-side, but there are some that require the controller to be plugged into the right-side (even for a single Player game), like I've recently discovered with Wizard of Wor (which is a game I got recently to play on my 2600+). 2 Quote Link to comment Share on other sites More sharing options...
Sean_1970 Posted December 23, 2023 Share Posted December 23, 2023 25 minutes ago, MysticSword said: Pitfall is like that too, where the countdown timer starts when you first move. Though when you run out of lives, it requires using the Reset switch to start a new game, then it waits again until moving to start the countdown timer. Yeah, it can be inconsistent between various games. What can throw me off though is where the majority (or most) of games (especially single player games) require the controller / joystick plugged into the left-side, but there are some that require the controller to be plugged into the right-side (even for a single Player game), like I've recently discovered with Wizard of Wor (which is a game I got recently to play on my 2600+). That’s weird - I have the PAL version and it plugs into the left. I suppose it makes sense given player one starts on the right side of the screen. 1 Quote Link to comment Share on other sites More sharing options...
Blinky Posted December 23, 2023 Share Posted December 23, 2023 20 hours ago, Brad_from_the_80s said: ust FYI, click "2600" at the top of the screen here and then find your game and go to the manual scan. Manuals for the 10 in 1 games can also be found here on the Atari site 1 Quote Link to comment Share on other sites More sharing options...
chad5200 Posted December 23, 2023 Share Posted December 23, 2023 Every reference to the word "PEEK" and the word "VISIBILITY" in the GAME MODES section for the Maze Craze manual is spelled wrong on Atari's web site: https://atari.com/pages/mazecraze Quote Link to comment Share on other sites More sharing options...
Ben from Plaion Posted December 23, 2023 Share Posted December 23, 2023 22 hours ago, littaum said: "Couch compliance" was a very rare thing back then. I think they expected you to be playing on the floor cross legged next to the console staring up at the TV. Which in their defense was how you had to do it with the early pong consoles (some of which had the control dials built directly into the system!) Still got to get up and press levers, but much comfier with a long lead, or really whats best is a wireless controller 4 Quote Link to comment Share on other sites More sharing options...
Ben from Plaion Posted December 23, 2023 Share Posted December 23, 2023 37 minutes ago, chad5200 said: Every reference to the word "PEEK" and the word "VISIBILITY" in the GAME MODES section for the Maze Craze manual is spelled wrong on Atari's web site: https://atari.com/pages/mazecraze noted Quote Link to comment Share on other sites More sharing options...
KainXavier Posted December 24, 2023 Share Posted December 24, 2023 16 hours ago, Ben from Plaion said: Still got to get up and press levers, but much comfier with a long lead, or really whats best is a wireless controller Is that a cropped photo of an existing product or are you teasing us with a new one? 1 Quote Link to comment Share on other sites More sharing options...
+Intellivision Master Posted December 24, 2023 Author Share Posted December 24, 2023 6 hours ago, KainXavier said: Is that a cropped photo of an existing product or are you teasing us with a new one? Hopefully it's real. It would be nice to have extension cables for the 2600+. 1 Quote Link to comment Share on other sites More sharing options...
MarcinJ Posted December 24, 2023 Share Posted December 24, 2023 On 12/23/2023 at 4:27 PM, Ben from Plaion said: noted The manual for Realsports Volleyball is also missing. The hyperlink redirects to the Surrender manual. Why on Earth no one noticed this up to now. 😉 Quote Link to comment Share on other sites More sharing options...
