Overange Posted December 28, 2023 Share Posted December 28, 2023 I've found a simple solution for the obsolescence issue related to the 24-pin keyboard ribbon connectors ( 2.54mm ds1020-24st1d-1 ) on Atari XL and XE Systems. This is going to be a great option for those wanting to build their own Motherboards. As you can see in the images, it's a 26-pin variety. To make it compatible with the original 24-pin version, all it requires is the removal of the two end contacts for the 800XL, 65XE, and 130XE machines and for the 600XL you'll need to remove the opposite two contacts. Removing the unused contacts is a straightforward process, and I recommend doing this before soldering it to the main board. If anyone is interested in purchasing any of these, feel free to let me know. I'm open to offering deals for larger bundles as well. 8 1 Quote Link to comment Share on other sites More sharing options...
Ray Gillman Posted December 28, 2023 Share Posted December 28, 2023 (edited) My issue is the ribbon got mangled so I need to think of a way to replace either the original 800xl keyboard+ribbon or just the ribbon? My connector looks fine. Wondering if we might be able to think of a way to make a USB keyboard to 24 pin output ribbon adapter? Edited December 28, 2023 by Ray Gillman one more thought Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted December 28, 2023 Share Posted December 28, 2023 (edited) 11 minutes ago, Ray Gillman said: My issue is the ribbon got mangled so I need to think of a way to replace either the original 800xl keyboard+ribbon or just the ribbon? My connector looks fine. Wondering if we might be able to think of a way to make a USB keyboard to 24 pin output ribbon adapter? It requires a lots of electronics, interfacing and key mapping in between since apart from anything else the Atari keyboard is a different layout than a standard modern ????USB keyboard. There is already the AKI usb adapter: https://retrolemon.co.uk/atari-8bit-upgrades/130-aki-usb-keyboard-interface.html Edited December 28, 2023 by Beeblebrox 4 Quote Link to comment Share on other sites More sharing options...
+Larry Posted December 29, 2023 Share Posted December 29, 2023 Does it work with wireless type keyboards? Just curious. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted December 29, 2023 Share Posted December 29, 2023 3 minutes ago, Larry said: Does it work with wireless type keyboards? Just curious. Yup. If your wireless USB keyboard has a 2.4ghz USB dongle for example it will work. Mine has a wireless dongle. Don't think USB bluetooth dongle keyboards will work though. 1 Quote Link to comment Share on other sites More sharing options...
djglish Posted December 29, 2023 Share Posted December 29, 2023 (edited) There should be a way to make a USB keyboard work with the 8-bit computers. I did the opposite and made an 800XL keyboard work with a Windows 10 computer. I put a mini-PC in the 800XL shell and found the instructions to make an adapter using an Arduino board. Having this connector would have made things a lot easier. DJ Sures did a video on the keyboard conversion and posted the Coding. I tell people that I couldn't program my way out of a paper bag, but I can put something together if the instructions are good. Edited December 29, 2023 by djglish needed to add info Quote Link to comment Share on other sites More sharing options...
+Larry Posted December 31, 2023 Share Posted December 31, 2023 Now there's just one other little thing... Does anyone know if there are PC keyboards with programmable keys that can be made to function more like our Atari keys? I know that lots of people love using a PC keyboard with the Atari, but I'm not one of them. Anyone have any experience with something similar? And would such a keyboard work with the AKI adapter? Quote Link to comment Share on other sites More sharing options...
Jfcatari Posted December 31, 2023 Share Posted December 31, 2023 On 12/28/2023 at 9:01 AM, Overange said: I've found a simple solution for the obsolescence issue related to the 24-pin keyboard ribbon connectors ( 2.54mm ds1020-24st1d-1 ) on Atari XL and XE Systems. This is going to be a great option for those wanting to build their own Motherboards. As you can see in the images, it's a 26-pin variety. To make it compatible with the original 24-pin version, all it requires is the removal of the two end contacts for the 800XL, 65XE, and 130XE machines and for the 600XL you'll need to remove the opposite two contacts. Removing the unused contacts is a straightforward process, and I recommend doing this before soldering it to the main board. If anyone is interested in purchasing any of these, feel free to let me know. I'm open to offering deals for larger bundles as well. Do you have a source link for these? Quote Link to comment Share on other sites More sharing options...
Overange Posted December 31, 2023 Author Share Posted December 31, 2023 1 hour ago, Jfcatari said: Do you have a source link for these? If you want to purchase some, Please DM me. Thanks Quote Link to comment Share on other sites More sharing options...
