magesticmage Posted December 31, 2023 Share Posted December 31, 2023 Creating a ATR drive image and copying *.BAS file to it on PC for My FujiNet What PC Program is everyone using to create ATR Drives and how do you copy of basic *.BAS to it ? I have DOS 2.5 booting fine with my FujiNet but want to load some basic games from a ATR image..... Quote Link to comment Share on other sites More sharing options...
chevymad Posted December 31, 2023 Share Posted December 31, 2023 (edited) I use MakeATR. Create a new disk in whatever flavor you need, then insert files to it. Edited December 31, 2023 by chevymad Quote Link to comment Share on other sites More sharing options...
TZJB Posted December 31, 2023 Share Posted December 31, 2023 14 hours ago, magesticmage said: Creating a ATR drive image and copying *.BAS file to it on PC for My FujiNet What PC Program is everyone using to create ATR Drives and how do you copy of basic *.BAS to it ? I have DOS 2.5 booting fine with my FujiNet but want to load some basic games from a ATR image..... I use Altirra, it does everything you could imagine. 1 Quote Link to comment Share on other sites More sharing options...
magesticmage Posted January 2 Author Share Posted January 2 On 12/31/2023 at 12:13 PM, chevymad said: I use MakeATR. Create a new disk in whatever flavor you need, then insert files to it. I cant get dos 2.5 to see the files i created. the app makeart.exe that i found is a 16 bit and wont run in my 64bit windows os. i found mkatr and compiled it in Linux from here https://github.com/dmsc/mkatr and created a drive with some basic files in it. I have drive 1 as DOS and drive 2 as my image i created with mkatr lsatr shows the BAS files i included onto the ATR file $ dir disk2.atr disk.atr user@magemint:~/Desktop/Share/atari_basic $ lsatr disk2.atr disk2.atr: 720 sectors of 128 bytes, volume name 'DSK_CD51'. 24175 28-08-21 01:59:58 /ADVNTISL.BAS 10669 28-08-21 01:58:24 /BIFFDROP.BAS 5243 28-08-21 01:38:44 /SYNDRUM.BAS 396 28-08-21 01:59:35 /TUBES.BAS but dos 2.5 on the Atari shows nothing on drive 2?? Quote Link to comment Share on other sites More sharing options...
magesticmage Posted January 2 Author Share Posted January 2 On 12/31/2023 at 12:42 PM, TZJB said: I use Altirra, it does everything you could imagine. How do you create an empty ATR Drive in Altirra? Quote Link to comment Share on other sites More sharing options...
chevymad Posted January 2 Share Posted January 2 This is the file I use. I have no idea about dos 2.5 or not. Looks like it just says atari dos and then you choose a density. makeATR.exe Quote Link to comment Share on other sites More sharing options...
magesticmage Posted January 2 Author Share Posted January 2 1 hour ago, magesticmage said: How do you create an empty ATR Drive in Altirra? never mind, figured it out 1 Quote Link to comment Share on other sites More sharing options...
magesticmage Posted January 2 Author Share Posted January 2 33 minutes ago, chevymad said: This is the file I use. I have no idea about dos 2.5 or not. Looks like it just says atari dos and then you choose a density. makeATR.exe 144 kB · 0 downloads thank you Quote Link to comment Share on other sites More sharing options...
+Larry Posted January 20 Share Posted January 20 mini-bump... I've always used APE to create ATR's, but it seems like there should be a way to do it internally in Altirra. But I don't see anything in the drop down menus, nor in the HELP. Is there? Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted January 20 Share Posted January 20 Use Altirra's Disk Manager. It can create formatted images and you can copy files between Altirra and you local PC. Only DOS needs to be written to a disk from inside Altirra. @Albert Attaching the below (animated) GIF directly fails and even crashed my Firefox. AltirraDiskManager.gif.zip Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted January 21 Share Posted January 21 do you mean phaeron? @phaeron Quote Link to comment Share on other sites More sharing options...
tschak909 Posted January 21 Share Posted January 21 Why has absolutely nobody noticed that you can create a new ATR directly inside CONFIG? You guys are making it 50 times harder than you should. Select the appropriate host slot, and then press 'N' for New. 2024-01-21 13-43-44.mp4 -Thom 3 Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted January 21 Share Posted January 21 16 hours ago, _The Doctor__ said: do you mean phaeron? @phaeron Do you ask me? If so : No, the non-working upload is a bug or feature of Invision. Quote Link to comment Share on other sites More sharing options...
