phoney Posted February 5 Share Posted February 5 Hey, do any of the graphical OS attempts run on an 800 (with a reifsnyder Axlon 1MB board?) Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted February 5 Share Posted February 5 (edited) The Axlon board afaik only gives you the 48k plus extended ram 1008k (1056k total) and doesn't provide any updated OS roms. It does, however, support SpartaDOS X. As such, I'd imagine some GUI DOS OS software would run, unless their are any stock 800 OS ROM barriers. (Maybe they will only run on XL/XE OS?) Do you have any in mind you wanted to try? See here:http://www.atarimania.com/faq-atari-400-800-xl-xe-are-there-graphical-user-interfaces-guis_88.html Also, how are you intending to load the GUIs? Edited February 5 by Beeblebrox Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 5 Share Posted February 5 I doubt the OS would be a stopping point - more likely that most 800 expansion banking methods are vastly different to what the XL uses. 1 Quote Link to comment Share on other sites More sharing options...
phoney Posted February 5 Author Share Posted February 5 I have a FujiNet - would boot them from images on SD using the virtual drives. Yes, I think the question is which ones run in 48K+Axlon So far I haven't been able to run SpartaDOS X because it requires a physical cartridge, but I assume these graphical OS ATRs are bootable. Quote Link to comment Share on other sites More sharing options...
+scorpio_ny Posted February 5 Share Posted February 5 5 hours ago, phoney said: Hey, do any of the graphical OS attempts run on an 800 (with a reifsnyder Axlon 1MB board?) 4 hours ago, Rybags said: I doubt the OS would be a stopping point - more likely that most 800 expansion banking methods are vastly different to what the XL uses With Incognito it allow XL banking scheme. But, that is a much more involved and expensive solution. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted February 5 Share Posted February 5 2 minutes ago, scorpio_ny said: With Incognito it allow XL banking scheme. But, that is a much more involved and expensive solution. In terms of either installing incognito, (which is more involved but actually not as complicated as one might think), and installing the plug in axlon 1056 board, cost wise incognito isn't that much more expensive in the grand scheme of things. $129 us dollars for incognito $74 us dollars for the Axlon 1056k Incognito brings to the table a considerable amount of additional functionality which is well known. Don't get me wrong. The Axlon 1056k is a great addition to an 800. 🙂 Quote Link to comment Share on other sites More sharing options...
phoney Posted February 5 Author Share Posted February 5 Soldering is a hard no for me. That's the issue there. I WILL break my computer. 1 Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted February 5 Share Posted February 5 (edited) 13 minutes ago, phoney said: Soldering is a hard no for me. That's the issue there. I WILL break my computer. Understood. Just thought I'd mention it. I've installed many incognitos. Is guess where there is no desire to undertake the install, and where there is budget, you can get someone near you to do it for you. Anyway, moot as you have your current axlon 1056k setup. It's just if you want to run a GUI on it, you might need perhaps run it on another A8 if it turns out not possible on the 800.:) I don't have much experience with the various old and newer A8 gui's. Check out the atarimania link I posted earlier and have a google search of Atariage (AA) for those that catch your eye. Chances are it will have be discussed on AA. Edit: where are you based BTW. It's not clear. Edited February 5 by Beeblebrox Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted February 5 Share Posted February 5 @phoneyJust to say for me the dream would be to see Fjc's Gui see completion. It is a massive job as it was started years ago. He is incredibly busy and something like this is very involved. If you've not seen it it is pretty amazing. 2 Quote Link to comment Share on other sites More sharing options...
+mytek Posted February 6 Share Posted February 6 Aside from Jon's GUI demo (which is fast and smooth as silk), most GUIs would probably require some form of acceleration to make them usable, or another word for it would be "tolerable". Of course for purely research purposes it's fun to try some of these out, but from a practical standpoint even BITD they were too slow for the non-accelerated 6502 to handle. I think the same holds true for GEOS on the C64, but at least there were 3rd party hardware add-ons that did make it quite usable, although quite expensive as well. Personally my favorite method of doing stuff on the A8 such as accessing disk files, is best done with a CLI such as Spartados or BW-Dos. Even using Atari or MyDos with their menu, adds unnecessary steps to get something done. The graphical desktop really required better graphics and horsepower in most cases, with the only exception being the direction of Jon's GUI. Quote Link to comment Share on other sites More sharing options...
+MrFish Posted February 6 Share Posted February 6 24 minutes ago, mytek said: GEOS on the C64 GEOS on the Atari is better (faster)! GEOS 2.0 for 8-bit Atari 3 Quote Link to comment Share on other sites More sharing options...
