+atari2600land Posted yesterday at 03:01 AM Share Posted yesterday at 03:01 AM You get matched tiles off the screen. It sounds easy, but I can't beat any level. In fact, the lowest number of tiles left I've got so far before there were no moves is 56. I'm beginning to think it's impossible. Quote Link to comment Share on other sites More sharing options...
Nop90 Posted 21 hours ago Share Posted 21 hours ago It ìs possible. The game requires some strategy in removing tiles, don't remove tiles only because at a first glance you can, try first to free es much tiles possible for the next move, keep count how many tiles of each kind are still trapped, estimate for each possible move the probability to get stuck at a later point, and your score will improve. Quote Link to comment Share on other sites More sharing options...
LordKraken Posted 20 hours ago Share Posted 20 hours ago Yeah it's a bit more strategic that it seems at first glance. I haven't looked at the math yet but there are probably some initial configurations that can't be beaten (but it must be relatively rare). Quote Link to comment Share on other sites More sharing options...
Stephen Moss Posted 19 hours ago Share Posted 19 hours ago It also depends on the layout of the tiles, you will probably find it help to try and remove them roughly one layer at at time otherwise you can find the tile you want is either surrounded by other/partially under other tiles and so cannot be removed because it is not on a top level and therefore is blocked in. Memory is a little fuzzy as it has been a while since I played but I think that to be removable a tile must have at least one free edge and no tile directly/partially on top of it, so as @Nop90 said, if you have more that two of the same tiles of the same type that you can remove, think careful about which pairs you remove and when so as to free up as many new tiles for removal as possible. Quote Link to comment Share on other sites More sharing options...
Fadest Posted 17 hours ago Share Posted 17 hours ago 3 hours ago, LordKraken said: Yeah it's a bit more strategic that it seems at first glance. I haven't looked at the math yet but there are probably some initial configurations that can't be beaten (but it must be relatively rare). Well, if 3 same tiles are topped, basically you can't win. I hope the distribution algorithm is made in order to avoid this Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted 11 hours ago Share Posted 11 hours ago Here's a strategy I use, maybe it will help. 1. Realize that most layouts are solvable, it just depends on how you pull tiles. AS @Fadest says, there is a random possibility that three of the same will be on top of one another, but my experience is that is lower than you might think. 2. Realize that there are FOUR of every tile. There are 4 seasons, 4 flowers, etc. So even though those might look different, they still count as a group of four. Always, always, always, look for the ability to pull groups of four off. 3. Have a definite game plan: try to free up more tiles with your moves. So, if you have a choice between an edge piece that will only open 1-2 and a "pile" piece that will open three or four, go for the pile. Always start with pulling pieces off of the pile. Always. Always. Always. If necessary, look for ways to pull pile pieces by searching for a path to do so (i.e., "Okay, so I need a season match to pull the top one off, there's an Autumn near the edge here, let me see if I can 4-pull towards that" 4. The trickiest thing to do is when you see a three pull. Leave those until you are absolutely certain the 4th one is not hiding underneath one of those three. This may all seem obvious, so YMMV. It has served me well. So much so that my friends will not play head-to-head with me as I pull tiles off too quickly. -M Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted 11 hours ago Share Posted 11 hours ago The sega master system Shanghai is the only acceptable game in the genre. Have you tried unplugging the Lynx and turning your SMS on again? UPDATE: Despite my flippant tone I'm actually suggesting this. Maybe practicing on a different game will train you up better. The SMS title even has a hint option. Quote Link to comment Share on other sites More sharing options...
PFG 9000 Posted 2 hours ago Share Posted 2 hours ago 8 hours ago, Gemintronic said: The sega master system Shanghai is the only acceptable game in the genre. Quote Link to comment Share on other sites More sharing options...
