Nukey Shay Posted March 23, 2004 Share Posted March 23, 2004 http://www.io.com/~nickb/atari/tools.html Oops...it's called Makewav Quote Link to comment Share on other sites More sharing options...
bjk7382 Posted March 24, 2004 Share Posted March 24, 2004 http://www.io.com/~nickb/atari/tools.html Oops...it's called Makewav There is also one called PlayBin which has a window and gui to let you load single files. (only problem is you have to sort out your 4 and 2k binaries with playbin and makewav does that for you if you are comfortable using command prompt) playbininst.zip Quote Link to comment Share on other sites More sharing options...
Fellow Atari Man Posted March 24, 2004 Share Posted March 24, 2004 I got it yesterday- This thing is great! I loaded my first homebrew song into the Atari without a hitch. I'm having trouble getting the included "Phaser Patrol" game to load tho- the screen just displays: "Rewind Tape" ??????? Oh, you have to mess with them a bit, they can get kind of squirrely (if that's a word): Make sure the tape player you use for the Supercharger isn't real close to the tv and your Atari, for one thing. Most important is mess with the volume control; the instructions say to crank it up full blast if the tape won't load, but I've found that to NOT be so. Try it a bit under the halfway mark, which is where mine currently is, then rewind the tape and press play. If the flashing "rewind tape" message comes up again, try turning the volume higher a little bit at a time...if you hit the right amount, the tape will start to load right then and there, but if not, then rewind it, take a deep breath, and try turning the volume up again a notch. If you can get the game to load up, then MAKE A MARK ON THE VOLUME CONTROL AND DON'T ERASE IT!!! That's probably the biggest problem you'll have...good luck, and let us know how it goes! Quote Link to comment Share on other sites More sharing options...
hellfish Posted March 24, 2004 Author Share Posted March 24, 2004 thanks! I'll try messing with it when I get offa work. Quote Link to comment Share on other sites More sharing options...
vb_master Posted March 24, 2004 Share Posted March 24, 2004 Anyone else have one? I'm interested in getting one. I just need the core unit (NTSC of course). It can be modded or not modded, who ever has the lowest price. Quote Link to comment Share on other sites More sharing options...
Zach Posted March 25, 2004 Share Posted March 25, 2004 One way to correct this is to edit the binaries by using a disassembler and move the data out of that memory location. In case anyone is interested, Muncher, Confrontation, and Mangia have been hacked to run on a Supercharger. I did what Nukey Shay described for three games that few of us will own as a cartridge. Download the binaries from this thread: http://www.atariage.com/forums/viewtopic.php?t=30497 Quote Link to comment Share on other sites More sharing options...
J.Max Posted March 25, 2004 Share Posted March 25, 2004 I've got a modded Supercharger for sale.... http://www.atariage.com/forums/viewtopic.php?t=46597 Quote Link to comment Share on other sites More sharing options...
