Ending the level
So today I worked on the level ending. When you shoot a certain number of lettuce heads (that number will rise with each level), the burger will dip down off the screen and then it will start a new level. But since there's only one level, it just goes back to the title screen.
Which changed for some reason. The title of the game was up at the top instead of down at the center, and when the level ended and went back to the title screen, the score quit showing. I eventually got these things under control. Next time I work on this, I will begin work on the second level. I designed a fish for it. I also designed the life-granting chicken nugget, which I don't know if I can do or not. I seem to be having trouble sometimes when I go and add stuff for some reason.
The nugget will not be in level 1. Nuggets will start on level 2. And they won't be in the last level. Or will they? I may decide to just have the levels loop over and over again instead of having a definitive ending. But then that would mean the burgers would never reach Switzerland, so I'm not sure what to do about that.
Loaded tots from Domino's Pizza are delicious and I urge you to try them if you haven't already.
