One bite.
So I kept having to give up on the fly eating just one bit of the banana and then flying away. I woke up after 12 hours of sleep and had an idea. What if I were to just make the flying away code run only after the fly had eaten a bite? Before, I was making it part of the main code, which I think was making the scanline uneven and running too much code. So I decided to attempt to make it so it only runs when the code is running the eating part. I think it works now. Sort of a "duh" moment now when I look back on it.
I went to sleep at 2 a.m. It's not my fault. I get tired, then I lay in bed for half an hour and if I'm not sleeping by then, I wake up, do something and try again an hour later. I was watching the news and it said you should only use your bed for sleeping and that you should go to bed 30 minutes before you fall asleep. I already use my bed just for sleeping. Imagine that, I already had been using the 30 minute thing before I heard it.
