flashjazzcat Posted May 8, 2012 Share Posted May 8, 2012 Amazing - especially Spring and Autumn! Quote Link to comment Share on other sites More sharing options...
R4ngerM4n Posted May 8, 2012 Share Posted May 8, 2012 Nice stuff! Quote Link to comment Share on other sites More sharing options...
emkay Posted May 8, 2012 Share Posted May 8, 2012 I wonder about the count of evaluations there. I have some pictures at 400Million and some parts still don't get changed. I don't have time to add promised features to RastaConverter yet, but meanwhile here are some nice pictures (Altirra PAL palette) beautiful-day.xex bliss.xex truck.xex Lonely.xex parrot.xex spring.xex autumn.xex afghan.xex (laoo palette) I wonder about the count of evaluations there. I have some pictures at 400Million and some parts still don't get changed. Quote Link to comment Share on other sites More sharing options...
analmux Posted May 8, 2012 Share Posted May 8, 2012 I don't have time to add promised features to RastaConverter yet, but meanwhile here are some nice pictures (Altirra PAL palette) ,,, [attachments] At least this shows to me that the VIC2, even if it has some features clearly better than GTIA+ANTIC, it is way different when we compare it to GTIA+ANTIC+CPU. Then we might say they have comparable quality. The VIC2 doesn't have an 'overall better' quality. By far. (And most of the best C64 pics also need VIC2+CPU.) I'm still surprised by the quality of most of these test-pics. Even compared to most G2F results. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 8, 2012 Share Posted May 8, 2012 Just discovered that those latest pictures even better on a CRT monitor. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 8, 2012 Share Posted May 8, 2012 Just discovered that those latest pictures even better on a CRT monitor. Everything is better on a CRT monitor Quote Link to comment Share on other sites More sharing options...
emkay Posted May 9, 2012 Share Posted May 9, 2012 I don't have time to add promised features to RastaConverter yet, but meanwhile here are some nice pictures (Altirra PAL palette) ,,, [attachments] At least this shows to me that the VIC2, even if it has some features clearly better than GTIA+ANTIC, it is way different when we compare it to GTIA+ANTIC+CPU. Then we might say they have comparable quality. The VIC2 doesn't have an 'overall better' quality. By far. (And most of the best C64 pics also need VIC2+CPU.) I'm still surprised by the quality of most of these test-pics. Even compared to most G2F results. Things will get even more interesing. It has it's causes why the results of Rastaconverter cannot be loaded into G2F. G2F sets limits where they weren't needed. But now there is a point to handle in G2F and as it seems Tebe is working on it.... You could create pictures directly, not do just conversions. Spring and Autumn show the huge ability of having real light FX in a picture. The Ambience in "Lonely" the approaching danger in "Truck".. the easyness in "Beautiful-Day" And so on. All supported by the available colours. Quote Link to comment Share on other sites More sharing options...
phaeron Posted May 9, 2012 Share Posted May 9, 2012 After ivop's report with G++ I decided to try a profile-guided optimization build, and to my surprise, it's significantly faster -- at least another 50% faster on my Core i7, around 3.5-4.5K evals/sec. Pogo build is attached. I also went ahead and integrated another one of the gcc build fixes and stripped out all the 'auto' crap I put in when I was hacking on it so it could be built with VS2005/2008. That's probably it from me for optimizations for now... it's up to someone else to get us the next order of magnitude. Trying to increase quality is the next thing, I think... emphasis masks might be the way to go for a start, and with the error map I put into my build it would essentially be free. Post-quantization dithering is much harder to do but might solve some of the blotchiness that results with the existing dither option. Rasta-opthack5.zip Quote Link to comment Share on other sites More sharing options...
1NG Posted May 9, 2012 Share Posted May 9, 2012 (edited) ... it could be built with VS2005/2008. That's probably it from me for optimizations for now... that results with the existing dither option. Good work! I tried to compile that and need a little help: Include is only "include", Lib is only "lib" and two libraries are refrenced: alleg.lib;freeimage.lib BTW: That is different from RastaConverter (alleg42.dll, freeimage.dll) freeimage OK. Got it from http://freeimage.sourceforge.net/ and put the dll and lib into a lib folder. the .h in the include folder But allegro is not that easy: After I tried some binaries, i downloaded source packages an tried to compile them but they all had other problems. And the docs were allways not correct. Building with cmake doesn´t work either. Even cmake-gui always produced defect project files. As far as I see compiling will go in the direction of copying files into default VS folder . That explaines why there are no includes-paths for allegro in the vcxproj-file. So none of the four possible ways worked for me here and I need a little help. I would appreciate any hint on how to get the source compiled with VS C++ ... Edited May 9, 2012 by 1NG Quote Link to comment Share on other sites More sharing options...
ilmenit Posted May 9, 2012 Author Share Posted May 9, 2012 I wonder about the count of evaluations there. I have some pictures at 400Million and some parts still don't get changed. And probably they won't change. You can't have guarantee that those changes will ever happen, because the optimization stucked in a local maximum. What you can do is to start the process with bigger number of solutions (/s parameter) f.e. 1000 or 10000. Then the algorithm will be less vulnerable to local maximum problem, but - as it is written in the manual - it is usually better to run a few instances of RastaConverter on the same picture and after some time choose the best one. The final result depends a lot on the initial (random) state. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted May 9, 2012 Share Posted May 9, 2012 I would appreciate any hint on how to get the source compiled with VS C++ ... I grabbed some Allegro libraries from here 1 Quote Link to comment Share on other sites More sharing options...
1NG Posted May 9, 2012 Share Posted May 9, 2012 (edited) I grabbed some Allegro libraries from here I fiddled a bit with it and it worked! Thank you! allegro-4.4.2-msvc-8.0.exe/7z (http://77.55.66.239/...4.2-msvc-8.0.7z) does it if allegro-4.4.2-monolith-mt is used (lib renamed to alleg.lib + put in lib directory and the dll copied in the debug folder.) Edited May 9, 2012 by 1NG Quote Link to comment Share on other sites More sharing options...
w1k Posted May 9, 2012 Share Posted May 9, 2012 for me is new version slowest.. win7 32bit amd phenom II X4 3ghz, 4gb ram Quote Link to comment Share on other sites More sharing options...
+Philsan Posted May 9, 2012 Share Posted May 9, 2012 Just discovered that those latest pictures even better on a CRT monitor. Everything is better on a CRT monitor Yesterday I read that someone has another opinion... I don't know if everything is better but surely the experience is different... and I like it! Quote Link to comment Share on other sites More sharing options...
w1k Posted May 9, 2012 Share Posted May 9, 2012 this result is great.. doom.zip 4 Quote Link to comment Share on other sites More sharing options...
bfollett Posted May 9, 2012 Share Posted May 9, 2012 doom.zip... Who zips a 15kb file. You must really be starved for bandwidth! Quote Link to comment Share on other sites More sharing options...
Goochman Posted May 10, 2012 Share Posted May 10, 2012 Doom pic looks great - can someone do the Guantlet title screen? Curious how that would come out. Quote Link to comment Share on other sites More sharing options...
AtariNerd Posted May 10, 2012 Share Posted May 10, 2012 (edited) Doom pic looks great - can someone do the Guantlet title screen? Curious how that would come out. That one with the female and male warriors? That should come out very well. There's a lot of dithering and not so many colors per line... I don't have the spare processes right now - have BOINC running, but I'm sure it would render very nicely.... Great work, everyone ... that Autumn picture is stunning. Sigh...I'll do a quick render a bit later. Had placed something up, but the quality of my source pic wasn't really up to snuff. Edited May 10, 2012 by AtariNerd Quote Link to comment Share on other sites More sharing options...
AtariNerd Posted May 10, 2012 Share Posted May 10, 2012 (edited) Here's a render of the Gauntlet attract screen, unaltered or "enhanced". I think a skilled pixel-artist could do something nice with that screen. (I'm going to work a little magic and see if I can get something a little more dynamic out of it.) gauntlet.xex Edited May 10, 2012 by AtariNerd Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted May 10, 2012 Share Posted May 10, 2012 Can Not believe the doom pic Jesus Quote Link to comment Share on other sites More sharing options...
potatohead Posted May 10, 2012 Share Posted May 10, 2012 Awesome! I would not have believed that Doom picture. Seriously. Quote Link to comment Share on other sites More sharing options...
MaPa Posted May 10, 2012 Share Posted May 10, 2012 Run the xex.... the attached thumbnail is source and not actual picture. Quote Link to comment Share on other sites More sharing options...
potatohead Posted May 10, 2012 Share Posted May 10, 2012 Of course! Still, the generated image is good at small size. My first glance wasn't full screen, big pixels. Looked damn good. Quote Link to comment Share on other sites More sharing options...
emkay Posted May 10, 2012 Share Posted May 10, 2012 Doom or Loom , that's the question ... loom.xex Quote Link to comment Share on other sites More sharing options...
AtariNerd Posted May 10, 2012 Share Posted May 10, 2012 (edited) It's going to take awhile to cook and I'm going to have to go back in and fix a few more things... but just to show what tweaking the brigtness contrast and color a bit can get you. Edited May 10, 2012 by AtariNerd 1 Quote Link to comment Share on other sites More sharing options...
