Quantizator
ilmenit
Beta4:
- Details mask added /details=inputfile /details_val=value
- Improved dithering algorithms
- New dithering algorithm (/dither=knoll)
- Dithering strength added (/dither_val=value)
- /distance param replaced /euclid
- new distance color function (CIEDE2000) that solves problems with "too gray" output
- /noborder param removed
EDIT: Source code attached, No more time today to push it to Github...
RastaConverterBeta4.zip
Beta4Src.zip
Edited by ilmenit
With regards to Beta3, any chance of a version with no allegro as an option?
If so, I'll do another BeagleBone version.
I merged ilmenit's latest changes into my fork. I added you as a collaborator if you'd like to upload another Beaglebone build. I also just received my own Beaglebone in the mail from Amazon a few hours ago and I just got your build running on it. I'm getting around 220 evaluations per second with only USB power. Amazing little device.
Ahh, excellent, thanks for the merge. I'll do a new build soon, though I'm not sure when because I have a bit of overtime to do at work this weekend.
Yes, it's a great bit of kit, though it would be nice if they supplied a power supply with it. I'd ordered mine from Farnell. You can get power supplies from them also if you need one. I do find that there isn't much information on the internet about the BeagleBone.
Thanks for adding me as a collaborator by the way.
Beta4 is now uploaded. It appears to be quicker as I'm getting around 300 evaluations per second after 50,000 iterations, but it really depends on the picture.
We may be able to bounce some ideas off each other with regards to the BeagleBone. It is a little quirky. Installed 'man' pages would be nice.
Edited by snicklin
I guess running rastaconv on a Cortex-A8 could benefit a lot from converting the usage of floats and doubles to fixed point math.
I realized my fork doesn't have all the Beta4 changes since ilmenit still hasn't pushed all of them to github yet.
EDIT: I had posted that the summing and comparing of distances were still floating point, but like phaeron said, it's integer math. You could speed up the initial distance computations and dithering but those don't take too much time.
Edited by Xuel
On around version 196 of this project in the year 2025, maybe we could have it connected into a central database, with a centrally stored datastore of pictures which people have worked on. Then it stores different people's pictures after 10K, 100K, 1M, 10M, 100M etc evaluations. The user who has the best quality has their image stored, then other people can work off that. It would be a form of distributed computing.
I can only dream...!
I have some new feature requests:
1) Pause. I'd just like some way that I can pause it and continue later, without stopping it and then continuing it from the command line. Maybe hitting the space bar would do this? Would there be much of an overhead in scanning the keyboard?
2) A gallery function. Could it create and store a picture after 100,000 iterations, 1M, 10M, 100M etc? This might seem a bit useless, but it would nice to be able to show comparisons on here of different pictures using different techniques/settings and how well they are converting.
3) A way of supplying a filename for the generator, rather than having to have all my files begin with "output".
Just for fun, here's another video that abuses the fact that block loads are instantaneous in Altirra and AtariWin800. (Haven't tested Atari800)
- Video: Fullscreen 160x240, 4++ bpp
- Audio: 4-bit 15.6kHz
- Length: 1m23s
- Uncompressed size: 46MB
- Link: im.zip
Next step is getting this working on real hardware using my Beaglebone. :grin: Need to buy some level shifters...
  • Like 5
- Length: 1m23s
- Link: im.zip
LOL
My BeagleBone won't work. As soon as I kill the Putty session, rastaconverter is killed. I can put it in the background and I can use the Linux "screen" command, but it doesn't matter what I do, due to a bug in Angstrom, it'll kill my processes.
I need to work a way around this.... , I want to leave it processing all day and night.
Oh my god... I can't belive my eyes and ears! :-D
Btw, next time try to play with higher values of /dither_val (=2 or 3) if your images get too gray. It works especially better with 'chess' dithering.
Also /distance=ciede may solve the grayness problem, but the initial preprocess can take a lot of time then.
Edited by ilmenit
