Atari 8-bit related BBS(s)
svenski
I used to run System Reset! BBS In Hamilton, Ontario, Canada, and was running Express Pro....I think node x_59 if I remember correctly....
I had a friend write a PC Dos term program called Genterm that did Atascii graphics.
It was never released to the general public, but if there is some interest I might be able to get a copy of it somewhere...
I also have a PC-based ATASCII terminal program for accessing internet-based ATASCII BBSes like mine. It's called AT_Telnet. It is just a terminal - no file transfers available in it. It was originally written by Tom Hunt and I took it over around 2000. You can download it at my website below. It is tested under Windows XP only.
http://bf.amfband.com
Edited by bf2k+
Must be another node# as x_59 is/was "The 19th Hole - 416-xxx-xxxx". "System Reset" doesn't seem to be listed on the 1999 Pro node list.
Yeah, the Jail was bad for that, but I don't now who was creating dupes....I used to pass off my messages to Europe....
It was a lot of fun back then, but long distance calls were expensive....
I've always wanted to put my BBS back up, but I suspect the costs wouldn't be worth the effort or the calls I would get.
I might be convinced if I could somehow hook it up to telnet from the internet.
Er... You've not heard of Atari Inside or my BBS (DarkForce) ?
We use a Lantronix serial port to LAN adaptor to hook our boards to the 'Net.
Works great. :)
Expensive, indeed. Apart from the Dutch netcalls I had to call to the USA, Canada and Germany at least once a week, usually more.
I still run my Pro BBS (5.0) but exchanged the modem for a null-modem cable and run a telnet conversion tool on a W2K server. Apart from up and downloads it works pretty well.
I run The Electric Cafe BBS - telnet thecafe.dtdns.net
This runs Steve Carden's TCP/IP Express Pro 7.0.
This BBS is 24 hours and runs on real Atari hardware:
Atari 130XE with 576K RAM upgrade
ICD 256kb MIO with Warerat's ROM upgrade
External Seagate SCSI Hard Drive 18GB
Lantronix telnet/serial converter
What happened to The Electric Cafe BBS?
-=[Lord Cygnus]=-
I finally got my BBS up and running with the Oasis Jr BBS 1988 software! It's working great after much trial & error to configure the program and menus. YYZ BBS is now available via telnet: yyzbbs.no-ip.org
Running on original Atari 130XE 1MB & disk drives. APE supplies the R: handler connection for telnet.
Come by and visit. It's been 1987 - 1988 since I ran this board.
-=[Lord Cygnus]=-
YYZ BBS
Houston, TX
I added the 80 column feature to the BBS. ASCII callers use 'ctrl [' for carriage return if stuck at a prompts if your enter key does not respond properly (don't ask me why it does that; I don't know). Of course, ATASCII 40 column looks and functions properly since the board was built for it! /|\TARI RULZ!
I'll have a UDS-10 or UDS-100 installed soon & a battery back-up unit. Until then, I'm still using APE connected to my real A8 equipment to answer calls via Telnet: yyzbbs.no-ip.org
-=[Lord Cygnus]=-
I added your BBS telnet address to our board @ YYZ BBS. ;)
I call your board on my real 130XE using ICE-T 80 column. I have called your board a few times with Windows XP Hyper-Term. I like using real A8 real equipment though (for the nostalgia)!
-=[Lord Cygnus]=-
Anyone who hasn't added the IRC gateway to your BBS list, please feel free to:
For VT100 emulation (if you're using and Atari with Ice-T or other VT100-capable terminal), telnet to irc.atarichat.net, port 800.
For ASCII dumb terminal, telnet to irc.atarichat.net, port 400.
Thanks!
Thanks!
Oh that is awesome! Can't wait to try that out in Bobterm.
-=[Lord Cygnus]=-
Thanks, appreciated. I understand about the nostalgia part - don't much care for emulation, as technically impressive
as it is... :)
-=[Lord Cygnus]=-
as it is... :)
Using our real equipment is the ultimate experience reminding us of our first experiences back in the dayz! /|\TARI RULZ!
Emulation is great when the real technology is not practical. For example in Kuwait I hit the Atari BBSs (when the crappy internet is not blocking me) using Syncterm that can do ATASCII. Otherwise while at home I get on the BBSs with my Atari 800. ;)
  • 2 weeks later...
Hey guys. I'm experimenting a bit with my UDS1100 and some settings...
Can the next few callers that logon tell me if the <enter> message now
comes up without having to bang the keyboard first? Previously, it would
just show a blank screen on connection until you bashed some keys...
Thanks!
