goldenegg Posted January 27, 2013 Share Posted January 27, 2013 Maybe there's a switch in qmake that turns off those Apple specific flags? Or you could try removing them from the generated Makefile by hand. I manually forced the build to complete with both GCC 4.5 and 4.7. Both have the same performance issue, so it's something specific to the platform that's causing problems. I also tried building on an older OS X 10.6 platform with the same results. EDIT: I also updated QT to 4.8.4 and tried various optimization levels (O3, Ofast, O0). Neither of those made a difference either. Haven't tried QT 5 yet, but that's due to a compile issue on OS X. Hopefully that will be fixed shortly, so I can finally start using it. Quote Link to comment https://forums.atariage.com/topic/183828-upcoming-virtual-jaguar-200-release/page/15/#findComment-2684875 Share on other sites More sharing options...
Zerosquare Posted January 27, 2013 Share Posted January 27, 2013 How about some Linux problems for a change? http://www.yaronet.com/posts.php?s=153901 In a nutshell : authentication fails for every ROM (red screen) ; recompiling VJ fixed the problem, but only after adding "-lz" on the "LIBS" line in "makefile.qt". Quote Link to comment https://forums.atariage.com/topic/183828-upcoming-virtual-jaguar-200-release/page/15/#findComment-2685235 Share on other sites More sharing options...
Shamus Posted January 28, 2013 Author Share Posted January 28, 2013 Now that is strange, I wonder what flavor of Linux he's using? Because in both the virtualjaguar.pro and the generated makefile-qt the -lz is in there. I wonder if his version of qmake stripped it out? Also strange that it linked without it, as -lz is a requirement for the Jaguar core library. @goldendegg: I'm stumped. It could be that there's a 32 vs. 64 bit issue there, with some kind of translation causing the slowdown; without dissecting it and being able to look at the pieces it's next to impossible to say what it is that's gone wrong there. Quote Link to comment https://forums.atariage.com/topic/183828-upcoming-virtual-jaguar-200-release/page/15/#findComment-2685875 Share on other sites More sharing options...
