xdt99: New TI 99 cross-development tools available
ralphb
  • 3 weeks later...
Had an idea to help newbies like me.
And this may already be possible...
One thing that I get stuck with is figuring out how many bytes each instruction uses. ie
					;rotate keys
		ci r3,90		;z key - rotate
		jne $+4
		b @rotl
		ci r3,67		;c key - rotate
		jne $+4
		b @rotr
		li r9,0
		bl @collsp
For the small keyscan routine above, to figure out that I needed to jump $+4, I actually loaded up the LBLA & entering each instruction (as the LBLA compiles each line as entered) it told me how many bytes each instruction took.
If it was possibly for the xdt tools to take an .asm file, & from a starting AORG actually output how many bytes each instruction took in 2 columns
ie
7D00 lwpi >70b8
7D04 li r0,>0384
7D08 etc etc
That might be useful for useless people such as myself!
cheers
Daryn
Use labels. They're a bit more cryptic with the LBLA than with the E/A module—2 characters as opposed to the 6 allowed with E/A. You then rarely need to know how many bytes instructions take. Your code above would be
;rotate keys
jne kc
b @rotl
kc ci r3,67 ;c key - rotate
jne ex
b @rotr
ex li r9,0
bl @collsp
...lee
Edited by Lee Stewart
I'm working on some F18A GPU code and will soon be using the XORG directive. Is there any chance you could add support for the new F18A GPU instructions?
CALL	>0C80	0000 1100 10Ts SSSS
RET	>0C00	0000 1100 0000 0000
PUSH	>0D00	0000 1101 00Ts SSSS
POP	>0F00	0000 1111 00Td DDDD
SLC	>0E00	0000 1110 SHFT SSSS
Thanks,
Rasmus
;rotate keys
jne kc
b @rotl
jne ex
b @rotr
ex li r9,0
bl @collsp
...lee
Funny, I use labels everywhere...but did not think of doing this! haha
cheers Lee!
Daryn
Sorry for the late reply, Daryn, but I've just returned from my vacation (nice to be offline for a while!).
There really isn't anything to add to Lee's reply, except for two minor points.
As you know, labels must be unique within each program so that references, e.g., in jump and branch instructions, can be resolved unambiguously. If you have many code sequences that correspond to IF or WHILE blocks you'll have to introduce a lot of unique labels.
;rotate keys
          jne nextkey1
          b @rotl
nextkey1  ci r3,67        ;c key - rotate
          jne nextkey2
          b @rotr
nextkey2  li r9,0
          bl @collsp
These labels are not meant to be called from outside your current subroutine, and coming up with unique names can get difficult as your program grows. Just imagine that you want to test another key before the C key -- then you'd have to add a "nextkey3" label, but before the "nextkey2" one, which looks ugly.
Mostly for this reason xas99 supports so-called local labels that need not be unique. This sounds weird at first -- where should we jump to if the target is not unique?
        jne !next
        b @rotl
!next   ci r3,67        ;c key - rotate
        jne !next
        b @rotr
!next   li r9,0
        bl @collsp
But the answer is actually quite simple: the assembler will pick the nearest label after the current position. In your example above, each "jne !next" will skip to the next "!next" label. You might even drop the name of the label and use
        jne !
        b @rotl
!       ci r3,67        ;c key - rotate
        jne !
        b @rotr
!       li r9,0
        bl @collsp
for maximum brevity (and IMHO legibility). The "!..." will always search forward. If you want to jump backwards you simple prefix the local label reference with a unary minus, e.g.,
   li   r0, >a000
   li   r1, 128
!  clr  *r0+
   dect r1
   jne  -!         ; jump back
   rt
And you can use "!!..." (and "-!!...") to jump to the label after the next label (the label before the previous label), although I personally rarely use this.
Keep in mind, though, that local labels are unique to xas99; the original TI assembler won't know about them.
Finally, if you ever really need to find out the size (or timings) of instructions, you can have a look at the listing file, generated with the -L option:
XAS99 CROSS-ASSEMBLER   VERSION 1.5.1
0001               checkkeys
0002 0000 0283  22         ci r3,90        ;z key - rotate
     0002 005A
0003 0004 1602  14         jne !
0004 0006 0460  28         b @rotl
     0008 001Cr
0005
0006 000A 0283  22 !       ci r3,67        ;c key - rotate
     000C 0043
0007 000E 1602  14         jne !
0008 0010 0460  28         b @rotr
     0012 001Er
0009
0010 0014 0209  20 !       li r9,0
     0016 0000
0011 0018 06A0  32         bl @collsp
     001A 0020r
The second column contains the (relative or absolute) address of the instruction.
;rotate keys
          jne nextkey1
          b @rotl
          jne nextkey2
          b @rotr
nextkey2  li r9,0
          bl @collsp
        jne !next
        b @rotl
        jne !next
        b @rotr
!next   li r9,0
        bl @collsp
        jne !
        b @rotl
        jne !
        b @rotr
!       li r9,0
        bl @collsp
   li   r0, >a000
   li   r1, 128
!  clr  *r0+
   dect r1
   jne  -!         ; jump back
   rt
0001               checkkeys
     0002 005A
     0008 001Cr
0005
     000C 0043
     0012 001Er
0009
     0016 0000
     001A 0020r
Thanks so much for this info ralphb, will try the local labels out for sure! Fantastic set of tools!
Sure! I've added all of the above, plus PIX as an alias for XOP. I guess the SPI instructions aren't needed for regular programming? Just grab the latest version directly from GitHub.
The IDEA plugin still needs to be updated, though. I noticed that a new IDEA platform version has been released, so I need to figure out any changes first. Are you staying put on IDEA 13, or do you plan to switch to their new subscription model?
Thank you, that's great.
I will probably get a licence for IDEA 15 from my workplace.
I think I just found an issue. This program:
WIDTH   EQU >100
HEIGHT  EQU >C0
        LI  R2,WIDTH*HEIGHT/4
produces this output:
XAS99 CROSS-ASSEMBLER   VERSION 1.5.2
**** **** ****     > problem.a99
0001      0100     WIDTH   EQU >100
0002      00C0     HEIGHT  EQU >C0
0003 0000 0202  20         LI  R2,WIDTH*HEIGHT/4
     0002 F000
but the result of the calculation should be >3000 instead of >F000.
problem.a99
Here is another issue, this time with XORG. If I try to assemble the code below I get an error that the JMP instruction is far out of range: ***** Out of range: LOOP +/- -0x3803
       AORG >A000
       B    @LOOP
XCODE  XORG >3000
LOOP   JMP  LOOP
       END
(This is just an example that wouldn't work with without a loop to copy the XCODE to >3000).
WIDTH   EQU >100
HEIGHT  EQU >C0
     0002 F000
>F000 is, in fact, correct. That is what the E/A cartridge Assembler will give you. According to the E/A Manual, the “well-defined” expression in the EQU directive uses signed, integer division as opposed to the unsigned, integer division of the TMS9900's DIV instruction, which would result in the >3000 you expected. Asm994a gives >3000 for that same expression, which is in error per the E/A Manual. The E/A Manual does have a handful of errors; but, I doubt this is one of them.
...lee
...lee
OK, thanks, so it's another backwards compatibility issue. I think it would be more useful if any rounding was postponed until the end, or at least it should give a warning at the point where the result of the multiplication of two unsigned numbers is being treated as a signed number.
Doh! That was caused by a typo: In one case I accidentally wrote self.symbols.xorgLOffset instead of self.symbols.xorgOffset! Well, that's what you get when giving up statically typed languages in favor of Python ... :)
It's fixed on GitHub now. (And note to self: Test the basic stuff as well. :grin:)
I could imagine you might want to find the difference of two memory location, and as soon as you assume negative values, you have to do signed arithmetics.
I concur. I guess what's missing here are shift operators. xas99 already supports &, |, and ^, but << and >> will require some fiddeling, as > is already used as hex indicator.
And yes, backwards compatibility can be a pain ... I particularly dislike that 1 + 2 * 3 yields 9, and I have to find a "modern" solution to that yet.
Perhaps you could switch to 32-bit arithmetic when brackets are used, which means it does not have to be backwards compatible? Then (>100*>C0) would not be treated as a negative number and (>100*>C0)/4 would return the expected result of >3000.
Edit: This would also prevent that (>100/4)*>C0 yields a different result than (>100*>C0)/4.
I would think it best to avoid using () to bracket calculations because of their use in addressing—perhaps [] or {} would be better.
...lee
Thanks. XORG, SLC, PIX all working fine.
Sorry, me again. I have switched to IDEA 15. but I'm still getting errors:
null
java.lang.NullPointerException
	at net.endlos.xdt99.xas99.Xas99Reference.findBeginningOfLine(Xas99Reference.java:78)
	at net.endlos.xdt99.xas99.Xas99Reference.<init>(Xas99Reference.java:27)
	at net.endlos.xdt99.xas99.psi.impl.Xas99PsiImplUtil.getReference(Xas99PsiImplUtil.java:79)
	at net.endlos.xdt99.xas99.psi.impl.Xas99OpLabelImpl.getReference(Xas99OpLabelImpl.java:40)
	at com.intellij.psi.impl.SharedPsiElementImplUtil.getReferences(SharedPsiElementImplUtil.java:83)
	at com.intellij.psi.impl.PsiElementBase.getReferences(PsiElementBase.java:82)
	at org.intellij.plugins.intelliLang.references.InjectedReferencesContributor.getInjectedReferences(InjectedReferencesContributor.java:56)
	at org.intellij.plugins.intelliLang.references.InjectedReferencesInspection$1.visitElement(InjectedReferencesInspection.java:38)
	at com.intellij.psi.impl.PsiElementBase.accept(PsiElementBase.java:274)
	at net.endlos.xdt99.xas99.psi.impl.Xas99OpLabelImpl.accept(Xas99OpLabelImpl.java:23)
	at com.intellij.codeInspection.InspectionEngine.acceptElements(InspectionEngine.java:81)
	at com.intellij.codeInsight.daemon.impl.LocalInspectionsPass$4.process(LocalInspectionsPass.java:320)
	at com.intellij.codeInsight.daemon.impl.LocalInspectionsPass$4.process(LocalInspectionsPass.java:315)
	at com.intellij.concurrency.ApplierCompleter.a(ApplierCompleter.java:122)
	at com.intellij.concurrency.ApplierCompleter.access$000(ApplierCompleter.java:44)
	at com.intellij.concurrency.ApplierCompleter$1.run(ApplierCompleter.java:85)
	at com.intellij.openapi.application.impl.ApplicationImpl.tryRunReadAction(ApplicationImpl.java:1169)
	at com.intellij.concurrency.ApplierCompleter$2.run(ApplierCompleter.java:94)
	at com.intellij.openapi.progress.impl.CoreProgressManager.a(CoreProgressManager.java:446)
	at com.intellij.openapi.progress.impl.CoreProgressManager.a(CoreProgressManager.java:443)
	at com.intellij.openapi.progress.impl.CoreProgressManager.executeProcessUnderProgress(CoreProgressManager.java:392)
	at com.intellij.openapi.progress.impl.ProgressManagerImpl.executeProcessUnderProgress(ProgressManagerImpl.java:54)
	at com.intellij.concurrency.ApplierCompleter.a(ApplierCompleter.java:106)
	at com.intellij.concurrency.ApplierCompleter.compute(ApplierCompleter.java:82)
	at jsr166e.CountedCompleter.exec(CountedCompleter.java:684)
	at jsr166e.ForkJoinTask.doExec(ForkJoinTask.java:260)
	at jsr166e.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:858)
	at jsr166e.ForkJoinPool.scan(ForkJoinPool.java:1687)
	at jsr166e.ForkJoinPool.runWorker(ForkJoinPool.java:1642)
	at jsr166e.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:108)
Source code attached.
f18a-isometric-xas99.a99
  • 4 weeks later...
I've just released version 1.5.1, which contains an updated IDEA plugin that supports IDEA 15, adds a code formatter, and fixes some bugs, including the one above.
Code Reformat will do exactly that, based on your preferences in Settings > Editor > Code Style. This is handy when you copy and paste code from other sources, or if you want to cover up your sloppiness. For technical reasons you may have to reformat twice in a row to get comments align properly -- don't ask. And I suspect a bug in the IntelliJ platform that results in incorrect indenting if the very first line of the file does not start in column 1; let's see where that bug report goes.
  • 4 weeks later...
Why does xga99 gpl compiler implement the SLL, SRC etc... (shift bit wise instructions) in reverse order to that specified in the gpl_programmers_guide.pdf ?
It took me some time to realise why it was throwing an exception.
According to PDF Shift Right Circular = SRC GD,GS
but XGA99 needs this instruction as SRC GS,GD
Thanks
  • Recently Browsing   1 member
