Rybags Posted December 12, 2017 Share Posted December 12, 2017 Killing the stations by just hitting the weak spot is quick and easy but to maximize points you should hit the bulbs... even just doing 2 or 3 before hitting the weak spot can give a decent boost. 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted December 12, 2017 Share Posted December 12, 2017 (edited) I can hear and understand everything being said except.... when the alert alert or alarm alarm is said... everyone thinks it's saying a lie a lie or Allie Allie unless we are saying aline aline? It's the only thing we can't make out... all else is spot on... Edited December 12, 2017 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
+Adam+ Posted December 12, 2017 Share Posted December 12, 2017 (edited) I can hear and understand everything being said except.... when the alert alert or alarm alarm is said... everyone thinks it's saying a lie a lie or Allie Allie unless we are saying aline aline? It's the only thing we can't make out... all else is spot on... I have exactly the same problem "Blast off" is clear, but supposed "Alert" message (see "Game Play" section here) sounds as "Allie" to me. Edited December 12, 2017 by +Adam+ 1 Quote Link to comment Share on other sites More sharing options...
shanti77 Posted December 12, 2017 Share Posted December 12, 2017 Orginal sounds: https://itunes.apple.com/us/album/bosconian/651926955 Quote Link to comment Share on other sites More sharing options...
tep392 Posted December 12, 2017 Share Posted December 12, 2017 Bummer I won't be able to play the 128k version on my 800XL with Antonia 4mb due to the LAX opcode. Quote Link to comment Share on other sites More sharing options...
shanti77 Posted December 12, 2017 Share Posted December 12, 2017 Only 64k NTSC version use LAX command. 1 Quote Link to comment Share on other sites More sharing options...
tep392 Posted December 12, 2017 Share Posted December 12, 2017 Only 64k NTSC version use LAX command. Cool. I misunderstood your post. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted December 12, 2017 Share Posted December 12, 2017 (edited) the apple sound, is not technically incorrect the sound are from versions in other locations, you might grab the sample from the other conversion.. maybe it is a Japanese word that sounds like A lie or Allie or Alive..... I have looked and you right a number of coin ops say it as you have recorded it! a poor translation from English to Japanese alert can mean alive, maybe we discovered something here.. Edited December 12, 2017 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
ZylonBane Posted December 13, 2017 Share Posted December 13, 2017 a poor translation from English to Japanese alert can mean alive, maybe we discovered something here.. No, all you've discovered is that low-bitrate digitized English spoken by some Japanese engineer in the 80s is hard to understand. 2 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted December 13, 2017 Author Share Posted December 13, 2017 bosco64NTSCs - don't use 'LAX' command (slower) Only 64k NTSC version use LAX command. I'm still confused which versions do and don't use the LAX command. From what you're saying I'm guessing: bosco64PAL.xex (No LAX Command) bosco128PAL.xex (No LAX Command) bosco64NTSC.xex (Uses LAX Command) bosco64NTSCs.xex (No LAX Command) bosco128NTSC.xex (No LAX Command) bosco128NTSCe.xex (No LAX Command) Is this correct? If so, I guess my response would be that I'd like to see one 128K NTSC version with the LAX command, since this is the main version I'll be playing on a 6502C machine. Quote Link to comment Share on other sites More sharing options...
shanti77 Posted December 13, 2017 Share Posted December 13, 2017 (edited) 128k version have different sprites procedure: lda background_char,y and mask,y ora shape,y sta new_char,y 64k: lda shape,y tax and background_char,y ora ora_tabx,x sta new_char,y LAX command give us2*8*6*5=480 cycles Edited December 13, 2017 by shanti77 2 Quote Link to comment Share on other sites More sharing options...
xxl Posted December 13, 2017 Share Posted December 13, 2017 Currently there is a trend that you must change cpu to 16bit for smooth efects, fortunately there are still coders who can write smooth code without the need to modify the hardware 5 Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted December 13, 2017 Share Posted December 13, 2017 How is the sample done without slowing down? Gameplay? 1 Quote Link to comment Share on other sites More sharing options...
shanti77 Posted December 13, 2017 Share Posted December 13, 2017 (edited) Samples use Pokey IRQ with 4Khz, fast procedure on page 0. When I play sample all unnecessary operation are off (change score, change panel elements), max 3 soft sprites on screen. VBLK IRQ must be very short. Pokey IRQ procedures: org 128+4 pok0 equ * sta pok0a+1 probka equ * lda #$ff sta AUDC4 sty pok0b+1 lda #0 .IF .DEF A800 sta IRQEN .ENDIF sta $fffe sam equ *+1 lda $ffff tay ora #%10000 sta probka+1 lda sampleDiv,y ;tab = /16 ora %10000 sta probka1+1 inc sam beq pok0end @ lda sam sam1 equ *+1 cmp #$ff ;sam1 beq @+1 .IF .DEF A800 @ lda #4 ;reset pokey sta IRQEN .ELSE @ inc IRQEN ;fast pokey reset, does not work on A800 emu .ENDIF pok0a lda #$ff ;register A pok0b ldy #$ff ;register Y rti @ lda sam+1 sam1s equ *+1 cmp #$ff bne @-1 dec repeat ;alarm alarm beq @+ sam2 equ *+1 lda #$ff sta sam sam2s equ *+1 lda #$ff sta sam+1 jmp @-1 @ lda #0 ;OFF IRQ sta sirq sta IRQEN lda pok0a+1 ldy pok0b+1 rti pok0end inc sam+1 .IF .DEF A800 lda #4 sta IRQEN .ELSE inc IRQEN .ENDIF lda pok0a+1 ldy pok0b+1 rti org 0 pok1 equ * ;second half sta pok1a+1 probka1 equ * lda #$ff sta AUDC4 .IF .DEF A800 lda #0 sta IRQEN .ENDIF lda #4+128 .IF .DEF A800 sta IRQEN .ELSE inc IRQEN ;fast pokey reset .ENDIF sta $fffe pok1a lda #$ff rti ; Edited December 13, 2017 by shanti77 4 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted December 13, 2017 Author Share Posted December 13, 2017 Currently there is a trend that you must change cpu to 16bit for smooth efects, fortunately there are still coders who can write smooth code without the need to modify the hardware You're exaggerating: people are interested using 65816 because it's possible, plausible, and it's fun to see what can be done. The problem for them is that they need software to be compatible. I don't think the existence 65816 upgrades should keep people from using illegal ops when they're of benefit to a production. But, I do think it's a reasonable request that compatible versions be made available, if they can be done with a minimal amount of difficulty to the one doing the coding. 1 Quote Link to comment Share on other sites More sharing options...
darwinmac Posted December 14, 2017 Share Posted December 14, 2017 I would like to thank the developers for a wonderful port. I am not a Bosconian expert, btu I think it plays very well. Right now, I stink at the game but the fault is all mine :-) I especially want to thank them for a 64k NTSC port so I can play it on my XEGS rather than having to depend on the awesome Altirra. I miss the voices, but Im glad they still produced a 64k version. Well done! Bob C 3 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted December 14, 2017 Author Share Posted December 14, 2017 (edited) I would like to thank the developers for a wonderful port. I am not a Bosconian expert, btu I think it plays very well. Right now, I stink at the game but the fault is all mine :-) I especially want to thank them for a 64k NTSC port so I can play it on my XEGS rather than having to depend on the awesome Altirra. I miss the voices, but Im glad they still produced a 64k version. Well done! Yes, it's very good version of Bosconian that exceeded my initial expectations and a real bonus to have all these different versions. And to top it all off, it's free. Edited December 14, 2017 by MrFish 6 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted December 14, 2017 Share Posted December 14, 2017 (edited) It really does deserve the full treatment... box, cart, disk, manual perhaps a save function for scores... Atarimax carts and or floppy can do that... it's so well done it deserves that kind of permanence, a physical existence. Edited December 14, 2017 by _The Doctor__ 5 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted December 14, 2017 Author Share Posted December 14, 2017 I miss the voices, but Im glad they still produced a 64k version. Actually, it's nice to have a version without the voices. The vocals can get a little annoying after a while, especially if you're having a bad game. Quote Link to comment Share on other sites More sharing options...
xxl Posted December 14, 2017 Share Posted December 14, 2017 You're exaggerating: people are interested using 65816 because it's possible, plausible, and it's fun to see what can be done. people exchange 16bit processor for benefit, you've heard about the trend of exchanging processors on 6809, because it can be done? Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted December 14, 2017 Share Posted December 14, 2017 It made me laugh (and trust me I don't feel much like laughing at the moment) when I heard the "A lie" and heard thanks to Shanti's post that it was "Alert", the arcade sounds the same...Good grief it was poor But that aside Shanti's game is a bloody amazing port, what he's shoved in to both versions defies belief but more importantly, its PLAYS REALLY WELL.... /me passes Shanti a virtual beverage of his choice as a thank you...You are a star... 2 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted December 14, 2017 Author Share Posted December 14, 2017 (edited) people exchange 16bit processor for benefit, you've heard about the trend of exchanging processors on 6809, because it can be done? Of course it's a benefit; It's kind of like driving a Porsche in the city when a Volkswagen will do. No Porsche owners are saying "you must" drive a Porsche; but they might say it's "a lot of fun to drive" and that it's "nice to have the power under the hood when you want to use it", especially when you get out on the open road. When I say, "because it can be done", I mean that there are several mass produced options available that weren't there just a few years ago. Edited December 14, 2017 by MrFish Quote Link to comment Share on other sites More sharing options...
xxl Posted December 14, 2017 Share Posted December 14, 2017 (edited) Of course it's a benefit; It's kind of like driving a Porsche in the city when a Volkswagen will do. No Porsche owners are saying "you must" drive a Porsche; but they might say it's "a lot of fun to drive" and that it's "nice to have the power under the hood when you want to use it", especially when you get out on the open road. When I say, "because it can be done", I mean that there are several mass produced options available that weren't there just a few years ago. exactly. No Porche driver will say that he has VW, he does not try to register car in VW fans club, and does not encourage the manufactory to produce parts that match VW and Porche simultaneously :-) Edited December 14, 2017 by xxl Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted December 14, 2017 Share Posted December 14, 2017 (edited) um many of the same parts were on VW Audi and Porsche.... not that it matters. There were some major difference between them. Distinctively different handling and body. and for the Porsche major engine changes. Still amazing the number of parts that still had VW molded, stamped, or etched into them. Edited December 14, 2017 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted December 14, 2017 Author Share Posted December 14, 2017 exactly. No Porche driver will say that he has VW, he does not try to register car in VW fans club, and does not encourage the manufactory to produce parts that match VW and Porche simultaneously :-) Haha... it's an analogy related to the speed only; don't extend it beyond it's use. Achieving the speed in this case is just upgrading the engine. The engine is still in the same family and the rest of the machinery is still from the maker. Quote Link to comment Share on other sites More sharing options...
