brain Posted December 9, 2017 Share Posted December 9, 2017 Hmm, I can't seem to see the picture... Quote Link to comment Share on other sites More sharing options...
brain Posted December 9, 2017 Share Posted December 9, 2017 Are these the rev 2 ones? They are whatever fixes we've discussed and you and Lee find in the next day or so (I'll commit the board order on Sunday night) 2 Quote Link to comment Share on other sites More sharing options...
+acadiel Posted December 9, 2017 Share Posted December 9, 2017 2 Quote Link to comment Share on other sites More sharing options...
brain Posted December 9, 2017 Share Posted December 9, 2017 Thanks. That is a good rendition. Quote Link to comment Share on other sites More sharing options...
brain Posted December 9, 2017 Share Posted December 9, 2017 Now that the boards are not such a mystery, I'd like to fit the little "tabs" from the original PCBs onto the RAM and ROM boards. If someone (Joe? :-) or Lee could micrometer them out, that would be appreciated. I also need to throw the entire set of design online, as all of my projects are open source. I hesitate only because I am not sure if I want to put up 3 separate projects in github, or 1 with all three designs. Jim Quote Link to comment Share on other sites More sharing options...
+acadiel Posted December 10, 2017 Share Posted December 10, 2017 Hey Jim - I got the two RAM carts working great. One ROM cart is working, and other is locking up the CC-40 when I put it in and then power it on. Tried multiple EPROMs. Cart does not lock up the unit with the ROM removed. Tried re-flowing all solder joints, so will likely have to go down the path of figuring out what's not conducting. Put under my magnified lighted loupe and I don't see any shorts or anything. Quote Link to comment Share on other sites More sharing options...
brain Posted December 10, 2017 Share Posted December 10, 2017 Hey Jim - I got the two RAM carts working great. One ROM cart is working, and other is locking up the CC-40 when I put it in and then power it on. Tried multiple EPROMs. Cart does not lock up the unit with the ROM removed. Tried re-flowing all solder joints, so will likely have to go down the path of figuring out what's not conducting. Put under my magnified lighted loupe and I don't see any shorts or anything. ROM cart is pretty simple, so it sounds like an address or data line not making connection (maybe the socket itself) Jim Quote Link to comment Share on other sites More sharing options...
+acadiel Posted December 10, 2017 Share Posted December 10, 2017 ROM cart is pretty simple, so it sounds like an address or data line not making connection (maybe the socket itself) Jim Found it. There was a non-connection by the breakaway at the very top of the cart where R2 connected to R1 on the common side that wasn't conducting. I jumpered it between the two resistors on the bottom and now have conductivity all the way to R5. I'm wondering if when I broke them apart I did something with the trace right there. Quote Link to comment Share on other sites More sharing options...
+acadiel Posted December 10, 2017 Share Posted December 10, 2017 Hey all - the EPROM thread is here for the CC-40 mega ROM. Please direct ROM questions to that thread if at all possible. 1 Quote Link to comment Share on other sites More sharing options...
+acadiel Posted December 10, 2017 Share Posted December 10, 2017 Hey, all. Here’s some internal pictures of the CC-40+, which had a cassette port. https://www.dropbox.com/sh/pyrvfgcycywt4k9/AAB3DgZSkrrncmvrtzGSJYnra?dl=0 Ksarul is now in possession of this unit. It’s a 6K model. 2 Quote Link to comment Share on other sites More sharing options...
TI998owner Posted December 10, 2017 Share Posted December 10, 2017 Hi Jim, OK, I did some measures for the little ( 4 ) tabs on the CC-40 ROM boards. Using several CC-40 Memo processor boards As examples to check with. , Looking at the board with the chip side up and the cart edge Connector facing you. The distance from the top edge to the First tab is 6/32 inch. ( left hand side of cart ) The tabs are slopped, so this measure Is to the beginning of the slop. The tab measures ( top of tab ) 3/32 of inch across, base of tab is 4/32 of an inch. Small slop From top edge to bottom edge, on the tab. Same for each tab. , The distance between the top tab and the bottom tab, ( Measure between Edge of base of the top and bottom tab) is 3/4 of inch. , You can use the same measure on the right hand side of the cart as well. The left and right side of the cart measure the same. I checked several CC-40 carts they all are the same. , The only difference I could find on other Texas Instruments produced CC-40 carts was some are missing the top left hand side tab. But This could of been a quality control issue, does not seem to Be an issue for the cart case, fitting the carts. , Hope this helps Lee TI998owner Quote Link to comment Share on other sites More sharing options...
+acadiel Posted December 11, 2017 Share Posted December 11, 2017 Were the tabs break away tabs meant to join a sheet of boards fogstjer? Sent from my Moto Z (2) using Tapatalk Quote Link to comment Share on other sites More sharing options...
+acadiel Posted December 11, 2017 Share Posted December 11, 2017 *together Sent from my Moto Z (2) using Tapatalk Quote Link to comment Share on other sites More sharing options...
TI998owner Posted December 11, 2017 Share Posted December 11, 2017 Hi Jon, The tabs on the original CC-40 carts are for Cart alignment when placed in the plastic cart case. The tab , you see on the first batch of ROM and Ram And proto boards from Jim are the break away that held The 3 boards together. Not what we were measuring For the production version or possible the next batch Of boards. , Lee TI998owner 1 Quote Link to comment Share on other sites More sharing options...
+acadiel Posted December 11, 2017 Share Posted December 11, 2017 Were we trying to replicate the tabs and also the cart case? I’m working on a case in Inventor that doesn’t expect the tabs to be there. Should be easier for me to 3D print. Should easily stay aligned if it fits the dimensions. Quote Link to comment Share on other sites More sharing options...
+acadiel Posted December 11, 2017 Share Posted December 11, 2017 Reason being that tabs that small are a pain in getting 3D filamint filler out of. Learned that lesson when I designed the replacement TI cartridge shell. Ksarul even gave me some mods to make it better Sent from my Moto Z (2) using Tapatalk Quote Link to comment Share on other sites More sharing options...
brain Posted December 11, 2017 Share Posted December 11, 2017 Hi Jim, OK, I did some measures for the little ( 4 ) tabs on the CC-40 ROM boards. Using several CC-40 Memo processor boards As examples to check with. , Looking at the board with the chip side up and the cart edge Connector facing you. The distance from the top edge to the First tab is 6/32 inch. ( left hand side of cart ) The tabs are slopped, so this measure Is to the beginning of the slop. The tab measures ( top of tab ) 3/32 of inch across, base of tab is 4/32 of an inch. Small slop From top edge to bottom edge, on the tab. Same for each tab. , The distance between the top tab and the bottom tab, ( Measure between Edge of base of the top and bottom tab) is 3/4 of inch. , You can use the same measure on the right hand side of the cart as well. The left and right side of the cart measure the same. I checked several CC-40 carts they all are the same. , The only difference I could find on other Texas Instruments produced CC-40 carts was some are missing the top left hand side tab. But This could of been a quality control issue, does not seem to Be an issue for the cart case, fitting the carts. , Hope this helps Lee TI998owner OK, from top of board: 0" top of board 6/32" from there to top most wide portion of top tab 4/32" from there to bottom of wide portion of top tab 24/32" from there to top most wide portion of bottom tab 4/32" from there to bottom of wide portion of bottom tab And: thinnest portion of tab is 3/32, meaning the slop is 1/64" for each side I laid them out, but they seem off compared to Jon's images, where the bottom tab look like it is also 6/32" from the bottom of the PCB. Maybe I misunderstood your measurements. I also don't see a measurement of the width of the tab (the part that sticks out). I used .025", but I doubt that is right. Here is a pic of what I have so far: Quote Link to comment Share on other sites More sharing options...
TI998owner Posted December 11, 2017 Share Posted December 11, 2017 Hi Jim, The width of each tab , the part that sticks out from The board is 1/32 inch. The measure of 6/32 from bottom. Of the cart to the base of the tab is correct. The picture is off, because the measure would be Rather squared , or even looking. Same distance for the top tabs And bottom tabs from top edge of cart as bottom edge of cart. ,Lee TI998owner Quote Link to comment Share on other sites More sharing options...
brain Posted December 11, 2017 Share Posted December 11, 2017 OK, I fixed the width to .03125 (1/32") I guess I need to get the length of teh main part of the PCB. If I exclude the edge connector, the height of the PCB is 1.55" If I figure the two tabs at 4/32", the distance from edge to tab as 6/32", and the distance from the tabs to each other is 24/32", that's: 6/32 + 4/32 + 24/32 + 4/32 + 6/32 = 44/32 = 1.375", not 1.55" That probably explains the difference. I used helocast's data for the PCB size minus the edge connector. Better data on the main PCB height would help. Jim Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted December 11, 2017 Share Posted December 11, 2017 Any objections to moving this thread to the dev sub? 1 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted December 11, 2017 Share Posted December 11, 2017 Actually, I think our TI section here on AtariAge is now large enough to accommodate a dedicated CC40 subgroup. With all this new activity from this new device, I think it deserves it. It would make a nice place for people to come for all things CC40 , hardware, software, modifications, etc. 1 Quote Link to comment Share on other sites More sharing options...
+acadiel Posted December 11, 2017 Share Posted December 11, 2017 OK, I fixed the width to .03125 (1/32") I guess I need to get the length of teh main part of the PCB. If I exclude the edge connector, the height of the PCB is 1.55" If I figure the two tabs at 4/32", the distance from edge to tab as 6/32", and the distance from the tabs to each other is 24/32", that's: 6/32 + 4/32 + 24/32 + 4/32 + 6/32 = 44/32 = 1.375", not 1.55" That probably explains the difference. I used helocast's data for the PCB size minus the edge connector. Better data on the main PCB height would help. Jim Can you please make these tabs breakaways or otherwise optional? Reason that I’m asking is because I tried making a 3D print with them, and it’s a pain to file the filler out of those four, and the board itself fits fine in mine without the tabs. Thoughts? Quote Link to comment Share on other sites More sharing options...
TI998owner Posted December 11, 2017 Share Posted December 11, 2017 Hi Jim, OK, I just got home from work. , Using the standard ruler. The height of the Cart, ( top edge to bottom Of cart at the edge connector is 61/32 or 3/32 short of 2 Inch total. , The main board is 1 inch and 15/32 or 47/32 or 1 inch and half inch minus 1/32 , From the main board edge to the cart edge connector is 14/32 or 2/32 short of 1/2 inch. , Adding these all together 47/32 + 14/32 = 61/32 or 3/32 short of 2 inch total height. , Also using this 47/32, measure from the top edge of the cart to the center of The first tabs , = 9/32 , measure from center of first tab to center of second Tab , = 29/32 , then measure from center of second tab to bottom edge of Main part of cart , = 9/32. Add them up 9/32 + 29/32 + 9/32 = 47/32 And if we add in the edge connector part 14/32 we end up with 61/32 Or 3/32 short of 2 inch's. , Again I hope this is useful Lee TI998owner Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted December 12, 2017 Share Posted December 12, 2017 Jim and Jon, Once the revised boards come in, if neither of you have any objection, I would be willing to supply the MegaMod EPROMs and/or Flash chips for a nominal fee for those who don't have the facility to burn their own from the file. I am thinking about $5 for the 39SF040 and $6 for the 27C040 which would include shipping via USPS First Class postage. 1 Quote Link to comment Share on other sites More sharing options...
brain Posted December 12, 2017 Share Posted December 12, 2017 Can you please make these tabs breakaways or otherwise optional? Reason that I’m asking is because I tried making a 3D print with them, and it’s a pain to file the filler out of those four, and the board itself fits fine in mine without the tabs. Thoughts? Can you puts some pics in? I'm not opposed to making these breakaways, but I am not sure why the 3D printer is having such a time making the channel. Do you have a stl file I can try here? Quote Link to comment Share on other sites More sharing options...
