+jedimatt42 Posted October 13, 2022 Author Share Posted October 13, 2022 that can be fixed with some edits to the /etc/samba/smb.conf either I can load the widelinks module and enable it, or create a separate share to the /media/usb0 mount point... creating a separate share is considered a better practice due to vulnerabilities in the widelinks functionality. I'll have to think about the right thing to do. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 14, 2022 Share Posted October 14, 2022 @jedimatt42 Just my thoughts, and not how I look at a business network, for certain. I think the security factor here would be allowing an open share access to a critical path or file, like accessing /etc or /etc/passwd directly, &c. In this case, there would seem to be no way to create such a link unless the TIPI is already compromised. The web service itself might be exploited to create the link necessary. Now, it could be possible to trick the TIPI in to doing things with a page retrieved via curl, so there is a potential for outside compromise. All this considered, I think if the TIPI is going to be compromised, it is going to be by something of larger concern within the network. 1 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted October 14, 2022 Author Share Posted October 14, 2022 18 minutes ago, OLD CS1 said: @jedimatt42 Just my thoughts, and not how I look at a business network, for certain. I think the security factor here would be allowing an open share access to a critical path or file, like accessing /etc or /etc/passwd directly, &c. In this case, there would seem to be no way to create such a link unless the TIPI is already compromised. The web service itself might be exploited to create the link necessary. Now, it could be possible to trick the TIPI in to doing things with a page retrieved via curl, so there is a potential for outside compromise. All this considered, I think if the TIPI is going to be compromised, it is going to be by something of larger concern within the network. One of the other factors is that the documentation on the feature to enable wide links is out of date with the feature, and I suspect at some point the SMBd engineers will just pull it. I've made it work locally, but I had to add the 'vfs objects = widelinks' to load the widelinks module, even though the 'current' docs say that is implicit. They also say it may become explicit in some future. But then that future has already arrived, and they didn't care enough about the feature to update the docs. Ideally, I'd fix it so 'USB' under tipi_disk is not present unless the drive is mounted, and that it is the mount point. 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 14, 2022 Share Posted October 14, 2022 This seems to indicate the security problem was addressed. https://unix.stackexchange.com/questions/505170/can-the-samba-security-setting-wide-links-be-bypassed-using-a-race-condition What about a cron job that checks for a USB drive then creates the symlink if one is mounted? Does Linux have something like event triggers? Is this still viable in Linux? https://unix.stackexchange.com/questions/47337/run-shell-script-when-new-volume-mounted 1 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted October 16, 2022 Author Share Posted October 16, 2022 So, I've been using rbrito/usbmount: Simple set of scripts to automount removable devices for a Linux system (github.com) This has a mount trigger and umount trigger I can add scripts to. I've modified the setup so that it dynamically adds and removes the mountpoint under /home/tipi/tipi_disk for each storage device as they are added or removed. And it performs a bind mount eliminating the issues with the softlinks and smbd. Devices show up in TIPI.USB0, TIPI.USB1, etc.. This is in update 2.40 which is now available. Note: there is a chance this will work fine for those booting off USB. I personally have not been able to 'reboot' if booted off USB. That is unsupported territory, or will require the community to provide the support. 5 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 16, 2022 Share Posted October 16, 2022 Very cool. It never occurred to me to see what my NASes use, as they automatically manage USB devices, as well. 2 Quote Link to comment Share on other sites More sharing options...
+9640News Posted October 19, 2022 Share Posted October 19, 2022 On 10/16/2022 at 1:13 PM, jedimatt42 said: So, I've been using rbrito/usbmount: Simple set of scripts to automount removable devices for a Linux system (github.com) This has a mount trigger and umount trigger I can add scripts to. I've modified the setup so that it dynamically adds and removes the mountpoint under /home/tipi/tipi_disk for each storage device as they are added or removed. And it performs a bind mount eliminating the issues with the softlinks and smbd. Devices show up in TIPI.USB0, TIPI.USB1, etc.. This is in update 2.40 which is now available. Note: there is a chance this will work fine for those booting off USB. I personally have not been able to 'reboot' if booted off USB. That is unsupported territory, or will require the community to provide the support. Just a FYI, I was not able to see my USB flashdrive plugged into the TIPI that has the USB-SSD setup. Beery 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted October 22, 2022 Author Share Posted October 22, 2022 @GDMike said "I wish it (DM2K) was an option from the tipi menu" in thread: What is it that users are calling the tipi menu? I know there is the 'mega menu for tipi' program, but it comes out of the box with a DM2K entry and is very end user customizable. So that cannot be the one referred to. FCMENU for Force Command is also end user configurable, and also not TIPI specific. Everyone has different terminology... And everyone uses this old computer differently... I just want to understand what is being asked for, as it might make enough sense for me to implement. 2 Quote Link to comment Share on other sites More sharing options...
jrhodes Posted October 22, 2022 Share Posted October 22, 2022 6 minutes ago, jedimatt42 said: @GDMike said "I wish it (DM2K) was an option from the tipi menu" in thread: What is it that users are calling the tipi menu? I know there is the 'mega menu for tipi' program, but it comes out of the box with a DM2K entry and is very end user customizable. So that cannot be the one referred to. FCMENU for Force Command is also end user configurable, and also not TIPI specific. Everyone has different terminology... And everyone uses this old computer differently... I just want to understand what is being asked for, as it might make enough sense for me to implement. Probably not what @GDMike was referencing, but i the program that is executed with CALL TIPI, TIPICFG, i myself have referred to as "The Tipi Menu", as it is where i go (albeit rarely) to change TIPI specific things like dsk mappings and apply updates. 3 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted October 22, 2022 Share Posted October 22, 2022 40 minutes ago, jrhodes said: Probably not what @GDMike was referencing, but i the program that is executed with CALL TIPI, TIPICFG, i myself have referred to as "The Tipi Menu", as it is where i go (albeit rarely) to change TIPI specific things like dsk mappings and apply updates. CALL TIPI("TIPI.DM2K") works great if you have DM2K in your root folder.. I also have the latest version at HTTP://ftp.whtech.com/TIPI/DM2K which you can load with CALL TIPI("PI.HTTP:///ftp.whtech.com/TIPI/DM2K") or if you set a URI to that url then "URI1.DM2K" 1 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted October 22, 2022 Author Share Posted October 22, 2022 8 minutes ago, arcadeshopper said: CALL TIPI("TIPI.DM2K") works great if you have DM2K in your root folder.. I also have the latest version at HTTP://ftp.whtech.com/TIPI/DM2K which you can load with CALL TIPI("PI.HTTP:///ftp.whtech.com/TIPI/DM2K") or if you set a URI to that url then "URI1.DM2K" Yep, there are 107 things that work, but I don't want to get confused with solutions here, I want to know what the heck @GDMike was suggesting. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted October 23, 2022 Share Posted October 23, 2022 (edited) 1 hour ago, arcadeshopper said: CALL TIPI("TIPI.DM2K") works great if you have DM2K in your root folder.. I also have the latest version at HTTP://ftp.whtech.com/TIPI/DM2K which you can load with CALL TIPI("PI.HTTP://tp.whtech.com/TIPI/DM2K") or if you set a URI to that url then "URI1.DM2K" I didn't know this, but I really would like to see a menu in the CALL TIPI cfg screen that allowed setting a path and filename along with a shortcut nickname that would launch from that menu. But at least theres another way to launch dm2k..I didn't know that was available.. yes, I know what they say about "WISH".. Ty Edited October 23, 2022 by GDMike 1 1 Quote Link to comment Share on other sites More sharing options...
+dhe Posted October 23, 2022 Share Posted October 23, 2022 Feature Request. I wouldn't mind having a file search function on the web interface. 2 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 23, 2022 Share Posted October 23, 2022 6 hours ago, dhe said: Feature Request. I wouldn't mind having a file search function on the web interface. Similarly, on a real TI, when requesting a directory listing, is it possible to pass a search pattern to the DSR? I have never worked with a TI file directory outside of something like DM2K. Comparable example, in Commodore DOS when you load a directory via the "$" DOS file token, you can make requests like "$0:TEST*" or "$0:*=P", where "0:" is the drive number, asking for all files starting with "TEST", or all files of type (P)rogram. 3 Quote Link to comment Share on other sites More sharing options...
Tursi Posted October 23, 2022 Share Posted October 23, 2022 1 hour ago, OLD CS1 said: Similarly, on a real TI, when requesting a directory listing, is it possible to pass a search pattern to the DSR? I have never worked with a TI file directory outside of something like DM2K. Nope, the directory open just opens a virtual file from which you read records, and accepts no name parameter (if you pass one, it's interpreted as a request for a file instead of the directory.) Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted October 23, 2022 Author Share Posted October 23, 2022 1 hour ago, OLD CS1 said: Similarly, on a real TI, when requesting a directory listing, is it possible to pass a search pattern to the DSR? I have never worked with a TI file directory outside of something like DM2K. Comparable example, in Commodore DOS when you load a directory via the "$" DOS file token, you can make requests like "$0:TEST*" or "$0:*=P", where "0:" is the drive number, asking for all files starting with "TEST", or all files of type (P)rogram. The DSR routines are quite specific... I suppose we could imagine extensions like modifier device names... Things could be done to add modifiers to the device. I really haven't found much need... but I enjoy typing. And I did implement 4A side wildcard support in ForceCommand so you can glob on the DIR command as well as many others. I didn't add it to commands that require singular file arguments. This wildcarding works on non-TIPI storage as well. So. now I'm in a trap.. and whatever syntax that could be used for globbing in a TIPI device name extension ( where on a 4A a device name specifies a root dir, a subdir, or a file ) needs to remain non-ambiguous with ForceCommand globbing. Or maybe ForceCommand figures out how to know if a DSR catalog file understands globbing, and just passes them through. (glob is a technical term) Anything like this will introduce compatibility issues with corner cases, since the 4A filesystem allows pretty much anything but a space in a file name. Smart use of sequences will mitigate coincidence. Some things can be context aware as well... Like TIPI allows OPEN'ing a text file, and LOAD'ing the same file detecting that it'll need to convert it to a PROGRAM image first. So.. the LOAD operation could filter out things that can't be LOAD'ed, for instance. Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted October 23, 2022 Author Share Posted October 23, 2022 4 minutes ago, Tursi said: Nope, the directory open just opens a virtual file from which you read records, and accepts no name parameter (if you pass one, it's interpreted as a request for a file instead of the directory.) We could support something like 'TIPI.G=TEST#?.' to open a catalog on a tipi device, and only include records that match 'TEST#?' The trailing magic subdir named G=TEST#? would be a filter on the device TIPI. Then you could pass that through to programs like DM2K Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted October 23, 2022 Author Share Posted October 23, 2022 Also, there is this fun looking game on the 4A that is like pacman but you type the letter in the adjacent section that you want your character to travel to. This might be a good place to start. ( LOL, just kidding... I do enjoy typing over shortcuts though... easier to remember ) 1 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted October 23, 2022 Share Posted October 23, 2022 2 hours ago, jedimatt42 said: (glob is a technical term) I groked it. 2 hours ago, jedimatt42 said: 'TIPI.G=TEST#?.' Your Amiga heritage is showing I am not familiar with your ForceCommand syntax, so I have nothing to offer at this point. I think "$" is a valid character for TI filenames, so that certainly would not work. The #? strikes me as a wildcard idea for the TI, not just because of its Amiga-ness, but because it is so unique in the computer world. Are either "#" or "?" valid for TI filenames? Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted October 24, 2022 Author Share Posted October 24, 2022 2 hours ago, OLD CS1 said: I groked it. Your Amiga heritage is showing I am not familiar with your ForceCommand syntax, so I have nothing to offer at this point. I think "$" is a valid character for TI filenames, so that certainly would not work. The #? strikes me as a wildcard idea for the TI, not just because of its Amiga-ness, but because it is so unique in the computer world. Are either "#" or "?" valid for TI filenames? ForceCommand uses dos like '*' and '?' --- so, DIR PAR* would list all the files starting with 'PAR' -- Looks like I only implemented the '*' : jedimatt42/fcmd Wiki (github.com) - DIR Everything except space ' ' and dot '.' are valid character in a 4A filename. This is where a complex character combination buys us probable immunity or something like the funny directory name that is actually a filter spec... The directory filter spec approach would be useful in other tools that can catalog a directory. The SETDIR DSR entry is stateful... (I think out loud a bunch, even if out loud is just the clicky keyboard) We could actually just use the modern asterisk approach... thinking about collisions, if the real name of something is 'TEST*' cause TIPI will let you do that, then that would simply have to be the dominant match for something opening 'TEST*' and then only when that dominant match is not present would it fall back on evaluating the wildcard. I hated the c64 load "$" thing back in the day, cause my friends with c64s didn't know what it meant and couldn't explain it. Learning that it was a query expression processed by the intelligent device made me appreciate it. But I don't really spend any time with my C64... If someone knows of a doc that describes all the expressions possible, ( I imagine it would be part of the floppy drive manual? -- oh, look, right there: Commodore_1541_Disk_Drive_Users_Guide_1982-09_Commodore.pdf (archive.org)) 2 Quote Link to comment Share on other sites More sharing options...
+dhe Posted October 30, 2022 Share Posted October 30, 2022 Dumb user question here 🤚 Can you give me the part numbers for the screws and gromlets used to mount PI to the TIPI board please? Thanks Quote Link to comment Share on other sites More sharing options...
Duewester Posted October 30, 2022 Share Posted October 30, 2022 (edited) 50 minutes ago, dhe said: Can you give me the part numbers for the screws and gromlets used to mount PI to the TIPI board please? I use 2.5 mm nylon screws for most of my Pi work (occasionally 2.5mm brass standoffs). You can find kit boxes of various lengths with nuts and washers on Amazon or Adafruit. https://www.adafruit.com/product/3299?gclid=Cj0KCQjwwfiaBhC7ARIsAGvcPe6uCYEUSqpSrQPWFdfcEymM28w-cTCDRAUjcHkUnIJjylyUwxX12ucaAinWEALw_wcB As an example. Edited October 30, 2022 by Duewester 3 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted October 30, 2022 Author Share Posted October 30, 2022 49 minutes ago, Duewester said: I use 2.5 mm nylon screws for most of my Pi work (occasionally 2.5mm brass standoffs). You can find kit boxes of various lengths with nuts and washers on Amazon or Adafruit. https://www.adafruit.com/product/3299?gclid=Cj0KCQjwwfiaBhC7ARIsAGvcPe6uCYEUSqpSrQPWFdfcEymM28w-cTCDRAUjcHkUnIJjylyUwxX12ucaAinWEALw_wcB As an example. When I have done this, I used 1 nut as the spacer. 2 Quote Link to comment Share on other sites More sharing options...
Switch1995 Posted October 30, 2022 Share Posted October 30, 2022 I purchased these three items on EBay to get my TIPI PEB set up the way I like it: nylon standoffs: https://www.ebay.com/itm/233655389241?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=F-5RbtsPRzi&sssrc=2349624&ssuid=QfU6nnIiRby&var=&widget_ver=artemis&media=COPY 3ft braided cord to power PI: https://www.ebay.com/itm/114634390195?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=pInRSGm0ToK&sssrc=2349624&ssuid=QfU6nnIiRby&var=&widget_ver=artemis&media=COPY power strip with four USB power ports: https://www.ebay.com/itm/333842426752?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=VQja2x6lQ4y&sssrc=2349624&ssuid=QfU6nnIiRby&var=&widget_ver=artemis&media=COPY 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted November 1, 2022 Share Posted November 1, 2022 http://tigameshelf.net/Files/Emu/MARBLE.dsk marble doesn't show up as a editable extended basic program in the web interface when it's loadable in xb. tried resaving the file in classic99 to the tipi drive and it still is not showing up as editable in web 1 Quote Link to comment Share on other sites More sharing options...
