+Cafeman Posted September 25, 2018 Share Posted September 25, 2018 Run it in emulation and check DMACTL shadow register $022f. Are the rightmost 2 bits $01, $02, or $03? (01, 10, 11 IN BINARY) Not sure what effect it would have changing the setting of DMACTL. You could try it in an emulator and see. Quote Link to comment Share on other sites More sharing options...
TIX Posted September 25, 2018 Author Share Posted September 25, 2018 (edited) Revision 2 slightly cropped yellow saucer slightly reduced animation of red saucer Check it out below (edit: download again..) Edited October 3, 2018 by TIX Quote Link to comment Share on other sites More sharing options...
doctorclu Posted September 25, 2018 Share Posted September 25, 2018 And an arcade color version... moon-test-n5c.bin 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 25, 2018 Share Posted September 25, 2018 (edited) much better... now if we just add the base-pad we roll off of in the beginning seriously though, later on that enemy rocket thing that tries to get at you from behind Looking good for me guys! Edited September 25, 2018 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
+Cafeman Posted September 25, 2018 Share Posted September 25, 2018 Run it in emulation and check DMACTL shadow register $022f. Are the rightmost 2 bits $01, $02, or $03? (01, 10, 11 IN BINARY) Not sure what effect it would have changing the setting of DMACTL. You could try it in an emulator and see. Maybe I'm mis-remembering and you can't query into a shadow, maybe that is the write register... anyway, running in Altirra, DMACTL is $3E or "0011 1110". So the playfield bytes are the right-most two bits so "10" which is (I believe) means it is a 'normal playfield'. What happens if I change it to setting 3 or "11" ? Not sure but I wouldn't be surprised if it abended because this affects timing and memory Antic uses. But I also think it answers the question why the edges are ugly - you are seeing the DLI color changes of COLBK on the edges. If they had coded the game in Wide "11" mode, I think you wouldn't have noticed that. But maybe they did it for optimization. Quote Link to comment Share on other sites More sharing options...
Gunstar Posted September 25, 2018 Share Posted September 25, 2018 That's my design. We have a few floating around here and can show people how to make their own if they want. It really needs a third wheel if the buggy is to be longer like the arcade... Quote Link to comment Share on other sites More sharing options...
TIX Posted September 25, 2018 Author Share Posted September 25, 2018 I tried the latest 'colored' version on Atari800 Retropie version and the colors are the same (washed up) as in the Altirra .. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 26, 2018 Share Posted September 26, 2018 (edited) but it looks awesome on real Atari 130XE NTSC and on Gunstars 800 Pal machine, both LCD and CRT !!!! Must be an emu thing... did you set the 800 lum setting in Altira? It might just fix your wash out.. Edited September 26, 2018 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
TIX Posted September 26, 2018 Author Share Posted September 26, 2018 (edited) Here is a new improved Station Wagon model, for those who like them big Edited September 26, 2018 by TIX 2 Quote Link to comment Share on other sites More sharing options...
doctorclu Posted September 26, 2018 Share Posted September 26, 2018 Here is a new improved Station Wagon model, for those who like them big Cute. I like the larger reflection on the windshield. Quote Link to comment Share on other sites More sharing options...
TIX Posted September 26, 2018 Author Share Posted September 26, 2018 (edited) New version with tweaked enemy missiles (2 out of the 3 frames).. I'm searching for the tank but can't find it.. any help ? Edited October 3, 2018 by TIX Quote Link to comment Share on other sites More sharing options...
EnderDude Posted September 26, 2018 Share Posted September 26, 2018 I think the tanks are playfield graphics, and use a different mode than the pms. If youre using omnivore, you can easily switch the bitmap view to a couple of antic modes. Quote Link to comment Share on other sites More sharing options...
Level42 Posted September 26, 2018 Share Posted September 26, 2018 how do i convert those bin files into ATRs easily ? Quote Link to comment Share on other sites More sharing options...
doctorclu Posted September 27, 2018 Share Posted September 27, 2018 And arcade color! moon-test-n6c.bin Quote Link to comment Share on other sites More sharing options...
EnderDude Posted September 27, 2018 Share Posted September 27, 2018 (edited) And while we're at it, how about we make the title screen a little better? Edited September 27, 2018 by EnderDude Quote Link to comment Share on other sites More sharing options...
doctorclu Posted September 27, 2018 Share Posted September 27, 2018 Title screen, maybe later. In the meantime, a ATR image I started to hack up. Has the cricket rover, and the arcade colors. No enemy mods yet. Moon Patrol-n01c.atr Quote Link to comment Share on other sites More sharing options...
TIX Posted September 27, 2018 Author Share Posted September 27, 2018 (edited) And arcade color! Can we have the yellow saucers to be yellow please ?? Edited September 27, 2018 by TIX Quote Link to comment Share on other sites More sharing options...
TIX Posted September 27, 2018 Author Share Posted September 27, 2018 I think the tanks are playfield graphics, and use a different mode than the pms. If youre using omnivore, you can easily switch the bitmap view to a couple of antic modes. ..thanks I 'll look into it Quote Link to comment Share on other sites More sharing options...
TIX Posted September 27, 2018 Author Share Posted September 27, 2018 but it looks awesome on real Atari 130XE NTSC and on Gunstars 800 Pal machine, both LCD and CRT !!!! Must be an emu thing... did you set the 800 lum setting in Altira? It might just fix your wash out.. Switched to pal mode in Alrirra, and bam there it is ! perfect colors and correct speed 1 Quote Link to comment Share on other sites More sharing options...
doctorclu Posted September 27, 2018 Share Posted September 27, 2018 Switched to pal mode in Alrirra, and bam there it is ! perfect colors and correct speed AWESOME! So this is working in PAL but not NTSC... which means... Atari 800 (though I had it in NTSC mode) is actually the PAL colors and that I need to make a NTSC color set. Quote Link to comment Share on other sites More sharing options...
doctorclu Posted September 27, 2018 Share Posted September 27, 2018 Can we have the yellow saucers to be yellow please ?? Haha... still tracking that down. 1 Quote Link to comment Share on other sites More sharing options...
EnderDude Posted September 27, 2018 Share Posted September 27, 2018 Okay, so after a little digging, the tank graphics are around 6c5 to 702. You're welcome. 2 Quote Link to comment Share on other sites More sharing options...
doctorclu Posted September 27, 2018 Share Posted September 27, 2018 Hey TIX, you seem full of energy, can you update these two with your enemy mods as you go? This is the Atari 800 disk image, they'll love that! Moon Patrol-n01c.atr 5200 version... the one we've promised for a while. MoonPatrol 02 5200.bin You got the sprite modding down, if you can update those two with what you've got, will be great. Quote Link to comment Share on other sites More sharing options...
TIX Posted September 27, 2018 Author Share Posted September 27, 2018 (edited) Sure I will, as soon as I declare this hack done (at least as far as i am concerned !) I'm currently trying to figure out how the wheels works.. It is confusing, but I'm getting there.. Edit aha now get it ! Edited September 27, 2018 by TIX Quote Link to comment Share on other sites More sharing options...
doctorclu Posted September 27, 2018 Share Posted September 27, 2018 So what did you find out on how it works? Quote Link to comment Share on other sites More sharing options...
