Mr Robot Posted October 19, 2020 Share Posted October 19, 2020 2 hours ago, mozzwald said: Typing +++ will hangup the connection so you don't need to wait for it to timeout. I was wondering about that! +++ should return you to command mode, ath should hang up here is the hayes command set and s registers https://en.wikipedia.org/wiki/Hayes_command_set The most common implementation after hayes I would guess would be US Robotics, everybody had a courier or one of its sequels bitd I've attached the courier manual with all the & and % codes in it. USRCourier-Manual.pdf Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 19, 2020 Author Share Posted October 19, 2020 The DOS 2.5's that I made in this zip have 1-4 enabled. the DOS 2.0D has 1-8 enabled. https://github.com/FujiNetWIFI/fujinet-sd-card/releases -Thom 2 Quote Link to comment Share on other sites More sharing options...
manterola Posted October 19, 2020 Share Posted October 19, 2020 (edited) 21 minutes ago, Mr Robot said: I was wondering about that! +++ should return you to command mode, ath should hang up here is the hayes command set and s registers https://en.wikipedia.org/wiki/Hayes_command_set The most common implementation after hayes I would guess would be US Robotics, everybody had a courier or one of its sequels bitd I've attached the courier manual with all the & and % codes in it. USRCourier-Manual.pdf 639.52 kB · 2 downloads Other cool features I've seen in the Lantronix and other modem emulators. I don't own the latest Fujinet official device, so I don't know if some of these features are already implemented: - Use of Phonebook directory: basically a list of fake phone numbers that redirect you to ip addresses: Ex: dial atdt 1234 , the modem emulator connects to irata.online:8005 - Relaxed use of atdt, atd commands. So you can dial atdt foo.com or ATDT foo.com or atdtfoo.com or atd foo.com or atdt foo.com,23 or atdt foo.com:23 - AT? or other option to get a quick help, or reference of AT commands. - Some other at command to enable/disable the telnet protocol (IAC) (Maybe later do something automatic like Lantronix does). Edited October 19, 2020 by manterola Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 19, 2020 Author Share Posted October 19, 2020 IAC can be enabled/disabled with ATNET1 and ATNET0. Right now, IAC processing is very basic, and needs to be extended (dunno how much more, as most Atari comms programs simply lack things to map to) -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 19, 2020 Author Share Posted October 19, 2020 The MODEM was something we found off the shelf and adapted for the Atari, integrating it into the SIO code, and making a special case to shunt main loop processing to it when concurrent mode was enabled, disabling it when the COMMAND line is asserted, while also adding the commands to set baud rate/translation/etc. It could really stand to use a rewrite, if anyone wants to take that on. -Thom Quote Link to comment Share on other sites More sharing options...
tsom Posted October 19, 2020 Share Posted October 19, 2020 (edited) I was able to test the latest firmware, and while, if a host was not found ("ERROR MOUNTING HOST SLOT"), the whole system does not reset, the FujiNet still resets (Shows the "connected to network xxx" screen) and the Host entry that was attempted is removed. I think removing the entry is a bit drastic, as was pointed out, the server may just not be up or responding at that time - deleting the entry is like a "tough cookies" response. This can be tested by putting in a bad server address and trying to connect. Edited October 19, 2020 by tsom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 19, 2020 Author Share Posted October 19, 2020 darn it, I thought I had gotten rid of that bug. I will dig deeper. -Thom Quote Link to comment Share on other sites More sharing options...
Calibus Posted October 19, 2020 Share Posted October 19, 2020 7 minutes ago, tsom said: I was able to test the latest firmware, and while, if a host was not found ("ERROR MOUNTING HOST SLOT"), the whole system does not reset, the FujiNet still resets (Shows the "connected to network xxx" screen) and the Host entry that was attempted is removed. I think removing the entry is a bit drastic, as was pointed out, the server may just not be up or responding at that time - deleting the entry is like a "tough cookies" response. This can be tested by putting in a bad server address and trying to connect. When I first saw this issue last week and was bugging Thom about it (turns out I was running an older version of TNFS which wasn't compatible) I noticed that while the host entries disappeared - if I power cycled the Atari - the entries would come back. Jim Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 19, 2020 Author Share Posted October 19, 2020 (edited) This is a very strange and reproducible issue. I have no code in CONFIG which explicitly wipes the host slot entry, which is _VERY_ strange. -Thom the relevant code for the host slots screen is here: https://github.com/FujiNetWIFI/fujinet-config/blob/master/src/diskulator_hosts.c Edited October 19, 2020 by tschak909 Quote Link to comment Share on other sites More sharing options...
phigan Posted October 19, 2020 Share Posted October 19, 2020 11 hours ago, mozzwald said: Typing +++ will hangup the connection so you don't need to wait for it to timeout. Do you have a list of AT commands you want added? Can you open an issue here with that list? It should be fairly easy to add some of them, only need to edit 2 files probably (modem.cpp & modem.h). Have you tried the +++ during ATDT connection? It doesn't work for me and I always have to wait for timeout. Some people have already responded with some good stuff about AT commands, but I'll also gather those with my list and open an issue like you suggested, or add to one if someone's beat me to it. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted October 19, 2020 Share Posted October 19, 2020 11 hours ago, mozzwald said: Typing +++ will hangup the connection so you don't need to wait for it to timeout. Do you have a list of AT commands you want added? Can you open an issue here with that list? It should be fairly easy to add some of them, only need to edit 2 files probably (modem.cpp & modem.h). Hayes Chronograph would be nice. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 20, 2020 Author Share Posted October 20, 2020 Hayes Chronograph commands conflict with the MODEM commands. -Thom 1 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted October 20, 2020 Share Posted October 20, 2020 That's OK, gotta go with the majority on this one. The Chrono is a beautiful, but seldom seen device. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 20, 2020 Author Share Posted October 20, 2020 I could add some equivalent commands. We want time and date? -Thom 1 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted October 20, 2020 Share Posted October 20, 2020 Maybe something as similar to the Hayes as possible so it would be easy to patch software (if any exists). :) Quote Link to comment Share on other sites More sharing options...
mozzwald Posted October 20, 2020 Share Posted October 20, 2020 A new firmware update is available that fixes the disappearing host slots when it cannot connect. More version information is also displayed on the download page 3 Quote Link to comment Share on other sites More sharing options...
tsom Posted October 20, 2020 Share Posted October 20, 2020 8 hours ago, mozzwald said: A new firmware update is available that fixes the disappearing host slots when it cannot connect. More version information is also displayed on the download page Is the fix posted up to GitHub? Curious as to what the issue was (been checking out the source code - who know, may be able to help out someday ) Thanks! Quote Link to comment Share on other sites More sharing options...
mozzwald Posted October 20, 2020 Share Posted October 20, 2020 1 hour ago, tsom said: Is the fix posted up to GitHub? Curious as to what the issue was (been checking out the source code - who know, may be able to help out someday ) Thanks! Always. The firmware is built directly from the master branch. The problem was that on the second attempt to connect after failure it was calling set_type(HOSTTYPE_TNFS) which wipes the hostname. Now it only calls that on the first attempt. Quote Link to comment Share on other sites More sharing options...
tsom Posted October 20, 2020 Share Posted October 20, 2020 17 minutes ago, mozzwald said: Always. The firmware is built directly from the master branch. The problem was that on the second attempt to connect after failure it was calling set_type(HOSTTYPE_TNFS) which wipes the hostname. Now it only calls that on the first attempt. Ah, ok. I was looking at the wrong repo (FujiNet-config). Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 20, 2020 Author Share Posted October 20, 2020 (edited) #Atari8bit #FujiNet I have added a new command ($DF) to the FUJI ($70) device which causes the #FUJINET to emit a clock signal on CLOCKIN pin for synchronous transmission. The AUX bytes specify the frequency in kHz, and will be used by @mr-atari to implement a UHSIO with a theoretical max rate of 440kbps. A tool in fnc-tools called FESCLK can set this. -Thom https://github.com/FujiNetWIFI/fujinet-platformio/wiki/SIO-Command-$DF-Set-External-SIO-Clock Edited October 20, 2020 by tschak909 6 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted October 21, 2020 Share Posted October 21, 2020 Let's see how fast PoKey can go. :) Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 21, 2020 Author Share Posted October 21, 2020 (edited) 1 hour ago, Kyle22 said: Let's see how fast PoKey can go. We already pretty much understand the theoretical max. If you remove ALL of the caps on the SIO lines, you can run at the max speed of 440 kilobits/sec. This is limited by the fact that POKEY needs at least four clock cycles to successfully sample the incoming bit. If you don't, you'll be able to hit about 220 kb/s.. -Thom Edited October 21, 2020 by tschak909 3 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted October 21, 2020 Share Posted October 21, 2020 A good speed boost. Now, if someone can figure out Synchromesh properly.... Quote Link to comment Share on other sites More sharing options...
Fred Olivas Posted October 21, 2020 Share Posted October 21, 2020 Okay so where is the manual? I'd like to learn how to log onto a BBS. Not having any luck. Can anyone help me figure it out? Quote Link to comment Share on other sites More sharing options...
fenrock Posted October 21, 2020 Share Posted October 21, 2020 My own fujinet is being built and shipped friday, but when I get it, I'll be starting here: https://github.com/FujiNetWIFI/fujinet-platformio/wiki/FujiNet-Quickstart-Guide 1 Quote Link to comment Share on other sites More sharing options...
