tschak909 Posted December 15, 2020 Author Share Posted December 15, 2020 @mozzwald has just gotten 1.3 boards back, and is working with testers. -Thom 2 Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted December 15, 2020 Share Posted December 15, 2020 The NUC+ Fujinet daughterboards are using the v1.3 schematic as well, hopefully they will be here this week. Quote Link to comment Share on other sites More sharing options...
Atari_bbs_fan Posted December 15, 2020 Share Posted December 15, 2020 12 hours ago, tschak909 said: @mozzwald has just gotten 1.3 boards back, and is working with testers. -Thom Will it be possible to rework older Fujinet boards to be compatible with v1.3 boards or is it a whole new design? Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted December 15, 2020 Share Posted December 15, 2020 1 hour ago, Atari_bbs_fan said: Will it be possible to rework older Fujinet boards to be compatible with v1.3 boards or is it a whole new design? Anything is possible, but it wouldn't be easy. The connection between the Atari and the ESP32 is now buffered so all of that would need to be reworked and the power goes through a couple of new mosfets so all that needs to be redone too. The ESP to USB/SD/LED's/Switches is all mostly the same. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 15, 2020 Author Share Posted December 15, 2020 (edited) It must be understood that what culminated in the 1.3 boards was really unexpected, it was a case of people testing with many different configurations, and we found very specific problems, (1) that the fuji's power switch being off was causing the ESP32 to be slightly back-bias powered (WHOOPS), (2) People with external peripherals other than fujinet were seeing bus signals get seriously degraded coming out of the fujinet pass-through due to a lack of buffering. This worked okay at normal speeds, but high speed transfers were seriously affected. It's a 1.3 revision because it took three board spins to get it right. -Thom Edited December 15, 2020 by tschak909 Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted December 15, 2020 Share Posted December 15, 2020 Also a few incremental improvements: the reset button is now a safe reset, not hard reset as before, the resistor that fixes cassette loading now has a home rather than between two sio pins, the on/off switch has a little hat to make it more robust, the USB UART is now a smaller part (all the hand solderers say "Thanks Mozz!" ) because the original part is out of stock everywhere. 1 Quote Link to comment Share on other sites More sharing options...
Jochen Posted December 16, 2020 Share Posted December 16, 2020 Can someone please upload Platoterm 1.4, or better the Modem programs atr? No chance to Mount it on Irata.online Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 16, 2020 Author Share Posted December 16, 2020 3 hours ago, Jochen said: Can someone please upload Platoterm 1.4, or better the Modem programs atr? No chance to Mount it on Irata.online @Jochen I have uploaded the entire Comms folder to fujinet.pl/uploads. -Thom Quote Link to comment Share on other sites More sharing options...
mozzwald Posted December 16, 2020 Share Posted December 16, 2020 3 hours ago, Jochen said: Can someone please upload Platoterm 1.4, or better the Modem programs atr? No chance to Mount it on Irata.online You can download any atr from fujinet.online tnfs thru this web front end https://fujinet.online/tnfs-data/ see the networking dir Quote Link to comment Share on other sites More sharing options...
Jochen Posted December 17, 2020 Share Posted December 17, 2020 14 hours ago, mozzwald said: You can download any atr from fujinet.online tnfs thru this web front end https://fujinet.online/tnfs-data/ see the networking dir Thanks to both of you. I tried it this morning after getting up. Now I can continue testing. ? Quote Link to comment Share on other sites More sharing options...
chad5200 Posted December 18, 2020 Share Posted December 18, 2020 Where might I find a copy of RHND850.COM as seen in the YouTube video "#Atari8bit #FujiNet hosting BBS Express Pro! 5.0b"? I found RLISTEN.COM and TIME.COM on fujinet.online inside the fnc-tools.atr. But cannot locate RHND850.COM. Thanks! Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 18, 2020 Author Share Posted December 18, 2020 altirra additions disk. part of the altirra emulator download. -Thom 2 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 19, 2020 Author Share Posted December 19, 2020 Just discovered Major bug, when writing to double density (256 byte sector) disks, sector offset of first three 128 bytes sectors is being calculated incorrectly, causing images that will not boot correctly. Am working on a fix. Sorry. -Thom Quote Link to comment Share on other sites More sharing options...
FifthPlayer Posted December 21, 2020 Share Posted December 21, 2020 (edited) I finally set up my Atari with Fujinet today. I set up a local TNFS server on a Raspberry Pi that works great - I can browse, mount disks, and boot. But remote Internet hosts such as fujinet.online behave very unreliably (actually all that come pre-loaded into the Fujinet firmware). Sometimes I can browse remote TNFS directories, but sometimes it times out after a long delay. Sometimes I can boot off remote disk images, sometimes it hangs in the middle of boot. I'm using an unmodified 130XE with Fujinet as the only peripheral on the device (and a joystick, FWIW). The Fujinet is running the 2020-12-14 firmware. Has anyone had this problem? Update: log of a failed attempt to browse fujinet.online - also attached a photo of the config app after the failed read. [17:36:32] [17:36:32]CF: 70 f9 01 00 6b [17:36:32]sioFuji::sio_process() called [17:36:32]ACK! [17:36:32]Fuji cmd: MOUNT HOST [17:36:32]::mount {1} "FujiNet.online" [17:36:32]::mount_local Attempting mount of "FujiNet.online" [17:36:32]::mount_tnfs {1:0} "FujiNet.online" [17:36:32]Calling TNFS::begin [17:36:32]Resolving hostname "FujiNet.online" [17:36:32]Resoled to address 157.245.127.133 [17:36:32]TNFS mount FujiNet.online[157.245.127.133]:16384 [17:36:32]TNFS mount successful. session: 0xf813, version: 0x0102, min_retry: 1000ms [17:36:32]vfs_tnfs_register "/tnfs0x3fff4be4" @ 0x3fff4be4 = 0 "ESP_OK" [17:36:32]COMPLETE! [17:36:32] [17:36:32]CF: 70 f7 01 00 69 [17:36:32]sioFuji::sio_process() called [17:36:32]ACK! [17:36:32]Fuji cmd: OPEN DIRECTORY [17:36:32]<-SIO read 256 bytes [17:36:32]ACK! [17:36:32]Opening directory: "/", pattern: "" [17:36:32]::dir_open {1:2} "/", pattern "" [17:36:32]::dir_open actual path = "/" [17:36:32]TNFS open directory: sortopts=0x00 diropts=0x00 maxresults=0x0000 pattern="" path="/" [17:36:32]Directory opened, handle ID: 0, entries: 11 [17:36:32]COMPLETE! [17:36:32] [17:36:32]CF: 70 e4 00 00 55 [17:36:32]sioFuji::sio_process() called [17:36:32]ACK! [17:36:32]Fuji cmd: SET DIRECTORY POSITION [17:36:32]::dir_seek {1:2} 0 [17:36:33]COMPLETE! [17:36:33] [17:36:33]CF: 70 f6 24 00 8b [17:36:33]sioFuji::sio_process() called [17:36:33]ACK! [17:36:33]Fuji cmd: READ DIRECTORY ENTRY (max=36) [17:36:33]::dir_nextfile {1:2} [17:36:35]Timeout after 2000 milliseconds. Retrying [17:36:36]Reached end of of directory [17:36:36]->SIO write 36 bytes [17:36:36]COMPLETE! [17:36:36] [17:36:36]CF: 70 f5 01 00 67 [17:36:36]sioFuji::sio_process() called [17:36:36]ACK! [17:36:36]Fuji cmd: CLOSE DIRECTORY [17:36:36]COMPLETE! Edited December 21, 2020 by FifthPlayer added log Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 21, 2020 Author Share Posted December 21, 2020 The quality of your WiFi connection is important. and yes, please output debugging information. -Thom 1 Quote Link to comment Share on other sites More sharing options...
FifthPlayer Posted December 21, 2020 Share Posted December 21, 2020 (edited) 5 minutes ago, tschak909 said: The quality of your WiFi connection is important. and yes, please output debugging information. -Thom Updated with debug output. The Fujinet is not more than 10 feet away from the wifi router, so signal strength is likely not an issue. But I will look into the signal quality and possible interference. Edited December 21, 2020 by FifthPlayer Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 21, 2020 Author Share Posted December 21, 2020 Just now, FifthPlayer said: Updated with debug output. The Fujinet is not more than 10 feet away from the wifi router, so signal strength is likely not an issue. Ok, I don't see anything unusual from your directory output. can you try atari-apps.irata.online ? also perhaps attach a traceroute to both atari-apps.irata.online and fujinet.online? -Thom Quote Link to comment Share on other sites More sharing options...
mozzwald Posted December 21, 2020 Share Posted December 21, 2020 29 minutes ago, FifthPlayer said: Update: log of a failed attempt to browse fujinet.online - also attached a photo of the config app after the failed read. 14 minutes ago, tschak909 said: and yes, please output debugging information. If it helps, here's debug from the tnfs server: Spoiler 111.222.333.444 s=f813 c=00 q=00 | Mounted / OK, SID=f813 111.222.333.444 s=f813 c=17 q=01 | REQUEST cmd=0x17 TNFS_OPENDIRX 111.222.333.444 s=f813 c=17 q=01 | opendirx: diropt=0x00, sortopt=0x00, max=0x0000, pat="", path="/" 111.222.333.444 s=f813 c=17 q=01 | opendirx response: handle=0, count=11 111.222.333.444 s=f813 c=16 q=02 | REQUEST cmd=0x16 TNFS_SEEKDIR tnfs_seekdir to pos 0 111.222.333.444 s=f813 c=18 q=03 | REQUEST cmd=0x18 TNFS_READDIRX 111.222.333.444 s=f813 c=18 q=03 | readdirx request for 32 entries 111.222.333.444 s=f813 c=18 q=03 | readdirx responding with 11 entries, status_flags=0x1 111.222.333.444 s=f813 c=18 q=04 | REQUEST cmd=0x18 TNFS_READDIRX 111.222.333.444 s=f813 c=18 q=04 | readdirx no more entries - returning EOF 111.222.333.444 s=f813 c=18 q=04 | readdirx request for 32 entries 111.222.333.444 s=f813 c=18 q=04 | readdirx responding with 0 entries, status_flags=0x1 111.222.333.444 s=f813 c=12 q=05 | REQUEST cmd=0x12 TNFS_CLOSEDIR Quote Link to comment Share on other sites More sharing options...
FifthPlayer Posted December 21, 2020 Share Posted December 21, 2020 (edited) 29 minutes ago, tschak909 said: Ok, I don't see anything unusual from your directory output. can you try atari-apps.irata.online ? also perhaps attach a traceroute to both atari-apps.irata.online and fujinet.online? [17:50:12] [17:50:12]CF: 70 f4 00 00 65 [17:50:12]sioFuji::sio_process() called [17:50:12]ACK! [17:50:12]Fuji cmd: READ HOST SLOTS [17:50:12]->SIO write 256 bytes [17:50:12]COMPLETE! [17:50:12] [17:50:12]CF: 70 f2 00 00 63 [17:50:12]sioFuji::sio_process() called [17:50:12]ACK! [17:50:12]Fuji cmd: READ DEVICE SLOTS [17:50:12]->SIO write 304 bytes [17:50:12]COMPLETE! [17:50:15] [17:50:15]CF: 70 f9 02 00 6c [17:50:15]sioFuji::sio_process() called [17:50:15]ACK! [17:50:15]Fuji cmd: MOUNT HOST [17:50:15]::mount {2} "atari-apps.irata.online" [17:50:15]::mount_local Attempting mount of "atari-apps.irata.online" [17:50:15]::mount_tnfs {2:2} "atari-apps.irata.online" [17:50:15]::mount_tnfs Currently connected to host "atari-apps.irata.online" [17:50:15]COMPLETE! [17:50:15] [17:50:15]CF: 70 f7 02 00 6a [17:50:15]sioFuji::sio_process() called [17:50:15]ACK! [17:50:15]Fuji cmd: OPEN DIRECTORY [17:50:15]<-SIO read 256 bytes [17:50:15]ACK! [17:50:15]Opening directory: "/", pattern: "" [17:50:15]::dir_open {2:2} "/", pattern "" [17:50:15]::dir_open actual path = "/" [17:50:15]TNFS open directory: sortopts=0x00 diropts=0x00 maxresults=0x0000 pattern="" path="/" [17:50:16]Directory opened, handle ID: 0, entries: 18 [17:50:16]COMPLETE! [17:50:16] [17:50:16]CF: 70 e4 00 00 55 [17:50:16]sioFuji::sio_process() called [17:50:16]ACK! [17:50:16]Fuji cmd: SET DIRECTORY POSITION [17:50:16]::dir_seek {2:2} 0 [17:50:16]COMPLETE! [17:50:16] [17:50:16]CF: 70 f6 24 00 8b [17:50:16]sioFuji::sio_process() called [17:50:16]ACK! [17:50:16]Fuji cmd: READ DIRECTORY ENTRY (max=36) [17:50:16]::dir_nextfile {2:2} [17:50:18]Timeout after 2000 milliseconds. Retrying [17:50:19]Reached end of of directory [17:50:19]->SIO write 36 bytes [17:50:19]COMPLETE! [17:50:19] [17:50:19]CF: 70 f5 02 00 68 [17:50:19]sioFuji::sio_process() called [17:50:19]ACK! [17:50:19]Fuji cmd: CLOSE DIRECTORY [17:50:20]COMPLETE! pi@jotabout:~ $ traceroute fujinet.online traceroute to fujinet.online (157.245.127.133), 30 hops max, 60 byte packets 1 192.168.1.1 (192.168.1.1) 2.063 ms 1.720 ms 1.552 ms 2 gw-v200b.static.monkeybrains.net (199.241.203.129) 78.942 ms 82.973 ms 82.727 ms 3 172.17.22.208 (172.17.22.208) 82.681 ms 82.456 ms 82.471 ms 4 172.17.18.138 (172.17.18.138) 111.460 ms 111.174 ms 111.144 ms 5 172.17.21.194 (172.17.21.194) 85.164 ms 83.821 ms 85.922 ms 6 172.17.22.206 (172.17.22.206) 109.127 ms 104.807 ms 105.729 ms 7 172.17.21.218 (172.17.21.218) 105.720 ms 70.233 ms 48.385 ms 8 172.17.20.59 (172.17.20.59) 41.117 ms 40.762 ms 40.678 ms 9 172.17.16.242 (172.17.16.242) 46.378 ms 46.116 ms 49.313 ms 10 10ge16-19.core1.sfo1.he.net (216.218.244.49) 48.991 ms 36.432 ms 36.290 ms 11 100ge3-1.core4.fmt2.he.net (72.52.92.25) 42.461 ms 10ge5-6.core1.sjc2.he.net (184.105.213.161) 67.898 ms 67.752 ms 12 100ge10-2.core1.nyc4.he.net (184.105.81.217) 109.124 ms 10ge7-5.core1.sjc2.he.net (72.52.92.70) 43.932 ms 100ge14-1.core1.sjc2.he.net (184.105.213.157) 83.766 ms 13 * 100ge10-2.core1.nyc4.he.net (184.105.81.217) 148.483 ms 140.602 ms 14 * * * 15 * * * 16 * * * 17 * * * 18 * * * 19 * * * 20 * * * 21 * * * 22 * * * 23 * * * 24 * * * 25 * * * 26 * * * 27 * * * 28 * * * 29 * * * 30 * * * pi@jotabout:~ $ traceroute atari-apps.irata.online traceroute to atari-apps.irata.online (35.184.35.130), 30 hops max, 60 byte packets 1 192.168.1.1 (192.168.1.1) 3.324 ms 3.194 ms 3.105 ms 2 gw-v200b.static.monkeybrains.net (199.241.203.129) 19.721 ms 19.491 ms 19.362 ms 3 172.17.22.208 (172.17.22.208) 22.925 ms 22.691 ms 22.580 ms 4 172.17.18.138 (172.17.18.138) 17.231 ms 18.304 ms 15.762 ms 5 172.17.21.194 (172.17.21.194) 19.172 ms 19.029 ms 21.514 ms 6 172.17.22.206 (172.17.22.206) 21.336 ms 24.901 ms 29.012 ms 7 172.17.21.218 (172.17.21.218) 37.613 ms 19.467 ms 19.241 ms 8 172.17.20.59 (172.17.20.59) 16.879 ms 16.789 ms 16.550 ms 9 172.17.16.242 (172.17.16.242) 25.262 ms 25.209 ms 25.094 ms 10 208.52.0.73 (208.52.0.73) 25.066 ms 24.964 ms 24.747 ms 11 192.175.30.252 (192.175.30.252) 31.421 ms 31.193 ms 18.703 ms 12 192.175.29.226 (192.175.29.226) 22.733 ms 23.648 ms 34.473 ms 13 * * * 14 * be1.cr3-55smarket.bb.as11404.net (192.175.30.71) 41.486 ms * 15 be10.cr4-11greatoaks.bb.as11404.net (192.175.30.33) 53.163 ms 53.032 ms be12.cr4-11greatoaks.bb.as11404.net (192.1 75.30.222) 58.264 ms 16 209.85.168.110 (209.85.168.110) 63.560 ms 65.563 ms 75.345 ms 17 108.170.243.1 (108.170.243.1) 50.761 ms 209.85.142.239 (209.85.142.239) 44.341 ms 49.893 ms 18 108.170.242.237 (108.170.242.237) 48.857 ms 48.729 ms 108.170.242.254 (108.170.242.254) 48.565 ms 19 74.125.253.151 (74.125.253.151) 48.439 ms 74.125.253.149 (74.125.253.149) 48.146 ms 142.250.234.139 (142.250.234.1 39) 47.777 ms 20 142.250.237.174 (142.250.237.174) 54.128 ms 142.250.233.118 (142.250.233.118) 56.247 ms 142.250.237.176 (142.250.2 37.176) 56.025 ms 21 142.250.235.182 (142.250.235.182) 97.561 ms * 100.516 ms 22 * 209.85.245.86 (209.85.245.86) 95.398 ms 142.250.231.46 (142.250.231.46) 95.159 ms 23 142.250.232.104 (142.250.232.104) 95.141 ms 142.250.231.124 (142.250.231.124) 83.720 ms 142.250.232.22 (142.250.23 2.22) 83.259 ms 24 * * * 25 * * * 26 * * * 27 * * * 28 * * * 29 * * * 30 * * * Edited December 21, 2020 by FifthPlayer fix cut/paste job on fujinet.online Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 21, 2020 Author Share Posted December 21, 2020 The fact that it's not returning ANY directory entries at the server side is .... interesting, to say the least. for contrast, here's my output: 19:58:41.833 > CF: 70 f9 02 00 6c 19:58:41.833 > sioFuji::sio_process() called 19:58:41.833 > ACK! 19:58:41.833 > Fuji cmd: MOUNT HOST 19:58:41.833 > ::mount {2} "fujinet.online" 19:58:41.833 > ::mount_local Attempting mount of "fujinet.online" 19:58:41.834 > ::mount_tnfs {2:2} "fujinet.online" 19:58:41.835 > ::mount_tnfs Currently connected to host "fujinet.online" 19:58:41.835 > COMPLETE! 19:58:41.931 > 19:58:41.932 > CF: 70 f7 02 00 6a 19:58:41.932 > sioFuji::sio_process() called 19:58:41.932 > ACK! 19:58:41.932 > Fuji cmd: OPEN DIRECTORY 19:58:41.933 > <-SIO read 256 bytes 19:58:41.955 > ACK! 19:58:41.955 > Opening directory: "/", pattern: "" 19:58:41.955 > ::dir_open {2:2} "/", pattern "" 19:58:41.955 > ::dir_open actual path = "/" 19:58:41.955 > TNFS open directory: sortopts=0x00 diropts=0x00 maxresults=0x0000 pattern="" path="/" 19:58:42.040 > Directory opened, handle ID: 0, entries: 11 19:58:42.040 > COMPLETE! 19:58:42.044 > 19:58:42.044 > CF: 70 e4 00 00 55 19:58:42.044 > sioFuji::sio_process() called 19:58:42.044 > ACK! 19:58:42.044 > Fuji cmd: SET DIRECTORY POSITION 19:58:42.046 > ::dir_seek {2:2} 0 19:58:42.107 > COMPLETE! 19:58:42.112 > 19:58:42.113 > CF: 70 f6 24 00 8b 19:58:42.113 > sioFuji::sio_process() called 19:58:42.113 > ACK! 19:58:42.113 > Fuji cmd: READ DIRECTORY ENTRY (max=36) 19:58:42.114 > ::dir_nextfile {2:2} 19:58:42.217 > tnfs_readdirx resp_count=11, dirpos=0, status=1 19:58:42.218 > tnfs_readdirx cached 11 entries 19:58:42.218 > _readdirx_fill_response: dir: Yes, size: 4096, mtime: 2020-07-28 19:29:48, ctime: 2020-12-08 15:58:31 "DOS" 19:58:42.219 > ::read_direntry "DOS" 19:58:42.221 > ->SIO write 36 bytes 19:58:42.221 > COMPLETE! 19:58:42.232 > 19:58:42.233 > CF: 70 f6 24 00 8b 19:58:42.233 > sioFuji::sio_process() called 19:58:42.233 > ACK! 19:58:42.233 > Fuji cmd: READ DIRECTORY ENTRY (max=36) 19:58:42.233 > ::dir_nextfile {2:2} 19:58:42.233 > tnfs_readdirx responding from cached entry 19:58:42.233 > _readdirx_fill_response: dir: Yes, size: 4096, mtime: 2020-11-19 19:42:41, ctime: 2020-12-08 15:58:31 "games" 19:58:42.234 > ::read_direntry "games" 19:58:42.234 > ->SIO write 36 bytes 19:58:42.234 > COMPLETE! 19:58:42.248 > 19:58:42.249 > CF: 70 f6 24 00 8b 19:58:42.249 > sioFuji::sio_process() called 19:58:42.249 > ACK! 19:58:42.249 > Fuji cmd: READ DIRECTORY ENTRY (max=36) 19:58:42.249 > ::dir_nextfile {2:2} 19:58:42.249 > tnfs_readdirx responding from cached entry 19:58:42.250 > _readdirx_fill_response: dir: Yes, size: 4096, mtime: 2020-08-31 20:05:56, ctime: 2020-12-08 15:58:31 "Holmes_CD1" 19:58:42.251 > ::read_direntry "Holmes_CD1" 19:58:42.251 > ->SIO write 36 bytes 19:58:42.253 > COMPLETE! 19:58:42.268 > 19:58:42.292 > CF: 70 f6 24 00 8b 19:58:42.292 > sioFuji::sio_process() called 19:58:42.292 > ACK! 19:58:42.292 > Fuji cmd: READ DIRECTORY ENTRY (max=36) 19:58:42.292 > ::dir_nextfile {2:2} 19:58:42.292 > tnfs_readdirx responding from cached entry 19:58:42.292 > _readdirx_fill_response: dir: Yes, size: 4096, mtime: 2020-12-08 15:57:56, ctime: 2020-12-08 15:58:31 "netgames" 19:58:42.292 > ::read_direntry "netgames" 19:58:42.292 > ->SIO write 36 bytes 19:58:42.292 > COMPLETE! 19:58:42.292 > 19:58:42.292 > CF: 70 f6 24 00 8b 19:58:42.292 > sioFuji::sio_process() called 19:58:42.292 > ACK! 19:58:42.292 > Fuji cmd: READ DIRECTORY ENTRY (max=36) 19:58:42.292 > ::dir_nextfile {2:2} 19:58:42.292 > tnfs_readdirx responding from cached entry 19:58:42.292 > _readdirx_fill_response: dir: Yes, size: 4096, mtime: 2020-12-16 10:48:15, ctime: 2020-12-16 10:48:15 "networking" 19:58:42.292 > ::read_direntry "networking" 19:58:42.292 > ->SIO write 36 bytes 19:58:42.292 > COMPLETE! 19:58:42.306 > 19:58:42.306 > CF: 70 f6 24 00 8b 19:58:42.306 > sioFuji::sio_process() called 19:58:42.306 > ACK! 19:58:42.306 > Fuji cmd: READ DIRECTORY ENTRY (max=36) 19:58:42.308 > ::dir_nextfile {2:2} 19:58:42.308 > tnfs_readdirx responding from cached entry 19:58:42.308 > _readdirx_fill_response: dir: Yes, size: 4096, mtime: 2020-11-24 18:20:51, ctime: 2020-12-08 15:58:31 "printing" 19:58:42.309 > ::read_direntry "printing" 19:58:42.309 > ->SIO write 36 bytes 19:58:42.310 > COMPLETE! 19:58:42.324 > 19:58:42.327 > CF: 70 f6 24 00 8b 19:58:42.327 > sioFuji::sio_process() called 19:58:42.327 > ACK! 19:58:42.327 > Fuji cmd: READ DIRECTORY ENTRY (max=36) 19:58:42.327 > ::dir_nextfile {2:2} 19:58:42.327 > tnfs_readdirx responding from cached entry 19:58:42.327 > _readdirx_fill_response: dir: Yes, size: 4096, mtime: 2020-10-24 19:48:54, ctime: 2020-12-08 15:58:31 "tools" 19:58:42.327 > ::read_direntry "tools" 19:58:42.327 > ->SIO write 36 bytes 19:58:42.327 > COMPLETE! 19:58:42.340 > 19:58:42.341 > CF: 70 f6 24 00 8b 19:58:42.341 > sioFuji::sio_process() called 19:58:42.341 > ACK! 19:58:42.341 > Fuji cmd: READ DIRECTORY ENTRY (max=36) 19:58:42.341 > ::dir_nextfile {2:2} 19:58:42.341 > tnfs_readdirx responding from cached entry 19:58:42.341 > _readdirx_fill_response: dir: no, size: 92176, mtime: 2020-10-21 16:12:45, ctime: 2020-12-08 15:58:31 "config.atr" 19:58:42.343 > ::read_direntry "config.atr" 19:58:42.343 > ->SIO write 36 bytes 19:58:42.344 > COMPLETE! 19:58:42.358 > 19:58:42.359 > CF: 70 f6 24 00 8b 19:58:42.359 > sioFuji::sio_process() called 19:58:42.359 > ACK! 19:58:42.359 > Fuji cmd: READ DIRECTORY ENTRY (max=36) 19:58:42.359 > ::dir_nextfile {2:2} 19:58:42.359 > tnfs_readdirx responding from cached entry 19:58:42.360 > _readdirx_fill_response: dir: no, size: 92176, mtime: 2020-11-13 20:43:44, ctime: 2020-12-08 15:58:31 "fnc-tools.atr" 19:58:42.361 > ::read_direntry "fnc-tools.atr" 19:58:42.361 > ->SIO write 36 bytes 19:58:42.363 > COMPLETE! 19:58:42.380 > 19:58:42.402 > CF: 70 f6 24 00 8b 19:58:42.402 > sioFuji::sio_process() called 19:58:42.402 > ACK! 19:58:42.402 > Fuji cmd: READ DIRECTORY ENTRY (max=36) 19:58:42.402 > ::dir_nextfile {2:2} 19:58:42.402 > tnfs_readdirx responding from cached entry 19:58:42.402 > _readdirx_fill_response: dir: no, size: 42535, mtime: 2020-07-28 19:31:28, ctime: 2020-12-08 15:58:31 "index.php" 19:58:42.402 > ::read_direntry "index.php" 19:58:42.402 > ->SIO write 36 bytes 19:58:42.402 > COMPLETE! 19:58:42.402 > 19:58:42.402 > CF: 70 f6 24 00 8b 19:58:42.402 > sioFuji::sio_process() called 19:58:42.402 > ACK! 19:58:42.402 > Fuji cmd: READ DIRECTORY ENTRY (max=36) 19:58:42.402 > ::dir_nextfile {2:2} 19:58:42.402 > tnfs_readdirx responding from cached entry 19:58:42.402 > _readdirx_fill_response: dir: no, size: 133136, mtime: 2020-09-25 17:30:00, ctime: 2020-12-08 15:58:31 "SAM-Test.atr" 19:58:42.402 > ::read_direntry "SAM-Test.atr" 19:58:42.402 > ->SIO write 36 bytes 19:58:42.503 > COMPLETE! 19:58:42.503 > 19:58:42.503 > CF: 70 f6 24 00 8b 19:58:42.503 > sioFuji::sio_process() called 19:58:42.503 > ACK! 19:58:42.503 > Fuji cmd: READ DIRECTORY ENTRY (max=36) 19:58:42.503 > ::dir_nextfile {2:2} 19:58:42.503 > tnfs_readdirx returning EOF based on cached value 19:58:42.503 > Reached end of of directory 19:58:42.503 > ->SIO write 36 bytes 19:58:42.503 > COMPLETE! 19:58:42.503 > 19:58:42.503 > CF: 70 f5 02 00 68 19:58:42.503 > sioFuji::sio_process() called 19:58:42.503 > ACK! 19:58:42.503 > Fuji cmd: CLOSE DIRECTORY 19:58:42.503 > COMPLETE! -Thom Quote Link to comment Share on other sites More sharing options...
mozzwald Posted December 21, 2020 Share Posted December 21, 2020 14 minutes ago, FifthPlayer said: [17:50:12] I've restarted the fujinet.online tnfs server if you wanna try it again just in case it's an issue there. Quote Link to comment Share on other sites More sharing options...
MrFSL Posted December 21, 2020 Share Posted December 21, 2020 I have found a continuous ping to the fujinet is a helpful tool. I sit right next to my wifi router (less than 10 feet away too) and didn't realize I was having wifi issues. I should start a thread asking folks to report their latency on pings. It would be good to know what "normal" looks like. For me with the device getting external power and away from any interference I still see latency averaging around 300ms which is pretty awful. All other devices on the network average 6. Since I discovered a device creating noise and interfering my fujinet now works pretty darn well. It was seeing ping drops and latency at 1200 ms that helped me understand what was going on. Quote Link to comment Share on other sites More sharing options...
FifthPlayer Posted December 21, 2020 Share Posted December 21, 2020 1 hour ago, mozzwald said: I've restarted the fujinet.online tnfs server if you wanna try it again just in case it's an issue there. Thank you, the situation has improved (browsing is working ok) but I still get the occasional glitch when trying to boot off a disk image. I have also noticed throughput when booting off a network image is significant slower than booting the inbuilt config app, and the data seems to come in chunks with a pause in between each. I would have expected SIO to be the bottleneck (plain old SIO, no high-speed mods) so maybe I do have wifi issues such as interference. I'll experiment some more and see what I can discover. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 21, 2020 Author Share Posted December 21, 2020 I have added a note to the Quick Start Guide: https://github.com/FujiNetWIFI/fujinet-platformio/wiki/FujiNet-Quickstart-Guide If you need to persist disk slots between cold starts, please power your #FujiNet externally. -Thom Quote Link to comment Share on other sites More sharing options...
FifthPlayer Posted December 22, 2020 Share Posted December 22, 2020 (edited) 23 hours ago, MrFSL said: I have found a continuous ping to the fujinet is a helpful tool. I sit right next to my wifi router (less than 10 feet away too) and didn't realize I was having wifi issues. I should start a thread asking folks to report their latency on pings. It would be good to know what "normal" looks like. For me with the device getting external power and away from any interference I still see latency averaging around 300ms which is pretty awful. All other devices on the network average 6. Since I discovered a device creating noise and interfering my fujinet now works pretty darn well. It was seeing ping drops and latency at 1200 ms that helped me understand what was going on. I've connected my Fujinet to an external USB power supply and I've also disconnected the wireless keyboard dongle from my RPi that I know from experience can cause interference issues with other equipment. So far, accessing remote sites is working well, knock on wood. Thank you for the continuous ping suggestion. Here are some ping statistics I'm getting for my Fujinet. It seems like 300ms latency might be close to "normal": Ping statistics for 192.168.1.33: Packets: Sent = 146, Received = 146, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 27ms, Maximum = 453ms, Average = 229ms Edited December 22, 2020 by FifthPlayer cut/paste again 1 Quote Link to comment Share on other sites More sharing options...
